Re: [pdebuild] exploding plugins [message #3268 is a reply to message #2014] |
Wed, 14 May 2008 21:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrew Niefer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aniefer%40gmail.com) Messages: 990 Registered: July 2009 |
Paul,
The bundle will need to be exploded for compilation to work, but that is
independent of the resolution errors you are getting.
The few import package statements I looked at all appear to also be
exported from that bundle. So I would guess that they aren't the
problem and they would have resolved to itself if everything else was fine.
The interesting bit is probably:
>[java] [eclipse.generateFeature] Bundle org.apache.xerces:
>[java] [eclipse.generateFeature] Missing required plug-in
>org.apache.xml.resolver_0.0.0.
-Andrew
Paul Gardiner wrote:
> We use pdebuild product build to create a couple of products. Recently, I
> added the knopflerfish axis2 bundle into the build (into my product config
> file), and it's having issues. Basically, it says that a bunch of
> dependencies are missing, although they are not.
> The axis2 bundle contains a bunch of other jars inside it. I tried
> exploding it, but that didn't work either. It works fine in the ide, but
> not from pdebuild. Any ideas what it might be?
> I attached the manifest from the axis2 bundle
> Paul
> (Snippet from ant output)
> [java]
> [java] generateFeature:
> [java]
> [java] fetch:
> [java]
> [java] [eclipse.generateFeature] Some inter-plug-in dependencies have
> not been satisfied.
> org.knopflerfish.bundle.axis2-osgi:
> [java] [eclipse.generateFeature] Unsatisfied import package
> org.knopflerfish.service.axis2_0.0.0.
> org.apache.xerces.jaxp_0.0.0.
> edu.emory.mathcs.backport.java.util_0.0.0.
> edu.emory.mathcs.backport.java.util.concurrent_0.0.0.
> edu.emory.mathcs.backport.java.util.concurrent.atomic_0.0.0.
> edu.emory.mathcs.backport.java.util.concurrent.helpers_0.0.0 .
> edu.emory.mathcs.backport.java.util.concurrent.locks_0.0.0.
> javax.mail_0.0.0.
> javax.mail.event_0.0.0.
> javax.mail.internet_0.0.0.
> javax.mail.search_0.0.0.
> javax.mail.util_0.0.0.
> javax.wsdl.extensions_0.0.0.
> javax.wsdl.extensions.http_0.0.0.
> javax.wsdl.extensions.mime_0.0.0.
> javax.wsdl.extensions.schema_0.0.0.
> javax.wsdl.extensions.soap_0.0.0.
> javax.wsdl.extensions.soap12_0.0.0.
> javax.wsdl.factory_0.0.0.
> javax.wsdl.xml_0.0.0.
> org.apache.axiom.attachments_0.0.0.
> org.apache.axiom.attachments.utils_0.0.0.
> org.apache.axiom.om_0.0.0.
> org.apache.axiom.om.impl.llom_0.0.0.
> org.apache.axiom.om.util_0.0.0.
> org.apache.axiom.om.xpath_0.0.0.
> org.apache.axiom.soap_0.0.0.
> org.apache.axis2_0.0.0.
> org.apache.axis2.addressing_0.0.0.
> org.apache.axis2.client_0.0.0.
> org.apache.axis2.client.async_0.0.0.
> org.apache.axis2.context_0.0.0.
> org.apache.axis2.databinding_0.0.0.
> org.apache.axis2.databinding.i18n_0.0.0.
> org.apache.axis2.databinding.typemapping_0.0.0.
> org.apache.axis2.databinding.types_0.0.0.
> org.apache.axis2.databinding.utils_0.0.0.
> org.apache.axis2.databinding.utils.reader_0.0.0.
> org.apache.axis2.databinding.utils.writer_0.0.0.
> org.apache.axis2.description_0.0.0.
> org.apache.axis2.engine_0.0.0.
> org.apache.axis2.rpc.receivers_0.0.0.
> org.apache.axis2.rpc.receivers.ejb_0.0.0.
> org.apache.axis2.transport_0.0.0.
> org.apache.axis2.transport.http_0.0.0.
> org.apache.axis2.transport.local_0.0.0.
> org.apache.axis2.transport.mail_0.0.0.
> org.apache.axis2.transport.nhttp_0.0.0.
> org.apache.axis2.transport.tcp_0.0.0.
> org.apache.axis2.util_0.0.0.
> org.apache.commons.fileupload_0.0.0.
> org.apache.commons.fileupload.disk_0.0.0.
> org.apache.commons.fileupload.portlet_0.0.0.
> org.apache.commons.fileupload.servlet_0.0.0.
> org.apache.neethi_0.0.0.
> org.apache.neethi.builders_0.0.0.
> org.apache.neethi.builders.xml_0.0.0.
> org.apache.neethi.util_0.0.0.
> org.apache.xerces.parsers_0.0.0.
> org.apache.xml.serialize_0.0.0.
> org.apache.ws.commons.schema_0.0.0.
> org.apache.ws.commons.schema.constants_0.0.0.
> org.apache.ws.commons.schema.extensions_0.0.0.
> org.apache.ws.commons.schema.resolver_0.0.0.
> org.apache.ws.commons.schema.utils_0.0.0.
> org.codehaus.annogen.generate_0.0.0.
> org.codehaus.annogen.override_0.0.0.
> org.codehaus.annogen.view_0.0.0.
> org.codehaus.jam_0.0.0.
> org.codehaus.jam.annotation_0.0.0.
> [java] [java] [eclipse.generateFeature] Unsatisfied import
> package org.codehaus.jam.mutable_0.0.0.
> [java] BUILD FAILED
> org.codehaus.jam.provider_0.0.0.
> [java]
> c:\eclipse\plugins\org.eclipse.pde.build_3.3.2.v20071019\scr ipts\productBuild\productBuild.xml:24:
> The following error occurred while executing this line:
> org.codehaus.jam.visitor_0.0.0.
> [java]
> c:\eclipse\plugins\org.eclipse.pde.build_3.3.2.v20071019\scr ipts\productBuild\productBuild.xml:51:
> Unable to find plug-in: org.apache.xerces. Please check the error log for
> more details.
> org.codehaus.
> jam.xml_0.0.0.
> [java]
> [java] Total time: 1 second
Re: [pdebuild] exploding plugins [message #3367 is a reply to message #3268] |
Fri, 16 May 2008 14:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Paul Gardiner![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pgardiner%40syntellect.com) Messages: 94 Registered: July 2009 |
Member |
Thanks. I figured it out a couple of weeks ago, and it turned out to be the
file name of the bundle. Once I changed the bundle's file name to match the
bundle name, it worked fine.
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:482B608C.8060700@ca.ibm.com...
> Paul,
> exported from that bundle. So I would guess that they aren't the problem
> -Andrew
>> I added the knopflerfish axis2 bundle into the build (into my product
>> config file), and it's having issues. Basically, it says that a bunch of
>> Thanks,
>> Paul
>> [java]
>> [java]
>> [java] fetch:
>> [java]
>> have not been satisfied.
>> javax.mail_0.0.0.
>> [java] BUILD FAILED
>> [java]
>> [java]
>> more details.
>> org.codehaus.
>> jam.xml_0.0.0.
>> [java]
Re: [pdebuild] exploding plugins [message #566840 is a reply to message #2014] |
Wed, 14 May 2008 21:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Paul,
-Andrew
> Paul
> [java]
> [java]
> [java] fetch:
> [java]
> not been satisfied.
> javax.mail_0.0.0.
> [java] BUILD FAILED
> [java]
> [java]
> more details.
> org.codehaus.
> jam.xml_0.0.0.
> [java]
Re: [pdebuild] exploding plugins [message #566885 is a reply to message #3268] |
Member |
> Paul,
> -Andrew
>> Thanks,
>> Paul
>> [java]
>> [java]
>> [java] fetch:
>> [java]
>> javax.mail_0.0.0.
>> [java] BUILD FAILED
>> [java]
>> [java]
>> more details.
>> org.codehaus.
>> jam.xml_0.0.0.
>> [java]
FUDForum. Page generated in 0.04073 seconds
