Home » Eclipse Projects » DSDP - Target Management » Difference between dstore and ssh connection
Re: Difference between dstore and ssh connection [message #23760 is a reply to message #23672] |
Fri, 30 May 2008 13:58 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
dstore requires a java-based server to run on the Remote,
whereas ssh requires a (smaller, less resource intensive)
native server, the sshd. This makes ssh an option for
embedded devices as well.
In terms of features, dstore allows
* Remote archive handling (browsing into tar,tgz,zip)
* Remote search (without transferring all files)
* More exact classification of files by type
dstore can be extended by more (Java based) miners to
perform specific advanced remote operations with
minimal network transfer.
ssh is a standards based solution, is available on most
servers out of the box, but provides fewer features.
Does that help?
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Axel Mueller wrote:
> what is the difference between dstore and ssh connection? What
> additional features does the dstore server provide?
> Axel
Re: Difference between dstore and ssh connection [message #23844 is a reply to message #23760] |
Fri, 30 May 2008 14:24 |
Axel Mueller Messages: 1973 Registered: July 2009 |
Thanks for your response.
Axel
> Does that help?
> Cheers,
> Axel Mueller wrote:
>> Axel
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Difference between dstore and ssh connection [message #575109 is a reply to message #23672] |
Does that help?
Axel Mueller wrote:
> Axel
Re: Difference between dstore and ssh connection [message #575145 is a reply to message #23760] |
Axel
> Does that help?
> Cheers,
> Axel Mueller wrote:
>> Axel
Before you ask
- search this forum
- google
Current Time: Sat Oct 19 17:11:53 GMT 2024
Powered by FUDForum. Page generated in 0.03900 seconds
