Re: -vm confusion [message #243017 is a reply to message #243015] |
Thu, 13 December 2007 19:03 |
Originally posted by: wharley.bea.com
"Eric Kolotyluk" <eric.kolotyluk@kodak.com> wrote in message
news:5ccc07822fe71858b6c987cbd220055d$1@www.eclipse.org...
> OK, so I'm running Eclipse on Windows
> In the shortcut that I use to start Eclipse I put
> -vm "c:\Program Files\Java\jre1.6.0_03\bin\javaw"
> and Eclipse starts just fine. However when I put the following in the
> eclipse.ini file
> -vm
Does it work if you put quote marks around that second line, just as you did
in the command-line version?
Re: -vm confusion [message #243053 is a reply to message #243016] |
Fri, 14 December 2007 12:32 |
Originally posted by: al_PUBLIC.gmx.de
On Thu, 13 Dec 2007 19:03:16 +0000 (UTC), eric.kolotyluk@kodak.com
(Eric Kolotyluk) wrote:
>OK, now I'm questioning my sanity.
>The eclipse.ini file is now working correctly with the following
> -vm
>I have no explanation - it just started working for no reason.
>Cheers, Eric
The eclipse.ini file is extremely fragile. If you've typed any sort of
whitespace after any of the lines in your .ini file it wouldn't work.
Achim
Eclipse Stammtisch Braunschweig/Wolfsburg/usw. am 18.12.2007
siehe http://www.bredex.de/de/news/eclipseregtable.html
Re: -vm confusion [message #243069 is a reply to message #243026] |
Fri, 14 December 2007 14:34 |
> news:0e3b7ab2efaae79bef9063bec76efcbd$1@www.eclipse.org...
> There's never any point in questioning your own sanity - if you're insane,
> other people will question it for you :-)
And the definition of insanity is relative, anyway.
"A man talking sense to himself is no more insane than a man talking
nonsense not to himself...or just as insane."
-Rosencrantz and Guildenstern are Dead
FUDForum. Page generated in 0.09257 seconds
