Home » Eclipse Projects » GEF » Is there now one command framework in the platform that EMF & GEF can use?
Is there now one command framework in the platform that EMF & GEF can use? [message #242535] Thu, 24 April 2008 17:39 Go to next message
Al B is currently offline Al BFriend
Hi there,
On July 2004, Randy Hudson mentioned that there were plans to create one
command framework in the platform that EMF & GEF could use (see link
below). Did that ever happen?
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 5417.html
Thanks!
Re: Is there now one command framework in the platform that EMF & GEF can use? [message #242540 is a reply to message #242535] Thu, 24 April 2008 18:25 Go to previous messageGo to next message
AJ,
Try to avoid cross posting. If you want to query multiple newsgroups,
do so with a single posting addressed to both so that my answer on the
EMF newsgroups would have appeared here too...
AJ wrote:
> Hi there,
> one command framework in the platform that EMF & GEF could use (see
> link below). Did that ever happen?
> Thanks!
Re: Is there now one command framework in the platform that EMF & GEF can use? [message #242545 is a reply to message #242540] Thu, 24 April 2008 18:58 Go to previous messageGo to next message
Ed,
Point well taken.
However, notice that I am accessing the newsgroup(s) using a Firefox
browser so I don't think you can post to multiple newsgroups using this
interface.
Re: Is there now one command framework in the platform that EMF & GEF can use? [message #242550 is a reply to message #242545] Thu, 24 April 2008 21:07 Go to previous message
AJ,
There is, but it apparently takes some tricky editing of the newsgroup
field. The webmaster explained it to me, after I complained it wasn't
possible, and I promptly forgot. Maybe he'll see this note on the
newcomer newsgroup.
AJ wrote:
> Ed,
> Point well taken.
> this interface.
Previous Topic:Clone GEF file
Next Topic:[Announce] GEF 3.4.0 I200804241705 is available
Current Time: Thu Jan 02 21:56:46 GMT 2025
Powered by FUDForum. Page generated in 0.04098 seconds
