Re: Problem with Tooltips display on SVG Charts [message #243978 is a reply to message #243889] |
Thu, 21 June 2007 15:41 |
David Michonneau Messages: 1145 Registered: July 2009 |
Henry,
I have set this bug as P1. I am not sure if we can fix it for 2.2 as the
final release is in one week, but it looks like a serious issue. I believe
we can fix it for 2.1.3 though.
David
"Henry Wilson" <hfwilson@uk.ibm.com> wrote in message
news:f5dtg6$huf$1@build.eclipse.org...
>I have filed a bugzilla report (#193708). Incidentally the problem seems to
>be to do with Triggers as a whole rather than just tooltips, I tried using
>triggers both for tooltip display and for Script invocation and both result
>in all triggers performing the action relating to the last plot on the
>chart. Any idea if/when this will be fixed? The chart engine is essentially
>useless to me until such time as this is sorted out :-(
> "David Michonneau" <dmichonneau@actuate.com> wrote in message
> news:f5dq3s$a44$1@build.eclipse.org...
>> It's not a known bug, can you please file one in bugzilla?
>> Thanks,
>> David
>> news:f5aue4$94s$1@build.eclipse.org...
>>> Just recompiled with 2.1.3, then with 2.2 RC3 (RC4 doesn't seem to be
>>> available). I still get the same problem with both of the newer
>>> versions. Is this a known bug?
>>> news:f58lfq$qgq$1@build.eclipse.org...
>>>>I believe this should be fixed. Can you try with the lastet 2.1.3
>>>>release or 2.2 RC4?
>>>> Thanks,
>>>> David
>>>> news:f567r9$7j5$1@build.eclipse.org...
>>>>> I've got a piece of code to generate bar charts in SVG format. The
>>>>> code adds a tooltip to each bar in the chart to display the bars value
>>>>> when the mouse is hovered over it. However, when I actually run it,
>>>>> the tooltip for each bar is the same - they all display the value of
>>>>> the last bar on the chart.
>>>>> I've verified that the data present in the list of triggers (obtained
>>>>> with BarSeries.getTriggers() ) is correct, yet it won't display
>>>>> correctly. Any ideas?
FUDForum. Page generated in 0.03658 seconds
