Re: SML, EMF, etc. [message #2077 is a reply to message #2036] |
Fri, 27 October 2006 21:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Brian Vetter![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bvetter%40alterpoint.com) Messages: 74 Registered: July 2009 |
Member |
Valentina Popescu wrote:
> As a short answer to your EMF question, yes, I think we should use EMF to
> model the SML, SML IF editors.
> We may actually want to use GEF, GMF to build a more complex editor but
I agree with using these as well. The Callisto XSD editor is a good
starting point. Considering the aggressive goals and time line outlined
in the COSMOS proposal, greatly leveraging other project and frameworks
is not just desirable, it is a must. If suspect you are already "there",
but perhaps not everyone else is.
> these are implementation details we can tackle after the high level usecase
> is defined. We also need to consider project schedule and delivery
> priorities versus available resource before we can answer to all these
> questions.
I guess I'm of the impatient sort. SML needs to have parser/validators,
graphical editors, etc. The first set of tools seem obvious. Hopefully,
we can push the use cases through quickly.
However, the real questions on how to map models to either inform or
direct the data collection/aggregation framework (and any persistence
and presentation of said data) will not be as obvious and will likely
result in some lively conversations.
> For the Monday's meeting I will come prepared with a first draft document of
> an SML-IF editor. It will be just a high level use-case but we can go over
> possible implementations.
I look forward to reading and reviewing on the call Monday. Thanks for
taking the organizing role.
Brian
Re: SML, EMF, etc. [message #567338 is a reply to message #2036] |
Member |
> questions.
Brian
FUDForum. Page generated in 0.04074 seconds
