Re: Cookies/Session For PHP integration [message #242850 is a reply to message #242840] |
Fri, 15 June 2007 03:49 |
Jim,
Take a look at this wiki page.
http://wiki.eclipse.org/index.php/Retrieve_Session_informati on_in_Script_%28BIRT%29
Jason
Jim wrote:
> I'm working on a PHP application that uses BIRT for it's reporting
> features. The problem is making sure that the reports only run for user
> who authenticated in the PHP application. I had looking at passing
> parameters in the URL that loads the report but I'm wondering if there
> is a way to work with cookies as an alternative.
> *Can I load cookies or read session data create by my application?
> *Better yet, how do I read this information in BIRT?
> My research leads me to believe that I create a script in the
> beforeFactory or initialize events. How to feed cookie/session values
> into parameters?
> //This appears to be a start now for specific cookies
> var request = reportContext.getHttpServletRequest();
Re: Cookies/Session For PHP integration [message #249755 is a reply to message #242850] |
Wed, 25 July 2007 15:48 |
Originally posted by: ian.munday.illumen.co.uk
Jim,
Did you get any where with this? I'm trying to do something very
similar to you, i.e. I have a PHP application which uses BIRT for
reporting and need to ensure reports only run for authenticated users.
Ian
Jason Weathersby wrote:
> Jim,
> Jason
>> user who authenticated in the PHP application. I had looking at
>> passing parameters in the URL that loads the report but I'm wondering
>> if there is a way to work with cookies as an alternative.
>> into parameters?
FUDForum. Page generated in 0.03220 seconds
