Re: Select Required Projects in Find Updates [message #243150 is a reply to message #243104] |
Fri, 14 December 2007 18:31 |
VK wrote:
> When I click the Select Required Projects field in the Find Updates
> menu, it does nothing when the required project is in an update site
> that wasn't initially selected in the list of update sites to search for
> new features - is this expected behavior?
Yes, I think so. If Eclipse were to try to search all "known" update
sites it would be very slow, and there could be conflicts when multiple
sites declare the same plugins.
> Even when I do include the necessary update site in the list, Select
> Required Projects does nothing unless you first maximize the menu for
> that update site. It seems that Eclipse doesn't search update sites
> selected that aren't first maximized - this certainly isn't expected
> behavior, is it?
That does sound like a bug; it is at least surprising. I can't try to
reproduce it, though, because my current Eclipse installation has almost
all of the "core" Europa features installed already ;-)
You are welcome to enter a bug report about it - that way someone will
be "forced" to confirm, explain, or deny its behavior.
Hope this helps,
Eric
FUDForum. Page generated in 0.05275 seconds
