Home » Eclipse Projects » Eclipse Platform » Using IFile on a file outside of project folders
Using IFile on a file outside of project folders [message #242663] Wed, 19 May 2004 17:07 Go to next message
Originally posted by: mafulton.us.ibm.com
Hey All,
My problem basically is opening an external file lying outside the eclipse
workspace from code inside eclipse. Since the actual "open external file"
functionality isn't the cleanest it could be(does not smoothly open
complex files such as Word Documents with external editors associated with
it), I am trying to go about this myself.
I have made a copy of the file inside the metadata folder that lies within
my workspace root. The problem is that the only way that the IFile can be
opened by an editor (internal or external) by eclipse is if the IFile
location lies within a project folder that is located in the workspace(not
within the metadata folder or the workspace root). And for the most part
you are not able to create an IFile object unless the path lies within
those project folders as well.
So I guess what I'm looking for is any ideas on how to create an IFile
from a file that is outside a project folder. Also if there are other
solutions that don't involve copying the file into the workspace or
anything I have said here then those are welcome as well.
Thanks.
Re: Using IFile on a file outside of project folders [message #242858 is a reply to message #242663] Thu, 20 May 2004 13:20 Go to previous message
I think that you can create a IFile linked to that external file, and then
open it.
Mike Fulton wrote:
> Hey All,
> Thanks.
Previous Topic:Finding Java Problems based on their ID
Next Topic:plugin for tiles
Current Time: Wed Oct 22 04:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.03004 seconds
