OSGI servlet hacks [message #1386686] |
Thu, 19 June 2014 13:11 |
Igor Masternoy Messages: 1 Registered: June 2014 |
Junior Member |
I have an OSGi app with servlets and this up can be setted up and launched on different machines with different size of memory and computing power. So I want to read some optimization servlet params NOT FROM PLUGIN.XML (because to change it server-admin will need repackage jar), but from property files.
Now I've impl this in dirty way:
1. I receive ServletConfig inside serlvet init method
2. Use reflection to get _initParams from the ServletHolder
Also I'd like to mention that there is possibility to set parameters for servlet context, but I need to set exactly servletParameters (_initParams).
How can I do this without reflection (it can be disabled on JVM lvl)? Does eclipse jetty has extension points to customize this?
FUDForum. Page generated in 0.02564 seconds
