Group On / Expression Builder [message #243077] |
Mon, 18 June 2007 07:53 |
Originally posted by: damian.delcampo.sealink.com.au
Hello all, can somebody please help me with hopefully a simple syntax
question ?
I'm trying to allow users to specify via a pararmeter the grouping on a
report.
If I specify the following in Expression Builder for a column called
Client_Code, the report is grouped by that column accordingly.
row["Client_Code"]
If I try to insert a conditional statement the report returns with no
data. I've reduced the Expression Builder statement down to the
following which I'd believe should give me the same as above.
if (true)
row["Client_Code"]
else if (false)
row["System_User_Code"]
Can somebody please tell me where I'm going wrong ??
Additionally, does anybody know of a reference manual online for
Expression Builder, the BIRT help is fairly skimpy in this area ??
Thanks in advance,
Damian Del Campo
Re: Group On / Expression Builder [message #243202 is a reply to message #243163] |
Tue, 19 June 2007 00:29 |
--------------060705020305040603090507
Thanks for the reply - I do not get an 'error', the report run but
simply returns no details.
I have attached a few screenshots indicating the problem I'm having.
When the GroupOn clause is simply
row["_name_of_colum"]
the group works fine.
However trying to change that to a conditional such as
if x
else
row["_name_of_other_colum"]
seems to kill it.
I'm hoping its just that I don't know the syntax for Expression Builder.
( however I tried the same syntax in a text box and it works fine
giving me the correct output for conditional branches - so I do believe
my issue is to do with the grouping )
Thanks again,
Damian
Ali Khan wrote:
> Can you please post the error you get?
Content-Type: image/jpeg;
name="report_group_section.JPG"
Content-Disposition: inline;
filename="report_group_section.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CADsATEDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3ueeO2t5biZtsUSF3bGcA DJPFUf7csv7t
5/4Azf8AxFO13/kXtT/69Jf/AEA0tNK4DP7csv7t5/4Azf8AxFH9uWX928/8 AZv/AIin0U+U
Qz+3LL+7ef8AgDN/8RTJvEem28TSztcxRr1d7OZQPxK1NWH4w/5Fa9/4B/6G tFhmz/bll/dv
P/AGb/4ij+3LL+7ef+AM3/xFPoo5RDP7csv7t5/4Azf/ABFH9uWX928/8AZv /iKfRRygM/ty
y/u3n/gDN/8AEUyXxHpsOzzWuY97BE32cw3MegHy8n2qasPxL/zCP+wnD/Wi wzZ/tyy/u3n/
AIAzf/EUf25Zf3bz/wAAZv8A4in0Ucohn9uWX928/wDAGb/4ij+3LL+7ef8A gDN/8RT6KOUB
n9uWX928/wDAGb/4ij+3LL+7ef8AgDN/8RT6KOUBn9uWX928/wDAGb/4ij+3 LL+7ef8AgDN/
8RT6KOUBn9uWX928/wDAGb/4imf8JHpvn+RuufO27/L+xzbtucZxtzjPepqw /wDme/8AuGf+
1aLDNn+3LL+7ef8AgDN/8RR/bll/dvP/AABm/wDiKfRRyiGf25Zf3bz/AMAZ v/iKP7csv7t5
/wCAM3/xFPoo5QGf25Zf3bz/AMAZv/iKP7csv7t5/wCAM3/xFPoo5QGf25Zf 3bz/AMAZv/iK
P7csv7t5/wCAM3/xFPoo5QGf25Zf3bz/AMAZv/iKP7csv7t5/wCAM3/xFPoo 5QIV8R6a8skS
NctJHjegs5iVz0yNvGaf/bll/dvP/AGb/wCIrG0v/kade/7d/wD0A1uUWGM/ tyy/u3n/AIAz
f/EUf25Zf3bz/wAAZv8A4in0Ucohn9uWX928/wDAGb/4ij+3LL+7ef8AgDN/ 8RT6KOUBn9uW
X928/wDAGb/4iin0UcoCa7/yL2p/9ekv/oBpaTXf+Re1P/r0l/8AQDWJ/wAI foP/AD4/+Rn/
APiqEM3KK5TUNE8PafNBEdIuJ5JgxVYZGPC4z1cf3hVOaz8PwQvNL4c1FI0G WYvwB/38qZVa
cXyykk/VDUZNXSf3Hb1h+MP+RWvf+Af+hrR/wh+g/wDPj/5Gf/4qqWq+GdHs 7Hz4LMLIs0QB
MjMMGRQeCcHgmrZJ1NFYjaLpQcqNLhYgZOEX+v0o/sXS/wDoExf98L/jS5hm 3RWJ/Yul/wDQ
Ji/74X/Gj+xdL/6BMX/fC/40cwG3WH4l/wCYR/2E4f60v9i6X/0CYv8Avhf8 ab/Y2lMygabA
vz7SDGP7uf8ACi4G7RWGNG0o526VCQCRnYvb8aX+xdL/AOgTF/3wv+NHMBt0 Vif2Lpf/AECY
v++F/wAaP7F0v/oExf8AfC/40cwG3RWJ/Yul/wDQJi/74X/Gj+xdL/6BMX/f C/40cwG3RWJ/
Yul/9AmL/vhf8aP7F0v/AKBMX/fC/wCNHMBt1h/8z3/3DP8A2rS/2Lpf/QJi /wC+F/xpo0fS
fmf+zrfYIw+PLGe9FwN2isT+xdL/AOgTF/3wv+NH9i6X/wBAmL/vhf8AGjmA 26KxP7F0v/oE
xf8AfC/40f2Lpf8A0CYv++F/xo5gNuisT+xdL/6BMX/fC/40f2Lpf/QJi/74 X/GjmA26KxP7
F0v/AKBMX/fC/wCNH9i6X/0CYv8Avhf8aOYDborE/sXS/wDoExf98L/jSNo2 lKpY6TEABk/I
v+NHMAaX/wAjTr3/AG7/APoBrcrD/sXSl8wnTrc4YAARjuB/jS/2Lpf/AECY v++F/wAaLgbd
FYn9i6X/ANAmL/vhf8aP7F0v/oExf98L/jRzAbdFYn9i6X/0CYv++F/xo/sX S/8AoExf98L/
AI0cwG3RXOfYdE/6BkX/AH7FFHMB0Wu/8i9qf/XpL/6AaWk13/kXtT/69Jf/ AEA0tEQMbVwg
1K2d8fJbTFSWxg74h/eXsT3FZt7LHPpl7Gzow+zSkASZ5CEj/ls3cehroLuw +0zxTpczW8ka
sgaLYchipOdyn+6KrzaRJcQSQS6retHIpR12xDIIwf8AlnT9lQk1KcU36a/k Q5VVpFuxp1m6
9/yCT/12h/8ARqVpVm69/wAgk/8AXaH/ANGpQyjlvFt7dP4w8MaDHPPb2epy TG6lt5GjciKM
uqB1wV3E84IPHWsr4gSzeHfCmn6PbeIr23k1HU44BfXV1tkt4SdzHzeDtXAG WJODgk11HifT
brUlgjh0i0v0VhIHmv5LR4XXO1o3RGYHk8grj3zWJb+HtQtZ7CaHwho6y2Ek s0D/ANuTEiSQ
Yd2zB87Ed2yagZxlh4luNUtfh2L/AFHVXhlW/g1BbCe4aSdolAQnyTvc8K2R nqSeM1oyr46T
w7bXUdtql7p0Gp3Lmxa5eC+msjjydzgiTcDvJGdx+XIIroLXw3f2WpQ6hb+E NJS6guJ7qJ/7
enIWSZQspAMOOQBxjA7AVb1bT9c1s27X3hjSmltmLwTRa7NFJESMHa6QBhkd cHmgC34B1Sy1
bw409jeancIlw8bx6m26e3cYzExxk4yMEljzyfTof+W3/bX/ANkrE8N2l/pU bWj6DY2Nod0p
e21B7iSSUkZL741JJ5yxYngfhtgN5ikqV3SZAP8Au0AeP65qGo/8JH8Qtja7 MunwQyWr2eot
FFZMYSxdk81dwyNxAVvunjnnS1j4jalo2iLdWc9lqv2Gzs5rwrbP84lCYdn3 KIixYlU2ucYJ
wOmzq/hKW61nU7qHw9bXC35UXEja/c232lVXAEkSIUIAyMc5H1NVtR8Hz6o0 5u/BejkTxxxS
pHr1xErrH9zKpCBlQMA4yBx0oAzNK8Y+ILGz1c3d1b313ceKzotoXhZI4CcD cQGJ8vA4QHIO
cs2eNHWr3xRB438GWU11aR3Fw+oK627yi3nRYlKM8ZOcjJO3Jwejc5FuTw9q EsN/E3hDR/Lv
7gXVwo1ycAzD/louIPkfgfMuCcUlp4d1CxurG6t/CGkLcWMk0sEp12dmDyjE jMTD87MAOWya
ANzwN4hm8V+DNO1q4hjhmuVfekedoKuyHGecHbn8a4jVpr2fxB8SZxq2pQPo 1pbXFgsV7Ikc
T/Z2c/uw2xgxUZBB6n1rWttO8daJY2+m+GdI8MafpkCkLBc3lxcsGLMzEPtU 4JboQfr2EP8A
wius3k9ze6v4a0e5v7wob1rfXLqCC52cIGh2MpAUAYOR1PegClq/xN1bT9EX UbeGzne2s7O5
vrUQOxj88Jw8m9RGSWOFCucAE4B4gsfG+vaTpeuT31zFf3MnihtItf8ARXKw njLbFYsyYHCL
82c/MxbjZ1Xwnc61NdS33g3SHa6SNJwmvXEayBPuZVYQCR0BxnHHSp38P6hJ FfxN4Q0fy7+4
F1cKNcnAMw/5aLiD5H4HzLgnvQBveEtZ1DWtJlm1OwltLmG5kgy9vJAJ1XG2 VEk+YKwI4PQ5
HatMf8e7/wDXBf5Gsfw1Z3+lRtZvoVlY2hLSl7fUXuZJJWOSXLxqWJ5yxYng D6bQRvLdMfN5
KjHvzQB4p4U1fVDongq/mvNbhmvdU8i41C7vnnt7pN8gEIi8xsMcBQSi4IJz 3rprD4n3rR2O
pXljAdM1O3v57WKFWE0QtckiQkkNuCnoBg+tWtO8JXelGz+yeE9PEdk5ktoZ fEl1LFC5z8yx
vEVB5JzjPJqzZ6DqFhqEt7beDtEWeUODnWZWVQ5y4VDAVXceu0DPegDkPFXj 3XZfBmoQTPHa
XdxpFpq9pc6c0kTRRyXCIY2O4ktz1GAQTxWtN451PU4tMvDbR2sEvia205LR mmiuIUIJJlKu
oJIwQhBXB53dr3/CHTHTbvTz4L0c2t2qJMh164JKI25VDeTlVBGQqkD2qzde HtQvdUOpXHhH
SWuzcw3Zca7OoM0IIjfaIcZAJHTnvmgDD0v4paydL0HU9Ts7B7fU7XUZ2jtl dHQ2qs3BZiPm
C4xj3z2rb8KeMdb1fxPY6bqUOnrBeaCmrq1srhgXkACncxHAP5jOecCFfCl/ b2NhbWfhPSbf
+zo7iOxf+25ZPI88ESHDwEPnJ4cMKoeFfB/ijw3rbaq2k6HLMLIWMaQajNGi xh92TujclsgD
qAAAABQBz1xq+rMuvtDd61Ff/wDCUSWVlqT37/YrZRIuI5I/MxtxuHKY+YDP Ydanj3W7/wAS
Xdlpum77SHU30okWE8piYDH2h5FIj2ByMpkNt5yOtXG0DUW0zU9Nbwho7Wmq XD3N5GdcmPmS
uQWbPkZXlQeMYxximx+HdQj1OPUV8I6SbmN1lBbXZ2UyBdokKmHaz4/jILe9 AD/hLPfaj4Ft
9X1K+mvLu+kldnkkdtoWRlAwzFR0P3AoxgYyMntp/wDj3k/3T/Kuf8LWN9ol jFpS6DZafpkC
sYVttSe5YMW3EHfGpwSzHO4+mPTekZ3idRC+SpHUf40AYnjGeW28FeIri3le KaKzmeOSNirI
wjyCCOQQe9ZTeJ5vD/wdsfEUyveXEWl20h8xyTJI6oMsep+Zsk/Wuk1azGo6 RqVk1ulys6NG
0DymNZAVAKlwCVB6ZAJFcna+HdUtLKSxTwzZSWbwfZjbXHiW6niEfHyhHiKj GBggAjtQBUuv
H+safdXeiXFtYyaxFqllp6XEaOtuftKl1YqWLfKFYEbuTj6VhXfxG1wanunt rIT2N1rMAEUk
4jP2a2V03KJAr5YnO4dPuhTzW3qHhLXJtEbTtO8O6La77lLl5JtWmuDIy9Nz GISccYKupGBg
4yDU0nwBqNnZtHf+GtHvZ3mu5i66xPCi/aUEcqqohOFKAKMkkdQc0AbnhTxj qureILHTNSgs
gt7oMOro9srKULMFKHcTnrntjpz1ruq4zS9H1Gw1eyvE8L6Zbvb2aaas0esz SNHaqwO0K0ID
EYzyQT/err/Mb/ni/wCa/wCNAGNRU/2O4/55/qKKANzXf+Re1P8A69Jf/QDW J/wh+g/8+P8A
5Gf/AOKrb13/AJF7U/8Ar0l/9ANLVIDD/wCEP0H/AJ8f/Iz/APxVH/CH6D/z 4/8AkZ//AIqt
yinYRh/8IfoP/Pj/AORn/wDiqqal4b0mwtFuba08uZJodreY5xmRQeCcdDXT 1m69/wAgk/8A
XaH/ANGpQ0BotDH5xjjs7dsKGJbA659j6UfZv+nK1/76/wDsa4LxhBDc/Gb4 fJPEkqAXrhXU
MAyxblPPcMAQexANV/h7a6Ne6Fp2u+IGgi8US6jcJLPJcGKc3AkdfIyGBYBA o8rlcdqgZ6L9
m/6crX/vr/7Gj7N/05Wv/fX/ANjXzh4U8Vaj4Z8NwXWn29tJLb+Fppoy1shc M2pumS+N5VQx
bbnbkZx3rtrnxf4vtXs7BtQ8syeILCzS5m+xyzvDPG5dZY4WZU5UFTwSpHPW gD1n7N/05Wv/
AH1/9jTPKiaWNWtoUKy7SFAIPyE+g9a8c03Wtc1n4oaBa32t3bx2WuatYqES JBIkESspZQmC
zBypPYfd2klj7N/y9f8Abx/7SoAm+yW3/PvF/wB8Cj7Jbf8APvF/3wKmooAh +yW3/PvF/wB8
Cj7Jbf8APvF/3wKmooAh+yW3/PvF/wB8Cj7Jbf8APvF/3wKmooAh+yW3/PvF /wB8Cj7Jbf8A
PvF/3wKmooAh+yW3/PvF/wB8Coltbf7XIvkRYCKQNg9Wq3UK/wDH5L/1zT+b UAH2S2/594v+
+BR9ktv+feL/AL4FTUUAQ/ZLb/n3i/74FH2S2/594v8AvgVNRQBD9ktv+feL /vgUfZLb/n3i
/wC+BU1FAEP2S2/594v++BR9ktv+feL/AL4FTUUAQ/ZLb/n3i/74FH2S2/59 4v8AvgVNRQBU
itbcyTgwREBwB8g4+Val+yW3/PvF/wB8CiH/AFtx/wBdB/6CtTUAQ/ZLb/n3 i/74FH2S2/59
4v8AvgVNRQBD9ktv+feL/vgUfZLb/n3i/wC+BU1FAEP2S2/594v++BRU1FAF PXf+Re1P/r0l
/wDQDS0mu/8AIvan/wBekv8A6AaWqiBiXGvvD4q/sYWisi2JvpJzLghQxXaF 28nOO46n05tf
2zb/AN1v++0/+Krldek8nxzqcnnSwbPC8rebEMumJT8y8jkdRyPqKwv7V/6i zf8Agx/++NaV
cLVqWdKfLp2v+phHExg2pxvr3seom7gW2juJZUijkKBTIwXlyAo+pJAA7kgV U17/AJBJ/wCu
0P8A6NSse509ta8G6C0SG9min067SW4CiTCSxM8nJOG8vfnBJ5Iyc87Gvf8A IJP/AF2h/wDR
qVFmtGbJp6oy/FHhK+13xZomtabrKadd6MHZPMtPPWUSfKykb1wNqkcc/NwQ Rmq9/YXOiXv9
t6jrPgywunOz7fcaKYnY4xjzGugTx2zXZr/x+S/9c0/m1cJr08OlfFnT9V1y WKDRP7Fmt7ee
4OIo7kyguCTwrNGMD+9ggZqBl2x8L6jBFHLp8/hGONrcwo9v4eYAwsd5QEXP 3CSWx0JOahuN
AuNF0tXub7wZYafazrcq0mgmKKGbOFkGbkBXyQA3XmuW8X6wLaSBdKubrR9A /sGe50gWaPZi
a/D/ACR7AFJyMEIRhtxODXNfELVNYu9C8SW/iO7urW5XTdLe0slJWKUsym4J XGDtk4z1GAM9
iAesDwrq4cOJvCocXJvA3/CPPkTnrL/x8/fP97r710EAmVoluJEknEoEjxoU Vm8rkhSSQM9s
nHqa8rttY8SS/EqaCbU1trhNdMKWUtzOfOsNvG22SNkwV+bziwwRg4r1j/l6 /wC3j/2lQBco
oooAKKKKACiiigAooooAKhX/AI/Jf+uafzapqhX/AI/Jf+uafzagCaiiigAo oooAKKKKACii
igAooooAhh/1tx/10H/oK1NUMP8Arbj/AK6D/wBBWpqACiiigAooooAKKKKA Keu/8i9qf/Xp
L/6AaWk13/kXtT/69Jf/AEA0tVECu9hZyX0d89pA13Gu1J2jBkUc8BuoHJ/M 1YooqritYKzd
e/5BJ/67Q/8Ao1K0qzde/wCQSf8ArtD/AOjUpMDD8dW+mXOq6VBqPiXX9Ee4 kW1tjpUskazy
u2FSRlRgDx8u4j+L0OL2m+DLzSrdoLfxr4mdGcuTdS29w2cAcNJCxA46Zx19 TWL8UP8Aj88H
/wDYzad/OWvRagZgf8I9qf8A0OWuf9+bL/5Ho/4R7U/+hy1z/vzZf/I9b9FA GB/wj2p/9Dlr
n/fmy/8Aker8EbQtFE8zzukoVpZAoZyIvvHaAMnrwAPQCtCqf/L1/wBvH/tK gC5RRRQAUUUU
AFFFFABRRRQAVCv/AB+S/wDXNP5tU1Qr/wAfkv8A1zT+bUATUUUUAFFFFABR RRQAUUUUAFFF
FAEMP+tuP+ug/wDQVqaoYf8AW3H/AF0H/oK1NQAUUUUAFFFFABRRRQBT13/k XtT/AOvSX/0A
1if8JL/1BNZ/8Bf/AK9beu/8i9qf/XpL/wCgGlqkBh/8JL/1BNZ/8Bf/AK9H /CS/9QTWf/AX
/wCvW5RTEYf/AAkv/UE1n/wF/wDr1U1LW/tlosH9l6nBumh/eT2+1BiRTyc+ 1dPWbr3/ACCT
/wBdof8A0alDAr+IfB+k+KL2xvNU0+8e4sSWtpIbkxNExIO4FHBzlRz2xxWt BbzW1vFAhvik
aBFMkiOxAGOWYksfckk96h1XUo7HU7G3khu53vp0tolt3C7WKyuztll+ULGx OMnjgE1W8Paz
/wAJDbwXaaNq9nZ3FutxDc3VxFtkVgCoASZmBIOeQOhzg8VAzT23Hpdf+QqN tx6XX/kKoLPU
9D1CzN5ZavbXNqJVgM0N9vQSMQFTcGxuJZQB1O4etEOp6HcT28EGr20s1zny I0vtzS4RZDtA
b5vkdW4/hYHoRQBPtuPS6/8AIVMIkjkiJhnZmlLEsUyTsI7H0FSWMun6nZx3 lhei7tZM7JoL
oyI2CQcMGwcEEfhQo23CpuYhbjA3MTj91nv9aAJfMl/59ZfzT/4qjzJf+fWX 80/+KqtJc2Nq
sb316tubi5MEPm3Jj8yQsQqLkjLHHAHJxVfTdb8O6zcNb6XrtnfTqhdo7XUB KwXIGSFYnGSB
n3FAGj5kv/PrL+af/FUeZL/z6y/mn/xVJOlra28txcTtDBEheSSS4ZVRQMkk k4AA5zUn2WP+
9N/3+f8AxoAZ5kv/AD6y/mn/AMVR5kv/AD6y/mn/AMVSQJa3VvFcW87TQSoH jkjuGZXUjIII
OCCOc1HfS6fplnJeX96LS1jxvmnujGi5IAyxbAySB+NAEvmS/wDPrL+af/FU eZL/AM+sv5p/
8VVbTbzSdZt2uNL1KK+gVyjSWt4ZVDYBwSrEZwQce4qxMlrbIHnnaJC6oGe4 ZQWZgqjk9SxA
A7kgUAL5kv8Az6y/mn/xVRLJJ9rkP2aXPlrxlfVverH2WP8AvTf9/n/xqmrt 9llfcd/2NDuz
znDc0AWfMl/59ZfzT/4qjzJf+fWX80/+KrCtPEumXN1JFKl7aRp9tP2i5nCx lLWVIpXyJDhd
z8bgOFYkAYzqQ3mk3LlINSilcXDWpVLwsRMqlmj4b74UEleoAJoAs+ZL/wA+ sv5p/wDFUeZL
/wA+sv5p/wDFVSm1PQ7eW2im1e2jkupWgt0e+wZZFbYyKC3zMG+Ugcg8daJd Q0y1iv5r28Fp
b2MqxTTz3oVFLKjDJ3/L/rFGGwfbBUkAu+ZL/wA+sv5p/wDFUeZL/wA+sv5p /wDFVWvLzSdP
uLW3vdSitp7t9ltHNeFGmbIGEBbLHLAYHqPWrn2WP+9N/wB/n/xoAZ5kv/Pr L+af/FUeZL/z
6y/mn/xVYS+J9HfR9a1FWvSuj/aDdQF2EmIWdSygthlYxPtbOCQRkFWA2Gl0 9PM3XoXypUgk
zdEbJH27UPzcMd6YHU7l9RQBL5kv/PrL+af/ABVHmS/8+sv5p/8AFVSOp6Gs s0R1e2EkMTzy
ob7mONGKO7DdwqsrKSeAQQeRU5+zzaabu0uGlieHzYpY7hmVgRkMCDgg8HNA CwySebP/AKNK
f3g7rx8q+9S+ZL/z6y/mn/xVRyZxcAEjM8YJBwcHYOtc9Z+KodSs7OfTtD1u 7kubSO9MCTxK
8MMhYRMxeYL8+xiApYjHzBSQCAdL5kv/AD6y/mn/AMVR5kv/AD6y/mn/AMVV Ky1LR9Q06K/t
tRD2svlBXNwy4MoQxqQSCrMJEwpwTvXjkVT1DxL4d07S9Xv21WKdNJQm8jgv QzxsMgIRv4dm
BUA4yeKANnzJf+fWX80/+Ko8yX/n1l/NP/iqpJqehyXlrZx6vbPdXcQntoVv svNGQSHRd2WX
AJyOODWh9lj/AL03/f5/8aAGeZL/AM+sv5p/8VRXN/bLr/n5m/77NFAG7rv/ ACL2p/8AXpL/
AOgGlpNd/wCRe1P/AK9Jf/QDS1UQCiiiqEFZuvf8gk/9dof/AEalaVZuvf8A IJP/AF2h/wDR
qUmBW8Szw23iXwu88scSHVFQM7BQWa1u1Uc9yxAA7kgVR0zwbPb/AAsl0NWn i1O80QWcqXd9
LNHFMYCmACzKihmP3BjAHBwK7Jf+P2X/AK5p/NqydY1jUrXWbHS9L060u57q 3nuGa6vGgVFi
aJcDbG5JJmHYdDUDOf1TRdQ8RyahdXGiyQwXT6VA1levCzPHBeNLKzBHZChS TpuydrDHTMmp
eFZb7/hIt+mQTf2lrenTHeEPn2sX2XeGz1UbJ/lPvgfNzsQeLbL+zIbm7jnj uHlnga2tYJLp
98MhilKrGpYxh1++VH3kyFLAVcTxHpEtvJcRX0csEdxBbGSMFlMkwjMQBAww YTRHcMj5uvBw
AR6NY3FpqviGaePZHd6gk0B3A70FrBGTx0+ZGHPp6Yq3/wAvf/bz/wC0qyIP Hvhu6t4p7a/k
mSZA9uIrWZmuQRk+SoTMpX+MIGKYO/bg1pwTw3TxXFvLHNBLMHjkjYMrqYcg gjggjnNAGVq/
/IW8K/8AYan/APSW7rifBmoTajbeALWLXtG1FLNEeWysYT9otVFjKmZW85uA zKhJRfmZemcH
0qXS7TUltXukkL2d41zAySvGVkBdc/KRkbWYFTkEEgg1MdUtF1lNJZ5BePbt copifa0asFYh
8bSQWXK5yNwOMGgDx/UNUl1LS/ENkJ7v7NP4cv7qcSanNNL58flFVlXaqW8q 723wRHb8+1l2
7M9xol5aS+KZ4v7Yu3dHjXToFuXmS4sfssbCRgdwZDKZP35+YsAm852HtKKA PO/AKTWFv4Qg
W9u5o7/w4bidJpSyhoxaiMIv3UCrK6/KBu4LbmGa6DxzPDa+G47i4ljhgi1P T3kkkYKqKLyE
kkngADnNbl9ZRahZyWszzpG+MmCd4XGCDw6EMOnY89OlU9N0Cz0q4ae3m1J3 ZChF1qVxcLjI
PCyOwB464z19TQBz9zqttqOsz6xoNzJfWlto91HdXGkbJmaXdG0KJ1SSVQJy qnO3fyAJBu4u
e/hv9P1S3ur7ZpFnd6PcrNBrtzcxAveMksgupAjFQqgYBKIyZBDg49oooAKz F/48pf8AryT+
TVp1mL/x5S/9eSfyagDz4aXd65o+sJpiR3Lpb+JNPdVlQFLia7Vo42yeCygn ngDBOMjPQar4
cu11K/u9LsY0FpZae2mxxFI90lvLcM0CHI8sNG4iLdAspHIyK1NG8Xadq91J Z7vKu0u7m18v
DMhaGV02+ZtC+YUTzPLzuCnOCvzVIni/Q3t7u4+1yLBa273TSPbyqskKDLSR EqBMgGDuj3D5
l/vLkA5e98K6nYaXqGlWltJqB1TQotLa9Ro4ws48/wAyecM4bDtcbyU8xiQ+ QTjdoXOkanBr
VzqsdhJcpDrovkgikjEk8R05bYlNzBQQ7HIZl4UkZ4B2NH8RLrGs31pDFGbS G3guba6SRj9o
SRpUztKjA3QsQQWDKVYHBrcoA871/wAL6rdXE0Vtb3dvZ6ho8GmyWukzWyQR bDNuWRpo9yxA
TAK0SFsBvlyFB6ifxp4VtbiW3uPEujQzxOUkjkv4lZGBwQQWyCDxityigDzv VfCWry+DNXTT
4Y49WuH1ONoWkCi7t55bho0LcgEeasik8g7lygdzVzVdM1YajqFtBpU9zDqG t2GoC7iliEcM
cRtQ4cM4fcBbucKrAhl5zkDuKKAOHtfCsq/2T52mQfu/Et7qdzkIcq32ryZT /eb54MdWGF6b
eNrRbG40/wAO30N1H5cjXl/MBuByklzLIh49VZT7Z55reqG8/wCPK4/65t/K gCB/+W//AF8x
/wDsleeaBb/bvCXhq8i0u+1K1OiWkCzaJqX2aZZI1IkSZvPiDqpICj5irebn bnn0N/8Alv8A
9fMf/slZEHj3w3dW8U9tfyTJMge3EVrMzXIIyfJUJmUr/GEDFMHftwaAMe20 i+bxZpEGoXkd
xP8AYoL7VUhT909zArRq7KMDMjSq6sVB/wBBXAO0bKb+Htbk8PaxpUOnTpCu iXNhZxXcls/l
syBY4rWVAHMJC4Yz4Y7Yj1DV6JBPDdW8VxbyxzQSoHjkjYMrqRkEEcEEc5qn p2p/b77Vrbyf
L/s+7W23bs+ZmGKXdjHH+txjn7ue+AAcfLoOr3fiO4lki1WOxv8AULTUjCk1 osERiSDKzEhp
fMDQdIyUPyDcMsw9Arm7PxrpkujaVf3hktnvrKG9eNIpJltUkXIaV1XEafe+ d9oOxj/CcaE3
iHTLfVBp0k8gn3rGziCQxRu2NqPKF2I53LhWYE70wPmXIBgUUUUAdHrv/Iva n/16S/8AoBpa
TXf+Re1P/r0l/wDQDS1UQMfVY4JNTtvPgt5lW2mKieLzFB3xDOPXBNZ99BYN pl7iw0xWFtKV
MdiUYEISCCRxzWlqsNyb62mgtppkWKVG8l1VlJaMj7zD+6aoXcF/PY3EKadf 75InRd9xGVyV
I5/ee9Y1KdeVaEoStFWvr569e3kNSpqElJa9NPL0OlrN17/kEn/rtD/6NStK s3Xv+QSf+u0P
/o1K3ZJb1HWbXSL3/SYr6TzY12/ZLCe5xgtnPlI23r3xnnHQ1kz6VpnjPWdP 1O602O60+zt7
m3aDVNPkjbzXaBlZY5kGQFRxu98DPONbVNWTSrhf9Gnuri5KQ29tBt3yviRy AXZVGER2+Zh9
3AySAaLeMrYmxittN1K7u7xLgpbQxpuR4JFjlR2ZwilWYjcW2naQGJKhoGGv 6De3dvYWmkyx
2tnAhiNtHcS2ix8KEkBgKswjAYeTlVbfyylVNY+i+FJrDW/DSTiR30vR4Eup o8+V50KSQxBS
QNwZbi6JA5GyInbnDl344vptXVdLtozpZTSp47uaLIniu5zEduJAynBUruTg xyBhyhPeUAcv
oPhu80v/AIRjz5IG/srRH0+fYxO6Q/ZsFcgZX9y3JweRx1xP4a02bRtA0jS7 ho2nsoobeRoy
SpZLcKSMgHGR6Cuhql/y9/8Abz/7SoA5rxpaXN5o9gIoo5bSPUne9jlsXvY2 i2TAb7dCGlHm
GIgDOCA3RTVXw5azWWueHIZmkJGmaoyB7c2+2Nrq2ZFWIsxjQKVCoTlVCghS Co7ONbiIMqxx
MN7MCZCOpJ/u+9RfY1/tH+0f7Psvt3leR9pz+88vO7Zu25255x0zQBeoqHdd f88Yf+/p/wDi
aN11/wA8Yf8Av6f/AImgCaiod11/zxh/7+n/AOJo3XX/ADxh/wC/p/8AiaAJ qKh3XX/PGH/v
6f8A4mjddf8APGH/AL+n/wCJoAmrMX/jyl/68k/k1Xd11/zxh/7+n/4moreL Y5hcBsQRqw6g
/eFAHNaZ4b1iDUbRbySxNjZ6reanC8LP5h843AWJlIxwJyxcHqNu0/fOPZ/D 2+tvD1/pmYPO
GiT6Ta3MupXNx5m9FXf5b/JbqTGpKIH6gAgJ83oX2O1/59of++BR9jtf+faH /vgUAYtiHfx9
rcvkTrCun2MIleFlR3D3LMFYjD4EiZ2k4zg88V0FQ/Y7X/n2h/74FH2O1/59 of8AvgUATUVD
9jtf+faH/vgUfY7X/n2h/wC+BQBNRUP2O1/59of++BR9jtf+faH/AL4FAE1Q 3n/Hlcf9c2/l
R9jtf+faH/vgUfY7X/n2h/74FAED/wDLf/r5j/8AZKxNB8N3ml/8Ix58kDf2 Voj6fPsYndIf
s2CuQMr+5bk4PI46423/AOW//XzH/wCyVB4e1yHxHo0Gq21rdwW1wivD9qjC M6lQchck4ySM
nrtJGVKsQDH0jVLbwtoOl6DfxalLd6fZQW8r2mlXc8TMsaglXSIhh/k4ORVh bXVYLq6vtDS0
eDV3S5lOoeZE9s/lJHuEezLjaiHy2MZBVgW+b5LF/f6lc6zJpGkS2ltPb28d 1PcXcDTLtkaR
URUV0JOYnJYsMYUANuJUn8QT2iWcEujXc2qXCSObG1kiYhI2VXkDuyKUy6Yy QxDj5RhgoBj3
vhC9trfTbTQ3jiFpZRWUV615LBPD5YIR3SMbLoDO4RuFUHcM4kO0uvB1xN4s uL/bHLaXV7b3
zM+o3MYiaJYgF+zIRHKcwqQ7MMFhlWCANJr/AI8t7Hw9d6hpNvPfMmlf2kkq wkxxI6OYGkXI
fa7Iw+UHaAS+wc1qXHii2ttUe0NpdvBDcRWk96oTyoZ5NnlxsCwck+bFyqlR vGSMNtAMiiii
gDo9d/5F7U/+vSX/ANANLSa7/wAi9qf/AF6S/wDoBpaqIBRRRVCCs3Xv+QSf +u0P/o1K0qzd
e/5BJ/67Q/8Ao1KTAj8U6Daa/wCVDcvZB7aRLiFL+3E8DttlQh4yy7htkYjD DDBTzjBTStDs
tKutLmjvrJVsrS5tzDbwJBGTPLFISiqcIqmMgDkkNyxIJbpqKgZ5zceGZ9Mt tKgsr2G+jji0
ixmUKkZVbO580zlmk4UqXBQBmyVwcZr0D7Za/wDPzD/32KmooAh+2Wv/AD8w /wDfYqujrJch
kYMpueCDkf6qr1Qz/wCutv8Arof/AEBqAJqKKKACiiigAooooAKKKKACoV/4 /Zf+uafzapqh
X/j9l/65p/NqAJqKKKACiiigAooooAKKKKACiiigCk//AC3/AOvmP/2Ssiza 88LaNpWi2+i6
lq6WdlDAbq1NvGrFF2crJMpB+XPccjk81p3cbTW95Ek0kDvMirLGFLISE+Yb gRkdeQR6g1B4
TvrjU/Buh395J5l1dafbzTPtA3O0aljgcDJJ6UAV3sdRvZV1nTv+JPqU0Qt7 iHUIFuQ0aM5T
KxSgBgXYgq+MOQwJ27S58PXiS2F3puq7b+0imgM+oQm5EqysjuSqvHht0a4w QqjKhcbdvQUU
AcXf+BJv7Gk0vSNVjtYJ9Hj0adru1NwxhjWRUZdrxhXxK+SQQflwBg5sXHge 2n8WPrYXTWM1
xFcyPPpqS3SvGqKoimY4RMRrxsJBLkMpIK9ZRQBxlFFFAHR67/yL2p/9ekv/ AKAaWk13/kXt
T/69Jf8A0A1if8I1/wBRvWf/AAK/+tVIDcork7i20611MadP4j1lLnyDckGd tqRDOXZ9u1Rw
eSR29RUO/wAP/wDQ8Tf+DaOr5JdiOePc7Ks3Xv8AkEn/AK7Q/wDo1KpReH45 4Umh17VpIpFD
I6XmQwPIIIHIqvqWifY7RZ/7U1OfbND+7nuNyHMijkY96llHbUVD9lj/AL03 /f5/8aPssf8A
em/7/P8A41Ayaiofssf96b/v8/8AjR9lj/vTf9/n/wAaAJqhn/11t/10P/oD UfZY/wC9N/3+
f/GoZrZBLbjdLzIR/rW/ut70AXKKh+yx/wB6b/v8/wDjR9lj/vTf9/n/AMaA JqKh+yx/3pv+
/wA/+NH2WP8AvTf9/n/xoAmoqH7LH/em/wC/z/40fZY/703/AH+f/GgCaiof ssf96b/v8/8A
jR9lj/vTf9/n/wAaAJqhX/j9l/65p/NqPssf96b/AL/P/jUK2yfbJBulwI0P +tb1b3oAuUVD
9lj/AL03/f5/8aPssf8Aem/7/P8A40ATUVD9lj/vTf8Af5/8aPssf96b/v8A P/jQBNRUP2WP
+9N/3+f/ABo+yx/3pv8Av8/+NAE1FQ/ZY/703/f5/wDGj7LH/em/7/P/AI0A TUVD9lj/AL03
/f5/8aPssf8Aem/7/P8A40AVLszrbXrW0SyzrKrRxuxVWICEAkBiB6kA49DV bw1bto3hXSNL
uNzT2VlDbyNHE5UsiBSRlQcZHoKvQ2yGW4G6XiQD/Wt/dX3qb7LH/em/7/P/ AI0AH2qP+7N/
35f/AAo+1R/3Zv8Avy/+FH2WP+9N/wB/n/xo+yx/3pv+/wA/+NAB9qj/ALs3 /fl/8KPtUf8A
dm/78v8A4UfZY/703/f5/wDGj7LH/em/7/P/AI0Acx9juv8An2m/74NFdP8A ZY/703/f5/8A
GigCrrv/ACL2p/8AXpL/AOgGlpNd/wCRe1P/AK9Jf/QDS1UQOF1uJ5/HmoxR wpM7+GZVWKRt
quTKQFJyMA9M5H1FZ/kar/09/wDgW3/ywrtZtBt5/EC6yZp1m+ym0eJSvlvG SWweM5yc5BHQ
e+bn9n2/pL/3+f8Axqq1fERsqCja2t7/AKGMMPSld1b79LHOakt3Z+DdC8qV 7CWK60yOWK2c
FSpniRoix3Ephj0bJwMkgkHa17/kEn/rtD/6NStBEWONY0GFUAAegFZ+vf8A IJP/AF2h/wDR
qUrtq8tzVJLRGtFeNIofygI8opO/nLAHpj/aHeiZ5jdMiGbaEU4j2dST13fS nx2ccbkjJGQV
XccDAAHGcHp1qYIocvj5iACfYZ/xNQMrtebAXZP3WWUEH5srnPH/AAE9/Ske 4mEscYRBJuGR
v4IIbvj1X0qb7PFuLFc5zwSSOevHT1/M0n2aLaRhiSc7i5LfnnPr+Z9aAIWv ipkIhYqgbnB6
rnqcYxx6ntUkhZntSy7SZDxnOPlanNbQsWypIYHI3HHPXA6A9efc0T/662/6 6H/0BqAJqKKK
ACiiigAooooAKKKKACoV/wCP2X/rmn82qaoV/wCP2X/rmn82oAmooooAKKKK ACiiigAooooA
KKKKAIYP9dc/9dB/6AtTVDB/rrn/AK6D/wBAWpqACiiigAooooAKKKKAM/Xf +Re1P/r0l/8A
QDWJ/wAIfoP/AD4/+Rn/APiq29d/5F7U/wDr0l/9ANLVIDmbjw3ocNzFbxaN NcSyIzhYpyMK
pUEnc4/vCorjw/pVrbS3E3hq9WKJC7t9oQ4UDJPEtaWrMg1K2RgD5ltMoBXI J3xH+63oexrO
vVSDTb1zGij7NKu4RAclCByIV9fUUe1oxajKST83r+ZDjUesU7F7/hD9B/58 f/Iz/wDxVVNS
8N6TYWi3NtaeXMk0O1vMc4zIoPBOOhrp6zde/wCQSf8ArtD/AOjUptFE/kRf 88k/75FHkRf8
8k/75FMaZlUuQCuWAHfjPf8AChmk8xU3LuyDkDjoe2faoGP8iL/nkn/fIo8i L/nkn/fIqNp5
AHbaNo3AZ9s+/PT0p8pYQ89dw+6cdxxQAvkRf88k/wC+RTHhiDx4jTluflHo aFZgNo4JfaN3
JXjPP5evek8wtLGGA4Y/jjcD/T86AJPIi/55J/3yKPIi/wCeSf8AfIqSigCP yIv+eSf98ijy
Iv8Ankn/AHyKkooAj8iL/nkn/fIo8iL/AJ5J/wB8ipKKAI/Ii/55J/3yKPIi /wCeSf8AfIqS
igCPyIv+eSf98imCGLz2HlpjaONo9TU9Rj/j4f8A3V/maADyIv8Ankn/AHyK PIi/55J/3yKk
ooAj8iL/AJ5J/wB8ijyIv+eSf98ipKKAI/Ii/wCeSf8AfIo8iL/nkn/fIqSi gCPyIv8Ankn/
AHyKPIi/55J/3yKkooAj8iL/AJ5J/wB8ijyIv+eSf98ipKKAIEhiLyZjThuP lHoKf5EX/PJP
++RRH9+X/e/oKkoAj8iL/nkn/fIo8iL/AJ5J/wB8ipKKAI/Ii/55J/3yKPIi /wCeSf8AfIqS
igCPyIv+eSf98iipKKALGtRvLoWoRxozu9tIqqoySSpwAKpf2lD/AM8L7/wB m/8AiK26Kadg
OV1BbbUJoJS2rQSQhgrQ2Ug4bGesZ/uiqc2nW88Lwy3uvvG4wym0fBH/AH6r tqKiVOnJ80op
v0Q1KSVk395if2lD/wA8L7/wBm/+IrN1zU7c6aEZbiMtPAAZraSNcmVABllA 5JA+pA711tUr
+ws9TX7Hf2kF3ayId8M8YkRsMpGVPBwQD+FaXuSyj5kAYsHj3HqcjNJvtgpU NFtPUZGKj/4Q
Twf/ANCpof8A4Lof/iaP+EE8H/8AQqaH/wCC6H/4mpGS77ckndFkjBORzSma E9ZIz/wIVD/w
gng//oVND/8ABdD/APE0f8IJ4P8A+hU0P/wXQ/8AxNAEpkgbO54znrkimPJD viw8fyt2I4GD
Tf8AhBPB/wD0Kmh/+C6H/wCJo/4QTwf/ANCpof8A4Lof/iaAJvPi/wCeqf8A fQo8+L/nqn/f
QqH/AIQTwf8A9Cpof/guh/8AiaP+EE8H/wDQqaH/AOC6H/4mgCbz4v8Anqn/ AH0KPPi/56p/
30Kh/wCEE8H/APQqaH/4Lof/AImj/hBPB/8A0Kmh/wDguh/+JoAm8+L/AJ6p /wB9Cjz4v+eq
f99Cof8AhBPB/wD0Kmh/+C6H/wCJo/4QTwf/ANCpof8A4Lof/iaAJvPi/wCe qf8AfQo8+L/n
qn/fQqH/AIQTwf8A9Cpof/guh/8AiaP+EE8H/wDQqaH/AOC6H/4mgCbz4v8A nqn/AH0KYJov
PY+YmNo53D1NM/4QTwf/ANCpof8A4Lof/iaP+EE8H/8AQqaH/wCC6H/4mgCb z4v+eqf99Cjz
4v8Anqn/AH0Kh/4QTwf/ANCpof8A4Lof/iaP+EE8H/8AQqaH/wCC6H/4mgCb z4v+eqf99Cjz
4v8Anqn/AH0Kh/4QTwf/ANCpof8A4Lof/iaP+EE8H/8AQqaH/wCC6H/4mgB6 TRB5MyJy3HzD
0FP8+L/nqn/fQqH/AIQTwf8A9Cpof/guh/8AiaP+EE8H/wDQqaH/AOC6H/4m gCbz4v8Anqn/
AH0KPPi/56p/30Kh/wCEE8H/APQqaH/4Lof/AImj/hBPB/8A0Kmh/wDguh/+ JoAm8+L/AJ6p
/wB9Cjz4v+eqf99Cof8AhBPB/wD0Kmh/+C6H/wCJo/4QTwf/ANCpof8A4Lof /iaAJvPi/wCe
qf8AfQoqH/hBPB//AEKmh/8Aguh/+JooA6CiiigAooooAKib/j6j/wBxv5rU tRN/x9R/7jfz
WmhMlooopDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigD/9k=
name="report_group_expr_builder_does_work.JPG"
filename="report_group_expr_builder_does_work.JPG"
CAHEAvEDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDsFia3hZcISzA/wuOM/X1p 0e1UbcDvZWBO
wEsSDzuPI6/p71tf8I/f/wDPv/4+v+NH/CP3/wDz7/8Aj6/40AYx4IzySh3l e7Fcc/56k0I6
qT8p5CjkA9EKnjv1rZ/4R+//AOff/wAfX/Gj/hH7/wD59/8Ax9f8aVgMSXEk Rj5PK4O0KON3
YdPvU9zHJN5h3jh1wBnht3PX/a6Vsf8ACP3/APz7/wDj6/40f8I/f/8APv8A +Pr/AI07AYse
2JTGoJQg/MyAnJIPQ8fwj+dJIEk27wzBWyBgDcMAY46cLW3/AMI/f/8APv8A +Pr/AI0f8I/f
/wDPv/4+v+NFgMpJETYME4OeIwv8SnoP92oGjjdYw4LMMAsFAIUDGPf6n0rc /wCEfv8A/n3/
APH1/wAaP+Efv/8An3/8fX/GlYDFjUExKxIVI3U/U7un5ikZUaDyfm2qBhsd SCx6Z4+9+lbf
/CP3/wDz7/8Aj6/40f8ACP3/APz7/wDj6/40wMgMivI4DFpH3EFRgZDD8fvU 3KH5Xy8YA+Ty
wA2Mnt93r2z/AErZ/wCEfv8A/n3/APH1/wAaP+Efv/8An3/8fX/GlYDJjVHe JmJUQsrducBR
6/7PbNQMoPmcH5olT8tv+Fbv/CP3/wDz7/8Aj6/40f8ACP3/APz7/wDj6/40 WA5e5tZmtZlt
2VJyjCNm6BscE/jV77fd/Zfsn2C0/szy/L/svzDs653+dt3+Zu+bdj8N3z1t f8I/f/8APv8A
+Pr/AI0f8I/f/wDPv/4+v+NMDl7a1mW1hW4ZXnCKJGXoWxyR+NWfE8XmW+gQ 5xuiK5+rAVv/
APCP3/8Az7/+Pr/jWF4zD2yaQCNskSOPoQ9HUaMjXfsUVrFFYi1R04ctPGCT 7knNc1Z3Er3E
kUr27YGV8q4jkP4hWJ/GrWty6nejzNP1O6t5G+9GZmCD3BB/TFU9Mtb+3jc3 +pXF5Kx6SSsy
r9AT+tds5UvZWW5L5uY3firaR2Pw70y2iLFE1I4LHnmNj/WucPw5sLLQIrvU L6Y3rgF4omVV
jz25Bya3vibdyX3wz0q5lCh31I5CjjhGH9Kzb/xwlxpyXlpLASVHmQPdSJIj dwFDjI+grXC8
3s1buzOSjzO55/q+mw2MmbeVnj6YfGRWhqHg+5021095b+zlvNRtobq1sIVm eaVJThQMR7d3
Xjd24zxmHVfFN5qtvJbSRhYmxk/aJ26HPRpCv5iul1LxpYajZaBAmseIbOGw tLO2uLO2VVSR
omBaRW83hgOVJTqq9O3ZJzVrHO1G7ORh0DWZ3KQ6RfyMJ2tiqWzkiVQWaPgf eABJXqADTpdA
1m2nkgn0i/imjgNy8b2zqyxA4MhBHCg/xdK9V0H4h6NrPjHTXmRNJWHVLu5D AJBbyRPA6rJP
ljmfOBu6fMfWsLTviDpejaLBpdj/AGk32XSb61gvPLWKTz55FdTtDnaq7B8w YnJ6DFZ+1qXt
y/1qHLHucQmgay8FzOmk37Q2rMlxILZysLKMsHOPlIHUHpSDR9U/sz+0/wCz bz+z/wDn68hv
K+9t+/jH3uOvXiuz034grFoOkwPfXllqeny3LG8XT4L15vObcW3SsrI3LA4z u6k9g1vG2my+
G9KtZo3l1ewa2FrqQsI0ktEjbJAPmHzgB8qqwQHqearnqX2Fyx7nOr4U1lPP +2afeWPlW0ly
PtNpMN6pjdjCHH3hycKM8kZFV20HWI4Lad9JvlhumVLeQ27hZmYZUIcfMSOm OtdzeeP9Anu9
QuYdLeK6vdHurOe5gtlgE80rAqzR+Y2AADl9xZi3TgVYk+JGjnVL/U0tr4za pd6dPcQlEC26
2zKzbG3fvCSuBkJ1/Cp9pU/lHyx7nnt/o+p6V5f9o6dd2fmZ8v7RA0e/GM43 AZxkfnW9J4D1
GPTxcreWMsp0xdW+yo0nmC2OMtkoEyM8jdng4zxUuu+K7HVPD2p6fBFcrLde IJdUQuqhREyF
QDgn5snp09617rx7pk3h9bL/AImM2NBj0v7DLGotxOMf6QDvPK44+TPA5HZu VSysgSicdD4f
1WS9a1fT7uF45Io5y9tJ+5MhATeApYZyMDGT2BrU1LwZeWNhpEtuZr271CS6 jFrDbOGUwPtO
AfmOeTgqpGORXVn4i6G2o6nqZh1EXGpXGnTyQeSm2H7O6FgH35fIU4O1e34N n+IukXEbW/2a
+WKeHVIJZNiFo1uphIjKu75iAACCV68E45nnq3Wn9W/zHyx7nMav4K1LTb3T 7K2t7u9u7nT4
76SCO1bfBuJBUqMn5SMZOOT0FZH9kakI5JDp92EikeKRjC2EdFLMpOOCFBJH UAE13knj7RzY
vpsSXYgbSrOyFzNZQzEPA7HJhdypDBu7ZBHQ9aztW8cyXvhq90+PUdQmvbvU BPLdGJLcTQ+Q
sZRlRiOoHHIIAJ54pxnU2aE1E4oU4U0U4VuZjhThTRThSAcKcKaKcKAHCnCm inCgBwpwpopw
pAOFKKQUooAeKcKaKcKAHCnCminCkA4U4U0U4UAOFOFNFOFAhwpRSClFADhT hTRThSAcKcKa
KcKAHCnCminCgBwpwpopwpAOFOFNFOFADhThTRThQA4U4U0U4UAOFOFNFOFI BwpwpopwoAcK
cKaKcKAHCnCminCgBRThTRThSAcKcKaKcKAHCnCminCkA4U4U0U4UCHCnCmi nCgBwpwpopwp
DFooooEemWc1xPAz3Vr9mkEsiBPMD5RXYI+R/eUK2O27B5FFxNcRz2iQWvnR yylJ38wL5KbG
IfB+98wVcD+/noDXGf8ACx4f+faT/vgf/FUf8LHh/wCfaT/vgf8AxVeNc9M7 uuX8Aakmp+Gp
JE1b+1Wi1C9iN0ZlkZgLiTZkrwMoUIAAG0rgAYrM/wCFjw/8+0n/AHwP/iqP +Fjw/wDPtJ/3
wP8A4qi4HZ3E1xHPaJBa+dHLKUnfzAvkpsYh8H73zBVwP7+egNOurqKztzPO WCAqvyoWJJIA
AABJySBXFf8ACx4f+faT/vgf/FVDdePbS8tzDLbzhSVbcigMpBBBB3dQQDyC OOhouB2Fhq0d
5Mbd0eK5+dxG0UigxhsBsui8kFSR2JIycZNm4muI57RILXzo5ZSk7+YF8lNj EPg/e+YKuB/f
z0Brzew8WWtpfG+lilkuAjQx4jAVIyQTxu5LbVJz0wAOhZ9X/hY8P/PtJ/3w P/iqLgd3Wfo1
1eXljJLfW/kTLd3MSpsK5jSZ0jbB/vIqtnoc5HBFcp/wseH/AJ9pP++B/wDF Uf8ACx4f+faT
/vgf/FUXA7O4muI57RILXzo5ZSk7+YF8lNjEPg/e+YKuB/fz0BqxXCf8LHh/ 59pP++B/8VR/
wseH/n2k/wC+B/8AFUXA7OzmuJ4Ge6tfs0glkQJ5gfKK7BHyP7yhWx23YPIo uJriOe0SC186
OWUpO/mBfJTYxD4P3vmCrgf389Aa4z/hY8P/AD7Sf98D/wCKo/4WPD/z7Sf9 8D/4qi4HX6tP
aWujX1xfyyQ2cVvI88kbOrJGFJYgp8wIGTlefTmsfwVdQ3mjTTW2px3ls1w3 kxrfC8a1Xav7
p5tzF3zlzljt8zaCVVScj/hY8P8Az7Sf98D/AOKo/wCFjw/8+0n/AHwP/iqL gdncTXEc9okF
r50cspSd/MC+SmxiHwfvfMFXA/v56A1YrhP+Fjw/8+0n/fA/+Ko/4WPD/wA+ 0n/fA/8AiqLg
dnZzXE8DPdWv2aQSyIE8wPlFdgj5H95QrY7bsHkViaj/AK8f8D/9Dasf/hY8 P/PtJ/3wP/iq
0HuReW9rdAYE0XmAHtlmP9aTGiOimN5zT28FukbyzuUXzHKqMKzckA/3fSrf 9kax/wA8bH/w
Jf8A+N1NmO5BdeGtL8VafFY6vA01vHK8yqsjJhgFAOQR2Y1Q/wCFN+Cf+gZL /wCBUn/xVdPp
UM0DiO4EYlXfuEbFl/g6EgfyqrceNNEt9YvNJ33099ZbPtMVpptzceVvXcuT HGw5HPX19K2h
UnFWTaIcU3qjC/4U34J/6Bkv/gVJ/wDFUv8AwpzwT/0DJf8AwKk/+KrvKKr2 1T+Z/eLkj2OD
/wCFOeCv+gZL/wCBUn/xVL/wp3wV/wBA2X/wKk/+Kru6KPbVP5n94ckexwn/ AAp7wX/0DZf/
AAKk/wAaX/hT/gv/AKBsv/gTJ/jXdVn3eq/ZNY07TvsF9N9u83/SYYd0NvsX d+9bPy7ui9cm
j21T+Z/eHJHscr/wqDwZ/wBA6X/wJk/xpf8AhUPgz/oHS/8AgTJ/jXc0Ue2q fzP7w5I9jhv+
FReDf+gdL/4Eyf40v/CovBv/AEDpf/AmT/GtzUvF2j6VrK6PcSXb6g1uLoW9 rYz3DeVuK7z5
aNgbhj8vUVoaVqtjrml2+p6Zcx3NncJvilTow/mCDkEHkEEHBFHtqn8z+8OS PY5P/hUfg7/o
Hy/+BMn+NH/CpPB3/QPl/wDAmT/GtDxT44s/CK3ct/peqyWtraJdPdQW4MJ3 SrEIw5YDzMsG
2/3efatDxT4ks/CPhy71y/jnktbXZvSBQXO51QYBIHVh3o9tU/mf3hyR7GB/ wqXwf/0D5f8A
wJk/xo/4VN4P/wCgfL/4Eyf4129FHtan8z+8OSPY4n/hU3hD/nwl/wDAl/8A Gj/hU/hD/nwl
/wDAh/8AGu2oo9rU/mf3hyR7HFf8Ko8I/wDPhL/4EP8A40f8Kp8I/wDPhL/4 EP8A412tFHta
n8z+8OSPY4v/AIVV4S/58Zf/AAIf/Gj/AIVX4S/58Zf/AAIf/Gu0oo9rU/mf 3hyR7HGf8Ks8
J/8APjL/AOBD/wCNH/CrPCf/AD4y/wDgQ/8AjXZ0Ue1qfzP7w5I9jjf+FW+F P+fKX/wIf/Gj
/hV3hT/nyl/8CH/xrsqKPa1P5n94ckexx3/Cr/Cv/PlL/wCBD/40f8Kw8K/8 +Uv/AIEP/jXY
0Ue1qfzP7w5I9jj/APhWPhb/AJ85f+/7/wCNH/CsfC3/AD5y/wDf9/8AGuwo o9rU/mf3hyR7
HIf8Ky8L/wDPnL/3/f8Axo/4Vn4Y/wCfOX/v+/8AjXX0Ue1qfzP7w5I9jkf+ FaeGP+fSX/v+
3+NH/CtfDP8Az6S/9/2/xrrqKPa1P5n94ckexyX/AArbwz/z6S/9/wBv8aP+ Fb+Gv+fSX/v+
3+NdbRR7Wp/M/vDkj2OT/wCFb+Gv+fWX/v8At/jR/wAK48N/8+sv/f8Ab/Gu sope1qfzP7w5
I9jlP+Fc+G/+fWX/AL/N/jR/wrrw5/z6y/8Af5v8a6uij2s/5n94ckexyv8A wrvw5/z7S/8A
f5v8aP8AhXfh3/n2l/7/ADf411VFHtZ/zP7w5I9jlv8AhXnh3/n2l/7/ADUf 8K98Pf8APtL/
AN/mrqaKPaz/AJn94ckexy//AAr7w9/z7y/9/mo/4V/4f/595f8Av81dRRR7 Wf8AM/vDkj2O
Y/4QDw//AM+8v/f5qP8AhANA/wCfeX/v81dPRR7Wf8z+8OSPY5n/AIQHQP8A nhL/AN/Wo/4Q
LQf+eEv/AH9NdNRR7Sf8z+8OSPY5r/hA9B/54S/9/TR/wgmhf88Jf+/prpaK PaT/AJn94cke
xzf/AAguhf8APGX/AL+mj/hBdD/54y/9/TXSUUe0n/M/vDkj2Oc/4QbQ/wDn jL/39NH/AAg+
if8APGX/AL+mujoo9pP+Z/eHJHsc7/whGif88pf+/po/4QnRf+eUv/f010VF HtJ/zP7w5I9j
nv8AhCtG/wCeUv8A38NH/CF6N/zyl/7+Guhoo9pPu/vDkj2Oe/4QvRv+ecv/ AH8NL/whmj/8
85f+/hroKKPaT7v7w5I9jn/+EN0f/nnL/wB/DS/8IdpH/POX/v4a36KPaT7v 7w5I9jA/4Q/S
P7kv/fw0v/CH6T/cl/7+Gt6ij2k+7+8OSPYwf+EQ0r+5L/38pf8AhEdK/uS/ 9/K3aKPaT7v7
w5I9jC/4RLS/7sv/AH3S/wDCJ6X/AHZf++63KKPaT7v7w5I9jD/4RTTP7sv/ AH3S/wDCK6Z/
dl/77rboo9pPuw5I9jE/4RXTPSX/AL7orboo9pPuw5I9jwCiiioKCiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAK9Ms/+QLpf/Xon8zXmdemWf8AyBdL/wCvRP5m pkNE1r/yGtM/
67v/AOipKueOfEjeEfBep66kKzSWsa+XG3QuzBFzjtlhn2qna/8AIa0z/ru/ /oqSt3XdFs/E
Wh3mkagjNa3cZjfacEehB9QcEe4px2BkGjwXlsI4dQvDeXaq3mz7FQMxEZOA oAAHQd8AZJOT
XBW63OlfFvxdqF0/iCzs7h7BoTY6U9zFeBIcOrMIZCADx8pU8nnI47zRra7s 1jtr28F7cRKy
NceX5ZkwI8Erk84xnsTk4GcDYoQjxf8AsS8/4WB9s/sLVf8AhFv+El837HtP mf2htx9u+5n7
Nn/ppjPPT5KwPA2ni98IeAX0bTr5tag1sS3d6LWZVS0Ek3mKLhhsEZU8xq2C zNwWJz9D1n6J
omneHNHg0nSbf7PYwbvLi3s+3cxY8sSTySeTTA8T07wDew/Aa4u7PSdSi8WS 2Ulq8bSSpL9n
+173jWJmwAyAnaAC249SxzqHweL9dde0mvrG0u9KFpcQ6N4dm02NSJVZZDHK +6dtpkBVASU3
LkMyh/aKKAPD4dAv9V8Janpd3p8+lWttqFsYNQ0zRpEivgik75tOYAtyVDbU wWKcFIiRTfS/
FWpHw7La+GZNKu4U1uKH+z45YIFZrYJDIivg2wdxwG25YF8Aua98ooA+f5/D 88mj6DH4f8OX
1pdQeGr+DWimly2pmka0VURiyL57GXoBuORn3rpND8N3Oka78Mbmz0u7t3bT J49YnET7s/Zo
yiXDnnAcYVWOF2gKBtAHrlFAHl/iS2vIPjJHqfma5ZWJ8Pi3+26ZpxusyfaC 3ln9zKBxz0B4
HPPPP/D/AErWPC2seH9Q1Hw7fQxv4akslitYHlP2g3ZkCvyfKZlZWJkKICxG VCkL7hRQB8sf
8In4k/4Q/wAj/hH9V87/AIRryPL+xSbvM/tbzNmMfe2fNjrt56V0/ivw7eXH hzx1Bc+F77UP
EdxrbT2V2tgZnWzLw7Ck2OVCgrsRiy5OVADEfQFFAHg974V1O/1HxTBfxz2u p3GtvcWF8mgz
Xd2IwY2g8m8DrHEuFCgMwCc5K9us8AeD4F8QeINd1TTbuLUIPEd/JYSTPKi+ VIFBdEJCMGBI
3YOcDngY9MooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigDn/8AhCfDv/QP/wDI0n/xVH/CE+Hf+gf/AORp P/iq6CigDn/+
EJ8O/wDQP/8AI0n/AMVR/wAIT4d/6B//AJGk/wDiq6CigDn/APhCfDv/AED/ APyNJ/8AFUf8
IT4d/wCgf/5Gk/8Aiq6CigDn/wDhCfDv/QP/API0n/xVH/CE+Hf+gf8A+RpP /iq6CigDn/8A
hCfDv/QP/wDI0n/xVH/CE+Hf+gf/AORpP/iq6CigDn/+EJ8O/wDQP/8AI0n/ AMVR/wAIT4d/
6B//AJGk/wDiq6CigDn/APhCfDv/AED/APyNJ/8AFUf8IT4d/wCgf/5Gk/8A iq6CigDn/wDh
CfDv/QP/API0n/xVH/CE+Hf+gf8A+RpP/iq6CigDn/8AhCfDv/QP/wDI0n/x VH/CE+Hf+gf/
AORpP/iq6CigDn/+EJ8O/wDQP/8AI0n/AMVUF1BHbCG3hXbFEhRFznADsAOa 6euc1H/Xj/gf
/obVMhopL5iXlrcReUWgkL7ZXZQ2UZcZCt/ez07Vqf21d/8APvY/+BUn/wAZ rMopJ2HY3NPm
e4n82RY1Zt+RG5ZeidCQD+lReKNWvNB8PXmrWdlBefY4nuJoprkw/u0RmbaQ j5bgAAgDnqKX
R/4f+2n/ALJU+u6Z/bfh7U9J87yft1pLbebt3bN6Fd2MjOM5xkVSEyuuvRWl neNrJgtLqwtP
tt7HA7zpFCTJtYMUUtkRPwFyMYx0Jji8X6HLcTwm7khEDzI89zbywwFoiwkC yuoRiuxyQrHh
GPRSRHreif2v4h0WV7fNvaeZLLPv67XidItuQeZEjl3Dp9n2nhzWHB4JvtWs Lqx1y7ji083u
pTQW9tDtnUXD3CBmlLsrAxzswGwEErk/KQWI6zTNastX80WrTrJFgvDc20lv IoOcNskVW2nD
ANjBKsAcg4p3Pi7R7I3K3Ml3C9u4Qo9jOGlJkWMeUuzMo3ugzHuHzr/eGY/D HhlPD32pxHpU
clxsDLpmmrZx4XOCQGZmb5jyWxgDAB3Fuft/hp5OqQXf26xHkeWPNi07Zc3O y5gn33EvmHzZ
D9nwW2rzIzY7UAdha63p15p09+lx5Vvb7vtBuUaBoNo3HzFkCsnykN8wHykH oQar23ijSbna
BNPCxlSHZdWktu6s+dhZZFUqrFSqsQFZhtBLcVHL4ahurTxJaXFxIYNddjJ5 YCtErW8cBAJy
CcR7s474xxzl2XgZLfTr2yc6VbwahtivYtK0pbRJYAGyn3mYM28gsWOFyFCM d9AGg/jXQUlV
PtU7K0QnMyWczQpEWdVlaQJsSMmNyHYhSo3A7eak/wCEv0NkuWju5Jvs1w1r IkFvLI/nKzho
1VVJZxsZiqgkLhz8pBOHeeFtd1HVtUt7jU4Dpt9pUNhc3L2gM06iS53BdsgE cgSVcsUKlmyF
ABWrl/4IhvtEisJZLSd4NTuNRiF7ZieAtK8zbZItw3BVnYDDD5lVv9kgGoni jSZZbWKCaeeS
5xtSC0lkMWWKfvQqnyfmVlPmbcFHB5VsVz4x0lmgeOfZavKUa6uYpYYWURSy 745GTZIu2Inc
G27ed33Q2fD4H+z3WlvBcWNolntLvYWH2WZ8StKYleNwotyzYMTK+Rkli53i n/wrZbi0a1u9
Rjit3dwbXTrdre3jRreeE+VE0jiNz9oLMw4Yovy5yxANx/GmiRxKzvfLI8oh W3Om3InZirsC
IfL8zaRHJhtu35GGcg1cl120/smDUbeWN4JriGAGTemGeZYipG0srhmI2kDD DDbeSMuLwteS
69aa3qWpwTX0EqEi2tDDG0aRXCKu1pHIbN05LbiCFUbRyTY/4Rj/AIkf9m/b P+Yr/aXmeV/0
+/atmM/8Azn3x2oAsaN4o0nX9n9nzTnzIhPF59pLB50Zx88fmKu9RuXJXIG5 c/eGcOTx9GHt
CLK7VP7YuNOuQtlPMSsa3O1oiqfvCWgUnbu2hiDjrWpo/hj+yv7A/wBM83+y NKbTf9Vt83d5
Hz9Tt/1HTn73XjmO38LzQX9q4v4zZ2mpzajBF9nPmbpknEis+/BG64JXCjAX B3E7qALEni/Q
4khdruQpIm92S3lYW6hipM+F/cAMrgmTbgo4ONjYp+KfF3/COajp9n/xKk+2 RTS+dqepfY41
8sxjaG8t9zHzM444U1l3Pw0tri7kuHk024ed5hK19paXLRo9xNOPJ3NiNx57 AswcNtQ7eCD0
GsaPqV1rNjqml6jaWk9rbz27LdWbTq6ytE2RtkQggwjuepoAsJrtpG6Wt5LH DqG+KKS2j3uf
MkXI2ZUF04f5wuMRuTjY+3Pi8e+G5bD7e9/Jb2hSORZru1mt1dHdUV1MiLuT dImWGQu9SSAQ
asf2LfSapbapPqcZvLdFhQR222Lym2GZSpYtl2UMDu+XZGMECTzOb0TwRqku g+H01u/gjutM
tLSKKGC22+UElt5nSRvMYSNm2RQy7QMscHIAAOoHijSTeQ2pmnWSXYMvaSqk bOAUjkcrtjkO
5cI5VvnUYywzGPF2jtbvcJJdvEHVI2Sxnb7QWBI8jCfvxtVmzHuG0bunNZ9x 4Htp/Fj62F01
jNcRXMjz6akt0rxqiqIpmOETEa8bCQS5DKSCtNPAU8enTQLdaUGeWN4oV06V bS02B/nt4ROD
DMS5JkR16A4DZYgGwPF+mq04lM5ZJRGkEFpcSzkGKKQl4RHvXAlQHggblBIZ toki8X6HPf8A
2OG7kkO+NPPS3lNvukRXjHnhfKywkTA3cl1A5IFZdt4LvNLvjqGm61uvuUEu o25uN0Zhto23
7XQtITaI2/IHzMNp4IksfA8OnaNJpdvfSGD7bY3UbSRgsq2q2yhDggEsLb72 Bjf045ADXPFk
uleILmzxHHb2WmHUJnktZpFkBE2AZYwRAF8nOWVy+7CjI5k1/wAZ2WnaTrL2 Uu++srS4khMt
vIIJZYo2YxrJgI7Ao25FbcNj9NrYsax4Y/tX+3/9M8r+19KXTf8AVbvK2+f8 /Ubv9f04+715
4w7v4aW1w+rCOTTYRfJeFbkaWjXavcLIG3zlssgMrYVQhwEUsQG3AGxdeLIP +Ei0rSbESSm4
vZLa4lNrL5QCQTOQk2BGXDxhSAxIw4IBBxc8Ua5/wjmgy6n5cD7JYYsXE/kR r5kqR7nfa21V
35JweBWfD4WvINYspV1OA6ZZ6hcahHbm0PnGSZZtwMvmbdoadyBszgKMnkm5 qWi32o+GLbTn
1ONtQhe1ma9ktsrJLDJHJuMasuAzJ0DDGeDxQBT0nxvp199mgupII7u6leK2 FpI1zDdbfL3N
DIEHmKvmqGOBtKSZ+WNmq5F4v0OY4W7kAZ41iZ7eVFn3yLGrRMVAlQtJGN6b lG9SSAwJr6X4
Xms/EH9uXd/HPeSpOLgRW5jjZpBbKCgLsVAW1QEEtksTkDArPXwJMbCC0l1W MjTrL7HpMiWp
Vrfa8TxyS5ciV1a3hbgIpwwKkNgAG5J4p0aJcveYz54UCJyWMMqwyKoxlm8x 1QKOWLDaDUcn
i7R4UheaS7iEieY3mWM6mBNxXfMCmYUyrYaTaCFYg4BIy5Ph/p0X2kWMNj5L 2kVtBbX9s11D
Ht8tXZlMg37kt7ZQCRtMIYZLNmnP8NYbg273F1aX8/2cW9xPqtiL2RVEkkmY GlcmMgyuBv8A
N4WMHdtO4A6TUPEEWm+IdM0mW3nf7fFM6ywxPJsZHiUBginap83JdiFXbz1r L8O+OtP1Pw1Z
X9+8ltdyWUVxNG9pNEJGYKCIA65lG91UbN+S6Dksudi/0qa41nT9UtbmOGe1 SSB1liMiyQyN
GzgYZSr5iTDZIHOVORjn7r4fQ3miaNps95HKmmaYtiBLbBknZXtpFZ0Lcput gGTPIcjcOtAG
pqfiaJPBus61ph3zWFpPKIrmF42SRIy4WSNgrrkbTg4JVgRwQakt/FOnzTJb lpJLh7iWHZaQ
TThNkzxBpCsf7sFkYZbC5V8MwUtVOHwekXg3V9BR7G2bUopo3aw09beGIyR+ XlYgcnAAJ3OS
TnkDAWvH4IePVLa6S/giWK7luXmgtmju3D3Mlx5JmEmDDlwrIyMGwTwSCoBY 0rx1puoeHtO1
SWC+hkvYlkFqljcSyA7FZiqrHueNd6jzQuwkjnJArY1PWrLSPKF007SS5KQ2 1tJcSMBjLbI1
ZtoyoLYwCygnJGebm8DXMujabpQ1K0SLTkNvbXkdm6XsEG1FURzLKNku1Tuc LtbIBTAKtuat
pN5dajaalpt7Ba31tFLbg3NsZ42jkMbN8quh3ZiTB3Yxu4OQQAU9H8SHWfE+ o2lvJG1haIgj
eO2kdZ90cUokFwD5WMS48vBY43ZwcVcv/FGk6XPcxX009v8AZonmeSW0lWNl VDIwSTbtkYIG
bahLYVuPlOI/DHhqHwvaXFpb3Ek0DvCY/MA3IsdvDAASOGJEO7OB97GOKy4/ A/l+L7bXPtFi
3kXct15jWGbyTzI5E8t7jfzGvmfKuzhURf4c0AdBd61ZWct1FI07zWsUU0sU FtJM4SRmVCFR
SWyUfoDjGTgc1jv4uiuNe0mw09oJYbuVVlLBxIitFdtgqVGxg9rtIJLAhwyq QCa//CBW8Xh7
+yreaAqLvz9l1bme3lRU8qKKWIuPMVIliUfMMvEjnJznPsfhl9k8r/ib+Rs3 /wDIPtvs3l7v
t3+q+dvL2/bvl648odc8AGpf+OLOCXTPs6XbJNe/Z7qGTTrgXCIYJpFZYdgk ILRY3bSMB/7p
IkTxnZf2tdI0u6xW0tpIBFbyPO8sklwrx+WoLllEHKbdy7X3fdOMe0+Hd5p+ prqVhe6HY3Uc
sMiR2eimGA7I7mM7oxPksRcn5twxsXg1JcfDWG4LTTXVpczl0n8u8sRNbtN5 l08haIuCUJvH
2ruypRCWbByAdZ/benf2P/av2j/ROm7Y2/du2eXsxu8zf8mzG7d8uN3FYc/j izj1nT4Y0u5b
Se3uWmSPTrh7iKWNoNqtEqb0BWYn5lGQUIOCM3B4XRPCsOjRSwQNDKlzG8Fq sUKSpMJ1xEuM
R7wBtzuK9XLEvWevhPWLfWBrVtrViupy+f8Aaml053hfzFt0GxBMGTC2sfV2 ySx44AANBvGO
kpeXEXn+ZHHFbyRm3ille484Oy+UqofNXbGW3Rl/uvkKEJNhPFGkyy2sUE08 8lzjakFpLIYs
sU/ehVPk/MrKfM24KODyrY5eb4eJdTrb7IDZ6baWNrYjUoFuo5zAlwpaSMFd y7bnA5U70Jxt
A3bGl+FLjRLq3m0y8sYFaKOG8hGnBY2RZZJAIVjdRFzNIPm8zjbnJDFgA0rx 1puoeHtO1SWC
+hkvYlkFqljcSyA7FZiqrHueNd6jzQuwkjnJArc1LU4NKt1nuI7t0ZwgFraS 3DZwTysasQOO
uMdPUVy83ga5l0bTdKGpWiRacht7a8js3S9gg2oqiOZZRsl2qdzhdrZAKYBV tTxP4a/4SD7K
26xfyN4+z6lZfa7Zt2PnMW9P3i7cK2eA7jB3cAEkXi/Q57/7HDdySHfGnnpb ym33SIrxjzwv
lZYSJgbuS6gckCq9n4sg1PxVaaZYCSS0ksri5ad7WVFkKPCqGKRgEkQiRjld wPykHB5p6V4F
/szw8NJ/tHzcXen3Pm+Rt/49Utl243fxfZs5zxv745saH4WvNI1HTnl1OCex 0zT5NPsoVtCk
gjYw4Mj+YQ7AQqMhVBJJwOlABqXjOytNa0+yil/cvdyxXl1LbyLBGkcE0j7Z yBHuVogGG44w
4IBBxoWnijSbyeG3SaeK4ml8lILm0lgkLFHcHZIoYKVikwxG0lGAORisPUPA k2pA2E2qxrop
uLy48hLUi43XMc6yDzS+3ANy5H7voFBzgk2JPCmpXF+usXGrWh1qJ4jBLHYs tuqok6ANEZSz
HFzNyJF52cfKQwADx1p6eI72zmeT7BBbxsLlLSZljkE9xFN5rhSsaKYB8zbR wxyRyJLLxnZC
2kOpy+XMt3dxt5FvI6QxRXMsSSSsoYRKRGSXcqp2uRwpxlx+AdSWLUYH1y0a DVreS31ELp7B
mWSe4lYxHziIzi6ZRuD42g88ii5+GltcXclw8mm3DzvMJWvtLS5aNHuJpx5O 5sRuPPYFmDht
qHbwQQDsNS1S00m3Wa7eQB3CRpFE8skjYJwiICzHAJIAOApPQE1z9r41gOra jb3hjht4XJg3
RSrOyCG0YDyypJcvdbdvytkooRiTi5feFLMzpfaPBY6bqaXf2w3AswyzSFJI yZVUoz/LNIR8
wIYg5PIOXceBJrvVJtTn1WP7XI4nGy1IQTL9iKnaXJKb7EErnJEhG4EbiAaF p4sguNeltHEk
Vs1vatbLNayxTySyyXCMpjYBsAQbvujChmJ2jIsT+J7Sz8S3OkXaSQpDZR3h uyjmJVYzbvMc
LsiAEOcuwznA6VT/AOEWvJdWk1u41OAa19kit4rm3tDGibJJWIKGRi0biVQy Fv4AwKsFKWNX
8Mf2reX7fbPKtdT0/wDs++j8rc7RgS7DE2QEYGZ8llcHCgAYJIBoaZrVlq/m i1adZIsF4bm2
kt5FBzhtkiq204YBsYJVgDkHFMeLtHa3e4SS7eIOqRsljO32gsCR5GE/fjar NmPcNo3dOak0
nSby11G71LUr2C6vrmKK3JtrYwRrHGZGX5WdzuzK+TuxjbwMEnLt/CmpWum6 dZw6taY0d4zp
TPYsdirE8OJ8SjzSY5Dyvl/MM4x8tAFx/GugpKsZupzmITSOtnMyQIWdMzOE 2w4aOQN5hXbs
bdjBrQj1vTpfs2y4z9pu5bKL5G+aaLzN69OMeTJyeDt4JyM8ePBGqG/1ayF/ BHpmp6esN9M1
tueZ5J7uScQ4kHlY+0HbuEmNy/e2nPQadonl+L9W1mW38nftit/n3eZmOLzZ evG7y4Y9pHH2
fcP9YaAC48X6bZancWFyZ3uI5WjSKztLi5chY4XYsscZ2489PUfMvOSVWO18 a6ZcXWqxsZBB
YvHsuYopJYrhHihdCjqu1nYzBVjUszcEA7hUlp4Y+y+L7rX/ALZu8/zv3HlY 2+ZHaJ97POPs
men8f+zzl6f4Em03RhpcOqxtAEs5tz2pLfarZYFjfh8eURbJmPG7lsSDIwAd AniHTH0a71Yz
yR2lmjvc+bBJHJCEXc2+NlDqduGAK5IIIyCMl/4h0zTbiS2uZ5PtEaRv5EUE ksjCQyBdiIpL
n91ISFBICEnAGaNF0qbTRezXdzHcXl9cfaLh4ojFHuEaRgIhZio2xpnLHnJ4 BAHP6P4PmtPD
mmmAx6dqkFwL1UlU3EcLeQYFhcBxvEcBWMMrLuMYc5ywIBuL4p0ZrO8uhefu bK0+2XJMTgxR
ZkB3LjIYGGQFMbgUIIBqxput6drEt3HYXHntaStBOQjARyKzKyEkY3Aqcjrg qejKTy934CvG
0zUbWx1mCGTVrSW21CSeyMobzJJ5C0SiRfL+a5lwGL8bB1BLdRo2mf2RYyW3 nebvu7m53bdu
POmeXbjJ6b8Z74zx0oApx+L9DlSaQXcixRJ5nmyW8qI8W4KZUZlAkiG5S0ik ooYMSAQaLrxd
o9pcLbtJdzys8qKtpYz3GTEUEmPLRshWdVJ6Bsr1BAx9C8BDw6jrptxpto62 4tIbm10qNLgx
bly0shJ8yXagw2FTcSzI/CgPhrWtP1nSE0W8tIrGwsrq2iku7UzeTEzWxjhI WVCxHlvh/wC6
oDZb52ANT/hO/B//AENeh/8Agxh/+Korz/8A4Zx8H/8AQS1z/v8Aw/8Axqig D2CiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACuc1H/AF4/4H/6G1dHXOaj /rx/wP8A9Dap
kNFOiiszxJdz2HhbV7y1fy7i3sppYnwDtZUJBweDyO9SUdXo/wDD/wBtP/ZK 165vwj9uGmW6
alzdx+bHJJ8v73ayqJMLwu8APt/h3Y7V0lWiWFFFFMQUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABXOaj/rx/wP
/wBDaujrnNR/14/4H/6G1TIaKdQ3lpBf2NxZ3SeZb3EbRSpkjcrDBGRyOD2q aq2oMyabdOjF
WWFyCDgg4NSUbFndfY4Uk8l5ss67UZFP8HPzsB+tWv7cP/QOuf8Av9b/APx2 ud0ZZB4U0l5Z
5Z5JYVmeSUgsWeNHPQdAWwPYCrHlyNHEyzRq0jP/AKyNgihd2SX6fw9KHLl0 sK1za/tw/wDQ
Ouf+/wBb/wDx2j+3D/0Drn/v9b//AB2sJpVjRGNxbTIzFTJbyb1Vhjg+nUVJ Qp30DlNn+3D/
ANA65/7/AFv/APHaP7cP/QOuf+/1v/8AHaxqpWeoxXUMTmSNTOz+Su7l1BOC AfYZqru1xaHT
f24f+gdc/wDf63/+O0f24f8AoHXP/f63/wDjtY1UZry6WZkisrhkCgiQQswY nkYx2xj8+2KE
7uwNWVzp/wC3D/0Drn/v9b//AB2j+3D/ANA65/7/AFv/APHawLad54VeSCWB yMmOUYI5I/LI
NTE4BPpS5h8ps/24f+gdc/8Af63/APjtH9uH/oHXP/f63/8AjtcbB4ks5I3a ZXhIzsU/MXHt
jv6jtVzTNQGo27SCJoyrlCCQR+BHX/HNSqqextPC1YJuUbJHTf24f+gdc/8A f63/APjtH9uH
/oHXP/f63/8AjtY1V5LkQmJ5QkdvMjNHK743bSozj0O4YOecemCSVVR+IyUG 9jof7cP/AEDr
n/v9b/8Ax2j+3D/0Drn/AL/W/wD8drAjklaUh02q0ayJkYOCWAz7/KD9GFEs kqygIm5VjaR8
DJwCoOPf5ifoppe3jy8/QOR3sb/9uH/oHXP/AH+t/wD47R/bh/6B1z/3+t// AI7XPR3QmMrx
BJLeFFaSVHzt3FhnHoNpyc8Z9MkWKcaql8IODW5s/wBuH/oHXP8A3+t//jtH 9uH/AKB1z/3+
t/8A47WNRVcwrGz/AG4f+gdc/wDf63/+O0f24f8AoHXP/f63/wDjtY1FHMFj Z/tw/wDQOuf+
/wBb/wDx2j+3D/0Drn/v9b//AB2saijmCxs/24f+gdc/9/rf/wCO0f24f+gd c/8Af63/APjt
Y1FHMFjZ/tw/9A65/wC/1v8A/HaP7cP/AEDrn/v9b/8Ax2saijmCxs/24f8A oHXP/f63/wDj
tH9uH/oHXP8A3+t//jtY1FHMFjZ/tw/9A65/7/W//wAdo/tw/wDQOuf+/wBb /wDx2saijmCx
s/24f+gdc/8Af63/APjtH9uH/oHXP/f63/8AjtY1FHMFjZ/tw/8AQOuf+/1v /wDHaP7cP/QO
uf8Av9b/APx2saijmCxs/wBuH/oHXP8A3+t//jtH9uH/AKB1z/3+t/8A47WN RRzBY2f7cP8A
0Drn/v8AW/8A8do/tw/9A65/7/W//wAdrGoo5gsbP9uH/oHXP/f63/8AjtH9 uH/oHXP/AH+t
/wD47WNRRzBY2f7cP/QOuf8Av9b/APx2j+3D/wBA65/7/W//AMdrGoo5gsbP 9uH/AKB1z/3+
t/8A47R/bh/6B1z/AN/rf/47WNRRzBY2f7cP/QOuf+/1v/8AHaP7cP8A0Drn /v8AW/8A8drG
oo5gsbP9uH/oHXP/AH+t/wD47R/bh/6B1z/3+t//AI7WNRRzBY2f7cP/AEDr n/v9b/8Ax2j+
3D/0Drn/AL/W/wD8drGoo5gsbP8Abh/6B1z/AN/rf/47R/bh/wCgdc/9/rf/ AOO1jUUcwWNn
+3D/ANA65/7/AFv/APHaP7cP/QOuf+/1v/8AHaxqKOYLGz/bh/6B1z/3+t// AI7R/bh/6B1z
/wB/rf8A+O1jUUcwWNn+3D/0Drn/AL/W/wD8do/tw/8AQOuf+/1v/wDHaxqK OYLGz/bh/wCg
dc/9/rf/AOO0f24f+gdc/wDf63/+O1jUUcwWNn+3D/0Drn/v9b//AB2j+3D/ ANA65/7/AFv/
APHaxqKOYLGz/bh/6B1z/wB/rf8A+O0f24f+gdc/9/rf/wCO1jUUcwWNn+3D /wBA65/7/W//
AMdo/tw/9A65/wC/1v8A/HaxqKOYLGz/AG4f+gdc/wDf63/+O0f24f8AoHXP /f63/wDjtY1F
HMFjZ/tw/wDQOuf+/wBb/wDx2j+3D/0Drn/v9b//AB2saijmCxs/24f+gdc/ 9/rf/wCO0VjU
UcwWOvoooqyQooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACuc1H/ AF4/4H/6G1dH
XOaj/rx/wP8A9DapkNFOqup/8gq8/wCuD/8AoJq1TJoknhkhk3bJFKttODgj BxUlDNJ/5FLR
P+vOH/0TFSRybXtnxjHnrvxjH+t/iwP/AEMfTvVsRRQabawW6FIYf3UaltxV VVFAz34FVTaQ
GTzBGEkznfGdjZ+owe9Umk7ktXRALiWX7QyTPJHHDJ5mJiwXKNjI89v/AEE/ h1F2oWt1dCrS
XDKwwQZ3II/OpqdSak7ijHlVjmr3Tb8adcI06QN5XkrJA53XDsQFZzgFTn0J +8efXW0m2s7S
3aK0g8pkIjkDctkAYycnPBHfjpVueCO5haGVdyN1GcH2II5BB5BHINNtbWGz i8uFWAJ3Es5d
mPqWJJPYcnoAO1VKpzR13JjDlemxNTIp1ltrJGUOCvAIzyImxxg/yP0p9VhY wKwZfNUqcrtl
cbfpg8da5ZQbnF9FubqSUWu46PHmo3kmJ2VlYbSu7aEw2Cicncegx/ITE4BO M+wpiwqsgk3S
swBALys+AcZ6k+gqStpct/d2IV+p5uItV1q41C/tbJ40LnfHnaVIGCoB6vxz 05rq/CV413oM
StbmIQHyQ23Ak2/xAH36+4NbtFZRhyu56WJzD29L2Tgkla3l/mRXEbSRgKFb BBKP92Qf3T7H
/wDWCMg2W11XeGNIZZJW3EodoMRXbndk8feHTPByMio6Z5Ufned5aebt2b9o 3beuM+lZVsP7
SSd7HDGdlZoF815JJrhgZZDkheijGAoPfHr3OenShvNSSOa3YCWM5Abowxgq T2z69jjr0p9F
a+zjycnQnmd7ki66qPNG8Mscq7SEG0mUtuxtwefunrjgZOBVa3jaOMhgq5JI RPuxj+6vsP8A
9QAwA7yo/O87y083bt37Ru29cZ9KfWVHD+zk3e5Up3VkgooorpICiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAOvooqjJrW lRSNHJqdmjoS
rK06ggjqCM1oQXqKz/7d0f8A6Ctj/wCBCf40f27o/wD0FbH/AMCE/wAaANCi s/8At3R/+grY
/wDgQn+NH9u6P/0FbH/wIT/GgDQorP8A7d0f/oK2P/gQn+NH9u6P/wBBWx/8 CE/xoA0KKz/7
d0f/AKCtj/4EJ/jR/buj/wDQVsf/AAIT/GgDQorP/t3R/wDoK2P/AIEJ/jR/ buj/APQVsf8A
wIT/ABoA0KKz/wC3dH/6Ctj/AOBCf40f27o//QVsf/AhP8aANCis/wDt3R/+ grY/+BCf40f2
7o//AEFbH/wIT/GgDQorP/t3R/8AoK2P/gQn+NH9u6P/ANBWx/8AAhP8aANC uc1H/Xj/AIH/
AOhtWn/buj/9BWx/8CE/xrKvZEleOSN1dHDMrKcggu2CDUyGirUN5dwWFjcX l0/l29vG0sr4
J2qoyTgcngdqmqG8tIL+xuLO6TzLe4jaKVMkblYYIyORwe1SUS20s82k28lz b/Z5WkkJiLhy
o+XAJHG7GMgZAOQCRycq1tdX1rxDqlnZ6tHZQ2aQMA1oJSxcNnncMfd9+tat tFPDpNvHc3H2
iVZJAZSgQsPlwSBxuxjJGATkgAcBnhH/AJG7xJ/1ys/5S01uJh/wiPiH/oaY P/BYP/jlMi8K
+IZYUk/4SeAb1DY/swcZ/wC2lWr25sYvivo8TXka3k2j3iCBrjkjzYGXbGTg EhZTkDJCHOQn
HO2crx6BaXep6zfJp91rl5BfTyXrQpbW0b3QiUSKVMS+YsQ3ZBOVTJXagqxJ t/8ACI+If+hp
g/8ABYP/AI5Ve/8AD+s6Zp1zf3ni2CO1tYnmmf8AsrO1FBLHAfJwAelZzapq VjaXOqeH7uTU
rCC9ksdP8+7a4gmWa3iMZ8wtmU/bQsQYsdgkkXKgZSPUDqkvhLxdbX087Q6L ol3p6s024zuV
dg83J3yfZ1tX3DHM8g65VSyAnFrfCO0aTxb5Ju/9Sk+hSROf3qRcqzBl+eWM cgfez05p15az
afNcQXXj7TI7i3jaWW3+woZVVU3k+WJNx+UbuB0r0CaztbmSOSe2hleP7jSI GK/MrcE9PmRD
9VB7CuHuNSsLf4ZX2i3F7bR61Ho863Nm8qicziFmlYrnLEtufdyGB3AkHJ7c Nh6dVLRt3Sdv
Prtsuv5oCxF4Y1ydC8Pi21kUMyFk01SAykqw4k6gggjsQak/4RHxD/0NMH/g sH/xysKbVLk3
86ajfQpaLJcfZ2vNcm04FheXKsFZAfM2osIwT8g24A3VaT+0m8OeI9WvdVv3 1HTYFkh2SyQx
pMtjDIzeVhcguclHXA5+UZbO8ssaer/q6X663t5XAvp4Y1yV5Uj8W2rtE2yR V01SUbAbB/ec
HDA49CPWibwxrltBJPP4ttYoY1LvI+mqqqoGSSTJwAO9X9BtbS08W+IVNxMt 7NciaOCW7kbf
CYYcyLGzYK7wyhgOMbQQBgXfEXyNpVzN/wAeFteia8J5RUEUm1mH91ZDE2ei 7QxwFJHK8PH2
igtmk/wvZfkgOdsNE1LVYGn07xtp95CrbDJb2KSKGwDjKyHnBHHvVr/hEfEP /Q0wf+Cwf/HK
k1XW9H1C+sGk12FNEMc4lubbUfJj+0KYvLQyxsPm2NKdm7kc4O0EZdnfW88x TXdUvIrIRt/Z
hS9mhe6H2i4UbDGwa4YxLb4++TuUjl8tssC3Hns15Wu+q8rvTXayAs2fh3Wt Qsbe9tfFkElv
cRrLE/8AZWNysMg4MmRwe9VH07UUu7m0/wCEuje5tkkeSKPRWdsIsbNgBjuO Jo+BkndgZIOM
PT9Qvk0S2i+221tdJp9qumefq81u+DaxFSlrGjC4Hml+oYsQUwcAV60tnapd NdJbQrcNndKE
Ac5Cg5PXkIg/4AvoKMVg44aXvap3tt5W/PXbUDzfRYdW17Urq3svE0Zggt45 fNk0lo2LNLPE
yGN2DKVa3I59enHO5/wiPiH/AKGmD/wWD/45VLwD/wAjP4i/4H/6ctSr0CvP sgOM/wCER8Q/
9DTB/wCCwf8Axyj/AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/AENMH/gs H/xyj/hEfEP/
AENMH/gsH/xyuzoosgOM/wCER8Q/9DTB/wCCwf8Axyj/AIRHxD/0NMH/AILB /wDHK7OiiyA4
z/hEfEP/AENMH/gsH/xyj/hEfEP/AENMH/gsH/xyuzoosgOM/wCER8Q/9DTB /wCCwf8Axyj/
AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/AENMH/gsH/xyj/hEfEP/AENM H/gsH/xyuzoo
sgOM/wCER8Q/9DTB/wCCwf8Axyj/AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hE fEP/AENMH/gs
H/xyj/hEfEP/AENMH/gsH/xyuzoosgOM/wCER8Q/9DTB/wCCwf8Axyj/AIRH xD/0NMH/AILB
/wDHK7OiiyA4z/hEfEP/AENMH/gsH/xyj/hEfEP/AENMH/gsH/xyuzoosgOM /wCER8Q/9DTB
/wCCwf8Axyj/AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/AENMH/gsH/xy j/hEfEP/AENM
H/gsH/xyuzoosgOM/wCER8Q/9DTB/wCCwf8Axyj/AIRHxD/0NMH/AILB/wDH K7OiiyA4z/hE
fEP/AENMH/gsH/xyj/hEfEP/AENMH/gsH/xyuzoosgOM/wCER8Q/9DTB/wCC wf8Axyj/AIRH
xD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/AENMH/gsH/xyj/hEfEP/AENMH/gs H/xyuzoosgOM
/wCER8Q/9DTB/wCCwf8Axyj/AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/ AENMH/gsH/xy
j/hEfEP/AENMH/gsH/xyuzoosgOM/wCER8Q/9DTB/wCCwf8Axyj/AIRHxD/0 NMH/AILB/wDH
K7OiiyA4z/hEfEP/AENMH/gsH/xyj/hEfEP/AENMH/gsH/xyuzoosgOM/wCE R8Q/9DTB/wCC
wf8Axyj/AIRHxD/0NMH/AILB/wDHK7OiiyA4z/hEfEP/AENMH/gsH/xyqlz4 e8Q27kHxPa7Q
B8zadjk59HPpXfVja0SqOQpYgIQoxk/f45oY0cn/AGRrv/Q02f8A4Lj/AI0/ w/Lcz2+qi8uh
dSWt6LZZFiEYICZJ289z3PQDpzUtiNYNxL9utIUhbLIUuI2KcdCA2T/j+lfw 1/qvEH/YXP8A
6LFSM1qKKKQwooooAKKKKACiiigAooooA6+sTTP+Peb/AK+7j/0c9bdYmmf8 e83/AF93H/o5
61iQXKKKKsQUUUUAYfg//kVrL/gf/obVuVh+D/8AkVrL/gf/AKG1blJAFFFF MAqjrX/IC1D/
AK9pP/QTV6qOtf8AIC1D/r2k/wDQTSANF/5AWn/9e0f/AKCKvVR0X/kBaf8A 9e0f/oIq9QAU
UUUwCiiigArJvvvp9G/9Datasm+++n0b/wBDas57FIq1FczfZ7Wafbu8tGfb nGcDNS1V1P8A
5BV5/wBcH/8AQTWZRNp929/oFleSW7W5nzKsbMGIVgpU5HqCD+NHhH/kbvEn /XKz/lLTdJ/5
FLRP+vOH/wBExU7wj/yN3iT/AK5Wf8papbkvY7OobT/jzg/65r/KpqhtP+PO D/rmv8qoRNVe
/sbfU9OubC8j8y1uonhmTcRuRgQwyORkE9KsUUAV7Gyi0+zjtYXneNM4M87z Ocknl3JY9e54
6dKsUUUAFFFFAEF3ax3tq9vK0yo+MmGZ4n4OeGQhh07Gqthotrp07TQS37sy 7SLi/nnXGQfu
yOwB464z+daNFWqk1HlTduwBRRRUAFRzwrc28sDmQJIhRjHIyMARjhlIKn3B BHapKKAMvSPD
2maGZG0+CRHkQJI8k8krOPMkk5Z2JJ3zSHJ5O72GNSiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigArmvEen6te3cf2DVYbOLYNyNaeaWYE853DjkDAHf1Kiulqh ej98OOq+nXr7
e/v198MmCOP/ALA8Qnp4kg9v+JaP/i/cfn3yu6xpWjy6NY3yz3i3UtzdrcPI sXljJQjGNx/u
569+OME9B198/jn+fr79e+fnrXZzC/OfmTv/AL/v/n36mWMoUUUUigooooAK KKKACiiigAoo
ooA6+uPg0T7Y1zP/AGpqcG67uP3cFxtQYlccDHtXYViaZ/x7zf8AX3cf+jnr VEGTd6LDY2zX
FxrutLEpAJFwW6kAcBc9SKz/APiV/wDQwa/+cv8A8RXQ63Gs2miJiQr3ECkj rgypVMSTjos/
5P8A/GKzq+2VvZRuhxdNfG7EVposN9bLcW+u600TEgE3BXoSDwVz1Bqb/hGv +o3rP/gV/wDW
q3okaw6aYlJKpcTqCeuBK9aNbW7k37HL6PpsA0Syfz72PfGDtiuJAMkZOADx 3NXv7Og/5+tT
/wDAmb/Gud17xBL4W+GA1mCNZJreBBGr9N7YRSfYFgfwrQlOq+GtI1PU9R1w 6jBb2TTbJrZI
2WRVJO1k2jaeylSf9o1AzS/s6D/n61P/AMCZv8aP7Og/5+tT/wDAmb/GvI4P Hfi21+HniWbU
NRH9tWKWN1bz/Z4hiK4KHG3btOAWByOp+lbs3ijxELrXrXwvqI8TQW+mpPDd FIn8q4MmDEDE
qq58vLgYJyAKAO//ALOg/wCfrU//AAJm/wAajm0u2kglRri/YFGyj3MuGGOQ cnkVzngHxOvi
G6uguv3N08UY87TdQs44rm3kzgncgUMvbG0kHGSOldncd/8Ark/9KAKQ0m2g VYkudQVVUBVS
5lwo6AcHjpS/2dB/z9an/wCBM3+Ncp4212/03xn4Z0631G9s7O/W5+1GxtFu Jm8tAybVMch6
nnC9Cc9MitonjjUo/D0lxdNa38h1K4tbaS4lFvI6IRsV440ZvOPPyLH0HOO4 B2n9nQf8/Wp/
+BM3+NH9nQf8/Wp/+BM3+NcBonxPvdY1+O5ezhttBGhTanKnmFpl8uUozfdw SGRgFyAQdxOf
lE/ibxt4hT4b32vWmmf2Xutra5srxZ45wVklQbWRlG1trZ6MOeuRQB3H9nQf 8/Wp/wDgTN/j
R/Z0H/P1qf8A4Ezf41S0HxM2sa5rWkT2BtLnSmh3jzRIGWVN68gDBwCCOR6E 1meK9R1RPG3h
PRbHU5rC21L7Z9paCOJnPlxqy4MiMBznt3oA6D+zoP8An61P/wACZv8AGlnU JHAoLEKhALkk
n5m6k85rjdL8d38WkXUd3FbXd9Z6rcaYZpZfIFw0RBBVUR2LsG+6qEfKenFd NY6iNY0PStUE
XlC8tEuBHu3bN5LYz3xmpkNEtVdT/wCQVef9cH/9BNWqUEqwZSQRyCO1SUQ6 YjR+FtGjdSrp
axIysMFWEMYII7EHil8I/wDI3eJP+uVn/KWrcrs9rGzsWYyPkk5PRaqeEf8A kbvEn/XKz/lL
VLcl7HZ1Daf8ecH/AFzX+VTVDaf8ecH/AFzX+VUImooooAKKKKACiiigAooo oAKKKKACiiig
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKoXo/fDjqvp16+ 3v79ffDX6oXo
/fDjqvp16+3v79ffDJgiv198/jn+fr79e+fnrXZzC/OfmTv/AL/v/n36mz19 8/jn+fr79e+f
nrXZzC/OfmTv/v8Av/n36mWMoUUVz50nTNS8W6q+oaZY3rRWNkIzd2yTbAZL rONwOM4HT0FI
Z0FFZf8AwjHhz/oWtD/8FkH/AMRR/wAIx4c/6FrQ/wDwWQf/ABFGgGpRWX/w jHhz/oWtD/8A
BZB/8RVW60rwbZT28F3o/hq3muW2QRy2NsjStkDCgr8xyR09RRoBvUViNonh JfM3aH4dHlyL
C+dPt/ldtu1T8vDHeuB1O4eoqf8A4Rjw5/0LWh/+CyD/AOIo0A1KKy/+EY8O f9C1of8A4LIP
/iKKNAPQ6xNM/wCPeb/r7uP/AEc9bdfN/jDx1rujeMdYsLO5ZLeK7k2KJHGM nJ6MB1JrppU5
VJWiZykoq7PeL+1e8tfKjkWNxIkisy7gCrhhkZGenrWf/Y0/rpf/AILz/wDH K+fP+Fm+Jv8A
n8b/AL+yf/F0f8LN8Tf8/jf9/ZP/AIuupYastEYudN6s+k7C1eztfKkkWRzI 8jMq7QSzljgZ
OOvrVmvmP/hZvib/AJ/G/wC/sn/xdH/CzfE3/P43/f2T/wCLqXhKrdylVgj2 6e1gvvAkFrc6
bPqUEtuqSWsBUO4IxwWZQCM5zkdOOcVzl3pdzqGj3um32l+N7mK7hSAtJdWW Y0VgcKokCZOM
FipYjvVHwvrfxA16wujolv4a+yWN9Jp6C8a5WVigBydrbehHpznit3yPi1/z 6+EP+/t1/wDF
VxGxh6j4P0u+F8kPgzxHp8N7ax2s0NibCNCEkWQPjzD8+VAJ9O2ea63UdXvd S0+azfwt4mgW
VcebbXFtFInfKss+QazvI+LX/Pr4Q/7+3X/xVHkfFr/n18If9/br/wCKoAND tXsvELapcaD4
ludQuIktGvr5rL93CGzgiKQZGcEnaW479K7KZt4YgNgRNklSPT1rjfI+LX/P r4Q/7+3X/wAV
TZIvittdZIfB6fu2bmS7PA6/xH170AXPF+kNda5pGqwW2uPeWCy+RLpZtf3e 8BW3ifg5HTAP
fPasCPw9DBJaXEPhzxbFfW11Pd/bFmsvNkknAWUt+92/MABwBjHGK2/sXxX9 PBX/AH8vf8aP
sXxX9PBX/fy9/wAaAMLR/DFnov2UQeFfFMqQ2E2nSJNLZMJ4JJGkKviUdGY4 K7T2OaSfw59q
8P3GiXGjeNpbGWGK3jja7ssQRxuHVUXzducqBuYM2BjNb32L4r+ngr/v5e/4 0fYviv6eCv8A
v5e/40AUjcarpOs6trej+Ctaur/VmgFxFeXlrDEixIVBQq7HPIyD+Yxg1bo6 /wCINW0/VNU8
Ja7pN5pfmfY5NMvrOfd5q7X3iXA6AAcHqemBWv8AYviv6eCv+/l7/jR9i+K/ p4K/7+Xv+NAG
ONChjGmPb+GPFlvdafNNOl1HPZmWR5hiUuWlIJb1AGO2K67T7NNP0HSbKKOe OO3s0iVLgqZF
C5ADlfl3cc44z0rJ+xfFf08Ff9/L3/Gt7bdrZ2a3/kfbBDifyC3l+Zubdt3c 7c5xnnHWpkND
aZMjSwSRpK8LMpUSIAWQkdRkEZHuCPan0yaJZ4JIXLhZFKko5RgCMcMCCD7g 5FSUUfDFxc3f
gfRLu8uXuLm4gWeSV1VSWdEY8KAABnA46AZyeau+Ef8AkbvEn/XKz/lLRYaf baVoVpYWault
AzpGryNIVXC4GWJOB0HPAwBwKPCP/I3eJP8ArlZ/ylqluSzs6htP+POD/rmv 8qmqG0/484P+
ua/yqhE1FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABVC9H74cdV9OvX29/fr74a/VC9H74cdV9OvX29/fr74ZMEV+ vvn8c/z9ffr3
z89a7OYX5z8yd/8Af9/8+/U2evvn8c/z9ffr3z89a7OYX5z8yd/9/wB/8+/U yxlCsuz/AORq
1n/rysP/AEO7rUrktW1yfQPEt7IuiapfrdWdoEe0tnkRTG9zuBZQcH94vHv+ aQzraK4n/hP7
r/oUde/8Apf/AIij/hP7r/oUde/8Apf/AIiizC521c3My2Gpaut/p9zfLqTK IBFbGdZIhEqe
QxxtQb/Mb5yqfvSc/fxm/wDCf3X/AEKOvf8AgFL/APEUf8J/df8AQo69/wCA Uv8A8RTswuR+
G9K1PStXmm1dJr1Vkt4VkAZ/Ln+ywRvOMjMiucoX6ptPZ5CvdVxP/Cf3X/Qo 69/4BS//ABFH
/Cf3X/Qo69/4BS//ABFFmB21FcT/AMJ/df8AQo69/wCAUv8A8RRSswuey18l /EX/AJKHrv8A
19tX1pXyX8Rf+Sh67/19tXo4D+I/T/I56/wnMUU+KIylgCBtXcSfSuhtPAXi e+tIbu20mSSC
ZBJG4kTDKRkH71ejVr0qKTqyUb92kc0ISm2oK9uxzdFX9W0XUNCu1tNTtjbz sgkCFgTtJIB4
J9DVCqhOM4qUHdPqhSi4uzVmemWl/eaZ8E/Gd3YXc9pcx+JH2TQSGN1y0IOG HIyCR+NekW8F
x4h8deItCm1PVbKy0S1s4rL7LeyRuWkQs0rNkmVhgL8+4cHIJJrh/DXhy88W /CrxZodhJBHc
3PiSXY87EINvlOckAnop7V32oeHda1vy5tY8N6DPeG3EE8tvrl1brOvUqyrB 8yZyQjFgM96+
fPQOT1HxFqmmfEvUbBr26u4P7d0SzRZrmVBGskEhdgsbIuWIBKkFCeqnjF2x +Kuu6hpdzq0G
jb7CSyvri3f7DcBLVoFYxiaY/u5A+wj5CMHjrW1J4QuZdRN+3g/QRcfaba63 JrtyqiS3UpCQ
otwoCqSMAYPcGk/4Q65826f/AIQ/Qf8ASYponX+3rnYqzDEvlr9nxGWHUoAT QBxvi34keK18
MyRxzWNnPcaBaawJ7SJw6LLMkTRgs5wfnB3Y4GRySGHsswmW3VbiRJJxauJH jQorNhckKSSB
ntk49TXF3Hgye7iEdx4O0GRF05NLCtr1yQLZGDKn/Hv1DKCG+9kda6m1GoLY GPUbW3t5I4JE
RYbx7rKAJgs7ojFuucg+uTmgDbooooAKKKKACiiigArn9Q/1y/8AAv8A0Nq6 Cuf1D/XL/wAC
/wDQ2qZDRUqtqDMmm3ToxVlhcgg4IODVmqup/wDIKvP+uD/+gmpKF0ZZB4U0 l5Z5Z5JYVmeS
UgsWeNHPQdAWwPYCpfCP/I3eJP8ArlZ/ylpuk/8AIpaJ/wBecP8A6Jip3hH/ AJG7xJ/1ys/5
S1S3Jex2dQ2n/HnB/wBc1/lU1Q2n/HnB/wBc1/lVCJqKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACqF6P3w46r6de vt7+/X3w1+qF
6P3w46r6devt7+/X3wyYIr9ffP45/n6+/Xvn5612cwvzn5k7/wC/7/59+ps9 ffP45/n6+/Xv
n5612cwvzn5k7/7/AL/59+pljKFFFFIoKKKKACiiigAooooAKKKKAOvr5L+I v/JQ9d/6+2r6
0r5L+Iv/ACUPXf8Ar7avRwH8R+n+RzV/hMC1/wCW3/XJq7jRV1ObRrV49J8W 3SbMLLZ3zJCQ
OBtGxsAYx17dulcCkjRklTjIweM8UomlAAErgDoNxr06lOFRJTSfqcK54ybi 7Gr4oNw2sPHc
w6jA6xqoi1CYyTIMZ5Ygcc5HA6/jWHACLeIEEEIMg/SpWdnOWYsfUnNJRGEY 25Vaxabt7259
B/Bf/kCa1/2Ml1/6KWt34oTzxaFpUQdksLnWLS31Jw20C1Z8PubspO0H6471 xXw/eWPwD4le
HXoNBkHiSfGpTojpD8sfUOQpz93k/wAXrXY6b4f8XzQGa48d6drdhdQYWK50 ONoZFbBDAxyr
uBHuQQenSvnz0Sr4gu9O8IWS2fhN7WylvdYtbO++zuHSwEvBk8okpGSAP4QD kEg1jWfjjxBd
3+laPJqMVvG+sahZSau8CETR2ybkJHCDeTg4x904xXXxeFtXt9MfTIZ/Csdh Jnfap4ecRNn1
QXOD0HanN4a1prKCya68Lm0t2DwwHw+/lxsOhVftOARk8igDyLwl4q8Q2Hgv QdH0Z3t0j0i8
1ETL9nCySLdSKFkadlVYwBlip3YbI4Fe5W11NfaNZ3dxHHHPPp5lkSNw6qzK hIDAkMMnqCQa
w38HahJZW9k58ItaWzFoID4cYxxEnJKr9owpJ54rcjj1KK3kXVLu1uZ/KlKv a2zQKFwvBVpH
JOc857jjjkA2KKKKACiiigAooooAK5/UP9cv/Av/AENq6Cuf1D/XL/wL/wBD apkNFSobqE3N
nNArKrSRsgZs4GRjJxU1RXM32e1mn27vLRn25xnAzUlE0FsLLRbCzEolFtGs HmAEBtkaLnB6
ZxUXhH/kbvEn/XKz/lLTdNvW1Lw/ZXrQNB55aRY2YMQpC4OR6jB/GneEf+Ru 8Sf9crP+UtUt
yXsdnUNp/wAecH/XNf5VNUNp/wAecH/XNf5VQiaiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAqhej98OOq+nXr7e/ v198Nfqhej98
OOq+nXr7e/v198MmCK/X3z+Of5+vv175+etdnML85+ZO/wDv+/8An36mz198 /jn+fr79e+fn
rXZzC/OfmTv/AL/v/n36mWMoUUUUigooooAKKKKACiiigAooooA6+vkv4i/8 lD13/r7avrSv
lzx3oWpXvjvWri3tt8T3b7W3qM4OO59q78FKMajcnbQ5qybjocPRWv8A8Ixr H/Pn/wCRU/xo
/wCEY1j/AJ8//Iqf416ftqf8y+85uSXYyKK1/wDhGNY/58//ACKn+NH/AAjG sf8APn/5FT/G
j21P+ZfeHJLsem+Ef+SReP8A/r/1T/0lr1TwL/yT3w1/2CrX/wBFLXj+mult 4P1rw7LoXjma
LU9Qlunu9M0nA2ttUoj7zuUhSM4G5WIxXT+H/Gtz4f0aDS08L+PbyC3RY4Wu tCTdHGqhVQbG
UEADqQTycmvBO89Yorzv/hZ91/0JHjP/AMEZ/wDjtH/Cz7r/AKEjxn/4Iz/8 doA9Eqne/wAX
/XvL/wCy1w//AAs+6/6Ejxn/AOCM/wDx2opviXK6SNJ4I8af6p1H/ElKgZxy T5h9KAPSaK4H
/haJ/wChD8cf+Cf/AOzo/wCFon/oQ/HH/gn/APs6AO+orgf+Fon/AKEPxx/4 J/8A7Oj/AIWi
f+hD8cf+Cf8A+zoA76iuB/4Wif8AoQ/HH/gn/wDs6P8AhaJ/6EPxx/4J/wD7 OgDvq5/UP9cv
/Av/AENqwf8AhaJ/6EPxx/4J/wD7OtZrr7da2l39nnt/Ph83ybhNkke5mO11 7MM4I7GpkNDK
q6n/AMgq8/64P/6CatUoJVgykgjkEdqkoqaJG8PhLSIpUZJEgVWRhgqRGmQR 2NTeEf8AkbvE
n/XKz/lLVuV2e1jZ2LMZHyScnotVPCP/ACN3iT/rlZ/ylqluSzs6htP+POD/ AK5r/KpqhtP+
POD/AK5r/KqETUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFUL0fvhx1X069fb39+vvhr9UL0fvhx1X069fb39+vv hkwRX6++fxz/
AD9ffr3z89a7OYX5z8yd/wDf9/8APv1Nnr75/HP8/X3698/PWuzmF+c/Mnf/ AH/f/Pv1MsZQ
ooopFBRRRQAUUUUAFFFFABRRRQB19Ymmf8e83/X3cf8Ao5626xNM/wCPeb/r 7uP/AEc9axIL
lFFFWIKKKKAMnTr+HTPBNle3M5gtYLcyzyhdxWNUZmOMHPC9hmnxeJtOnv8A 7FFcau84eNH2
6VOVjZ0V1Dt5O1DtdSQxG3POKxda/wCSN3n/AGCLn/0nkrU0bS71PFniG/e+ voLV9QQpaeXG
IbgfZIF35KbzhgR8rgZTGOucxnReRJ/z9Tfkn/xNHkSf8/U35J/8TXC6Zp7p 4otHGnTx6umq
3kuoXptWXzbJhceSpuCNsqjda4jDMV2rwPLO2n4d8HWjW/g231DR5HgTQpmv Y7pHZTcEWYCz
BuGICEKj5C+UuAPLXaAejeRJ/wA/U35J/wDE1XuhJGkqGZ3VoJDhgvUY9APW uR8IaVc2Fx4a
uZLa7S4u9CkfVp595kluc2xXz3bkuuZgoY5UbguACK6++/j/AOvaX/2WgCVh JJdOgmdFVFOF
C9SW9QfSneRJ/wA/U35J/wDE1z/jn/kSvFf/AGBZ/wD0XLXC+INH+zQ+O73T vDeht/Z//Hvf
vJ5VzZeXYQFfJAhbGzhlw68+nWgD1ryJP+fqb8k/+Jo8iT/n6m/JP/ia4nX/ ABLead4lhFvd
3bwDU7TTmiEdulqrymPcj72895fLkLgx/KBsyDtkzn6FPqFjAmnjxBJbxG41 q/lvLmKEgeRe
hNr/ACqPKPmO742tn7roOKAPRvIk/wCfqb8k/wDiaPIk/wCfqb8k/wDia4Vr jUdO17xDqNvf
bbdfEFjbG08pSsvnRWUTs7HLcK4KhduGB3bwdo9AoAh8iT/n6m/JP/iawdQB EygkkgNye/zt
XL6DpOm6R4D8IanpOn2lprFymmoZraFUluFcx+eGwMyDyvNcg5xt38FAw6nU f9eP+B/+htUy
GinVXU/+QVef9cH/APQTVqqup/8AIKvP+uD/APoJqSiLw5GsfgzRwu47ohIx ZixLMqMTk+5N
W/CP/I3eJP8ArlZ/ylqvoH/Im6L/ANe6f+i0qx4R/wCRu8Sf9crP+UtUtyXs dnUNp/x5wf8A
XNf5VNUNp/x5wf8AXNf5VQiaiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAqhej98OOq+nXr7e/v198NfrL1KQRyl2 3EAKMKQM53dc
g+n6n1NJjQzr75/HP8/X3698/PWuzmF+c/Mnf/f9/wDPv1LPtif3ZT9XU/8A sv1/M+prI0rU
bjUU1ozvuW31EQRDA+VBGDj3OSST6k1Iy3RRRSGFFFFABRRRQAUUUUAFFFFA HX1iaZ/x7zf9
fdx/6OetusTTP+Peb/r7uP8A0c9axILlFUdWJ+xKod0D3ECMUcqdplQEZHI4 JFUMWv8Acf8A
8HUv/wAVUVsRSopOo7X8m/yKhTnNtRW3mbtFUdJJ+xMpd3CXE6KXcsdolcAZ PJ4AFXq2as7G
ad1czdGghuvCulW9xFHNBLEUkjkUMrqUYEEHggjjFXdTv7bw1oiSxWMjwRPB awWtoqKcu6xR
ooYqoGWUckACs7TL+z0zwlpN5f3cFpaxqu+aeQRouVYDLHgZJA/Gqmt6jo/j HSv7J0XWLHUL
j7XaTyxWOoJ5iwpdRNI4KMGXCgnIIOcY5xWZRsWXiKC4+2rfWs+lTWUS3E8d 88Q2QtuxIWR2
QLmOT+LI2EkAEE3LPVtN1FIHsdQtLpJ0d4WgmVxIqMFcrg8hWIBI6EgGse+8 PLY6Jdro8Ek9
5I8TmS7na5mKo4b5HnZhvUbmjDHYshBOAWNcfPoeuQ6feXF1dXdpq1/rHlWk 5kia6eGe0jtz
kwhADHjzmVRjNr1IAloA9Eh13R7ie3gg1Wxlmuc+RGlwjNLhFkO0A/N8jq3H 8LA9CKiN/Z6n
Zi8sLuC7tZLabZNBIJEbBAOGHBwQR+Fcxd+Dg9vr1vFo9p5F7rGmskYSMLJZ wi0DKR02KI5g
EPvgfNzr2ljcWmq+JJp49kd3O00B3A70FrbRk8dPmRhz6emKANPVNNh1mz1P S7hpFgvbM28j
RkBgrh1JGQRnB9DVG50XwxZ3lnf6ta6VJqbyxRRahewQrPPOAAmG2jMh28Bc dOAMVN4jmvrb
Q9cn0sSHUI9Nd7URx72MoWQphcHcd2OMHNcLbXUtzpl0Yr60udPXU9H8pbXV ptTVJftqeYTP
Kg5K+V+7BO3AbA35YA9Im0nTbm9F7Pp9pLdhFQTvCrOFVxIo3EZwHAYDsQD1 qP8AsLR/+gVY
/wDH39u/490/4+P+e3T/AFn+11960KKAK7WFm/mbrSBvNlSeTMYO+RNu1z6s NiYPUbV9BWXB
oWow3EUr+LNZnRHDNFJFZhXAP3TtgBwenBB9CK3KKAMvTfDWg6NcNcaXomm2 M7IUaS1tUiYr
kHBKgHGQDj2FUNR/14/4H/6G1dHXOaj/AK8f8D/9DapkNFOmvGksbRyKHjYF WUkjIPUcc06q
2oMyabdOjFWWFyCDgg4NSUXikcdhAkMSQxIzKkcYwqgKoAA9KreEf+Ru8Sf9 crP+UtRaMsg8
KaS8s8s8ksKzPJKQWLPGjnoOgLYHsBVLR7qa28Xa95L7d0VrngHtJ601oxHo tQ2n/HnB/wBc
1/lWF/al5/z2/wDHR/hUy6hJBbwqWkOU7FQAASP7p9KfMKxu0VzE/iF/7Lmu 7Z3YLG7RsSpU
lcj+6MjIPSptC1K8vPD2m3NxMXnntYpJG2gbmZAScAep9PTjpudwsdDRWb9q mP8AH19AP/r+
o9e3Xjefapj/AB9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/6/qPXt143n2qY/ x9fQD/6/qPXt
143lwsaVFZv2qY/x9fQD/wCv6j17deN59qmP8fX0A/8Ar+o9e3XjeXCxpUVm /apj/H19AP8A
6/qPXt143n2qY/x9fQD/AOv6j17deN5cLGlRWb9qmP8AH19AP/r+o9e3Xjef apj/AB9fQD/6
/qPXt143lwsaVFZv2qY/x9fQD/6/qPXt143n2qY/x9fQD/6/qPXt143lwsaV FZv2qY/x9fQD
/wCv6j17deN59qmP8fX0A/8Ar+o9e3XjeXCxpUVm/apj/H19AP8A6/qPXt14 3n2qY/x9fQD/
AOv6j17deN5cLGlRWb9qmP8AH19AP/r+o9e3Xjefapj/AB9fQD/6/qPXt143 lwsaVFZv2qY/
x9fQD/6/qPXt143n2qY/x9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/wCv6j17 deN59qmP8fX0
A/8Ar+o9e3XjeXCxpUVm/apj/H19AP8A6/qPXt143n2qY/x9fQD/AOv6j17d eN5cLGlRWb9q
mP8AH19AP/r+o9e3Xjefapj/AB9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/6/ qPXt143n2qY/
x9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/wCv6j17deN59qmP8fX0A/8Ar+o9 e3XjeXCxpUVm
/apj/H19AP8A6/qPXt143n2qY/x9fQD/AOv6j17deN5cLGlRWb9qmP8AH19A P/r+o9e3Xjef
apj/AB9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/6/qPXt143n2qY/x9fQD/6/ qPXt143lwsaV
FZv2qY/x9fQD/wCv6j17deN59qmP8fX0A/8Ar+o9e3XjeXCxpUVm/apj/H19 AP8A6/qPXt14
3n2qY/x9fQD/AOv6j17deN5cLGlRWb9qmP8AH19AP/r+o9e3Xjefapj/AB9f QD/6/qPXt143
lwsaVFZv2qY/x9fQD/6/qPXt143n2qY/x9fQD/6/qPXt143lwsaVFZv2qY/x 9fQD/wCv6j17
deN59qmP8fX0A/8Ar+o9e3XjeXCxpUVm/apj/H19AP8A6/qPXt143n2qY/x9 fQD/AOv6j17d
eN5cLGlRWb9qmP8AH19AP/r+o9e3Xjefapj/AB9fQD/6/qPXt143lwsaVFZv 2qY/x9fQD/6/
qPXt143n2qY/x9fQD/6/qPXt143lwsaVFZv2qY/x9fQD/wCv6j17deN8Ut9L GrOXYgbQAu0d
dx9D6D/6/Ulwsa9Y2tKro6OoZWCAgjII+eq8WuicMYpJG2OUbDLwwOCPuVyX kx+KtQ1KbVfN
lNpdtbQKkzxhIwqnGEIBOWJJxn8AAE2FjR03R7HTHnmii3zyEhGk5ESY6L7n nnrjj1Jr+Gv9
V4g/7C5/9Fiof+EQ0X/n3n/8C5v/AIutbTNMtNK0y4hs42RHnWRt0jOS20jO WJPQD8qVxk1F
FFIYUUUUAFFFFABRRRQAUUUUAdfWJpn/AB7zf9fdx/6OetusTTP+Peb/AK+7 j/0c9axII9aD
/wBnZRHcrNC5VFLHAlUngcngGsz7R/1/f+C5/wD4iujopVKVOqkpp6ebX5BG Uou8X+Cf5mfo
wb+zsujoWmmcK6lTgysRweRwRWhRRWjd3clKysZujTw2vhXSri4ljhgiiLyS SMFVFCMSSTwA
BzmpT4v0NLC4vbi7ks4Ld4lm+228ts0fmOERmWRVYIWON+NvDc/KcZyaZ/bf w8g0nzvJ+3WU
lt5u3ds3xOu7GRnGc4yKqW3hC+NtcPJFBb3U13p7kPqlzfEx29yJjmWYZGQX AQKADyWO75cy
jQvvGtrG2lxafbT3U+oXb2axywTwmGQRNIBKPLLR5wn3lB2OZACqmtjQtT/t vw9pmreT5P26
0iufK3btm9A23OBnGcZwK5++0O/tdXk1iPyJYY9bGpvGDIX8gWAtmCqqMWkB ywUD5sAZBPGp
4LgmtfAvh63uIpIZ4tMtkkjkUqyMIlBBB5BB4xQBuVSvv4/+vaX/ANlq7VK+ /j/69pf/AGWg<
Re: Group On / Expression Builder [message #243313 is a reply to message #243202] |
Tue, 19 June 2007 15:16 |
Originally posted by: xxx.xxx.com
I don't see any issues with expression , you can try adding semicolon at
the end of the line , if you have if(true) you might know that the first
condition would always be met , try adding a semicoln at the end of the
line.
If you run the report in html view ,in the IDE and not in the preview mode
, I think you should be able to see the errors if any...which would help
Re: Group On / Expression Builder [message #243430 is a reply to message #243313] |
Wed, 20 June 2007 01:29 |
Thank you Ali.
The conditional has 'true' to remove ambiguity and ensure that the first
branch of statements is executed.
I have tried placing a ';' after the statement ( row["Client_Code"]; )
but my report still returns no data.
Have you ever or do you know of anyone who has successfully used a
custom "Group On" field? Perhaps this functionality hasn't been implemented?
Kind regards,
Damian Del Campo
> line.
> mode , I think you should be able to see the errors if any...which would
> help
> Thanks
FUDForum. Page generated in 0.05282 seconds
