Home » Eclipse Projects » Eclipse Platform » how to load my plugin at launch time
how to load my plugin at launch time [message #242892] Thu, 20 May 2004 18:14 Go to next message
Marcos López is currently offline Marcos LópezFriend
Member
Plugins are loaded the precise moment they are going to be used, but i
want to load when eclipse launches. how can i do it?
Re: how to load my plugin at launch time [message #242911 is a reply to message #242892] Thu, 20 May 2004 18:38 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
http://www.google.com/search?hl=en&ie=UTF-8&q=org.ec lipse.ui.startup
Sam Mesh - http://openrules.com
Re: how to load my plugin at launch time [message #242921 is a reply to message #242911] Thu, 20 May 2004 18:42 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
However, make sure you really need to be loaded at startup. Startup is
slow enough as it is and just adding more to it will slow it down even more.
The use of this mechanism is discouraged except for rare cases where it
must be done that way.
Thanks, Rich Kulp
Re: how to load my plugin at launch time [message #242962 is a reply to message #242921] Thu, 20 May 2004 20:19 Go to previous message
> more.
And even when you use this mechanism, program defensive. Don't rely on
your plug-in being loaded at startup, the user may override this.
marko
Previous Topic:Bootloader.inDevelopmentMode replacement. How do I get to it?
Next Topic:Where should I post a bug?
Current Time: Thu Nov 14 08:52:18 GMT 2024
Powered by FUDForum. Page generated in 0.03774 seconds
