Home » Language IDEs » Java Development Tools (JDT) » Debugger gets disconnected
Debugger gets disconnected [message #242787] Thu, 12 April 2007 16:06 Go to next message
Originally posted by: schaal.joel.e-serve.ch
Good morning everybody.
I have encountered an embarrassing problem with the eclipse debugger.
In the Debug view, when I hit the F6 key to get further I am sometimes
automaticallly disconnected from the program which I am debbugging. I
mean, the program continues to work but I cannot debug anymore.
This is specially annoying when the program is big and needs time to get
started again. I am almost sure I have seen something about this in the
Bugzilla repository, but I can't find it again. Could anyone tell me the
Bug ID of this problem (or whether I have some problems with my config..)
I have seen this with eclipse 3.2 and 3.2.1, JRE 1.5.0_04 and JRE 1.6.1.
(strangely not in eclipse 3.1, is it bad luck ?)
Thank you for your time and consideration,
Joel.
Re: Debugger gets disconnected [message #242792 is a reply to message #242787] Thu, 12 April 2007 20:11 Go to previous messageGo to next message
Genady Beryozkin is currently offline Genady BeryozkinFriend
Maybe https://bugs.eclipse.org/bugs/show_bug.cgi?id=171075
fixed in 3.2.2
Genady Beryozkin
http://www.genady.net/
> get started again. I am almost sure I have seen something about this
> in the Bugzilla repository, but I can't find it again. Could anyone
> tell me the Bug ID of this problem (or whether I have some problems
> with my config..)
> 1.6.1. (strangely not in eclipse 3.1, is it bad luck ?)
> Joel.
Re: Debugger gets disconnected [message #242842 is a reply to message #242792] Fri, 13 April 2007 11:43 Go to previous message
Thank you very much, that was it !
Now I sometimes experience another problem (the UI freezes when hitting a
breakpoint) but this is very less annoying, since it is rare.
This product is really something good, and so seems this mailing list ;)
Joel.
Previous Topic:Recommended way to use AST to do template-based code gen?
Next Topic:AST: inserting comments and blank lines
Current Time: Thu Jan 02 21:30:00 GMT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
