Home » Language IDEs » PHP Development Tools (PDT) » running the builder/scanner depending on system load
running the builder/scanner depending on system load [message #23736] Sun, 27 May 2007 22:24 Go to next message
Originally posted by: alex_foe.yahoo.de
hi,
is it possible to set a "system-load-limit" to the builder, scanner? -
To run in "really" in background?
The process core should watch the system load and keep the crawling in
idle as long as the system load is above a nominal value. Can I define
this value somewhere.
Or if there is no known way: - can I have some directions, where to
start, if I'd like to do sth. by my own? - Where can I find the crawler
any developer-docs about the builder? (I'm quite new to eclipse, so I
don't really know where to start whit this...)
BTW: (some more rookie questions)
Is there a way, to load all "opened docs" by re-starting the editor? -
And what about the positions of the view-settings? - Where to start, if
I'd like to change the initial positions? - Any extensions to have sth.
like an application-session?
many tnx
Re: running the builder/scanner depending on system load [message #23863 is a reply to message #23736] Mon, 28 May 2007 08:34 Go to previous message
Michael Spector is currently offline Michael SpectorFriend
"Alexander F
Previous Topic:No build of projects (no outline, no completion, no ctrl+click)
Next Topic:debug as a web page
Current Time: Thu Dec 26 10:52:27 GMT 2024
Powered by FUDForum. Page generated in 0.03736 seconds
