How do I start [message #242747] |
Tue, 11 December 2007 06:51 |
Originally posted by: Vivek.Sundriyal.gmail.com
Hi ,
I am very new to Eclipse. And I want to know how do I start.
I want to do the following :
-- I want to use Eclipse to debug a MIPS code which is running on a
target(remote debugging). How do i start ? What is that i need to download
? etc....
I am very new to this and hence this very basic question.
Thanks in adv ,
Cheers !
Re: How do I start [message #242752 is a reply to message #242747] |
Tue, 11 December 2007 08:09 |
Originally posted by: dmsubs.NOSPAM.consertum.com
You will need
- Eclipse for C/C++ Developers as can be found on the Eclipse Download page
- a MIPS GNU toolchain (compiler/assembler/linker/debugger aka gcc/gas/gld/gdb)
- a GDB compatible jtag probe to connect to your hardware
Derek
Vivek Sundriyal wrote:
> Hi ,
> download ? etc....
> Thanks in adv ,
> Cheers !
Re: How do I start [message #242757 is a reply to message #242752] |
Tue, 11 December 2007 08:35 |
Thanks for that reply.
I have downloaded the Eclipse for C/C++. But I also see something as CDT ?
Do I need to install the CDT(4.0.2) also ?
Vivek
Re: How do I start [message #242777 is a reply to message #242757] |
Tue, 11 December 2007 09:58 |
Originally posted by: jakub.jurkiewicz.gmail.com
Vivek Sundriyal pisze:
> ? Do I need to install the CDT(4.0.2) also ?
> Vivek
If you had downloaded Eclipse for C/C++ then CDT is included.
Kind regards,
Jakub Jurkiewicz
Re: How do I start [message #242791 is a reply to message #242777] |
Tue, 11 December 2007 10:49 |
Hi ,
I installed the Eclipse for C/C++ and tried to create a "test" project.
For simplicity, I created the HelloWorld project supplied by Eclipse.
After creating the project, and I try to compile the program, it gives me
an error :
**** Build of configuration Default for project tes ****
make all
make: Error -- Don't know how to make tes.o
Do i need to do something more besides this ?
Thanks ,
Vivek
Re: How do I start [message #242923 is a reply to message #242791] |
Wed, 12 December 2007 17:00 |
> Hi ,
> me an error :
> make all make: Error -- Don't know how to make tes.o
> Thanks ,
> Vivek
What operating system do you use?
On Linux you need gcc, and on Windows you need CygWin with gcc and
configure this properly to use CDT
Beside newsgroup org.eclipse.cdt is a better place for asking CDT
related questions.
kind regards,
Jakub Jurkiewicz
http//eclipser-blog.blogspot.com
FUDForum. Page generated in 0.06513 seconds
