Can't find genClass for class 'MyClass' in package myPckage [message #23387] |
Fri, 18 August 2006 11:11  |
I get the following message when invoke "Create generator model..." in
gmfmap file. Does anyone know what the cause is ????
An internal error occurred during: "Create generator model...".
java.lang.IllegalStateException: Can't find genClass for class 'MyClass'
in package myPckage
org.eclipse.gmf.internal.bridge.genmodel.GenModelMatcher.fin dGenClass(GenModelMatcher.java:82)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.findGenClass(DiagramGenModelTransformer.java:638)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.setupModelFacet(DiagramGenModelTransformer.java:699)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.createModelFacet(DiagramGenModelTransformer.java:658 )
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:241)
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer. transform(MappingTransformer.java:32)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.transform(TransformToGenModel.java:189)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.run(TransformToGenModel.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: Tutorial - Audit doesn´t work [message #23775 is a reply to message #23731] |
Fri, 18 August 2006 16:30   |
The latest working (fixed duplicate links) code is in CVS, and in the
provided solution zips (as of yesterday).
Can you provide more detail on the problem with the audits? Are there any
error log entries?
Rich
On 8/18/06 4:26 PM, in article ec57ln$au7$1@utils.eclipse.org, "Leonardo
Coelho" <leonardo.coelho@siliconstrategy.com.br> wrote:
> Hi, guys, i´m a newbie and it´s my second day working with GMF.
> I´ve downloaded the MindMap tutorial 2 source code and it doesn´t work.
> Can everybody help me? I´ve followed all tutorial instructions.
> The first example works well and everything is ok, except audit and the
> problem with the duplicate graphical link.
> By the way, is there a new eclipse environment download available? Of
> course, with duplicate graphical link corrected!
> Regards!
FUDForum. Page generated in 0.22387 seconds
