Home » Archived » BIRT » Deploying a Report that use my own Data Source and Data Set
Deploying a Report that use my own Data Source and Data Set [message #242588] Wed, 13 June 2007 17:48 Go to next message
Originally posted by: kiev.gama.fpf.br
I've extended the oda.jdbc and provided a UI for it. I am able to create a
data source and a data set using my custom UIs. The data can be previewed
with no problem in design time.
However, I am not able to display the data when I deploy the report in the
report viewer.
The steps that I've followed:
1 - Jarred my two plugins (myODAExtension.jar and myODAExtensionUI.jar)
and copied to the BIRT Report Designer's plugins directory
2 - Using the above application, created my reports with no problem using
my ODA extensions. Data preview OK.
3 - Copied the myODAExtension.jar file to the plugins directory of the
WebViewer
4 - Copied my report to the deploy folder
5 - Result: Just the column names are displayed. No data at all.
If I change the extension ID's of my data set and data source to the
corresponding org.eclipse.birt.report.data.oda.jdbc extension IDs the
report works fine.
I guess I've missing something.
Any help would be welcome.
Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244336 is a reply to message #242588] Fri, 22 June 2007 11:44 Go to previous messageGo to next message
Originally posted by: andrey.gmail.com
I have faced with the same problem.
Under Eclipse all works fine, in runtime (Tomcat 5.5) - empty report and
error messages in logs
Pligin with custom ODA Runtime Driver implementation was placed in
WEB-INF/platform/plugins
Recieved exception
SEVERE: Cannot process data source extension configuration.
java.lang.IllegalArgumentException: custom.data.source.id
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getExtensionManifest(ManifestExplorer.java:163)
org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest(Driver.java:147)
org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSour ceExtensionConfig(Driver.java:123)
org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExt ensionConfig(Driver.java:78)
org.eclipse.birt.data.engine.odaconsumer.Driver.getExtension Config(Driver.java:60)
org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverHel per(Driver.java:93)
org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDr iverHelper(DriverManager.java:86)
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:136)
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:134)
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:121)
Environment - BIRT 2.2
Any advices and suggestions will be appeciated
Andrey Dulub
"Kiev Gama" <kiev.gama@fpf.br> wrote in message
news:7a5059c1780fc1a6ae03e52ff04ddabe$1@www.eclipse.org...
> report viewer.
> and copied to the BIRT Report Designer's plugins directory 2 - Using the
> above application, created my reports with no problem using my ODA
> WebViewer
> report works fine.
> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244445 is a reply to message #244336] Fri, 22 June 2007 17:10 Go to previous messageGo to next message
You seem to use BIRT 2.2. A possible reason for your exception is
because BIRT 2.2 no longer supports BIRT ODA extension point
(org.eclipse.birt.data.oda.dataSource) and supports only DTP ODA
extension point.
If your report works in Eclipse but doesn't work in runtime, you
probably have different versions of BIRT libraries or plugins in Eclipse
and Tomcat.
Snjeza
> Recieved exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Best regards,
> Andrey Dulub
>> report viewer.
>> WebViewer
>> report works fine.
>> Regards,
>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244451 is a reply to message #244445] Fri, 22 June 2007 17:54 Go to previous messageGo to next message
Thank you for attention,
I 'm not using BIRT extesion points and working with DTP ODA only.
On the Tomcat I deployed BIRT runtime from BIRT/WTP integration plugin (zip
file with BIRT runtime stored inside this plugin)
Andrey
"Snjezana Peco" <snjeza.peco@gmail.com> wrote in message
news:f5hdrh$c0b$1@build.eclipse.org...
> You seem to use BIRT 2.2. A possible reason for your exception is because
> (org.eclipse.birt.data.oda.dataSource) and supports only DTP ODA extension
> point.
> If your report works in Eclipse but doesn't work in runtime, you probably
> have different versions of BIRT libraries or plugins in Eclipse and
> Tomcat.
> Snjeza
>> Recieved exception
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Best regards,
>> Andrey Dulub
>>> Hi,
>>> a data source and a data set using my custom UIs. The data can be
>>> previewed with no problem in design time.
>>> the report viewer.
>>> WebViewer
>>> report works fine.
>>> Regards,
>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244454 is a reply to message #244451] Fri, 22 June 2007 18:33 Go to previous messageGo to next message
Check versions of plugins in your Eclipse and Tomcat.
You can see a version of a plugin within the name of the plugin's jar
file or plugin's directory.
> Andrey
>> point.
>> Tomcat.
>> Regards,
>> Snjeza
>>> Recieved exception
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Best regards,
>>> Andrey Dulub
>>>> Hi,
>>>> the report viewer.
>>>> WebViewer
>>>> report works fine.
>>>> Regards,
>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244467 is a reply to message #244454] Sat, 23 June 2007 06:09 Go to previous messageGo to next message
I'm working with BIRT 2.2 and get runtime from its WTP integration plugin.
Runtime has the same 2.2 version.
May be runtime from
eclipse\plugins\org.eclipse.birt.integration.wtp.ui_2.2.0.v2 0070413\runtime\birt.zip
doesn't contain all needed plugins ?
Where I have to place my plugin with ODA Data Source implementation ?
Andrey
news:f5hinj$9ug$1@build.eclipse.org...
> You can see a version of a plugin within the name of the plugin's jar file
>> (zip file with BIRT runtime stored inside this plugin)
>> Andrey
>>> extension point.
>>> and Tomcat.
>>> Regards,
>>> Snjeza
>>>> and error messages in logs
>>>> Recieved exception
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Best regards,
>>>> Andrey Dulub
>>>>> Hi,
>>>>> create a data source and a data set using my custom UIs. The data can
>>>>> be previewed with no problem in design time.
>>>>> the report viewer.
>>>>> myODAExtensionUI.jar) and copied to the BIRT Report Designer's plugins
>>>>> directory 2 - Using the above application, created my reports with no
>>>>> problem using my ODA extensions. Data preview OK.
>>>>> WebViewer
>>>>> report works fine.
>>>>> Regards,
>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244483 is a reply to message #244467] Sat, 23 June 2007 12:10 Go to previous messageGo to next message
I am using an RCP application that creates its own classloader. It
starts its own web server and a web application using that classloader.
Since you are using an independent web application, I suppose
that you need to place your plugin in WEB-INF/platform/plugins.
If this doesn't work, you probably have started the application the
first time without your plugin. Eclipse environment has been configured
without your plugin. Adding plugins after configuring Eclipse is
ignored. You can solve this issue in the following way:
- remove the file
WEB-INF/platform/plugins/configuration/org.eclipse.update/pl atform.xml
that contains the configuration.
- add 'osgi.clean=true' to the
WEB-INF/platform/plugins/configuration/config.ini file
You wouldn't use 'osgi.clean=true' in production environment.
Snjeza
> May be runtime from
> Andrey
>>> Andrey
>>>> extension point.
>>>> and Tomcat.
>>>> Regards,
>>>> Snjeza
>>>>> Recieved exception
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Best regards,
>>>>> Andrey Dulub
>>>>>> Hi,
>>>>>> the report viewer.
>>>>>> WebViewer
>>>>>> report works fine.
>>>>>> Regards,
>>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244593 is a reply to message #244483] Mon, 25 June 2007 10:52 Go to previous messageGo to next message
Unfortunatelly, any changes - still "java.lang.IllegalArgumentException:
custom.data.source.id"
You are rigth, my plugin doesn't available for BIRT viewer application - I
debugged BIRT vierer under Tomcat.
Andrey Dulub
news:f5jgmf$lur$1@build.eclipse.org...
>I am using an RCP application that creates its own classloader. It starts
> If this doesn't work, you probably have started the application the first
> time without your plugin. Eclipse environment has been configured without
> your plugin. Adding plugins after configuring Eclipse is ignored. You can
> - remove the file
> Snjeza
>> plugin. Runtime has the same 2.2 version.
>> May be runtime from
>> Thanks,
>> Andrey
>>>> Andrey
>>>>> extension point.
>>>>> Eclipse and Tomcat.
>>>>> Regards,
>>>>> Snjeza
>>>>>> Recieved exception
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Best regards,
>>>>>> Andrey Dulub
>>>>>>> Hi,
>>>>>>> can be previewed with no problem in design time.
>>>>>>> in the report viewer.
>>>>>>> plugins directory 2 - Using the above application, created my
>>>>>>> reports with no problem using my ODA extensions. Data preview OK.
>>>>>>> the WebViewer
>>>>>>> the report works fine.
>>>>>>> Regards,
>>>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244634 is a reply to message #244593] Mon, 25 June 2007 12:43 Go to previous messageGo to next message
Could you send the
WEB-INF/platform/plugins/configuration/org.eclipse.update/pl atform.xml file?
Snjeza
> Best regards,
> Andrey Dulub
>> - remove the file
>> Snjeza
>>> May be runtime from
>>> Thanks,
>>> Andrey
>>>>> Andrey
>>>>>> extension point.
>>>>>> Eclipse and Tomcat.
>>>>>> Regards,
>>>>>> Snjeza
>>>>>>> Recieved exception
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Best regards,
>>>>>>> Andrey Dulub
>>>>>>>> Hi,
>>>>>>>> the WebViewer
>>>>>>>> Regards,
>>>>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244653 is a reply to message #244593] Mon, 25 June 2007 14:20 Go to previous messageGo to next message
You can also look over the
WEB-INF/platform/plugins/configuration/<BIG_NUMBER>.log file and check
if your plugin has been started correctly. It is possible that your
plugin depends on other plugins that you haven't added to the configuration.
You can set
osgi.console=8089
to the config.ini file and explore the configuration using:
telnet <your_host> 8089
You will get the osgi prompt.
The 'ss' command will display installed bundles, for instance.
Snjeza
> Best regards,
> Andrey Dulub
>> - remove the file
>> Snjeza
>>> May be runtime from
>>> Thanks,
>>> Andrey
>>>>> Andrey
>>>>>> extension point.
>>>>>> Eclipse and Tomcat.
>>>>>> Regards,
>>>>>> Snjeza
>>>>>>> Recieved exception
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Best regards,
>>>>>>> Andrey Dulub
>>>>>>>> Hi,
>>>>>>>> the WebViewer
>>>>>>>> Regards,
>>>>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set [message #244774 is a reply to message #244653] Tue, 26 June 2007 02:59 Go to previous messageGo to next message
As stated before in the Thread "Deploying Custom Data Source to
ReportEngine API" my Problem seems to be quite close to this one.
Unfortunately none of your tips worked.
osgi.clean didn't help at all.
Looking at the osgi configuration via telnet I can't find my plugin.
the .log files just state that some emf bundles couldn't be installed
because of invalid activators.
That's all. Looks like it is simply ignored.
Re: Deploying a Report that use my own Data Source and Data Set [message #244786 is a reply to message #244774] Tue, 26 June 2007 03:29 Go to previous messageGo to next message
I'm sorry my fault. I found my plugin via the telnet osgi. It is marked as
installed. Trying to start it tells me it is missing a required bundle.
Which I found as marked as installed and which is also missing a required
bundle.
I'm no trying to find out which bundles are missing.
Hope to get somewhere with this.
Re: Deploying a Report that use my own Data Source and Data Set - solved [message #244791 is a reply to message #244786] Tue, 26 June 2007 03:34 Go to previous messageGo to next message
Ok now I have it all figured out.
I had to manually add eclipse.core.resources, eclipse.core.expressions and
eclipse.core.filesystem.
After that a restart also started my custom plugin and it is now available.
Hope that works for others too.
Tahnks a lot and greeting from germany
franzi
Re: Deploying a Report that use my own Data Source and Data Set [message #244821 is a reply to message #244653] Tue, 26 June 2007 06:45 Go to previous messageGo to next message
Thank you very much, Snjeza
You are exactly right - reason is unresolved dependencies.
Problem solved
Andrey
news:f5p10j$tnk$1@build.eclipse.org...
> WEB-INF/platform/plugins/configuration/<BIG_NUMBER>.log file and check if
> your plugin has been started correctly. It is possible that your plugin
> You can set
> osgi.console=8089
> Snjeza
>> I debugged BIRT vierer under Tomcat.
>> Best regards,
>> Andrey Dulub
>>> - remove the file
>>> Snjeza
>>>> May be runtime from
>>>> Thanks,
>>>> Andrey
>>>>>> plugin (zip file with BIRT runtime stored inside this plugin)
>>>>>> Andrey
>>>>>>> extension point.
>>>>>>> Eclipse and Tomcat.
>>>>>>> Regards,
>>>>>>> Snjeza
>>>>>>>> report and error messages in logs
>>>>>>>> Recieved exception
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Best regards,
>>>>>>>> Andrey Dulub
>>>>>>>>> Hi,
>>>>>>>>> report in the report viewer.
>>>>>>>>> the WebViewer
>>>>>>>>> the corresponding org.eclipse.birt.report.data.oda.jdbc extension
>>>>>>>>> IDs the report works fine.
>>>>>>>>> Regards,
>>>>>>>>> Kiev Gama
Re: Deploying a Report that use my own Data Source and Data Set - solved [message #245232 is a reply to message #244791] Wed, 27 June 2007 16:31 Go to previous message
You are welcome.
Greeting from Serbia!
> Tahnks a lot and greeting from germany franzi
Previous Topic:How to use an image as a watermark?
Next Topic:Dynamic images
Current Time: Sun Oct 26 15:16:38 EDT 2025
Powered by FUDForum. Page generated in 0.08023 seconds
