Home » Eclipse Projects » GEF » change the figure of an edit part
change the figure of an edit part [message #242571] Mon, 28 April 2008 04:54 Go to next message
Originally posted by: wirth.ase.jku.at
Hi, my GEF-based editor should get another type of view. Thus, I added
some switch-functionality to my editparts' createFigure method to create
the currect type of view, based on the current state of the model. When I
start the editor this i working just great.
I just have one problem: I want to change this state during runtime. Thus,
the editpart would need to remove its view and create another one, without
the hierarchy of the model and/or the editpart itself having changed (i.e.
just one boolean changed in the model).
Of course, this would be possible if I removed the old model-object and
created a new one. Then the parent editpart would take care of creating a
new editpart and a new view (in AbstractEditPart.refreshChildren). As i do
not change the model itself (don't add or remove anything) but just change
some variable inside one object, this is obviously not working.
I would need to tell the parent of the current editpart to recreate the
child's view. My last idea was to overwrite
AbstractEditPart.refreshChildren and add functionality to change the view,
but: "This method should not be overridden."
Is there a suggested way to do what I want?
Thanks in advance,
Christian Wirth
Re: change the figure of an edit part [message #242628 is a reply to message #242571] Tue, 29 April 2008 21:45 Go to previous message
Christian Wirth 写道:
> I start the editor this i working just great.
> Thus, the editpart would need to remove its view and create another one,
> without the hierarchy of the model and/or the editpart itself having
> changed (i.e. just one boolean changed in the model).
> a new editpart and a new view (in AbstractEditPart.refreshChildren). As
> i do not change the model itself (don't add or remove anything) but just
> change some variable inside one object, this is obviously not working.
> view, but: "This method should not be overridden."
It means, at most case:) NO problems If you ensure your childpart right
processed. ex. change ZOrder need reorder children.
> Thanks in advance, Christian Wirth
Yes, refreshChildren is an option.
And Figure self is an option too.
And refreshVisuals too, same like figure style.
Qinxian
Previous Topic:[Announce] GEF 3.4.0 I200804291800 is available
Next Topic:Newbie needs some basic info
Current Time: Fri Nov 07 00:58:30 EST 2025
Powered by FUDForum. Page generated in 0.04288 seconds
