Re: Xtext 0.7.0M3: Couldn't find resource on classpath - bug? [message #23367 is a reply to message #23131] |
Thu, 20 November 2008 00:28 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Dennis,
yes, please submit a bugzilla.
Would be helpful if you could provide a small example project (or at
least the grammar you used) so that we can reproduce the described behavior.
thanks,
Sven
Dennis Harmath schrieb:
> I installed Xtext 0.7.0M3, created a project, generated the project
> contents with the grammar generator class, ran the UI plugin as an
> Eclipse Application, and when I opened a DSL file of mine with the
> editor, I got the following error:
> Could not open the editor:
> org.eclipse.xtext.resource.ClasspathUriResolutionException:
> java.lang.IllegalStateException: Couldn't find resource on classpath.
> URI was 'classpath:/org/lilypond/LilyPond.ecore#/'
> <stack trace>
> Strangely, if I deploy the plugin to my Eclipse installation, it works
> fine. But I want to be able to run the DSL editor in an RCP app too.
> Did this occur to someone else also? Should I submit a bug on this?
FUDForum. Page generated in 0.03562 seconds
