Home » Eclipse Projects » Babel » non translatable Strings
non translatable Strings [message #23402] |
Thu, 04 December 2008 06:08  |
--------------090907040001000405040904
Hi translators,
I often maintain a single .properties file in my plugins to hold both
translatable and untranslatable (as in "do not translate") Strings. The
latter are located below comments warning the translators _not_ to
translate any further such as
# END OF TRANSLATED PROPERTIES #
# do not translate values beyond this point #
Needless to say, when using the babel UI translators won't see these
warnings and translate anyway when the key has a value that is valid
english and hence translatable... Granted, there is a way to mark
Strings as being untranslatable in the babel UI, yet I'd rather have
them automatically marked as such or better yet, totally hidden from the
translation UI.
Are there specific comments we can add to properties files so that babel
will not mark them for translation? AFAIK, with babel as it is now, we
cannot even create a config.properties file since it walks the entire
plugin tree and parses all properties file for translation.
Laurent Goubet
Obeo
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------090907040001000405040904--
Re: non translatable Strings [message #23489 is a reply to message #23402] |
Thu, 04 December 2008 07:32   |
Originally posted by: atoulme.intalio.com
No, but we have an open bug about it I think.
We couldn't really come to terms as to what should be the flag to mark a
string as untranslatable.
Good news is though, that you can flag a straing as untranslatable in
the Babel UI.
Just login, go to the string, and check non-translatable.
It's a bit bothersome, but it is the workaround for now.
Antoine
laurent Goubet wrote:
> Hi translators,
> translation UI.
> Laurent Goubet
> Obeo
Re: non translatable Strings [message #23618 is a reply to message #23575] |
Thu, 04 December 2008 08:41   |
Laurent, the bug reference: 226378
Antoine
> Antoine,
> Yes, as mentionned in the previous mail I saw this as a potential
> workaround too. Still remains the problem that anyone can also "just
> login, uncheck the box and translate the string" since "untranslatable"
> doesn't bear the same meaning as "shouldn't be translated".
> If I go in the babel UI and see a String "Compare" marked as
> "untranslatable", I'm bound to think "hey wait! But this is translatable
> in any language?"... An option would be to prevent anyone to uncheck the
> "untranslatable" box if he is not the one who checked it in the first
> place (save for Eclipse Genie), but this remains a bothersome option :).
> Since you've confirmed that there is no other option for now, I'll try
> and find a bug report or raise one myself for this;
> Thanks
> Laurent Goubet
> Obeo
>> a string as untranslatable.
>> the Babel UI.
>> Thanks,
>> Antoine
>>> Hi translators,
>>> translation UI.
>>> Laurent Goubet
>>> Obeo
Re: non translatable Strings [message #23661 is a reply to message #23618] |
Thu, 04 December 2008 09:08  |
--------------080300080401010700050405
Thanks, cced myself on it when you told about a bug earlier ;).
Laurent Goubet
Obeo
Antoine Toulme a
Re: non translatable Strings [message #576062 is a reply to message #23402] |
the Babel UI.
Antoine
> Hi translators,
> translation UI.
> Laurent Goubet
> Obeo
Re: non translatable Strings [message #576120 is a reply to message #23489] |
Thu, 04 December 2008 07:45  |
--------------020601060104070103040703
Antoine,
Laurent Goubet
Obeo
Antoine Toulme a
Re: non translatable Strings [message #576153 is a reply to message #23575] |
Antoine
> Antoine,
> Thanks
> Laurent Goubet
> Obeo
>> the Babel UI.
>> Thanks,
>> Antoine
>>> Hi translators,
>>> translation UI.
>>> Laurent Goubet
>>> Obeo
Re: non translatable Strings [message #576179 is a reply to message #23618] |
Laurent Goubet
Obeo
Antoine Toulme a
Current Time: Wed Oct 22 20:26:03 EDT 2025
Powered by FUDForum. Page generated in 0.05194 seconds
