Home » Modeling » Epsilon » [EuGENia] Node label from attribute of contained class
[EuGENia] Node label from attribute of contained class [message #23406] |
Sun, 26 July 2009 06:59  |
Below is the snippet from the .emf file. The output of the below code
resembles to the UML Object diagram where ObjectTemplateExp is Object
and PropertyTemplateExp is the attribute in the object.
I want to fetch the value of attr "name" from VariableExp class and show
it as a label for ObjectTemplateExp node. Also, want to fetch the name
of the referred class so that the label pattern looks like "variable :
(name of referredClass)"
Same for the label of PropertyTemplateExp "(name of referredProperty) =
value"
Any help/pointers to help will be highly appreciated.
code:
@gmf.node(label="variable.name")
class ObjectTemplateExp extends ExtendedOclExp {
val VariableExp variable;
@gmf.compartment(layout="list", collapsible="false")
val PropertyTemplateExp[*] propertyTemplates;
ref EClass referredClass;
@gmf.node(label="name", label.icon="false", figure="rectangle")
class PropertyTemplateExp {
val ExtendedExp value;
@gmf.link(target.decoration="arrow")
ref ecore.EStructuralFeature referredProperty;
class VariableExp {
!unique !ordered attr String name;
Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23534 is a reply to message #23406] |
Sun, 26 July 2009 07:24   |
Hi Mihir,
In this case, you'd have to add a new derived volatile and transient
attribute, and set it as the label of your ObjectTemplateExp like this:
@gmf.node(label="label")
derived transient volatile attr String label;
When you generate the EMF code, you'll need to go into the generated
ObjectTemplateExpImpl.getLabel() method, turn it to @generated NOT and
make it return variable.name (instead of throwing an unsupported
operation exception).
Dimitris
Mihir wrote:
> Hello,
> value"
> code:
> class VariableExp {
> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23576 is a reply to message #23449] |
Sun, 26 July 2009 07:27   |
Hi Mihir,
I'm not sure I understand this :( Do you need links to be automatically
created between unlinked objects when a certain condition is satisfied?
Dimitris
Mihir wrote:
> Just to add further to my last post. I also want a simple reference link
> to link a instance of ObjectTemplateExp to the other instance of
> ObjectTemplateExp if the type of the referredProperty (in instance of
> PropertyTemplateExp) is of type EReference.
> Hope this all makes sense.
> Mihir
> Mihir wrote:
>> Hello,
>> show it as a label for ObjectTemplateExp node. Also, want to fetch the
>> name of the referred class so that the label pattern looks like
>> "variable : (name of referredClass)"
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23662 is a reply to message #23534] |
Sun, 26 July 2009 07:41   |
Hello Dimitris,
Many thanks for your quick reply. I'll try and implement this and get
back to you soon. I don't if it is a feasible question but can we make
it work without adding that extra derived transient volatile attribute??
Because, the thing is I don't want to make any changes in the metamodel.
I'll still try your this suggested technique.
Mihir
Dimitris Kolovos wrote:
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23704 is a reply to message #23576] |
Sun, 26 July 2009 07:45   |
Hi Dimitris,
Thanks for you quick reply. I was meant to add the link manually from
tools palette. But, it would be great to achieve your idea as well.. ;)
Awaiting for your input. :)
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
>> link to link a instance of ObjectTemplateExp to the other
>> instance of ObjectTemplateExp if the type of the referredProperty (in
>> instance of PropertyTemplateExp) is of type EReference.
>> Thanks,
>> Mihir
>> Mihir wrote:
>>> Hello,
>>> the name of the referred class so that the label pattern looks like
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23785 is a reply to message #23704] |
Sun, 26 July 2009 07:52   |
Hi Mihir,
Mihir wrote:
> Hi Dimitris,
> tools palette.
So you actually want to prevent users from creating a link between the
two objects if the condition is not satisfied. I know that this is
possible using OCL but to be honest, I haven't ever played with this
feature. I'll look into this in the next few days and get back to you.
If by any chance you manage to make any progress with this before I do,
it'd be great if you could report back with the solution you've found.
It should be possible to do this in a batch mode using EWL. See
http://www.eclipse.org/gmt/epsilon/doc/ewl
and the example in
http://www.eclipse.org/gmt/epsilon/cinema/#GMFWizards2
for more details.
> Mihir
Dimitris
>> Hi Mihir,
>> automatically created between unlinked objects when a certain
>> Cheers,
>> Dimitris
>>> Thanks,
>>> Mihir
>>> Mihir wrote:
>>>> Hello,
>>>> code resembles to the UML Object diagram where ObjectTemplateExp is
>>>> Object and PropertyTemplateExp is the attribute in the object.
>>>> referredProperty) = value"
>>>> code:
>>>> class VariableExp {
>>>> Thanks,
>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23828 is a reply to message #23662] |
Sun, 26 July 2009 07:54   |
Hi Mihir,
I don't know if it is possible to do this without adding that extra
attribute. Another question for the GMF newsgroup it seems ;)
Dimitris
Mihir wrote:
> Hello Dimitris,
> Mihir
>> Hi Mihir,
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello,
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23868 is a reply to message #23785] |
Sun, 26 July 2009 08:11   |
OK Dimitris,
I'm looking at the links sent by you. And I'll update you if I found
anything.
Meanwhile, I've this 1 stupid question. It is related to GMF but, still
asking if you know any solution for this. The description of question is
once I've generated all the codes for the editor and tested it. Then, I
update the definition in .emf file and generate all the required codes.
Now if I've removed anything from the .emf ( for example I remove a link
annotation) and then generate the code I get error in the generated
code. If I delete all the code and regenerate it, it works fine. Just
wondering if you have any solution for this.
Mihir
> Hi Mihir,
> Mihir wrote:
>> Hi Dimitris,
>> tools palette.
> and the example in
> for more details.
>> Thanks,
>> Mihir
> Cheers,
> Dimitris
>>> Hi Mihir,
>>> Cheers,
>>> Dimitris
>>>> (in instance of PropertyTemplateExp) is of type EReference.
>>>> Thanks,
>>>> Mihir
>>>> Mihir wrote:
>>>>> Hello,
>>>>> code:
>>>>> class VariableExp {
>>>>> Thanks,
>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23909 is a reply to message #23868] |
Sun, 26 July 2009 08:16   |
Hi Mihir,
This is reasonable as the generator doesn't attempt to delete files that
it generated in a previous run but are not necessary any more.
Dimitris
Mihir wrote:
> OK Dimitris,
> anything.
> Cheers,
> Mihir
>> Hi Mihir,
>> Mihir wrote:
>>> Hi Dimitris,
>>> tools palette.
>> do, it'd be great if you could report back with the solution you've
>> found.
>> and the example in
>> for more details.
>>> Thanks,
>>> Mihir
>> Cheers,
>> Dimitris
>>>> Hi Mihir,
>>>> Cheers,
>>>> Dimitris
>>>>> Thanks,
>>>>> Mihir
>>>>> Mihir wrote:
>>>>>> Hello,
>>>>>> is Object and PropertyTemplateExp is the attribute in the object.
>>>>>> and show it as a label for ObjectTemplateExp node. Also, want to
>>>>>> fetch the name of the referred class so that the label pattern
>>>>>> looks like "variable : (name of referredClass)"
>>>>>> code:
>>>>>> class VariableExp {
>>>>>> Thanks,
>>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23949 is a reply to message #23909] |
Sun, 26 July 2009 08:23   |
So I'll have to delete the generated code before generating new code.
I'll have to keep track if I've made any changes in the generated code
and make those changes again. Arghhh!!
Anyways thanks a million for your quick response. I'm newbie in this
group and even to the GMF stuffs.
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> OK Dimitris,
>> anything.
>> still asking if you know any solution for this. The description of
>> question is once I've generated all the codes for the editor and
>> tested it. Then, I update the definition in .emf file and generate all
>> the required codes. Now if I've removed anything from the .emf ( for
>> example I remove a link annotation) and then generate the code I get
>> error in the generated code. If I delete all the code and regenerate
>> it, it works fine. Just wondering if you have any solution for this.
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> Mihir wrote:
>>>> Hi Dimitris,
>>>> from tools palette.
>>> the two objects if the condition is not satisfied. I know that this
>>> is possible using OCL but to be honest, I haven't ever played with
>>> this feature. I'll look into this in the next few days and get back
>>> to you. If by any chance you manage to make any progress with this
>>> before I do, it'd be great if you could report back with the solution
>>> you've found.
>>> and the example in
>>> for more details.
>>>> Thanks,
>>>> Mihir
>>> Cheers,
>>> Dimitris
>>>>> Hi Mihir,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> reference link to link a instance of ObjectTemplateExp to the
>>>>>> other instance of ObjectTemplateExp if the type of the
>>>>>> referredProperty (in instance of PropertyTemplateExp) is of type
>>>>>> EReference.
>>>>>> Thanks,
>>>>>> Mihir
>>>>>> Mihir wrote:
>>>>>>> Hello,
>>>>>>> code:
>>>>>>> class VariableExp {
>>>>>>> Thanks,
>>>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #23987 is a reply to message #23534] |
Sun, 26 July 2009 15:22   |
Hello Dimitris,
Sorry for delayed reply. I'd gone out for a while.
I've implemented a derived attribute and generated all the code as told
by you. But, what I saw is that it is same as adding a new simple
attribute to the class because the generated code seems like the same as
that generated for simple attribute. Below is the code that is
generated. I can't find any code throwing unsupported operation exception.
public String getLabel() {
return
(String)eGet(Moment2transformationPackage.Literals.OBJECT_TE MPLATE_EXP__LABEL,
true);
public void setLabel(String newLabel) {
eSet(Moment2transformationPackage.Literals.OBJECT_TEMPLATE_E XP__LABEL,
newLabel);
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #24024 is a reply to message #23987] |
Mon, 27 July 2009 08:03   |
Hi Mihir,
Could you please check again that you have all 3 modifiers in your label
attribute and that you have regenerated the .ecore from the .emf and
reloaded the .genmodel? (if necessary, please delete the .genmodel and
regenerate it).
Dimitris
Mihir wrote:
> Hello Dimitris,
> return
> true);
> newLabel);
> Cheers,
> Mihir
>> Hi Mihir,
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello,
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #80936 is a reply to message #24024] |
Mon, 27 July 2009 14:29   |
Hi Dimitris,
I did tried this couple of times. Deleted all the generated code and all
those model files. Regenerated everything.. still it generates same code. :S
Mihir
> Hi Mihir,
> regenerate it).
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello Dimitris,
>> told by you. But, what I saw is that it is same as adding a new simple
>> as that generated for simple attribute. Below is the code that is
>> exception.
>> return
>> true);
>> newLabel);
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> and make it return variable.name (instead of throwing an unsupported
>>> Cheers,
>>> Dimitris
>>> Mihir wrote:
>>>> Hello,
>>>> code:
>>>> class VariableExp {
>>>> Thanks,
>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #110008 is a reply to message #80936] |
Mon, 27 July 2009 14:57   |
Hi Mihir,
Strange! Could you please send me your metamodel so that I can have a look?
Dimitris
Mihir wrote:
> Hi Dimitris,
> code. :S
> Cheers,
> Mihir
>> Hi Mihir,
>> label attribute and that you have regenerated the .ecore from the .emf
>> and reloaded the .genmodel? (if necessary, please delete the .genmodel
>> and regenerate it).
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello Dimitris,
>>> simple attribute to the class because the generated code seems like
>>> the same as that generated for simple attribute. Below is the code
>>> that is generated. I can't find any code throwing unsupported
>>> return
>>> true);
>>> newLabel);
>>> Cheers,
>>> Mihir
>>>> Hi Mihir,
>>>> Cheers,
>>>> Dimitris
>>>> Mihir wrote:
>>>>> Hello,
>>>>> code:
>>>>> class VariableExp {
>>>>> Thanks,
>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #138345 is a reply to message #110008] |
Mon, 27 July 2009 15:22  |
Hi Dimitris,
I've mailed you on your id.
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hi Dimitris,
>> all those model files. Regenerated everything.. still it generates
>> same code. :S
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> .emf and reloaded the .genmodel? (if necessary, please delete the
>>> .genmodel and regenerate it).
>>> Cheers,
>>> Dimitris
>>> Mihir wrote:
>>>> Hello Dimitris,
>>>> return
>>>> true);
>>>> newLabel);
>>>> Cheers,
>>>> Mihir
>>>>> Hi Mihir,
>>>>> transient attribute, and set it as the label of your
>>>>> generated ObjectTemplateExpImpl.getLabel() method, turn it to
>>>>> @generated NOT and make it return variable.name (instead of
>>>>> throwing an unsupported operation exception).
>>>>> Cheers,
>>>>> Dimitris
>>>>> Mihir wrote:
>>>>>> Hello,
>>>>>> code:
>>>>>> class VariableExp {
>>>>>> Thanks,
>>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571120 is a reply to message #23406] |
Sun, 26 July 2009 07:08  |
Mihir
Mihir wrote:
> Hello,
> value"
> code:
> class VariableExp {
> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571170 is a reply to message #23406] |
Hi Mihir,
Dimitris
Mihir wrote:
> Hello,
> value"
> code:
> class VariableExp {
> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571187 is a reply to message #23449] |
Hi Mihir,
Dimitris
> Mihir
> Mihir wrote:
>> Hello,
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571209 is a reply to message #23534] |
Hello Dimitris,
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571228 is a reply to message #23576] |
Hi Dimitris,
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
>> Thanks,
>> Mihir
>> Mihir wrote:
>>> Hello,
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571272 is a reply to message #23704] |
Hi Mihir,
Mihir wrote:
> Hi Dimitris,
> tools palette.
and the example in
for more details.
> Mihir
Dimitris
>> Hi Mihir,
>> Cheers,
>> Dimitris
>>> Thanks,
>>> Mihir
>>> Mihir wrote:
>>>> Hello,
>>>> code:
>>>> class VariableExp {
>>>> Thanks,
>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571295 is a reply to message #23662] |
Hi Mihir,
Dimitris
Mihir wrote:
> Hello Dimitris,
> Mihir
>> Hi Mihir,
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello,
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571306 is a reply to message #23785] |
OK Dimitris,
anything.
Mihir
> Hi Mihir,
> Mihir wrote:
>> Hi Dimitris,
>> tools palette.
> and the example in
> for more details.
>> Thanks,
>> Mihir
> Cheers,
> Dimitris
>>> Hi Mihir,
>>> Cheers,
>>> Dimitris
>>>> Thanks,
>>>> Mihir
>>>> Mihir wrote:
>>>>> Hello,
>>>>> code:
>>>>> class VariableExp {
>>>>> Thanks,
>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571321 is a reply to message #23868] |
Hi Mihir,
Dimitris
Mihir wrote:
> OK Dimitris,
> anything.
> Cheers,
> Mihir
>> Hi Mihir,
>> Mihir wrote:
>>> Hi Dimitris,
>>> tools palette.
>> found.
>> and the example in
>> for more details.
>>> Thanks,
>>> Mihir
>> Cheers,
>> Dimitris
>>>> Hi Mihir,
>>>> Cheers,
>>>> Dimitris
>>>>> Thanks,
>>>>> Mihir
>>>>> Mihir wrote:
>>>>>> Hello,
>>>>>> code:
>>>>>> class VariableExp {
>>>>>> Thanks,
>>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571342 is a reply to message #23909] |
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> OK Dimitris,
>> anything.
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> Mihir wrote:
>>>> Hi Dimitris,
>>>> from tools palette.
>>> you've found.
>>> and the example in
>>> for more details.
>>>> Thanks,
>>>> Mihir
>>> Cheers,
>>> Dimitris
>>>>> Hi Mihir,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> EReference.
>>>>>> Thanks,
>>>>>> Mihir
>>>>>> Mihir wrote:
>>>>>>> Hello,
>>>>>>> code:
>>>>>>> class VariableExp {
>>>>>>> Thanks,
>>>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571357 is a reply to message #23534] |
Hello Dimitris,
return
true);
newLabel);
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> = value"
>> code:
>> class VariableExp {
>> Thanks,
>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571381 is a reply to message #23987] |
Hi Mihir,
regenerate it).
Dimitris
Mihir wrote:
> Hello Dimitris,
> return
> true);
> newLabel);
> Cheers,
> Mihir
>> Hi Mihir,
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello,
>>> = value"
>>> code:
>>> class VariableExp {
>>> Thanks,
>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571412 is a reply to message #24024] |
Hi Dimitris,
Mihir
> Hi Mihir,
> regenerate it).
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello Dimitris,
>> exception.
>> return
>> true);
>> newLabel);
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> Cheers,
>>> Dimitris
>>> Mihir wrote:
>>>> Hello,
>>>> code:
>>>> class VariableExp {
>>>> Thanks,
>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571433 is a reply to message #80936] |
Hi Mihir,
Dimitris
Mihir wrote:
> Hi Dimitris,
> code. :S
> Cheers,
> Mihir
>> Hi Mihir,
>> and regenerate it).
>> Cheers,
>> Dimitris
>> Mihir wrote:
>>> Hello Dimitris,
>>> return
>>> true);
>>> newLabel);
>>> Cheers,
>>> Mihir
>>>> Hi Mihir,
>>>> Cheers,
>>>> Dimitris
>>>> Mihir wrote:
>>>>> Hello,
>>>>> code:
>>>>> class VariableExp {
>>>>> Thanks,
>>>>> Mihir
Re: [EuGENia] Node label from attribute of contained class [message #571468 is a reply to message #110008] |
Hi Dimitris,
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hi Dimitris,
>> same code. :S
>> Cheers,
>> Mihir
>>> Hi Mihir,
>>> Cheers,
>>> Dimitris
>>> Mihir wrote:
>>>> Hello Dimitris,
>>>> return
>>>> true);
>>>> newLabel);
>>>> Cheers,
>>>> Mihir
>>>>> Hi Mihir,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Mihir wrote:
>>>>>> Hello,
>>>>>> code:
>>>>>> class VariableExp {
>>>>>> Thanks,
>>>>>> Mihir
Current Time: Tue Apr 29 03:00:34 EDT 2025
Powered by FUDForum. Page generated in 0.47039 seconds
