Home » Eclipse Projects » Eclipse Platform » Effects of activities on help in M8
Effects of activities on help in M8 [message #238948] Wed, 05 May 2004 17:42 Go to next message
No real name is currently offline No real nameFriend
This is a multipart message in MIME format.
--=_alternative 00623E1D85256E8B_=
Content-Type: text/plain; charset="US-ASCII"
I'm trying to figure out what effect activities have on the help in M8 and
haven't had much luck finding information on this. I have been able to
locate some information regarding the use of activities - but not specific
to the help system. Can anyone provide any insight on this or direct me to
an appropriate source of information?
Basically, I'm trying to figure out how help that is related to a specific
activity (eg. Debugging) can be filtered. Is it filtered at the book
level, so that only books that contain information related to enabled
activities appear in the online help? If this is the case, how can this be
accomplished?
Thanks for your help.
Colleen
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi,</font>
<br>
<br><font size=2 face="sans-serif">I'm trying to figure out what effect
activities have on the help in M8 and haven't had much luck finding information
on this. I have been able to locate some information regarding the use
of activities - but not specific to the help system. Can anyone provide
any insight on this or direct me to an appropriate source of information?</font>
<br>
<br><font size=2 face="sans-serif">Basically, I'm trying to figure out
how help that is related to a specific activity (eg. Debugging) can be
filtered. Is it filtered at the book level, so that only books that contain
information related to enabled activities appear in the online help? If
this is the case, how can this be accomplished?</font>
<br>
<br><font size=2 face="sans-serif">Thanks for your help.</font>
<br><font size=2 face="sans-serif">Colleen</font>
--=_alternative 00623E1D85256E8B_=--
Re: Effects of activities on help in M8 [message #239103 is a reply to message #238948] Thu, 06 May 2004 02:37 Go to previous messageGo to next message
Konrad Kolosowski is currently offline Konrad KolosowskiFriend
------=_NextPart_000_0057_01C432F1.82F7C6C0
charset="iso-8859-1"
A plugin, but typically main product plugin defines Eclipse activities =
as in =
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/acti=
vities/activities.html
where in expression=20
identifier :=3D plugin-identifier + "/" + local-identifier=20
local-identifier in help context is a name of the TOC file. For example =
pattern=3D"org\.eclipse\.platform\.doc\.isv/topics_Samples\.xml "> =
corresponds to examples subtree in Platform Developers Guide book. If =
the activity for which this pattern is defined in product plugin.xml is =
disabled, the topics from topic_Samples.xml are missing from the tree.
Identifiers for activity mapping are regular expressions so another =
example pattern=3D"org\.eclipse\.platform\.doc\.isv.*" will match =
anything in this plug-in effectively filtering all TOCs from this =
plug-in. More elaborate expressions can be created.
Konrad
<acolleen@ca.ibm.com> wrote in message =
news:c7b92c$njl$1@eclipse.org...
Hi,=20
I'm trying to figure out what effect activities have on the help in M8 =
and haven't had much luck finding information on this. I have been able =
to locate some information regarding the use of activities - but not =
specific to the help system. Can anyone provide any insight on this or =
direct me to an appropriate source of information?=20
Basically, I'm trying to figure out how help that is related to a =
specific activity (eg. Debugging) can be filtered. Is it filtered at the =
book level, so that only books that contain information related to =
enabled activities appear in the online help? If this is the case, how =
can this be accomplished?=20
Thanks for your help.=20
Colleen
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>A plugin, but typically main product =
plugin defines=20
Eclipse activities as in <A=20
href=3D" http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-h=
ome/activities/activities.html">http://dev.eclipse.org/viewcvs/index.cgi/=
~checkout~/platform-ui-home/activities/activities.html</A><BR >where=20
in expression <BR>identifier :=3D plugin-identifier + "/" + =
local-identifier=20
<BR>local-identifier in help context is a name of the TOC file.&nbsp; =
For=20
example =
pattern=3D"org\.eclipse\.platform\.doc\.isv/topics_Samples\.xml "&gt;=20
corresponds to examples subtree in Platform Developers Guide book.&nbsp; =
If the=20
disabled,=20
the topics from topic_Samples.xml are missing from the =
tree.<BR>Identifiers for=20
activity mapping are regular expressions so another example&nbsp;=20
pattern=3D"org\.eclipse\.platform\.doc\.isv.*" will match anything in =
this plug-in=20
effectively filtering all TOCs from this plug-in.&nbsp; More elaborate=20
expressions can be created.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Konrad</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A =
href=3D"mailto:acolleen@ca.ibm.com">acolleen@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:c7b92c$njl$1@eclipse.org">news:c7b92c$njl$1@eclipse.org</A>.=
...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi,</FONT> <BR><BR><FONT face=3Dsans-serif =
size=3D2>I'm=20
trying to figure out what effect activities have on the help in M8 and =
haven't=20
had much luck finding information on this. I have been able to locate =
some=20
information regarding the use of activities - but not specific to the =
help=20
system. Can anyone provide any insight on this or direct me to an =
appropriate=20
source of information?</FONT> <BR><BR><FONT face=3Dsans-serif =
size=3D2>Basically,=20
I'm trying to figure out how help that is related to a specific =
activity (eg.=20
Debugging) can be filtered. Is it filtered at the book level, so that =
only=20
books that contain information related to enabled activities appear in =
the=20
online help? If this is the case, how can this be accomplished?</FONT> =
<BR><BR><FONT face=3Dsans-serif size=3D2>Thanks for your help.</FONT> =
<BR><FONT=20
face=3Dsans-serif size=3D2>Colleen</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0057_01C432F1.82F7C6C0--
Re: Effects of activities on help in M8 [message #239232 is a reply to message #239103] Thu, 06 May 2004 15:09 Go to previous messageGo to next message
--=_alternative 00542DF785256E8C_=
Thanks for the information - I have been able to get this to work in M8
using the name of a TOC file as the local identifier.
I have one further question...can I use activities to filter at a lower
level than the TOC file? For example, I have a TOC file called
toc_Reference.xml that contributes a book called "Reference" to the help
system. This book contains a variety of parent topics, including a top
level "Debugger" topic. When I have the Debugging activity enabled, I want
this "Debugger" topic (and its children) to appear; when the Debugging
activity is disabled, I don't want this topic (and its children) to appear
within the Reference book in the help.
Is there any way using activities that I can control filtering at this
level?
Thanks again for your help.
Colleen
<br><font size=2 face="sans-serif">Thanks for the information - I have
been able to get this to work in M8 using the name of a TOC file as the
local identifier. </font>
<br>
<br><font size=2 face="sans-serif">I have one further question...can I
use activities to filter at a lower level than the TOC file? For example,
I have a TOC file called toc_Reference.xml that contributes a book called
&quot;Reference&quot; to the help system. This book contains a variety
of parent topics, including a top level &quot;Debugger&quot; topic. When
I have the Debugging activity enabled, I want this &quot;Debugger&quot;
topic (and its children) to appear; when the Debugging activity is disabled,
I don't want this topic (and its children) to appear within the Reference
book in the help.</font>
<br>
<br><font size=2 face="sans-serif">Is there any way using activities that
I can control filtering at this level?</font>
<br>
<br><font size=2 face="sans-serif">Thanks again for your help.</font>
<br><font size=2 face="sans-serif">Colleen </font>
--=_alternative 00542DF785256E8C_=--
Re: Effects of activities on help in M8 [message #239311 is a reply to message #239232] Thu, 06 May 2004 19:07 Go to previous message
------=_NextPart_000_0018_01C4337B.D981E860
Books can be built from multiple TOCs. The solution is to group =
debugger topics into their own TOC file. Your toc_Reference.xml can =
contain anchor or link to toc_debugger.xml and toc_debugger.xml can be =
mapped to a Debugger activity. This way the Reference book will stay =
visible, but its Debugger part will be filtered out.
Konrad
news:c7dkeb$eng$1@eclipse.org...
Thanks for the information - I have been able to get this to work in =
M8 using the name of a TOC file as the local identifier.=20
I have one further question...can I use activities to filter at a =
lower level than the TOC file? For example, I have a TOC file called =
toc_Reference.xml that contributes a book called "Reference" to the help =
system. This book contains a variety of parent topics, including a top =
level "Debugger" topic. When I have the Debugging activity enabled, I =
want this "Debugger" topic (and its children) to appear; when the =
Debugging activity is disabled, I don't want this topic (and its =
children) to appear within the Reference book in the help.=20
Is there any way using activities that I can control filtering at this =
level?=20
Thanks again for your help.=20
Colleen
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Books can be built from multiple =
TOCs.&nbsp; The=20
solution is to group debugger topics into&nbsp;their own TOC file.&nbsp; =
Your=20
toc_Reference.xml&nbsp;can contain anchor or link to toc_debugger.xml =
and=20
toc_debugger.xml can be mapped to a Debugger activity.&nbsp; This way =
the=20
Reference book will stay visible, but its Debugger part will be filtered =
out.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A =
href=3D"news:c7dkeb$eng$1@eclipse.org">news:c7dkeb$eng$1@eclipse.org</A>.=
face=3Dsans-serif size=3D2>Thanks for the information - I have been =
able to get=20
this to work in M8 using the name of a TOC file as the local =
identifier.=20
</FONT><BR><BR><FONT face=3Dsans-serif size=3D2>I have one further =
question...can=20
I use activities to filter at a lower level than the TOC file? For =
example, I=20
have a TOC file called toc_Reference.xml that contributes a book =
called=20
"Reference" to the help system. This book contains a variety of parent =
topics,=20
including a top level "Debugger" topic. When I have the Debugging =
activity=20
enabled, I want this "Debugger" topic (and its children) to appear; =
when the=20
children) to=20
appear within the Reference book in the help.</FONT> <BR><BR><FONT=20
face=3Dsans-serif size=3D2>Is there any way using activities that I =
can control=20
filtering at this level?</FONT> <BR><BR><FONT face=3Dsans-serif =
size=3D2>Thanks=20
again for your help.</FONT> <BR><FONT face=3Dsans-serif =
size=3D2>Colleen=20
------=_NextPart_000_0018_01C4337B.D981E860--
Previous Topic:Re: Problems recompiling downloaded plugins
Next Topic:fixFocus and Tree widget causing view activation issues
Current Time: Mon Nov 04 19:27:18 GMT 2024
Powered by FUDForum. Page generated in 0.03753 seconds
