Re: Error in xml pages before opening other pages [message #242822 is a reply to message #242780] |
Fri, 15 June 2007 02:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nisha,
You should be getting red blocks in the outline for errors and the
problem should show up in the problems tab. If this is failing than
this should be logged as a bug.
Jason
Nisha Agarwal wrote:
> I deleted the section in XML that I added recently and the error went
> away. However, if anyone knows a better way of trying to figure this
> out, please let me know.
Re: Error in xml pages before opening other pages [message #243102 is a reply to message #242993] |
Mon, 18 June 2007 14:20 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Lester,
Can you log a bugzilla entry for this. You should be getting the red
highlights.
Jason
Lester Mundt wrote:
> I have this error as well. I am using the RCP designer though. I
> doesn't have a problems tab. It stays on the XML Source tab and
> produces the error when I click another tab.
> The XML is not highlighted with any red blocks.
> Any suggestions or should I stick to loading it in a full eclipse install.
> Lester
>> I did not pay attention to that. I will check it out and file a bug if
>> I don't see the error.
>> Thanks a lot,
>> Nisha
FUDForum. Page generated in 0.04056 seconds
