Home » Modeling » Epsilon » Re: Copying models in ETL
| Re: Copying models in ETL [message #1977] |
Tue, 11 November 2008 10:29  |
Originally posted by: szchaler.acm.org
Hi again,
I have a core ecore metamodel and want to generate an extension
metamodel for this. This essentially means that I need to add a few
subclasses for some abstract classes in the core metamodel. As discussed
in earlier mails, I have a few tools that have problems with ecore
metamodels referencing each other. Hence, I cannot use linking between
the metamodels. Instead, I am planning to hack around this by including
a copy of all classes and relationships from the core metamodel in my
generated metamodel.
What is the most efficient way of creating such a copy?
Many thanks,
Steffen
Dimitrios Kolovos wrote:
> Hi Steffen,
> There are more than one ways to do this in ETL, EOL. Could you please
> give me a bit more details as to what you are trying to do so that I
> can suggest the best solution?
> I'd be grateful if we could take the discussion over to the
> eclipse.epsilon newsgroup as it sounds as something potentially
> interesting to others too (and also the more activity in the
> newsgroup, the better for the project ;)
> Cheers,
> Dimitrios
> Steffen Zschaler wrote:
>> Is there a possibility in ETL to create a copy of a source model to
>> be further expanded in the transformation?
>> Many thanks,
>> Steffen
| Re: Copying models in ETL [message #2005 is a reply to message #1977] |
Tue, 11 November 2008 10:53   |
--------------000209080005090406070101
Hi Steffen,
I think that the most efficient way in your case is to load the two
metamodels in an EOL program, move the eClassifiers and eSubpackages of
the core metamodel to the extension metamodel and then save the
extension metamodel using a different name. E.g.
var coreEPackage := Core!EPackage.all.first();
var extEPackage := Ext!EPackage.all.first();
var coreClassifiers := coreEPackage.eClassifiers.clone();
var coreSubpackages := coreEPackage.eSubpackages.clone();
extEPackage.eClassifiers.addAll(coreClassifiers);
extEPackage.eSubpackages.addAll(coreSubpackages);
Ext.store(Ext.modelFile.replace('ecore', 'merged.ecore'));
(just make sure you un-tick the Save on disposal checkbox when
specifying the models)
I've attached an example project (+launch configuration) that does this
on two minimal core and ext metamodels.
Hope this helps,
Dimitrios
> Hi again,
> Many thanks,
> Steffen
>> Hi Steffen,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Many thanks,
>>> Steffen
Content-Type: application/x-zip-compressed;
name="MergeMetamodels.zip"
Content-Disposition: inline;
filename="MergeMetamodels.zip"
UEsDBBQAAAAIACCFazkZDX08iAAAANsAAAAIAAAALnByb2plY3RVjkEOwiAQ RdeaeIeGvaI7
F5RujLuu1AMg/DSYMhCgxuPb1qphN+/9mZ8Rzcv11RMxWU81O+z2rAJpbyx1 Nbtdz9sja+Rm
LUL0D+h8QtLRhjxuj3YlSDnIFrFDi6ycN+iT4LOdYu2dA2Up+Hea7NKVZuAF 3Qfbm0uA/mQl
kspDxHL2h19F+dwbUEsDBBQAAAAIADaFazkVMWuC1QAAAFQBAAAKAAAAY29y ZS5lY29yZVWQ
ywrCMBBF94L/EGZvU+tGQqsLURAUxAe4DXFag01SmmLr3zuND2hWk7n3HmYm XXamZE+svXY2
g2kUA0Or3E3bIoPLeTOZw3IxHqWoXI1ifZDqIQtkndHin0ooNR4xegSzXpCY wb1pKsF527aR
M0Xk6oJf91v4WfzQ0s6CI4njKdl2J3VHIyfa+kZahQN6mGQQRlXqymMgoMl7 SsLXvQ2YlYbM
of5ArL8ct98OfQ415rrLABa9nOKqlN7rXNNujIYUzaui/Hf7IP6YK+D9Yfjw MtR6A1BLAwQU
AAAACAA1hWs5cbq1p0MAAABFAAAACAAAAGNvcmUuZW1mc8hLzE0tLkhMTtUo Lcq0VUrOL0pV
0lEoKEpNy6ywVVLS5OUCSmYnpqcqgKSsebl4uZJzEouLFZwVqnm5FBQUeLlq AVBLAwQUAAAA
CADUhWs5+4UWlecAAABpAQAACQAAAGV4dC5lY29yZVWQwWrDMBBE74H8g9ie YznupQgrOQQH
AimEJoFehbp2RC3JWGrt/n1XTlOwTmLnzbA75Xa0LfvGPhjvJKyzHBg67T+M ayRcL/vVC2w3
y0WJ2vcoqpPSn6pBNloj/l0FuZYLRo/CXBAkSrjF2AnOh2HIvG0y3zf8/fUA DyTMkeF5Ioo8
XxN2POsbWrUyLkTlNM7Sp01mZtSt6QJOCWjrlFLwKmHAnLIE4xj/Mly4vh3u A/qfeqzNKAE2
SS1x16oQTG3oMkYrivjTJff99kl8JFbU0/mrw/5CSJCQkCfOd8BTW3xeF41+ AVBLAwQUAAAA
CABXhWs5mYi7aFwAAABkAAAABwAAAGV4dC5lbWZzyEvMTS0uSExO1SgtyrRV Sq0oUdJRKChK
TcussFVS0uTlAsplJ6anKgBlrHm5eLkycwvyi0oUlJLzi1KVwCLJOYnFxQqu IBWpeSnFCiAZ
PWeFal4uBQUFXq5aAFBLAwQUAAAACAAdhms5S7zf6xYBAAAQAgAAEAAAAGV4 dC5tZXJnZWQu
ZWNvcmWdkVFLwzAUhd8F/0OIz1u6iiilcYxZobrh5jacTxLT2zbYpKXp1u7f m7RYrLAX38LN
Oec7N/GnjczQEUotckXxZOxgBIrnkVAJxbvt4+gOT+8vL3zgeQlesGL8iyWA Gim83uVal8lR
2jNzitOqKjxC6roe5zIZ52VC9suwl+ihpL5uFa7jTIxsseEpSDYSSldMcfhx tfyBD3gmCg2t
GWRsA1wSWBlu64mI4o/1y+FmtpiFQeSKt9un5fO72j+sMVJMmjRoKnPUu9ew P69KiEVDMTZL
I+TDPGNai1iYXZFp7lWnwhq712gv/9I+z9GCLtOmbg4FlFsTpVFqgBTbvCtC 5ph0XPIb/L8q
2TE4W6XjGMrgV83oG1BLAwQUAAAACAD8hWs54TAraqgAAAB6AQAAEgAAAE1l cmdlRXh0ZW5z
aW9uLmVvbHWPQQrCMBBF94XeIa6aguQAFhdS6lrwBGMyLcGpLUksPb4JQZmK 7jLz//t/soAT
enLYXUDfYUBxOIo2zrv3QgGR6q3zQdZNWSzRj2vg9m4N/9zZn/JbAu9tb9H5 xPBKxUWlaXrg
pyr5rs/bnJ0/UCYytCzYjdt8MOZEJL9uStAG4bkMYevcEz+vfIiKTK9xMkhn S6gczgQaZYUJ
q/aiGtENaFSe67p5AVBLAwQUAAAACAAbhms524muo3gBAAAXBAAAFQAAAE1l cmdlRXh0ZW5z
aW9uLmxhdW5jaNVTPW/CMBDdK/U/WEbq1jiBliLARS2ECcoCG4ubHMGqY0f2 hY9/XwMCAkxV
u3Sx7Lt37+6e9bq9Ta7ICqyTRnMaBSEloBOTSp1xOpsOH1uUOBQ6Fcpo4FQb 2nu9v+sqUepk
2Td6IbPSCvTlBLeFRxibBVA46fEBGBVAomThIEgxOBR56iA2anTLMAAFmUCg +w7S4RuilZ8l
AvmCLae5SUG5UzbWaLdkJVTp29YealGj44+wU5uWQD7MikQRiZrtp+d244X0 4ymph2HrDJNu
DCj2nEOp4F04SPlCKAdnjBY58L6xlZAFkU70yIiUoy0rCYceN9ED6QrjhLqm Ekr6Do6fI/mx
/cxKvkQs5m3G1uv1STIvJYN8wfzcdRYnF2PsxY7HwwrdcRPOxmAzOG3n2K7U s14QwKbw33q1
Q15VpDIqZT8VvdkOw9+IHm/wf2sOG/wDydmFDXYR5+86u3KGM6VNgB7/ZX41 zOHtJQW9M/rO
l0f6Wxf6+DdQSwECFAAUAAAACAAghWs5GQ19PIgAAADbAAAACAAAAAAAAAAB ACAAAAAAAAAA
LnByb2plY3RQSwECFAAUAAAACAA2hWs5FTFrgtUAAABUAQAACgAAAAAAAAAB ACAAAACuAAAA
Y29yZS5lY29yZVBLAQIUABQAAAAIADWFazlxurWnQwAAAEUAAAAIAAAAAAAA AAEAIAAAAKsB
AABjb3JlLmVtZlBLAQIUABQAAAAIANSFazn7hRaV5wAAAGkBAAAJAAAAAAAA AAEAIAAAABQC
AABleHQuZWNvcmVQSwECFAAUAAAACABXhWs5mYi7aFwAAABkAAAABwAAAAAA AAABACAAAAAi
AwAAZXh0LmVtZlBLAQIUABQAAAAIAB2GazlLvN/rFgEAABACAAAQAAAAAAAA AAEAIAAAAKMD
AABleHQubWVyZ2VkLmVjb3JlUEsBAhQAFAAAAAgA/IVrOeEwK2qoAAAAegEA ABIAAAAAAAAA
AQAgAAAA5wQAAE1lcmdlRXh0ZW5zaW9uLmVvbFBLAQIUABQAAAAIABuGaznb ia6jeAEAABcE
AAAVAAAAAAAAAAEAIAAAAL8FAABNZXJnZUV4dGVuc2lvbi5sYXVuY2hQSwUG AAAAAAgACADR
AQAAagcAAAAA
--------------000209080005090406070101--
| Re: Copying models in ETL [message #2019 is a reply to message #2005] |
Tue, 11 November 2008 11:17   |
--------------030005000309050801090702
Hi Dimitrios,
Thanks for the quick reply. I am actually generating ext. Would I be
able, then, to do this in the preamble of my ETL file, e.g.:
pre {
var extEPackage := new Ext!EPackage;
extPackage.name := 'Bla';
Steffen
> Hi Steffen,
> of the core metamodel to the extension metamodel and then save the
> this on two minimal core and ext metamodels.
> Hope this helps,
> Dimitrios
>> Hi again,
>> discussed in earlier mails, I have a few tools that have problems
>> with ecore metamodels referencing each other. Hence, I cannot use
>> linking between the metamodels. Instead, I am planning to hack around
>> this by including a copy of all classes and relationships from the
>> core metamodel in my generated metamodel.
>> Many thanks,
>> Steffen
>>> Hi Steffen,
>>> please give me a bit more details as to what you are trying to do so
>>> that I can suggest the best solution?
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> Many thanks,
>>>> Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
WWW http://www.steffen-zschaler.de/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
<html>
<head>
</head>
Hi Dimitrios,<br>
<br>
able, then, to do this in the preamble of my ETL file, e.g.:<br>
<blockquote>
<pre>pre {
</pre>
</blockquote>
Cheers,<br>
<br>
Steffen<br>
<br>
<blockquote cite="mid:gfc9pb$vev$1@build.eclipse.org" type="cite">Hi
Steffen,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<blockquote type="cite">Hi again,
<br>
<br>
discussed in earlier mails, I have a few tools that have problems with
ecore metamodels referencing each other. Hence, I cannot use linking
between the metamodels. Instead, I am planning to hack around this by
including a copy of all classes and relationships from the core
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<blockquote type="cite">Hi Steffen,
<br>
<br>
<br>
<br>
interesting to others too (and also the more activity in the newsgroup,
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
Is there a possibility in ETL to create a copy of a source model to be
<br>
<br>
Many thanks,
<br>
<br>
Steffen<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<pre class="moz-signature" cols="72">--
Email <a class="moz-txt-link-abbreviated" href="mailto:szschaler@acm.org">szschaler@acm.org</a>
WWW <a class="moz-txt-link-freetext" href="http://www.steffen-zschaler.de/">http://www.steffen-zschaler.de/</a>
<a class="moz-txt-link-freetext" href="http://qosa.ipd.uka.de/">http://qosa.ipd.uka.de/</a>
<a class="moz-txt-link-freetext" href="http://wikiserver.sse.cs.tu-bs.de/mise09">http://wikiserver.sse.cs.tu-bs.de/mise09</a></pre>
</body>
</html>
--------------030005000309050801090702--
| Re: Copying models in ETL [message #2047 is a reply to message #2019] |
Tue, 11 November 2008 11:23   |
I'd do this in the post section instead so that it runs after the ETL
rules. Otherwise the rules will have nothing to transform in the source
model. (Just make sure you don't store Core after the transformation is
done because by putting the classifiers and subpackages to ext you are
actually removing them from core).
Dimitrios
> Hi Dimitrios,
> pre {
> Cheers,
> Steffen
>> Hi Steffen,
>> Hope this helps,
>> Dimitrios
>>> Hi again,
>>> Many thanks,
>>> Steffen
>>>> Hi Steffen,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Many thanks,
>>>>> Steffen
| Re: Copying models in ETL [message #2089 is a reply to message #2047] |
Tue, 11 November 2008 11:28   |
Thanks again. Not sure, I completely understand this. Why would there be
nothing to transform? The rules I am writing are not actually
transforming elements from Core, but rather are creating additional
elements based on information from a 'source' model. Am I right in
assuming that in this case I would be OK to do the copy in pre?
Steffen
> source model. (Just make sure you don't store Core after the
> transformation is done because by putting the classifiers and
> subpackages to ext you are actually removing them from core).
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> pre {
>> Cheers,
>> Steffen
>>> Hi Steffen,
>>> Hope this helps,
>>> Dimitrios
>>>> Hi again,
>>>> around this by including a copy of all classes and relationships
>>>> from the core metamodel in my generated metamodel.
>>>> Many thanks,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> so that I can suggest the best solution?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> to be further expanded in the transformation?
>>>>>> Many thanks,
>>>>>> Steffen
| Re: Copying models in ETL [message #3110 is a reply to message #2089] |
Tue, 11 November 2008 11:35   |
Oh! I made the assumption that your source model would be Core. Since it
is not, putting the code either in pre or post should be fine.
Dimitrios
> Cheers,
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> pre {
>>> Cheers,
>>> Steffen
>>>> Hi Steffen,
>>>> Hope this helps,
>>>> Dimitrios
>>>>> Hi again,
>>>>> Many thanks,
>>>>> Steffen
>>>>>> Hi Steffen,
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Many thanks,
>>>>>>> Steffen
| Re: Copying models in ETL [message #3143 is a reply to message #3110] |
Tue, 11 November 2008 11:44   |
Steffen
> it is not, putting the code either in pre or post should be fine.
> Cheers,
> Dimitrios
>> be nothing to transform? The rules I am writing are not actually
>> Cheers,
>> Steffen
>>> ETL rules. Otherwise the rules will have nothing to transform in the
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> be able, then, to do this in the preamble of my ETL file, e.g.:
>>>> pre {
>>>> Cheers,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> two metamodels in an EOL program, move the eClassifiers and
>>>>> eSubpackages of the core metamodel to the extension metamodel and
>>>>> then save the extension metamodel using a different name. E.g.
>>>>> Hope this helps,
>>>>> Dimitrios
>>>>>> Hi again,
>>>>>> few subclasses for some abstract classes in the core metamodel.
>>>>>> As discussed in earlier mails, I have a few tools that have
>>>>>> problems with ecore metamodels referencing each other. Hence, I
>>>>>> cannot use linking between the metamodels. Instead, I am planning
>>>>>> to hack around this by including a copy of all classes and
>>>>>> relationships from the core metamodel in my generated metamodel.
>>>>>> Many thanks,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> do so that I can suggest the best solution?
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi,
>>>>>>>> model to be further expanded in the transformation?
>>>>>>>> Many thanks,
>>>>>>>> Steffen
| Re: Copying models in ETL [message #3377 is a reply to message #3110] |
Wed, 12 November 2008 06:55   |
--------------090907000804080207050102
It seems I'm still doing something wrong here. Here's the code I put
into pre:
pre {
-- Copy Core Metamodel
var extEPackage := new target!EPackage;
However, all I get is an empty resulting model.
Any ideas where the error could be?
Steffen
> Cheers,
> Dimitrios
>> Cheers,
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> pre {
>>>> Cheers,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> Hope this helps,
>>>>> Dimitrios
>>>>>> Hi again,
>>>>>> Many thanks,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi,
>>>>>>>> Many thanks,
>>>>>>>> Steffen
<html>
<head>
</head>
Hi,<br>
<br>
into pre:<br>
<blockquote>
<pre>pre {
</pre>
</blockquote>
However, all I get is an empty resulting model.<br>
<br>
Any ideas where the error could be?<br>
<br>
Steffen<br>
<br>
<blockquote cite="mid:gfcc9j$pj0$3@build.eclipse.org" type="cite">Oh! I
made the assumption that your source model would be Core. Since it is
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<blockquote type="cite">I'd do this in the post section instead so
that it runs after the ETL rules. Otherwise the rules will have nothing
to transform in the source model. (Just make sure you don't store Core
after the transformation is done because by putting the classifiers and
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<blockquote type="cite">Hi Dimitrios,
<br>
<br>
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090907000804080207050102--
| Re: Copying models in ETL [message #3481 is a reply to message #3377] |
Wed, 12 November 2008 08:13   |
Hi Steffen,
The only thing that comes to mind is that you don't store target when
the transformation ends. Could you please add a few print statements after
to see the state of your model once the statements above have executed?
e.g.
extEPackage.eClassifiers.println();
If the problem persists, could you please send me your transformation
and involved models/metamodels so that I can investigate more?
Dimitrios
> into pre:
> pre {
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Cheers,
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> pre {
>>>>> Cheers,
>>>>> Steffen
>>>>>> Hi Steffen,
>>>>>> Hope this helps,
>>>>>> Dimitrios
>>>>>>> Hi again,
>>>>>>> Many thanks,
>>>>>>> Steffen
>>>>>>>> Hi Steffen,
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Hi,
>>>>>>>>> Many thanks,
>>>>>>>>> Steffen
| Re: Copying models in ETL [message #3578 is a reply to message #3481] |
Wed, 12 November 2008 08:27   |
No output at all from println statement (even from something like
'Test'.println()). So it seems like I am making a mistake in setting up
the actual transformation and the transformation is never run.
Steffen
> Hi Steffen,
> after
> e.g.
> Cheers,
> Dimitrios
>> into pre:
>> pre {
>> Steffen
>>> Since it is not, putting the code either in pre or post should be fine.
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> there be nothing to transform? The rules I am writing are not
>>>> actually transforming elements from Core, but rather are creating
>>>> additional elements based on information from a 'source' model. Am
>>>> I right in assuming that in this case I would be OK to do the copy
>>>> in pre?
>>>> Cheers,
>>>> Steffen
>>>>> the source model. (Just make sure you don't store Core after the
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> pre {
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> and then save the extension metamodel using a different name. E.g.
>>>>>>> does this on two minimal core and ext metamodels.
>>>>>>> Hope this helps,
>>>>>>> Dimitrios
>>>>>>>> Hi again,
>>>>>>>> planning to hack around this by including a copy of all classes
>>>>>>>> and relationships from the core metamodel in my generated
>>>>>>>> metamodel.
>>>>>>>> Many thanks,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> potentially interesting to others too (and also the more
>>>>>>>>> activity in the newsgroup, the better for the project ;)
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi,
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>> Conference on
>>>>>> on Models in Software Engineering
| Re: Copying models in ETL [message #3611 is a reply to message #3481] |
Wed, 12 November 2008 08:37   |
:-( It seems I found another stupid mistake one can make in using
Epsilon. I used module.parse ("path_to_ETL_file") and then went on from
there. Debugging shows me that this seems to try and interpret
"path_to_ETL_file" as the actual ETL code instead of the name of the
file. Unfortunately, it didn't give me any error messages or exceptions
but just silently ignored any problems involved and left me with an
empty ETL module.
Steffen
> Hi Steffen,
> after
> e.g.
> Cheers,
> Dimitrios
>> into pre:
>> pre {
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> in pre?
>>>> Cheers,
>>>> Steffen
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> pre {
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Hope this helps,
>>>>>>> Dimitrios
>>>>>>>> Hi again,
>>>>>>>> metamodel.
>>>>>>>> Many thanks,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi,
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>> Conference on
| Re: Copying models in ETL [message #3644 is a reply to message #3611] |
Wed, 12 November 2008 08:45   |
Hi Steffen,
The parse methods (located in AbstractModule) return a boolean
indicating if parsing has succeeded/failed (in your case it should
return false). If you think raising an exception instead would be a
better approach could you please add a new bug/enhancement request? (you
can use the following direct link - also available in the Epsilon
homepage -
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon)
Dimitrios
> empty ETL module.
> Cheers,
> Steffen
>> Hi Steffen,
>> after
>> e.g.
>> Cheers,
>> Dimitrios
>>> Hi,
>>> into pre:
>>> pre {
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> in pre?
>>>>> Cheers,
>>>>> Steffen
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>> pre {
>>>>>>> Cheers,
>>>>>>> Steffen
>>>>>>>> Hi Steffen,
>>>>>>>> Hope this helps,
>>>>>>>> Dimitrios
>>>>>>>>> Hi again,
>>>>>>>>> metamodel.
>>>>>>>>> Many thanks,
>>>>>>>>> Steffen
>>>>>>>>>> Hi Steffen,
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Hi,
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Steffen
>>>>>>> Conference on
| Re: Copying models in ETL [message #3712 is a reply to message #3644] |
Wed, 12 November 2008 09:28   |
--------------020902040106010302050708
I think there should be an exception instead. However, I'm not sure that
this is at the heart of things here. In particular, I was using the
following code to do the parsing:
module.parse ("path_to_ETL_file");
if (module.getParseProblems().size() > 0) {
System.err.println("Parse errors occured...");
for (ParseProblem problem : module.getParseProblems()) {
System.err.println(problem.toString());
throw new RuntimeException("Parse Problems.");
and no parse problems where indicated...
Steffen
> Hi Steffen,
> (you can use the following direct link - also available in the Epsilon
> homepage -
> Cheers,
> Dimitrios
>> from there. Debugging shows me that this seems to try and interpret
>> exceptions but just silently ignored any problems involved and left
>> me with an empty ETL module.
>> Cheers,
>> Steffen
>>> Hi Steffen,
>>> when the transformation ends. Could you please add a few print
>>> statements after
>>> e.g.
>>> transformation and involved models/metamodels so that I can
>>> investigate more?
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> put into pre:
>>>> pre {
>>>> Steffen
>>>>> fine.
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Am I right in assuming that in this case I would be OK to do the
>>>>>> copy in pre?
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> the ETL rules. Otherwise the rules will have nothing to
>>>>>>> Core after the transformation is done because by putting the
>>>>>>> classifiers and subpackages to ext you are actually removing
>>>>>>> them from core).
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi Dimitrios,
>>>>>>>> I be able, then, to do this in the preamble of my ETL file, e.g.:
>>>>>>>> pre {
>>>>>>>> Cheers,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> the two metamodels in an EOL program, move the eClassifiers
>>>>>>>>> and eSubpackages of the core metamodel to the extension
>>>>>>>>> metamodel and then save the extension metamodel using a
>>>>>>>>> Hope this helps,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi again,
>>>>>>>>>> extension metamodel for this. This essentially means that I
>>>>>>>>>> need to add a few subclasses for some abstract classes in the
>>>>>>>>>> core metamodel. As discussed in earlier mails, I have a few
>>>>>>>>>> tools that have problems with ecore metamodels referencing
>>>>>>>>>> each other. Hence, I cannot use linking between the
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>>>>>>> Hi Steffen,
>>>>>>>>>>> you please give me a bit more details as to what you are
>>>>>>>>>>> trying to do so that I can suggest the best solution?
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitrios
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> Many thanks,
>>>>>>>>>>>> Steffen
>>>>>>>> Conference on
>>>>>>>> Workshop on Models in Software Engineering
<html>
<head>
</head>
Hi,<br>
<br>
that this is at the heart of things here. In particular, I was using
the following code to do the parsing:<br>
<blockquote>
<pre>module.parse ("path_to_ETL_file");
</pre>
</blockquote>
and no parse problems where indicated...<br>
<br>
Steffen<br>
<br>
<blockquote cite="mid:gfemlr$kt2$4@build.eclipse.org" type="cite">Hi
Steffen,
<br>
<br>
homepage -
<a class="moz-txt-link-freetext" href=" https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon"> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& amp;component=Epsilon</a>)
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<blockquote type="cite">:-( It seems I found another stupid mistake
one can make in using Epsilon. I used module.parse ("path_to_ETL_file")
and then went on from there. Debugging shows me that this seems to try
and interpret "path_to_ETL_file" as the actual ETL code instead of the
name of the file. Unfortunately, it didn't give me any error messages
or exceptions but just silently ignored any problems involved and left
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
after
<br>
<br>
<br>
<br>
<br>
<br>
e.g.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
into pre:
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<blockquote type="cite">Oh! I made the assumption that your
source model would be Core. Since it is not, putting the code either in
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
instead so that it runs after the ETL rules. Otherwise the rules will
have nothing to transform in the source model. (Just make sure you
don't store Core after the transformation is done because by putting
the classifiers and subpackages to ext you are actually removing them
from core).
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
WWW <a class="moz-txt-link-freetext" href="http://www.steffen-zschaler.de/">http://www..steffen-zschaler.de/</a>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020902040106010302050708--
| Re: Copying models in ETL [message #4089 is a reply to message #3712] |
Wed, 12 November 2008 09:37  |
Hi Steffen,
With the current version you'd have to do something like:
boolean parseOK = module.parse(...);
if (!parseOK || module.getProblems().size() > 0) {
Thanks for submitting https://bugs.eclipse.org/bugs/show_bug.cgi?id=255046
Dimitrios
> Steffen
>> Hi Steffen,
>> homepage -
>> Cheers,
>> Dimitrios
>>> Cheers,
>>> Steffen
>>>> Hi Steffen,
>>>> statements after
>>>> e.g.
>>>> investigate more?
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> put into pre:
>>>>> pre {
>>>>> Steffen
>>>>>> fine.
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> copy in pre?
>>>>>>> Cheers,
>>>>>>> Steffen
>>>>>>>> them from core).
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Hi Dimitrios,
>>>>>>>>> pre {
>>>>>>>>> Cheers,
>>>>>>>>> Steffen
>>>>>>>>>> Hi Steffen,
>>>>>>>>>> Hope this helps,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Hi again,
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Steffen
>>>>>>>>>>>> Hi Steffen,
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Dimitrios
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Many thanks,
>>>>>>>>>>>>> Steffen
>>>>>>>>> WWW http://www..steffen-zschaler.de/
>>>>>>>>> Conference on
| Re: Copying models in ETL [message #561482 is a reply to message #1977] |
Hi Steffen,
Hope this helps,
Dimitrios
> Hi again,
> Many thanks,
> Steffen
>> Hi Steffen,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Many thanks,
>>> Steffen
AQAAagcAAAAA
| Re: Copying models in ETL [message #561503 is a reply to message #2005] |
Hi Dimitrios,
pre {
Steffen
> Hi Steffen,
> Hope this helps,
> Dimitrios
>> Hi again,
>> Many thanks,
>> Steffen
>>> Hi Steffen,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> Many thanks,
>>>> Steffen
<html>
<head>
</head>
Hi Dimitrios,<br>
<br>
<blockquote>
<pre>pre {
</pre>
</blockquote>
Cheers,<br>
<br>
Steffen<br>
<br>
Steffen,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
| Re: Copying models in ETL [message #561537 is a reply to message #2019] |
Dimitrios
> Hi Dimitrios,
> pre {
> Cheers,
> Steffen
>> Hi Steffen,
>> Hope this helps,
>> Dimitrios
>>> Hi again,
>>> Many thanks,
>>> Steffen
>>>> Hi Steffen,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Many thanks,
>>>>> Steffen
| Re: Copying models in ETL [message #561596 is a reply to message #2047] |
Steffen
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> pre {
>> Cheers,
>> Steffen
>>> Hi Steffen,
>>> Hope this helps,
>>> Dimitrios
>>>> Hi again,
>>>> Many thanks,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Many thanks,
>>>>>> Steffen
| Re: Copying models in ETL [message #561631 is a reply to message #2089] |
Dimitrios
> Cheers,
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> pre {
>>> Cheers,
>>> Steffen
>>>> Hi Steffen,
>>>> Hope this helps,
>>>> Dimitrios
>>>>> Hi again,
>>>>> Many thanks,
>>>>> Steffen
>>>>>> Hi Steffen,
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Many thanks,
>>>>>>> Steffen
| Re: Copying models in ETL [message #561649 is a reply to message #3110] |
Steffen
> Cheers,
> Dimitrios
>> Cheers,
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> pre {
>>>> Cheers,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> Hope this helps,
>>>>> Dimitrios
>>>>>> Hi again,
>>>>>> Many thanks,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi,
>>>>>>>> Many thanks,
>>>>>>>> Steffen
| Re: Copying models in ETL [message #561786 is a reply to message #3110] |
into pre:
pre {
Steffen
> Cheers,
> Dimitrios
>> Cheers,
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> pre {
>>>> Cheers,
>>>> Steffen
>>>>> Hi Steffen,
>>>>> Hope this helps,
>>>>> Dimitrios
>>>>>> Hi again,
>>>>>> Many thanks,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi,
>>>>>>>> Many thanks,
>>>>>>>> Steffen
<html>
<head>
</head>
Hi,<br>
<br>
into pre:<br>
<blockquote>
<pre>pre {
</pre>
</blockquote>
<br>
<br>
Steffen<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
| Re: Copying models in ETL [message #561846 is a reply to message #3377] |
Hi Steffen,
e.g.
Dimitrios
> into pre:
> pre {
> Steffen
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Cheers,
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> pre {
>>>>> Cheers,
>>>>> Steffen
>>>>>> Hi Steffen,
>>>>>> Hope this helps,
>>>>>> Dimitrios
>>>>>>> Hi again,
>>>>>>> Many thanks,
>>>>>>> Steffen
>>>>>>>> Hi Steffen,
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Hi,
>>>>>>>>> Many thanks,
>>>>>>>>> Steffen
| Re: Copying models in ETL [message #561906 is a reply to message #3481] |
Steffen
> Hi Steffen,
> after
> e.g.
> Cheers,
> Dimitrios
>> into pre:
>> pre {
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> in pre?
>>>> Cheers,
>>>> Steffen
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> pre {
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Hope this helps,
>>>>>>> Dimitrios
>>>>>>>> Hi again,
>>>>>>>> metamodel.
>>>>>>>> Many thanks,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi,
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>> Conference on
| Re: Copying models in ETL [message #561928 is a reply to message #3481] |
empty ETL module.
Steffen
> Hi Steffen,
> after
> e.g.
> Cheers,
> Dimitrios
>> into pre:
>> pre {
>> Steffen
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> in pre?
>>>> Cheers,
>>>> Steffen
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> pre {
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> Hi Steffen,
>>>>>>> Hope this helps,
>>>>>>> Dimitrios
>>>>>>>> Hi again,
>>>>>>>> metamodel.
>>>>>>>> Many thanks,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi,
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>> Conference on
| Re: Copying models in ETL [message #561948 is a reply to message #3611] |
Hi Steffen,
homepage -
Dimitrios
> empty ETL module.
> Cheers,
> Steffen
>> Hi Steffen,
>> after
>> e.g.
>> Cheers,
>> Dimitrios
>>> Hi,
>>> into pre:
>>> pre {
>>> Steffen
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> in pre?
>>>>> Cheers,
>>>>> Steffen
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>> pre {
>>>>>>> Cheers,
>>>>>>> Steffen
>>>>>>>> Hi Steffen,
>>>>>>>> Hope this helps,
>>>>>>>> Dimitrios
>>>>>>>>> Hi again,
>>>>>>>>> metamodel.
>>>>>>>>> Many thanks,
>>>>>>>>> Steffen
>>>>>>>>>> Hi Steffen,
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Hi,
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Steffen
>>>>>>> Conference on
| Re: Copying models in ETL [message #561994 is a reply to message #3644] |
Steffen
> Hi Steffen,
> homepage -
> Cheers,
> Dimitrios
>> Cheers,
>> Steffen
>>> Hi Steffen,
>>> statements after
>>> e.g.
>>> investigate more?
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> put into pre:
>>>> pre {
>>>> Steffen
>>>>> fine.
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> copy in pre?
>>>>>> Cheers,
>>>>>> Steffen
>>>>>>> them from core).
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Hi Dimitrios,
>>>>>>>> pre {
>>>>>>>> Cheers,
>>>>>>>> Steffen
>>>>>>>>> Hi Steffen,
>>>>>>>>> Hope this helps,
>>>>>>>>> Dimitrios
>>>>>>>>>> Hi again,
>>>>>>>>>> Many thanks,
>>>>>>>>>> Steffen
>>>>>>>>>>> Hi Steffen,
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitrios
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> Many thanks,
>>>>>>>>>>>> Steffen
>>>>>>>> Conference on
<html>
<head>
</head>
Hi,<br>
<br>
<blockquote>
</pre>
</blockquote>
<br>
Steffen<br>
<br>
Steffen,
<br>
<br>
homepage -
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
after
<br>
<br>
<br>
<br>
<br>
<br>
e.g.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
into pre:
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
from core).
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
pre {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Hope this helps,
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitrios
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Many thanks,
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
| Re: Copying models in ETL [message #562033 is a reply to message #3712] |
Hi Steffen,
Dimitrios
> Steffen
>> Hi Steffen,
>> homepage -
>> Cheers,
>> Dimitrios
>>> Cheers,
>>> Steffen
>>>> Hi Steffen,
>>>> statements after
>>>> e.g.
>>>> investigate more?
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> put into pre:
>>>>> pre {
>>>>> Steffen
>>>>>> fine.
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> copy in pre?
>>>>>>> Cheers,
>>>>>>> Steffen
>>>>>>>> them from core).
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Hi Dimitrios,
>>>>>>>>> pre {
>>>>>>>>> Cheers,
>>>>>>>>> Steffen
>>>>>>>>>> Hi Steffen,
>>>>>>>>>> Hope this helps,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Hi again,
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Steffen
>>>>>>>>>>>> Hi Steffen,
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Dimitrios
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Many thanks,
>>>>>>>>>>>>> Steffen
>>>>>>>>> Conference on
Current Time: Sat Nov 08 20:02:18 EST 2025
Powered by FUDForum. Page generated in 0.07733 seconds
