Re: Errors starting BIRT Runtime Engine [message #239413 is a reply to message #239220] |
Tue, 22 May 2007 19:28 |
Earl,
What version of BIRT are you using?
2.2 RC0 should be out in a day or two.
Jason
Earl Bennett wrote:
> I have found the following errors in a log file in the
> ReportEngine/Configuration directory.
> !ENTRY org.eclipse.update.configurator 2007-05-22 09:04:33.735
> !MESSAGE Could not install bundle
> update@plugins/org.eclipse.emf.common_2.2.1.v200702131851.jar The
> activator org.eclipse.emf.common.CommonPlugin$Implementation for bundle
> org.eclipse.emf.common is invalid
> update@plugins/org.eclipse.emf.ecore.xmi_2.2.2.v200702131851.jar The
> activator org.eclipse.emf.ecore.xmi.XMIPlugin$Implementation for bundle
> org.eclipse.emf.ecore.xmi is invalid
> update@plugins/org.eclipse.emf.ecore_2.2.2.v200702131851.jar The
> activator org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation for
> bundle org.eclipse.emf.ecore is invalid
> I also am no longer able to generate PDF reports, although HTML reports
> work OK.
> Are these related? Do I need to be concerned about these errors?
> Earl
Re: Errors starting BIRT Runtime Engine [message #239592 is a reply to message #239556] |
Wed, 23 May 2007 14:39 |
Earl,
I believe these are known. What version of the iText lib did you copy
into the runtime?
Jason
Earl Bennett wrote:
> Jason,
> Sorry.. I should have been more specific.. I'm using 2.2M6.
> Earl
FUDForum. Page generated in 0.03059 seconds
