tag library descriptor? [message #242767] |
Tue, 11 December 2007 09:32 |
Originally posted by: MacAdam.eden.invalid
Hi all,
If this is the wrong user group, apologies. I searched, but did not find
an appropriate one.
At the moment I'm trying to get an Example working. The error message I
get in Eclipse, after saving my .jsp is:
Cannot find the tag library descriptor for
(1) http://java.sun.com/jsp/jstl/core
and
(2) http://java.sun.com/jsp/jstl/sql
I downloaded the 'Jakarta Taglib Standard 1.1', and extracted the
jstl.jar and standard.jar files to
D:\eclipse\workspace\DBTest\WebContent\WEB-INF\lib
The taglib's I use in my jsp are:
<%@ taglib uri="http://java.sun.com/jsp/jstl/sql" prefix="sql" %> (1)
<%@ taglib uri="http://java.sun.com/jsp/jstl/core" prefix="c" %> (2)
Note: (1) and (2) in error message and taglib correspond to each other.
So the easy question is, what do I need to do to get this example working?
Background:
I want to start with JAAS (Java Authentication and Authorization
Service), and came out at the following Tomcat tutorial
http://tomcat.apache.org/tomcat-6.0-doc/jndi-datasource-exam ples-howto.html.
As development environment I installed Wampserver 2.0 (Apache, MySQL,
PHP for Windows XP), Tomcat 6.0 and I use jdk1.6.0_03. Using phpmyadmin,
I configured MySQL for the example.
My problem might be caused by the place I saved my Context
configuration. I placed it in %CATALINA_HOME%/conf/context.xml. So it
might be Eclipse did not find this context configuration. Might it be I
need to add this context configuration to Eclipse too? Where?
TIA,
Abel
FUDForum. Page generated in 0.07946 seconds
