Home » Newcomers » Newcomers » EPF composer
EPF composer [message #242650] Mon, 10 December 2007 13:35 Go to next message
Originally posted by: eduardo.paqueta.com.br
I have problems for execute the EPF composer. I need a solution.
!SESSION 2007-12-10 11:25:37.234
eclipse.buildId=unknown
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Framework arguments: -defaultlibrary OpenUP
Command-line arguments: -os win32 -ws win32 -arch x86 -data
@user.home/EPF/workspace.1202 -defaultlibrary OpenUP
!ENTRY org.eclipse.osgi 4 0 2007-12-10 11:25:38.062
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.epf.rcp.ui.MainApplication" could not be found in the
registry. The applications available are: org.eclipse.ant.core.antRunner,
org.eclipse.equinox.app.error,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.ui.ide.workbench,
org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:92)
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:129)
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042)
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967)
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:94)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1224)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1603)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1578)
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl. <init>(ServiceRegistrationImpl.java:103)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:657)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:609)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:675)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:359)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
!ENTRY org.eclipse.osgi 2 0 2007-12-10 11:25:38.187
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-12-10 11:25:38.187
!MESSAGE Bundle
update@plugins/org.eclipse.ocl.ecore_1.1.0.v200706071450.jar was not
resolved.
!SUBENTRY 2 org.eclipse.ocl.ecore 2 0 2007-12-10 11:25:38.187
!MESSAGE Missing required bundle org.eclipse.ocl_[1.1.0,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.query.ocl_1.1.0.v200706071712.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.query.ocl 2 0 2007-12-10 11:25:38.187
!MESSAGE Bundle update@plugins/org.eclipse.ant.ui_3.2.100.v20070511.jar
was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-12-10 11:25:38.187
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_[3.2.0,4.0.0).
org.eclipse.ui.externaltools_[3.1.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.platform_3.3.0.v20070613/ was
not resolved.
!SUBENTRY 2 org.eclipse.platform 2 0 2007-12-10 11:25:38.187
org.eclipse.ui.intro.universal_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2007-12-10 11:25:38.218
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-12-10 11:25:38.218
was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.emf.common.ui_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.common.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.common_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.commonj.sdo_2.3.0.v200706262000.jar
was not resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.emf.common_2.3.0.v200706262000.jar was not
resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore.change_2.3.0.v200706262000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.change 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore.edit_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.edit 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.edit_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore.sdo_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.sdo 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.commonj.sdo_[2.3.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.3.0,3.0.0).
org.eclipse.emf.ecore.change_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore.xmi_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.xmi 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore_2.3.0.v200706262000.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.ecore 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.emf.edit.ui_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.edit.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.common.ui_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.edit_2.3.0.v200706262000.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.edit 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing optionally required bundle
!MESSAGE Bundle
update@plugins /org.eclipse.emf.mapping.ecore.editor_2.3.0.v200706262000.ja r
was not resolved.
!MESSAGE Bundle
update@plugins /org.eclipse.emf.mapping.ecore2ecore_2.3.0.v200706262000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.ecore.edit_[2.3.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.mapping_[2.3.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.mapping.ecore2xml_2.3.0.v200706262000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.emf.mapping_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle update@plugins/org.eclipse.emf.ocl_1.1.0.v200706201508.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.ocl 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.ocl.ecore_[1.1.0,2.0.0).
!MESSAGE Bundle
not resolved.
!SUBENTRY 2 org.eclipse.emf.query.ocl 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.query_[1.0.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ocl_[1.1.0,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.query_1.1.0.v200706071712.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.query 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.emf.transaction.ui_1.0.100.v200706071723.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.transaction.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.edit.ui_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.transaction_[1.0.0,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.transaction_1.1.0.v200706131240.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.transaction 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.edit_[2.2.0,3.0.0).
org.eclipse.emf.ecore.change_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.validation_[1.0.0,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.validation_1.1.0.v200706071520.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.validation 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.ecore.edit_[2.2.0,3.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.workspace_1.1.0.v200706131240.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.workspace 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.transaction_[1.1.0,2.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.epf.authoring.ui_1.2.0.v20071109_1544.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.authoring.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.library.xmi_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.library.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.richtext_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.validation_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.ad_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.add_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.wpdd_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.ui_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.base_1.2.0.v20071015-1648.jar was not
resolved.
!MESSAGE Bundle
update@plugins /org.eclipse.epf.common.win32.win32.x86_1.2.0.v20070806-1500 .jar
was not resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.common_1.2.0.v20071102-1707/ was not
resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.dataexchange_1.2.0.v20070906-1418.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.dataexchange 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.library_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.add_1.2.0.v20071015-1126.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.add 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.ecore_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.edit.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.gmf.runtime.emf.core_0.0.0.
org.eclipse.gmf.runtime.emf.commands.core_0.0.0.
org.eclipse.gmf.runtime.emf.ui.properties_0.0.0.
!MESSAGE Missing required bundle org.eclipse.gmf.runtime.diagram.ui_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.printing.render_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.printing_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.providers_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.providers.ide_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.render_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.resources.editor_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide_0.0. 0.
org.eclipse.gmf.runtime.notation.providers_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.edit_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.uma_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.uma.edit_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.common_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.ad_1.2.0.v20071015-1126.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.ad 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.uml2.uml_0.0.0.
!MESSAGE Missing required bundle org.eclipse.uml2.uml.edit_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.ecore.edit_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.geoshapes_0.0.0.
org.eclipse.gmf.runtime.diagram.ui.actions_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.core_1.2.0.v20071025-1311.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.core 2 0 2007-12-10 11:25:38.218
org.eclipse.gmf.runtime.diagram.ui.properties_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.edit_1.2.0.v20071015-1126.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.edit 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.edit_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.diagram.model_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.model_1.2.0.v20071015-1126.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.model 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.library.edit_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.transaction_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.workspace_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.ui_1.2.0.v20071113-1309.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.epf.diagram.wpdd_1.2.0.v20071015-1126.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.diagram.wpdd 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.epf.doc_1.2.0.v20070831-1033.jar was not
resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.export.msp.ui_1.2.0.v20071029-1233/
was not resolved.
!SUBENTRY 2 org.eclipse.epf.export.msp.ui 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.export_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.export.msp_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.publishing.ui_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.export.msp_1.2.0.v20071008-1708/ was
not resolved.
!SUBENTRY 2 org.eclipse.epf.export.msp 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.msproject_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.publishing_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.export.xml_1.2.0.v20071029-1509.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.export.xml 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.authoring.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.dataexchange_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.xml.uma_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.export_1.2.0.v20071101-1635.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.export 2 0 2007-12-10 11:25:38.218
!MESSAGE Bundle
update@plugins/org.eclipse.epf.help.doc_1.2.0.v20070905-1644/ was not
resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.import.xml_1.2.0.v20071101-1635.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.import.xml 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.export.xml_0.0.0.
!MESSAGE Missing required bundle org.eclipse.epf.import_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.import_1.2.0.v20071031-1043.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.import 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.epf.services_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.library.edit_1.2.0.v20071109_1544.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.library.edit 2 0 2007-12-10 11:25:38.218
!MESSAGE Missing required bundle org.eclipse.emf.common.ui_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.epf.library.persistence_1.2.0.v20070927-1135.ja r
was not resolved.
!SUBENTRY 2 org.eclipse.epf.library.persistence 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.emf.mapping.ecore2ecore_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.mapping.ecore2xml_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.library.ui.xmi_1.2.0.v20070806-1500.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.library.ui.xmi 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.epf.ui_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.library.ui_1.2.0.v20070831-1755.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.library.ui 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.library.xmi_1.2.0.v20071019-1627.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.library.xmi 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.library_1.2.0.v20071101-1436/ was not
resolved.
!SUBENTRY 2 org.eclipse.epf.library 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.epf.library.persistence_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.migration.diagram_1.2.0.v20071017-1313.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.migration.diagram 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.msproject_1.2.0.v20070806-1500.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.msproject 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.platform_1.2.0.v20070806-1500.jar was
not resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.publishing.ui_1.2.0.v20071030-2325.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.publishing.ui 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.publishing_1.2.0.v20071023-1506/ was
not resolved.
!SUBENTRY 2 org.eclipse.epf.publishing 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.epf.search_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.rcp.ui_1.2.0.v20071015-1648.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.rcp.ui 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.rcp_1.2.0.v20071015-1648.jar was not
resolved.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.richtext_1.2.0.v20071107-1814/ was
not resolved.
!SUBENTRY 2 org.eclipse.epf.richtext 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.search.ui_1.2.0.v20070806-1500.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.search.ui 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.search_1.2.0.v20070824-2327.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.search 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.services_1.2.0.v20070806-1500.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.services 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.ui.intro_1.2.0.v20070829-2239/ was
not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.epf.ui_1.2.0.v20070806-1500.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.ui 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.uma.ecore_1.2.0.v20070911-1625.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.uma.ecore 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.emf.ecore.sdo_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.uma.edit_1.2.0.v20070806-1500/ was
not resolved.
!SUBENTRY 2 org.eclipse.epf.uma.edit 2 0 2007-12-10 11:25:38.234
!MESSAGE Bundle
update@plugins/org.eclipse.epf.uma_1.2.0.v20071019-1802.jar was not
resolved.
!SUBENTRY 2 org.eclipse.epf.uma 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.epf.uma.ecore_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.validation_1.2.0.v20070822-1930.jar
was not resolved.
!SUBENTRY 2 org.eclipse.epf.validation 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing required bundle org.eclipse.emf.validation_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.epf.xml.uma_1.2.0.v20070905-1712.jar was
not resolved.
!SUBENTRY 2 org.eclipse.epf.xml.uma 2 0 2007-12-10 11:25:38.234
!MESSAGE Missing imported package
org.eclipse.epf.common.serviceability_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.core_1.0.100.v20070601-1400 .jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.core 2 0 2007-12-10
11:25:38.234
11:25:38.234
org.eclipse.gmf.runtime.notation_[1.0.0,2.0.0).
11:25:38.234
org.eclipse.gmf.runtime.emf.core_[1.0.0,2.0.0).
11:25:38.234
org.eclipse.gmf.runtime.emf.type.core_[1.0.0,2.0.0).
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.actions_1.0.100.v2007062 1-0000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.actions 2 0 2007-12-10
11:25:38.234
org.eclipse.gmf.runtime.diagram.ui_[1.0.0,2.0.0).
11:25:38.234
org.eclipse.gmf.runtime.emf.commands.core_[1.0.0,2.0.0).
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.dnd_1.0.1.v20070601-1400 .jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.dnd 2 0 2007-12-10
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.geoshapes_1.0.1.v2007060 1-1400.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.geoshapes 2 0 2007-12-10
11:25:38.234
11:25:38.234
org.eclipse.gmf.runtime.diagram.ui.providers_[1.0.0,2.0.0).
11:25:38.234
org.eclipse.gmf.runtime.diagram.ui.actions_[1.0.0,2.0.0).
11:25:38.234
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.printing.render_1.0.1.v2 0070601-1400.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.printing.render 2 0
org.eclipse.gmf.runtime.diagram.ui.printing_[1.0.0,2.0.0).
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.printing_1.0.100.v200706 21-0000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.printing 2 0 2007-12-10
11:25:38.234
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.properties_1.0.100.v2007 0608-1300.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.properties 2 0 2007-12-10
11:25:38.234
11:25:38.234
org.eclipse.gmf.runtime.emf.ui_[1.0.0,2.0.0).
11:25:38.234
org.eclipse.gmf.runtime.emf.ui.properties_[1.0.0,2.0.0).
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.providers.ide_1.0.1.v200 70601-1400.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.providers.ide 2 0
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.providers_1.0.100.v20070 621-0000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.providers 2 0 2007-12-10
11:25:38.234
11:25:38.234
org.eclipse.gmf.runtime.diagram.ui.properties_[1.0.0,2.0.0).
11:25:38.234
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.render_1.0.100.v20070621 -0000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.render 2 0 2007-12-10
11:25:38.234
11:25:38.234
11:25:38.234
!MESSAGE Bundle
update@plugins /org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide_1.0 .3.v20070601-1400.jar
was not resolved.
!SUBENTRY 2 org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide 2 0
org.eclipse.gmf.runtime.diagram.ui.resources.editor_[1.0.0,2 .
Re: EPF composer [message #242660 is a reply to message #242650] Mon, 10 December 2007 14:10 Go to previous message
Better to ask on the EPF newsgroup, eclipse.technology.epf
Eric
Previous Topic:Focus in Tree Viewer
Next Topic:Column binding "xxx" has referred to a data set column "xxx" which does not exis
Current Time: Thu Jan 02 21:39:53 GMT 2025
Powered by FUDForum. Page generated in 0.07156 seconds
