Home » Archived » BIRT » Error evaluating scripts
Error evaluating scripts [message #243597] Wed, 20 June 2007 11:30 Go to next message
Originally posted by: zia.zia.com
Hi guys,
I am encountering this errors:
The following items have errors:
Row (id = 838):
- There are errors evaluating script "if (row["BEN_CHG1"] == "") { true; }
else {false;}".
Error.ScriptEvaluationError ( 2 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "if (row["BEN_CHG1"] == "") { true; } else
{false;}". at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:557)
1.) Is it about my scripting?
2.) I am trying to hide a table row that has 2 rows inside.
3.) I tried using the same script in a small table its seems to be ok.
Please explain to me the meaning of the error.
Any suggestions on how to solve this problem would be most welcome.
Zia
Re: Error evaluating scripts [message #243615 is a reply to message #243597] Wed, 20 June 2007 12:38 Go to previous messageGo to next message
Originally posted by: a.x.com
Can you try changing it to
if (row["BEN_CHG1"]) { true; } else {false;}
Zia wrote:
> Hi guys,
> Row (id = 838):
> else {false;}".
> {false;}". at
> Zia
Re: Error evaluating scripts [message #243634 is a reply to message #243615] Wed, 20 June 2007 13:20 Go to previous messageGo to next message
Hi Ali Khan,
I tried to change the script but the error is still the same.
I just wanted to check if the FieldName is blank, then the visibility of
the row table is true.
Thank you very much for your help, greatly appreciated.
Zia
Zia wrote:
Hi guys,
Row (id = 838): - There are errors evaluating script "if (row["BEN_CHG1"]
== "") { true; } else {false;}". Error.ScriptEvaluationError ( 2 time(s) )
{false;}". at
Zia
Re: Error evaluating scripts [message #243689 is a reply to message #243634] Wed, 20 June 2007 16:44 Go to previous messageGo to next message
Zia,
Are the values null or blank?
Can you hit the + sign at the bottom of the preview and post the whole log?
Jason
Zia wrote:
> Hi Ali Khan,
> Zia
> Zia wrote:
> Hi guys,
> (row["BEN_CHG1"] == "") { true; } else {false;}".
> {false;}". at
> Zia
Re: Error evaluating scripts [message #243898 is a reply to message #243689] Thu, 21 June 2007 10:00 Go to previous messageGo to next message
Originally posted by: popscie.yahoo.com
Hi Jason,
The values are blank.
If the [Field] value is blank then the row visibility is equal to
true.(The whole row is hidden.)
When I hit the + sign the log says...
Row (id = 582):
(row["CHARGES_INTS_1_CLA"]==""){true;} else{false;}".
errors evaluating script "if (row["CHARGES_INTS_1_CLA"]==""){true;}
else{false;}". at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:529)
org.eclipse.birt.report.engine.executor.ReportItemExecutor.e valuate(ReportItemExecutor.java:221)
org.eclipse.birt.report.engine.executor.ReportItemExecutor.p rocessVisibility(ReportItemExecutor.java:383)
org.eclipse.birt.report.engine.executor.RowExecutor.execute( RowExecutor.java:69)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:63)
org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l ayoutChildren(HTMLTableBandLM.java:67)
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:159)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:68)
org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:74)
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:94)
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutChildren(HTMLInlineStackingLM.java:138)
org.eclipse.birt.report.engine.layout.html.HTMLRowLM.layout( HTMLRowLM.java:30)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:139)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:85)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:205)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:142)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source) at
Source) at
org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(Unknown
Source) at
org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Un known Source)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGe t(Unknown
Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740) at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Unknown Source)Caused by:
org.mozilla.javascript.EvaluatorException:
org.eclipse.birt.data.engine.core.DataException: Invalid bound column
org.eclipse.birt.report.engine.data.dte.NativeRowObject.get( NativeRowObject.java:93)
org.mozilla.javascript.ScriptableObject.getProperty(Scriptab leObject.java:1263)
org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1301)
org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1283)
at org.mozilla.javascript.gen.c43._c0(<inline>:1) at
org.mozilla.javascript.gen.c43.call(<inline>) at
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c43.call(<inline>) at
org.mozilla.javascript.gen.c43.exec(<inline>) at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:223) at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:550)
... 68 more
Kindly guide me on this matter.
Thank you and best regards,
Zia
Re: Error evaluating scripts [message #243927 is a reply to message #243898] Thu, 21 June 2007 10:48 Go to previous message
Zia,
There error is that the column CHARGES_INTS_1_CLA does not exist in the
bound columns for the table. Select the table, then select properties,
and finally bindings. This column should be listed.
Jason
Zia wrote:
> Hi Jason,
> Row (id = 582):
> else{false;}". at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 68 more
> Zia
Previous Topic:Problems getting BIRT 2.2 to run in eclipse 3.2
Next Topic:Using a Javascript function of a Library and display the result in a report
Current Time: Thu Oct 23 10:38:49 EDT 2025
Powered by FUDForum. Page generated in 0.05264 seconds
