Home » Archived » BPMN Modeler » ReadOnly Diagram
ReadOnly Diagram [message #2006] Wed, 15 October 2008 06:01 Go to next message
Hi everybody ,
i'm displaying a diagram (using DiagramInputDocumentProvider as document
provider and DiagramEditorInput as editor input) .
My problem is that it's a readonly diagram : it seems like the diagram has
not a corresponding EMF Model to synchronise with.
I tried to override isReadOnly() and isModifiable() methods but :((.
When i'm trying to move shapes or edit labels nothing is shown on the
console log.
Should i use a BpmnDiagram in the place of the Diagram Type ??
Best Regards ,
Dali.
Re: ReadOnly Diagram [message #2024 is a reply to message #2006] Wed, 15 October 2008 09:28 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Dali,
the BpmnDiagram is the semantic element while the Diagram object is the
graphical element. You can access the BpmnDiagram object by doing
diagram.getElement();
I can't help much more on this issue, you'll need to investigate your
code to see what's going wrong.
Antoine
Dali wrote:
> Hi everybody ,
> has not a corresponding EMF Model to synchronise with.
> console log.
> Best Regards ,
> Dali.
Re: ReadOnly Diagram [message #2037 is a reply to message #2024] Thu, 16 October 2008 11:12 Go to previous messageGo to next message
Hi Antoine ,
I think that the problem is due to the usage of diagrameditorinput .
Infact it brings a readonly image of the diagram.
I think that i should create a file based on my generating diagram and
open my editor on a file input.
How can i achieve this , is there any methods that should be called by the
Modeler API.
Best Regards ,
Dali
Re: ReadOnly Diagram [message #2050 is a reply to message #2037] Thu, 16 October 2008 12:52 Go to previous message
Dali, look at how to save files with EMF.
Antoine
Dali wrote:
> Hi Antoine ,
> the Modeler API.
> Best Regards ,
> Dali
Previous Topic:connecting object
Next Topic:Change the sequenceEdge look
Current Time: Mon Apr 28 23:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.09142 seconds
