Sun Communcation API installation under Eclipse and use ? [message #240694] |
Wed, 12 May 2004 08:34 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fb.idylic.com
I have to use the Comm API from Sun to connect to my serial port. I am
under Windows and so I have to install a dll (win32comm.dll) into the
jdk_dir\bin\ directory but when I write a program under Eclispe using the
Comm API and I run it under Eclipse, it doesn't work ! no port found !
because I think the win32com.dll is not a the right place or must be
linked to my project but how ??
Help me !
Thanks in advance !
Best regards
François
Re: Sun Communcation API installation under Eclipse and use ? [message #240884 is a reply to message #240694] |
Wed, 12 May 2004 15:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
/François Breuiller/:
IIRC, you should copy the .dll to <jdk_home>/jre/bin/ or you may try
to copy it to a more common location like %windir%\System32.
Stanimir
FUDForum. Page generated in 0.03547 seconds
