Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243190 is a reply to message #243091] |
Mon, 18 June 2007 22:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris,
Can you post the stacktrace? Also have you tried this with RC2 or 3?
Please log a bugzilla entry as well.
BTW, I would be interested in understanding where you found pain points
in using BIRT. We are beginning post 2.2 planning and anything we can
do to make the BIRT experience more pleasant is worth considering.
Jason
chris wrote:
> Hi there,
> i experienced birt during the last three month, there were a lot of
> downs and also a few highlights ;)
> finally my framework works quite allright on a tomcat and also on a sun
> appserver...
> but today after the presentation my boss decided TO CHANGE TO A BEA
> WEBLOGIC PLATFORM!
> i went through the newsgroups and found some known bugs using this
> webserver.. and after a lot of trying a finally got my framework
> deployed without getting any exceptions.
> i figured out, that the following jar
> org.eclipse.equinox.registry_3.3.0.v20070416.jar
> causes the java.lang.StringIndexOutOfBoundsException.
> so now my questions:
> 1. are there any experiences in working with birt2.2rc0 on a weblogic?
> 2. will this bug be fixed in the 2.2 release?
> or:
> is there no light at the end of the tunnel and so i have to persuade my
> boss to use a tomcat?
> greetings,
> chris from munich
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243346 is a reply to message #243284] |
Tue, 19 June 2007 15:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris,
Thanks for the responses. We will look into the bug.
Jason
Chris wrote:
> i forgot to mention the exception of the viewerServlet:
> org.eclipse.birt.report.exception.ViewerException: Fatal error occurred
> when try to startup report engine.
> at
> org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(Unknown
> Source)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(Unknown
> Source)
> at
> org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown Source)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
> Source)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
> at
> weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run(ServletStubImpl.java:971)
> at
> weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:402)
> at
> weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:305)
> at
> weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionAction.run(WebAppServletContext.java:6350)
> at
> weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticatedSubject.java:317)
> at
> weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:118)
> at
> weblogic.servlet.internal.WebAppServletContext.invokeServlet (WebAppServletContext.java:3635)
> at
> weblogic.servlet.internal.ServletRequestImpl.execute(Servlet RequestImpl.java:2585)
> at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:197 )
> at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:170)
> maybe it could be related to this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=136818
FUDForum. Page generated in 0.03741 seconds
