Home » Eclipse Projects » Eclipse Platform » Possible bug?
Possible bug? [message #242971] Thu, 20 May 2004 17:32 Go to next message
I keep getting this error when I close down my eclipse runtime workbench
with 3.0M8. Has anyone else seen it?
org.eclipse.jdt.internal.core.JarPackageFragmentRoot.getReso urce(JarPackageF
ragmentRoot.java:244)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:169)
org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:54
3)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:28
0)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:26
6)
org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaEl ement.java:221)
org.eclipse.jdt.internal.core.JavaProjectElementInfo.getPack ageFragmentsInRo
ots(JavaProjectElementInfo.java:222)
org.eclipse.jdt.internal.core.JavaProjectElementInfo.getAllP ackageFragments(
JavaProjectElementInfo.java:178)
org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:212
8)
org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:213
9)
org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnviron
ment.java:63)
org.eclipse.jdt.internal.core.JavaProject.newSearchableNameE nvironment(JavaP
roject.java:2154)
org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.p rocess(Compilati
onUnitProblemFinder.java:147)
onUnitProblemFinder.java:203)
org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation. executeOperation
(ReconcileWorkingCopyOperation.java:73)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java
:700)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOpera
tion.java:739)
org.eclipse.jdt.internal.core.CompilationUnit.reconcile(Comp ilationUnit.java
:1051)
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.reconcile(Java
ReconcilingStrategy.java:87)
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.initialReconci
le(JavaReconcilingStrategy.java:145)
org.eclipse.jface.text.reconciler.CompositeReconcilingStrate gy.initialReconc
ile(CompositeReconcilingStrategy.java:111)
Re: Possible bug? [message #242975 is a reply to message #242971] Thu, 20 May 2004 17:42 Go to previous message
A quick search of bugzilla found no stack traces similar to this.
If you can, try your test case using one of the builds of this week to see
if the problem is fixed in what will become M9
Either way, make sure to file a bug if the problem persists.
Darins
"Del" <delmyers@cs.uvic.ca> wrote in message
news:c8j7mq$af6$1@eclipse.org...
> java.lang.NullPointerException
> at
> at
> 3)
> at
> 0)
> at
> 6)
> at
> at
> at
> at
> 8)
> at
> 9)
> at
> ment.java:63)
> at
> roject.java:2154)
> at
> at
> at
> at
> :700)
> at
> tion.java:739)
> at
> :1051)
> at
> at
> at
Previous Topic:3.0M8 does not start
Next Topic:Detatched window in RCP application
Current Time: Thu Mar 13 13:49:18 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
