Home » Archived » BIRT » Change chart size dynamically
Change chart size dynamically [message #243236] |
Tue, 19 June 2007 09:00 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: MCIPRIA1.it.ibm.com
This is a multipart message in MIME format.
--=_alternative 0031789BC12572FF_=
Content-Type: text/plain; charset="US-ASCII"
I'm working with Birt 2.1.2. I have a report in which I display a chart
multiple times (it is inside a table group in a table). Each time, the
chart inherit the dataset from the table, and displays its entries. The
chart is a flipped bar chart. Is there a way to change dynamically the
chart size in order to show different dataset sizes?
For example, I have a data set with 2 columns NAME, VALUE, and a table
grouped by NAME. Consider this case (VALUEs aren't important):
NAME VALUE
a 1
a 12
a 41
a 541
a 61
a 231
a 41
a 541
a 1
a 31
a 1
a 12
a 11
b 25
In this case, my report will display 2 charts, one for "a" with 13 bars,
and one for "b" with 1 bar. Is there a way to resize the chart in order to
have small charts for small amounts of bars and higher charts for higher
number of bars? In my case, the bar number varies from 1 to 200 ca.
Choosing a static size that allow 200 bars to be displayed clearly, will
result in awful enormous charts in the case of only one bar.
Any suggestions?
Thanks!
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi,</font>
<br><font size=2 face="sans-serif">I'm working with Birt 2.1.2. I have
a report in which I display a chart multiple times (it is inside a table
group in a table). Each time, the chart inherit the dataset from the table,
and displays its entries. The chart is a flipped bar chart. Is there a
way to change dynamically the chart size in order to show different dataset
sizes?</font>
<br>
<br><font size=2 face="sans-serif">For example, I have a data set with
2 columns NAME, VALUE, and a table grouped by NAME. Consider this case
(VALUEs aren't important):</font>
<br>
<br><font size=2 face="sans-serif">NAME VALUE</font>
<br><font size=2 face="sans-serif">a 1</font>
<br><font size=2 face="sans-serif">a 12</font>
<br><font size=2 face="sans-serif">a 41</font>
<br><font size=2 face="sans-serif">a 541</font>
<br><font size=2 face="sans-serif">a 61</font>
<br><font size=2 face="sans-serif">a 231</font>
<br><font size=2 face="sans-serif">a 31</font>
<br><font size=2 face="sans-serif">a 11</font>
<br><font size=2 face="sans-serif">b 25</font>
<br>
<br><font size=2 face="sans-serif">In this case, my report will display
2 charts, one for "a" with 13 bars, and one for "b"
with 1 bar. Is there a way to resize the chart in order to have small charts
for small amounts of bars and higher charts for higher number of bars?
In my case, the bar number varies from 1 to 200 ca. Choosing a static
size that allow 200 bars to be displayed clearly, will result in awful
enormous charts in the case of only one bar.</font>
<br><font size=2 face="sans-serif">Any suggestions?</font>
<br><font size=2 face="sans-serif">Thanks!</font>
--=_alternative 0031789BC12572FF_=--
Re: Change chart size dynamically [message #244004 is a reply to message #243236] |
Thu, 21 June 2007 15:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David Michonneau![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dmichonneau%40actuate.com) Messages: 1145 Registered: July 2009 |
------=_NextPart_000_0090_01C7B42C.AA1EBB90
charset="iso-8859-1"
Can you please file an enhancement request in bugzilla. We will provide =
a way to do this, I am not sure this is currently supported by =
scripting. If it is, we will post an example there.
David
<MCIPRIA1@it.ibm.com> wrote in message =
news:f585v2$4k4$1@build.eclipse.org...
Hi,=20
I'm working with Birt 2.1.2. I have a report in which I display a =
chart multiple times (it is inside a table group in a table). Each time, =
the chart inherit the dataset from the table, and displays its entries. =
The chart is a flipped bar chart. Is there a way to change dynamically =
the chart size in order to show different dataset sizes?=20
For example, I have a data set with 2 columns NAME, VALUE, and a table =
grouped by NAME. Consider this case (VALUEs aren't important):=20
NAME VALUE=20
a 1=20
a 12=20
a 41=20
a 541=20
a 61=20
a 231=20
a 41=20
a 541=20
a 1=20
a 31=20
a 1=20
a 12=20
a 11=20
b 25=20
In this case, my report will display 2 charts, one for "a" with 13 =
bars, and one for "b" with 1 bar. Is there a way to resize the chart in =
order to have small charts for small amounts of bars and higher charts =
for higher number of bars? In my case, the bar number varies from 1 to =
200 ca. Choosing a static size that allow 200 bars to be displayed =
clearly, will result in awful enormous charts in the case of only one =
bar.=20
Any suggestions?=20
Thanks!
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16481" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Can you please file an enhancement =
request in=20
bugzilla. We will provide a way to do this, I am not sure this is =
currently=20
supported by scripting. If it is, we will post an example =
there.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>David</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
<DIV><<A =
href=3D"mailto:MCIPRIA1@it.ibm.com">MCIPRIA1@it.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f585v2$4k4$1@build.eclipse.org">news:f585v2$4k4$1@build.ecli=
pse.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi,</FONT> <BR><FONT face=3Dsans-serif =
size=3D2>I'm working=20
with Birt 2.1.2. I have a report in which I display a chart multiple =
times (it=20
is inside a table group in a table). Each time, the chart inherit the =
dataset=20
from the table, and displays its entries. The chart is a flipped bar =
chart. Is=20
there a way to change dynamically the chart size in order to show =
different=20
dataset sizes?</FONT> <BR><BR><FONT face=3Dsans-serif size=3D2>For =
example, I have=20
a data set with 2 columns NAME, VALUE, and a table grouped by NAME. =
Consider=20
this case (VALUEs aren't important):</FONT> <BR><BR><FONT =
face=3Dsans-serif=20
size=3D2>NAME VALUE</FONT> <BR><FONT =
size=3D2>a 1</FONT> <BR><FONT =
size=3D2>a 12</FONT> <BR><FONT =
size=3D2>a 41</FONT> <BR><FONT =
size=3D2>a 541</FONT> <BR><FONT =
size=3D2>a 61</FONT> <BR><FONT =
size=3D2>a 231</FONT> <BR><FONT =
size=3D2>a 31</FONT> <BR><FONT =
size=3D2>a 11</FONT> <BR><FONT =
size=3D2>b 25</FONT> <BR><BR><FONT =
size=3D2>In this case, my report will display 2 charts, one for "a" =
with 13=20
bars, and one for "b" with 1 bar. Is there a way to resize the chart =
in order=20
to have small charts for small amounts of bars and higher charts for =
higher=20
number of bars? In my case, the bar number varies from 1 to 200 ca.=20
clearly, will=20
result in awful enormous charts in the case of only one bar.</FONT> =
<BR><FONT=20
face=3Dsans-serif size=3D2>Any suggestions?</FONT> <BR><FONT =
size=3D2>Thanks!</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0090_01C7B42C.AA1EBB90--
Re: Change chart size dynamically [message #244208 is a reply to message #244004] |
Fri, 22 June 2007 08:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
--=_alternative 00308729C1257302_=
Submitted enhancement request 193914
<br><font size=2 face="sans-serif">Submitted enhancement request
193914</font>
--=_alternative 00308729C1257302_=--
Current Time: Tue Jul 16 05:04:46 GMT 2024
Powered by FUDForum. Page generated in 0.03658 seconds
