Home » Language IDEs » Java Development Tools (JDT) » Compiler question about inlining...
Compiler question about inlining... [message #243034] |
Fri, 20 April 2007 04:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kwarner.uneedspeed.net
I read some where that javac would only inline a method if the method was declared final or static and that it had no local variables. Is this the way the JDT compiler handles inlining?
What are the rules regarding inlining the JDT compiler uses to decide if a method can be inlined or not?
And does anyone know of a white paper that describes current good programming practice to produce faster, smaller class files? For example: is it better to use public static variables or get() set() methods. Which will produce smaller class files?
Re: Compiler question about inlining... [message #243055 is a reply to message #243049] |
Fri, 20 April 2007 17:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
uh...what's IIRC???
And really? "...by the runtime..." What does that mean?
> AFAIK inlining is not done by the compiler but by the runtime. And IIRC
> it will also inline non final methods.
> Kind regards
> robert
Re: Compiler question about inlining... [message #243064 is a reply to message #243055] |
Fri, 20 April 2007 20:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wharley.bea.com
"DemonDuck" <kwarner@uneedspeed.net> wrote in message
news:f0arqo$686$1@build.eclipse.org...
> uh...what's IIRC???
Read up on "hotspot" and "JIT optimization".
Basically, the JVMs now are incredibly smart about performing on-the-fly
optimization, including all the sorts of optimization that a compiler might
do as well as things like recompiling to native code. It's quite unlikely
you can do a better job by hand with small tweaks of the sort you mention.
Your primary job, at this point, is to write code that is clear, simple,
direct, correct, and uses appropriate data structures and algorithms; let
the compiler and JVM take care of making it run fast.
Re: Compiler question about inlining... [message #243068 is a reply to message #243064] |
Fri, 20 April 2007 22:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Will do...
I had no idea that JIT would do inlining on the fly.
A casual thinker (like me) would think that would take
more time than to just push the stack -- or heap -- or...
Now you're going to tell me there's no stack and heap right :-)
>>uh...what's IIRC???
Re: Compiler question about inlining... [message #243073 is a reply to message #243064] |
Fri, 20 April 2007 23:20 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
This is excellent advice. At the current stage of JVM and compiler
history, worrying about micro-optimizations in application code is
totally futile unless it is within REALLY large loops or other code that
executes millions of times in succession.
Premature optimization is a long-known anti-pattern, one that we have
all fallen victim to at one time or another as we learn. Unless you have
profiled your application and found an obvious bottleneck or memory
problem, the best advice is to focus on the readability and design of
the code.
Hope this helps,
Eric
Re: Compiler question about inlining... [message #243078 is a reply to message #243068] |
Fri, 20 April 2007 23:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
news:f0bgbl$hnn$1@build.eclipse.org...
> Will do...
> I had no idea that JIT would do inlining on the fly. A casual thinker
No, there's still a stack and a heap :-) Although I'm told that the latest
batch of JIT compilers can actually move variables between the two when
appropriate for optimization purposes...
JIT compilation really is pretty incredible; this is where some of the
smartest folks in computer science have spent their time over the last
decade or so.
The basic idea is that, as you may have noticed if you've ever disassembled
a compiled Java program, Java bytecode contains about the same information
as Java source code, only a tad more compactly. But bytecode is not native
machine code, at least not for any real machine, and native execution is
faster than bytecode interpretation. So rather than just interpret
bytecode, like early JVMs did, modern JVMs have built-in compilers, that
compile the bytecode to native code for the machine it's running on; that
way they can take advantage of not only all the flow analysis and the like
that a traditional compiler would use, but also realtime analysis of the
execution patterns of your code, e.g., which methods are frequently hit.
Thus the (trademarked) term "hotspot": like a profiler, it identifies the
execution hotspots, and focuses its effort there (frequently on a separate
thread of execution than the one actually running your code - so a method
may be interpreted the first few times it's hit, and then compiled to native
code thereafter).
You can learn more about the Sun version of this at
http://java.sun.com/docs/hotspot/HotSpotFAQ.html.
Re: Compiler question about inlining... [message #243083 is a reply to message #243078] |
Sat, 21 April 2007 00:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Walter and Eric,
I well understand your point about readability. Maintenance is more time
consuming over the long term than any other factor.
The hotspot or JIT compiler is amazing. If you look at the right
application or applet you can see it "breathing" at first before
it gets up to full speed. Although, early versions did bite (not byte)
me every once in a while. Some portions of my code wouldn't execute.
But that was a long time ago.
Thanks again for youse guys input...
>>Will do...
> decade or so.
> code thereafter).
Re: Compiler question about inlining... [message #243093 is a reply to message #243073] |
Sat, 21 April 2007 12:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Eric,
I agree. Having spend a lot of time micro optimizing things (not
surprisingly, when you generate code for people, they will tend to blame
you all their performance problems), you can't performance optimize code
without measuring it in great detail. And with a JIT, the performance
of warmed up code can be drastically different than from a cold start,
so measuring the performance accurately is a challenge. The results of
such measurements can be very surprising and at times even counter
intuitive (like the cost of a method call will simply disappear as if it
were free because it's been in lined away, or the presence of an unused
derived class can have an impact). If Eclipse provided a performance
analysis tool as totally excellent as the rest of JDT, I'd be such a
happy guy! With a good measurement tool and a focused effort on only
the bottlenecks, you can of make simple changes that have a shockingly
huge impact on overall performance. The key is to measure, measure, and
measure again. (And then the depressing part is that what's optimal for
one JVM might well be significantly suboptimal on another one.)
>> on-the-fly optimization, including all the sorts of optimization that
>> a compiler might do as well as things like recompiling to native
>> code. It's quite unlikely you can do a better job by hand with small
>> tweaks of the sort you mention. Your primary job, at this point, is
>> to write code that is clear, simple, direct, correct, and uses
>> appropriate data structures and algorithms; let the compiler and JVM
> that executes millions of times in succession.
> have profiled your application and found an obvious bottleneck or
> memory problem, the best advice is to focus on the readability and
> design of the code.
> Hope this helps,
> Eric
Re: Compiler question about inlining... [message #243103 is a reply to message #243093] |
Sat, 21 April 2007 16:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Someone mentioned the Eclipse Profiler Plugin on sourceforge --
http://eclipsecolorer.sourceforge.net/index_profiler.html
Does anyone have an opinion on how good this profiler is?
Ed Merks wrote:
> Eric,
>> design of the code.
>> Hope this helps,
>> Eric
Current Time: Tue Jul 16 12:21:42 GMT 2024
Powered by FUDForum. Page generated in 0.06050 seconds
