Re: ".pdf" extension is missing when exporting report to PDF [message #243176 is a reply to message #243130] |
Mon, 18 June 2007 19:17 |
Ali,
I just tried this with RC2 and it worked fine.
I used
WebViewer.display(reportName, WebViewer.HTML, browser, "frameset");
And then did the export to pdf.
Jason
Ali Naddaf wrote:
> Hello all.
> I am using Birt 2.2 (came along with Eclipse 3.3 M7) in my RCP app and
> am using WebViewer with frameset servlet. When I try to export (or
> print) to PDF, it doesn't add the ".pdf" extension automatically; the
> content is correct. Is there a setting for that?
> Many thanks
> Ali.
Re: ".pdf" extension is missing when exporting report to PDF [message #243341 is a reply to message #243207] |
Tue, 19 June 2007 15:51 |
Ali,
Can you try this with the allinone/runtime download from the BIRT site?
Jason
Ali Naddaf wrote:
> Thanks Jason. Do you have any suggestion on how I can debug it here in
> my environment?
> Ali.
> Jason Weathersby wrote:
>> Ali,
>> I used
>> Jason
>> Ali Naddaf wrote:
>>> Hello all.
>>> and am using WebViewer with frameset servlet. When I try to export
>>> (or print) to PDF, it doesn't add the ".pdf" extension automatically;
>>> the content is correct. Is there a setting for that?
>>> Many thanks
>>> Ali.
FUDForum. Page generated in 0.03457 seconds
