Home » Eclipse Projects » GEF » Zesty Mindmaps
Zesty Mindmaps [message #243580] Fri, 13 June 2008 16:14 Go to next message
AntóinÃ?g is currently offline AntóinÃ?gFriend
I am investigating using Zest to implement a Mind Map like representation
of a business model. Does it have collapse/expand functionality when
nodes are double-clicked. All the snippets I've looked at don't display
this functionality.
Thanks in advance,
Anthony
Re: Zesty Mindmaps [message #243591 is a reply to message #243580] Fri, 13 June 2008 18:08 Go to previous message
Stefan Tucker is currently offline Stefan TuckerFriend
Take a look at the Zoom and Nested Graphs snippet:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gef/tes t/org.eclipse.zest.tests/src/org/eclipse/zest/tests/swt/Zoom Snippet.java?root=Tools_Project
Zest provides GraphContainer, which you can nest nodes in, but it's a
bit limited. You can't easily override the container to implement your
own meaning for open/close. The default size is a hardcoded 250x30,
which is rather large. I haven't been able to get scaling to do
anything, despite some samples showing how it should work.
In order to implement double-clicking, I think you'll have to dig into
the GraphContainer's figure to get the Clickable object and add a mouse
listener to it.
Previous Topic:Strange NoClassDefFoundError
Next Topic:Overriding handleCreateConnection in ConnectionCreationTool
Current Time: Tue Nov 12 19:51:45 GMT 2024
Powered by FUDForum. Page generated in 0.02803 seconds
