Home » Language IDEs » Java Development Tools (JDT) » unavailable local variables when debugging
unavailable local variables when debugging [message #23596] Wed, 14 May 2003 15:34 Go to next message
Originally posted by: dweiler-thiessen.purina.com
I am trying to debug some code, and am stepping into some javax.swing
classes, and I get the [local variables unavailable] message next to the
stack frame when I select it.
Is there someway to see local variables when debugging through these types
of classes?
Re: unavailable local variables when debugging [message #23639 is a reply to message #23596] Wed, 14 May 2003 15:38 Go to previous messageGo to next message
Basically no. The standard jvm rt.jar's are compiled without local
variables. And without that turned on you don't get local variables.
Rich Kulp
Re: unavailable local variables when debugging (build file that generates the full debug info) [message #24174 is a reply to message #23596] Thu, 15 May 2003 05:53 Go to previous messageGo to next message
Here my build file for recompiling rt.jar.
set this xml script in youre JDK dir and run it with ANT.
Then you will have a rt.jar with full debug info.
johan
P.S. I also want to thank Greg Rishea for improving this file!
"David Weiler-Thiessen" <dweiler-thiessen@purina.com> wrote in message news:b9u5nj$n7d$1@rogue.oti.com...
> Hi
> of classes?
  • Attachment: rt_build.xml
    (Size: 3.20KB, Downloaded 264 times)
Re: unavailable local variables when debugging (build file that generates the full debug info) [message #24993 is a reply to message #24174] Thu, 15 May 2003 13:12 Go to previous message
> johan
Hi Johan
Thx for that information. I actually, did it manually, based on the
information provided by Robert.
At least now, I know that what I did works, as others have done it also.
Dave
Previous Topic:Error while performing Extract Interface refactoring
Next Topic:prevent build/selective builds
Current Time: Tue Dec 02 12:57:32 EST 2025
Powered by FUDForum. Page generated in 0.03621 seconds
