problems implementing swimlanes [message #23105] |
Fri, 18 August 2006 12:10 |
Originally posted by: sayed.shoed.tavant.com
--------------090502090709090506060408
I am trying to implement swimlanes using GMF.
I am trying to model a school.The school has a number of classes.These
classes are to be represented as swimlanes.There are teachers who
are assigned to each of the class. The xml that I expect should be
something like this:
<classes section="Section A"/>
<classes section="Section B"/>
<teachers name="Lucy" class="Section A"/>
<teachers name="Karen" class="Section A"/>
<teachers name="Cathy" class="Section B"/>
In my case the teacher has to be represented "WITHIN" the swimlane
"classes" and when i drag and drop the teacher node on the swimlane it
should dynamically set the "class" attribute of teacher as that of the
swimlane on which it has been pasted.
I have attached the zipped file of my example.Could anyone tell me what
all changes i should make so as to get the desired result.
Sayed Aamir
Content-Type: application/x-zip-compressed;
name="school.zip"
Content-Disposition: inline;
filename="school.zip"
UEsDBBQAAAAIAJpmEjXVHJzSpQAAADMBAAApAAAAdGVzdGluZy5wcm9qZWN0 LnN3aW1sYW5l
cy5lZGl0Ly5jbGFzc3BhdGidjz0LwjAURWcF/0PIbqqbQ2sRqaBDlVJnqcmj jcaXmA/Rf29V
ii46uL17OZzLi9PrSZELWCc1JnTMRpQAci0k1gndlovhhKbTQT/mqnLOVL5p Q++dAL29kaNE
kVBnOSWP8nVG30musSO1rRlwJY0DdhCeqSogb9p1tiqy3Xydl7NlnhV/2IwA xrUFZuEcpAWx
UaGW6H6pdPAm+M62l/iE4+jz+ztQSwMEFAAAAAgAmmYSNa/bAKLwAAAAswIA ACcAAAB0ZXN0
aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvLnByb2plY3S9UsFKQzEQPCv4 D+XdTerNQ/oK
Kt4qQvUDYrK+bkk2Icmrfr5Jmqc8SsGDeNuZnWGGZcX605rFAUJER6vuhi27 BZByGmlYda8v
j9e33bq/uhQ+uD2o9ABRBfQpqzN7IUha6BPElPWsaVj8QGskQWSgMQleRUWt nLVAqRd8mgrb
bLECPkNvIxq99aAKavA+WyXpyrQCLgwMlEEfge11YsqFPMiDrAYIPxWyQ4Zh LNmxYT4nBD9J
+VWu18A2kvA9H+Puf2O3agdW/kloY6aT57w0BmjqIzh/7eO+FKi6c55S+dmM A9LTiWGaS+L3
L8yf7gtQSwMECgAAAAAAm2YSNQAAAAAAAAAAAAAAACMAAAB0ZXN0aW5nLnBy b2plY3Quc3dp
bWxhbmVzLmVkaXQvYmluL1BLAwQKAAAAAACbZhI1AAAAAAAAAAAAAAAAKwAA AHRlc3Rpbmcu
cHJvamVjdC5zd2ltbGFuZXMuZWRpdC9iaW4vdGVzdGluZy9QSwMECgAAAAAA m2YSNQAAAAAA
AAAAAAAAADMAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvYmlu L3Rlc3Rpbmcv
cHJvamVjdC9QSwMECgAAAAAAm2YSNQAAAAAAAAAAAAAAAD0AAAB0ZXN0aW5n LnByb2plY3Qu
c3dpbWxhbmVzLmVkaXQvYmluL3Rlc3RpbmcvcHJvamVjdC9Td2ltbGFuZXMv UEsDBAoAAAAA
AJtmEjUAAAAAAAAAAAAAAABGAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5l cy5lZGl0L2Jp
bi90ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL3Byb3ZpZGVyL1BLAwQUAAAA CACbZhI1tlUj
Z8cGAADlEAAAXQAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZWRpdC9i aW4vdGVzdGlu
Zy9wcm9qZWN0L1N3aW1sYW5lcy9wcm92aWRlci9DbGFzc0l0ZW1Qcm92aWRl ci5jbGFzc51X
+3MaVRg9N8EsIWvb0JpofbRqVQIxtKbWGmotpbSihKQhTdr4wA3cJFuXXVyW xNhq1fq2vt/v
t9WqM7bjUKMzjj/pjH+U43eXDRAgQoQZ2L17v/Ode77Hvfv3P7/+DmAHfpTQ xrDT4nlL1WeD
OdM4ztNWMLmgZjVF53kxMq9muBmMaEo+H7N4dtQZkeBi2GGYs0Ge1tRcngd5 dibIM6pVMaqe
H84oOUuYdTDsbmIWpVvic8DIKqq+0qmbYU8T66RlFtJWweQZYRoxdIvrVgXB w7CrCcK4yXlD
W5lhexNbYRdXprlWsVrXXChnkTluWotJo2CmOUPHHlVXrb1k7IvXmqeNbNbQ g7phqTOLQUfb
g0raMszFUN8EgytiZLgH7dgoYz02MKyPqzpPFLLT3BxXpjXC98aNtKJNKKYq 7p1BlzWn5kmh
+P/JiRDDOmUFF4aBtXFn6Jnl1rIUB3g+bao5ekKctvnix5V5JUgsZoMj04JV qK80VLBULRhX
81aoEwxXy7gGWxh61SpVV0BtqDUTSl0rYzOu9BDA9TK24QaGq5RMJkluVEOv h2G4rBEh0r7D
sK+FwnXPBb8+GZfjCgkBhtv+Oy8iRjZn5LkIzUqduuDHzTIGECQaJNiYYVjh GuVDvr467VuE
DwkVdsi4BYO0CoHP83ZWipSx1x5sAO4E1la1xiDkxq0MV6SOxFJ21qTyJVlT M1wRpSr83SZj
N25n6CR/VMOUfAw3VktcGlyOefWQG5Q41wn0+jilMs4luXPjDkrRCgtrMWe7 vlO43sdwdwN3
rYw0oNSJ/TggIcIwuHopla9GlfRDyizfFqeUNRUtLyOKg0Q1Eg8nk6lUMhoZ j40kaI31EU0b
Jg9Gwxa5nS5YnBzfhbslxKivt9Sda+SScQ9uYth4KJqIjsUiqYlw/Eg0FRsO H4oKpYZlJDBC
pZE2KXK8MQZjV66xZa0pl1qK0So6LW8OinawlHmhqamp+jKtB7y3UdT/j8Ch LhxGUsIYhXdl
F5IxjiMM7dR1VmkuUwxuqo5YlnKlpjhWNsTqITeOUcebKWhakBrTjl2lvt2F e3G/hPsYAmvQ
XsYEHmhelo5nkTAPylAwzSAb89zUlEWH++4G3FtaDYNECozzR6zmAjjMJMww bFm9Ch09OOZk
qDjO4BEdqNSgGDb5GkB6oEGXkCVha5/JMJCjTUDj+qw1R+H09cUkUMvsrZ25 v6BqlCcCi2Jf
AEVdmle0Ah+Z8eBhLIid+5GaTFgWe8KNRxnYVjHxpIzH8Di5VHI5rhPKzS11 Tcd9SEA8IeNJ
sXK3ZSy33ks0cYpZuYk5WAyXlso4MkejPCO2gyb1nhB/KuUQaUrsRWY8J+N5 PENVUMhlqJVE
5oiOyfUuvIgzEl5i8LcOKeNlvEJJRoFz6jp2QISuirsd5ZCIxWtNT3ETKl/g ZrUDweoNGW/i
LYYu8lJ6xs3a/Chn/qt4R8TvXYbImrSpx5qaKun1vowPhF7dM6rJE9X6i9PL RzKeFk9lvQqN
oX8tvhk2pw1NI6cJvmDHY8WpKeCrOjZFShMbUxaE2/GFjE/xGe0leiO0nsZg nfgG30o4S2fQ
Fo6g5SHxyjCqFWZVSoXvcI4yOZZIjocTkSj1mlYOsw2QSA9P6TB+UBVn4566 A++AWAKupeC0
4xL6SuhEFy6ldys3jdG5m3676W4v2ugLdPgDF+E9T1dt2ES/Hnt0kCx34jK6 6inNov9ewL6i
gyJhMHEydbAmHaxe/8+46i+sE5BbJ/2BIq4TIz+Vwb1w0e8dRGovUdpH9/ur nPSWnfTiRtxE
4C5x6HWcnCMLMWtIQPrpx/cH/Evop6IsYrvfu7OIXX7vkHend08Rey8g7Gpv v4BDjBURX8Jo
GyYri9xPMgBxwh+mhSYIf4R4jNKCDpO/MfiQRB9tfX4cQYD2lwFaYhBHsZ3m D5Ld7ThWxXuo
zHvI4c3IZtLhHSUvYla3PyCIeo8uYaoNRaQqsnTQVGC6CrK7DNldhkwj40C+ QJDt9B8K/AG+
BOqMw/1/wtNfxEMfQPYLAXadxZbf8PCx0s0vyF/EvHexiBM06UQRpyrOe0gB UL/3IEsEdHpP
MWgdWZvM1pKbMpmQQ8ZDL+pP4TQhMFHiDq3TFFdBPiQi/2zAS9ReaKO4iY8P lc9G/2949Vgg
sITXKUtdF/F2Ee+dF0nzYSVEm0kV4FEid5JoPE7ZeAq30o4wRI4rOlVT+xif 2ClDBe4QihF9
sQDJH+i/iM9rk/wMuXi5ap1SGUzCl/jKDopkr1isk148HNgBOxyA6wK+rg3i OzaeXHru4DF8
b8/64V9QSwMEFAAAAAgAm2YSNQAfzCscBgAARg8AAF4AAAB0ZXN0aW5nLnBy b2plY3Quc3dp
bWxhbmVzLmVkaXQvYmluL3Rlc3RpbmcvcHJvamVjdC9Td2ltbGFuZXMvcHJv dmlkZXIvU2No
b29sSXRlbVByb3ZpZGVyLmNsYXNznVZrVxNXFN0XkPAYFaJCa7X1LSQpEamI xkppDJU2DZRE
rPRBh8kFBieZdDIBsQ9ra2vfD6u1z4/th36qri5ctGv1q2v1R3X1nMmQhBAM SNYiMzf37LPP
3uc+/v3vr38AdON7D2oEjtkya+vp6WDGMmelZgfj83rKUNMyyyNzelJawbg2 Y5rGkC1TI+6Q
B3UC3aY1HZSaoWeyMihTU0GZ1O1iVOn8gaSasTmsXqCvSliEXonQGTOl6umV SRsETlWJjttW
TrNzlkxyaNhM2zJtFxGaBHqrICQsKSvGKgJHqsRyXFSdlEYxakt1odwiM9Ky F+JmztKkQP0p
Pa3bpym4I1oerpmplJkOpk1bn1oIutoOqpptWguhzjGBurCZlE2oxTYFW9Ei sDWqp2Usl5qU
VkKdNAjfGzU11RhTLZ3f3cE6e0bPChyPPlRThAS2qCvICHRtjLxA27S0l7U4 I7OapWfoFyJ1
oCM6q86pQaIxHRyeZFqhzvxQztaNYFTP2qFGCOxW8DieEGjXS2RdAdVSHsZS 7VWwE4+R8KaD
zQqtyiewjeiFZ3Qjacn0oFS50QjQV4Vb2DQMGtPNtMPwsIIOZtiilSExD5+C AzjYiAC6PHhS
oGdtLwpPI6p2UZ2WB6JUsqUaWQVBHCHX4+Gzw8PRiYlwdCAej8QF9q2yQ2qm JYORUTkliYgm
Q804iqc86CEzV6qk4Bh6BWrVZFJgR6WKx5l1n4ITnLxlOXkiMhA+Gxml7FuX xXPrFRipAFNJ
yjVYLy921XARHSefVnAS5NUmR16BBko7lCJ9BA6tbVTpUBOZ9KyCMM5QG1D0 qMw6y5LXDLWQ
QLBjNSe3sR29ygJCDRgUaJ3KGUaQ2qu71109zTiL5z0YEvBvAE1BP14oq4WU oB5Zq5YXFcQw
LKCYc9Iy1AVXjb51ql9hHXhIlYS8ZFeX1GXWAG6AiXNDE/nSJ+yFjGRu5xSM 4bxAIyHm51Yv
zR0S2JzfRsIzNCqT7EuV/SbGXzrJyGuxc4wJvKLgVVygds9lkqotl1e3B68L 7HnA4nMdfAOT
Hqi0B6w/sQINRFahit2+HaJG215adNhQs9lQ55AHU1VPnTFdzkurNAGzmlGg Y1agmbLkf5MW
J6nYIhIGnxQpgfCGFFyNNT6eV9VUkGFVW6d0S8ZKXeIlSj38Mv+qpEvQBAIb yS2wU8vvqzE5
77i2YpP3d1TegCt06xhTuqQgh7lGXMbbHrxFfq5j33WPLQXv4F3qYDkUiycG YuEIV7L+cNpy
L+M9BVfxPtmlWZK7kP0X2E92rQ2UbxJW+5qCD/ER2etGsxojqqWmpM2un3vY bZb7jC1Q00nS
0PkuwBLtj/mk+ITSVlKaq/pMwef4gtZpnldCqtoMEzr4wLrcaXzcpitZ27bW 0foNvvXgBl3x
1nN/WR7i++aIkZvWaV3exC06L4o29q3rJrQaiag35W9ygzpfrNpX35a6uAbs JfNqsYk+HjSi
GZvpas5XBLq10f9WejuNGvoA9T7/PXjv0FMNttP/Jmf0GEX2Ygc9teVn0Xc7 4Dw9gkcJQ/C1
xsWKuVhe35/YdR+NDLnnPL/8UcDdQnxAJ4wHzxCbcAm2t4DtxT7sd7DpquJi Z1zsAMEduo/9
jN3J2Ifuwr+E7hq4L8eLL8WsbVQHMExZRyjrS8R5FIeRKMkeKGQPuNnr+Jh3 s0eINfP2+PyB
ezhVBK6nCaDtkIH25KcUgDwuED+dpqcaeu6nspch65zErT6/bxED3sgSnqvB IqLl4LMlLFsL
4K0FjUaonjxkyNXI4/OOLiJRDmSXAK1mKXjLdIGu0yjP6vf5FzHu9762hIka /O7MDyD/x4iM
0O77G/KCnzygk7Wu9h4uLiJ9h+15s9hNO4kCcIVcuEqeXkMf7ScnKM1pWuNF Uv0FUv3IEl32
gDZNl9Sv9MYC9zgezPt9ZPxdLCzhiiDZPljCdbKdR487o5+WjBaJnKQGBG4Q nZtU4y004Dta
FrexjZ7baGwXfsBu/EhX/J9o8fyMTnoO0NhR/FLicU+BaA++xFeOFj2Ojuwx 3etcyl2OrkDd
XXxd7sZvDp6S/93FE8SGZ93+H1BLAwQUAAAACACbZhI1jM7aTUEBAAB2AgAA bgAAAHRlc3Rp
bmcucHJvamVjdC5zd2ltbGFuZXMuZWRpdC9iaW4vdGVzdGluZy9wcm9qZWN0 L1N3aW1sYW5l
cy9wcm92aWRlci9Td2ltbGFuZXNFZGl0UGx1Z2luJEltcGxlbWVudGF0aW9u LmNsYXNzrVBN
TwIxFJzCysKyguIXVxMOyIHVixeMFwIGg8YEQvRYlieW7LZkt+Dv8qTx4A/w Rxm7C4kx8WRo
k2lm+uZ1+j6/3j8AnKFqI8PQ0RRrIafePFIz8rU3eBZhwCXFibIUE4p+pM5E 6LtgMRWy1gvn
AYUkNddCSRsWQ1NFU4/8QMxj8ih89HwVhkp6nZvu2tRZXa4YQ+5CSKEvGbL1 kxGD1VYTcpBF
wcUWcg6K2LbhMpz/L6OLEsoMee77FMe1U4bren8j320lcct9Iel2EY4pGvJx QAyVvvJ5MOKR
SPhatPSTiBmuNvQygzNQi8inrki6V/+wNGd8yRncnpQUtQMex2QClH43wjHM 3JEsZraZt0Hb
sFbKgULjFfnGG5wXQzLYMVhKDUNYuEceD9g1zF0Vo4K9tG4/xQMcmtNJWxVx hMI3UEsDBBQA
AAAIAJtmEjWTQsZhAAIAAM4EAABfAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1s YW5lcy5lZGl0
L2Jpbi90ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL3Byb3ZpZGVyL1N3aW1s YW5lc0VkaXRQ
bHVnaW4uY2xhc3OtU1tPE0EU/k5v2y1rQfBSwQtC0QKmKy+GpMTENMXU1IZY QmJ4WrZjHbKX
ZmeKf0vkgUSjP8AfZZwZ1qIEHyDdhzk73znfd86ZOfPz19cfADbw1EKG8EIy IXk0cIdJfMh8
6fY+8TDwIiY0csT7LDmHWn0ud4LRgEcWcoTFOBm4zA/4UDCXhR9cPw7DOHJb b7fPogjFdre3
+6rbbBE2O9dL1SAUhqnc62tqVNvhMGAhi6Qneawli1uq7ojLl4RsbXWPkGvG fVYC4YaDMkoq
6Zbx2wqacZBHgTDd4RHrjsIDlux6BwEjzHZi3wv2vITrvQEt3CKs/+doRpIH 7jsm4lHiM82V
cVJCFnd00ruEjdp+5wrUhqlcfuSCUBmwtNsLQQS3tnolVd3zfQcWigR7LEto K52JXYDn+0yI
6nPCm9qEVPVplHqmlW2ur6dyCal+6B15BKcdRSxpBp4QTFhYIbQmUgSh/C+g npqaMfXkMrin
x0j9lfTRKptXqw09dFNq56oI/U19A70/hXOC6WNDu2ko2jmv7BxmDQpFK4/J DYWQsvZa9jvm
TnH7nFo22deV+5nKVzd05ywYFVMPqcrmU6G6stqX+4KFz2ONgsE2/+LmUq6N B3iYcqvGczm3
+afsmSIeYTFlrKTZ8msnWDi+QFkad5rBY7MuYRkwPetUT2D/BlBLAwQUAAAA CACbZhI1RBw0
9iEGAABBEAAAbwAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZWRpdC9i aW4vdGVzdGlu
Zy9wcm9qZWN0L1N3aW1sYW5lcy9wcm92aWRlci9Td2ltbGFuZXNJdGVtUHJv dmlkZXJBZGFw
dGVyRmFjdG9yeS5jbGFzc51XW3ATZRT+NqRdSJYWWlraglzkYpu0BJCrLdWa UmgJ5dJaBAXd
bv62C8lu3N0WqgKKeMEZnx14wxdnHB5whraDjogzDsz4oK/66uj46uXd8Zzd bZImgUSmM/kv
e853zn8u3//3h3+/ugdgG67JCEjoc4Tt6MZ4LGOZZ4XmxIbO6+mUagibd6b0 pLByW/2OSB/1
d3uSasYRVp+qOaY1LSMoYdejsSYdPZVbFupWS9htWuMxoaX0jC1iIj0WE0nd ybkQN9MZ0xbq
aEoUKi+W0PF45f74hGqMi0HT0cd0YckISWgro9Kr22SQ7UlYkVEtYTgLDdNx ExX5nFyo1ymh
Rlvgj4RYGaSCAzCEPZnJmJYjksPTGWFLaEycVadUL85xM5Wi8OumQZJ1tjZh mqn81FG0E5Wk
vUiR4JZrKdW2F6LtqgQtXqhHYPWOULUJYS2E21MJ3HCxJgFWd+mG7nRLWNTa NiIhGDeTIoRF
WKVgJZpkPCWhvUzSFkQ6hNVYtQQS1ilYihoZT5PTuUD3WJY6ndBtJ4T1ntwm BbVYJuMZOkaZ
nO6nJR2y10yrupF/jjDaEJURocIrlVMF7eigE6rJpISGVi/vFJ3x2JFRjlZn 2ykZMQldZewP
Odak5kxaIsnG46bhUI3P+yBjG+W1DMKwJURJ3WclbC2jy3oJdVSkclo7JWyr QIsUMsJypofM
SUuj7qxN6IYYnEyPCmvY69e6hKmpqRHV0nntbwadCZ365GBFlV+e8Lh6NUuo jvDaxP9KxNLa
VtTNmplOm0bM4KqajvminVwv+xQsR52M5yXsfKKWDKEbPVzdL1L0WiuzPH8E bpE67xBud/qf
2a/9CuqxQsYBCTuepLlD6EMPFbCH7jdrHv4hBQ1olHH4sbfG47o9hARbaBgX znHTLCLnzhJp
qPBKcRNzXEEYSgjDGJHxEkXhSbhewREclbDSFs7RklfI3uKMVXSHcOaW6ba/ 7DMtvgWYN15R
8Cqzw2KNepJ4xWb2O6PgJG8GHZLi9iiiDAlVKluQoJWroewlVIJ4Kix89imp QMUoOWpkb8GK
LRO3lqC9Uv4UbYUotWfY/lm2Py4jRQSSk3LrOIRzIJY1OWQh3e43bEc1mGmq TRdEgqzOd3uY
WJgvAGHwqmw6+90zTHuXTFaR0hmGjEkFFoiiGoxSQuXfG48Ap8eCJdLmlJjf YVtvKrjAtpaP
6ZZYoEevkcoSoanuC8Pz/ZKCt/A2t8slCYqRJ0A37v+Bo+Am3aeXYGa7quAK mphMrnK/X6WE
eLTfpzOnt1ZA1Fs4u3Q9041Jf1Xk6xJUI8jdTc/gIF/r7kjXtjsSHbsj0Z87 Ek3RuJT06QVB
v820uklIEo0nInNoiXyN1SfnsGYGa2m6nqYbZrAxcgcb6zbfRWuApHi+JW++ NW++PW++w5t/
SdAB7KLfzeQs6PRBWtVSPFpwgPYOYjv6aTVAf4cwQoHZTVKK5xL2YC+NEp5D p+/uAOnztyYy
0vUQteRm90ly/YUZdPHW7ay9GjoYcJqCdIYCoObhNmVx4yVxez3cPsY9OINe 3irEtQnXIdzz
JXH7S+IOeLgJxh2cwQBvFeJeI9yPCfeTkrhEwT7uPhr5Wz2BHHsIOfI5Qjyd xVAOstoV+TQP
qj4LdQIv+1DdJB1g6Uh0BsdyCQu5uzepzj5zERo9KR+BZ2EXVWJG9rEO+1jN XAPRuzgVwA0s
jUTncPoGqhbdCt4qcO6LPOjmLHQzXsPrLjQRqw+93y160FGjFD+t8JR3XKB1 nkgWSIbAmPtd
diEDLuS4D3mRpIM0boq0z2LiOtZEou1z0Afbv8O566hpv49zHbNIX0dVx20p Z7CRQgJ8g8W4
R5X8LTXkfWzA964DEQ8w68AmZNyT8MxzoJaa8Q2acdsRR/quxP3AhSlwaylw TgCFmfiRxp/y
whXOGgljigqRw3XhkYDTxYA/0/hLGUBiQh/wlA/Y4gNeDIAL7oFr4Vh0Fpdz +HVuFH4l/N+I
hH4n/T/y7LRk7bTgHbzr2rmSJSTVr+wot/MDt6q7ZvEeN6G36p3F+9w63mpg Fh8UGv6Tmukv
+nfnb0rHP3nVH81W/4euxkf/AVBLAwQUAAAACACbZhI1ye463DgHAAAPEgAA XwAAAHRlc3Rp
cy9wcm92aWRlci9UZWFjaGVySXRlbVByb3ZpZGVyLmNsYXNznVf7cxvVFf6u 7XhleQlYgSQE
tyQ0UFtyrKSBvJTiKrISRBXF2I6DnbZiLV3bm6x2xWrlYPouhJS+W6CB0HcL tPQBSalSl5lO
f2pn+kd1+l1pLcuygmTsGT2u7vnOd8757rln//u/f/wTwCH8TUOXwBFPljzT XowWXeeSzHnR
qStmwTJsWVIry2ZeutFpaeSWpJvyZGHCX9PQI3DIcRejMmeZxZKMysJCVOZN b92scX88bxQ9
ZdYrcKyNWZJfyWjcKRimvdFpQOBkG+spzy3nvLIr88o04dietL11hCBDboMw 7UrZ0lYXONjG
VtmljXlprVttb58oP8iidL2VKafs5qRA70nTNr3HaTyUbjbPOYWCY0dtxzMX VqJ+bk8bOc9x
V2LDMwI9CScvg+jGDh134x6Bu9OmLTPlwrx0p415i/ihtJMzrBnDNdV3f7HH WzJLrFD646ki
JrDd2MBGYHRr7AV2LkpvLRnjspRzzSJ/Iav9Q+lLxrIRJY/F6Ll5xSs2XFsq e6YVTZslL9YH
gU/o+CQeFNhlNuR1A9Q9zWYqV/t07MEDQQJ8Ssd+PCxwv5HPZ4yC3IwhcF8r NjPK+tM6hpT1
HlonLKNUamXe61RNVB02wagYRnTsxv0aRgWOfrR6Ek6h6JSkKuDGXPbjAA7q POmfIVsmddJx
vHhTdWJDw5vq0yF8TMX6qI7HcIRRKHxZqmpXCasaY7QFuF/8auabDGIBHBPY nT2fyvraytpM
fnZBGuo8K3cndMRwUqCP7njQqVCBRxoLUVtck0XjUgA8Sw8p8M3lyOb9j6Zj B/A56qORhLdS
rDo/pZwnBJ5s4bCTlRak+pDEGQ2nBQ7f+cTVP00YucvGotyfpq5dwyrpeAIp gbumk/HEE8nJ
bDYTP5tkkJsrmnNcGU3GPXqdL3uSfj+PsxrSLGBHPbwpXzoyCAvsOJPMJCdT iexMPH0+mU2d
jZ9JqkRN6HgKkwKDOZelk60xhHhgi41tS1rqqER3yNPaFWJYp2vSi83NzW0+ ppsBL7Yq+sdJ
cKwf05jRcJ4NdWOn0nEBTwt0s7fcoQfNBTDH1tWo4JzqQmvnSGnuCzq+qKSz vS6dRDo+NSUQ
4MFKFSiypnO1sd02LgVg8PgvlC0rypZ26MjavdCPHKQGsoxsoW46voSF9mfa 963EtqTDxCUB
3VmWrmWs+OyPtWDfUTwCGnMwLZ/z2qfAZ6bBFth35wNcz0gBRR3Pwq35UDeL wL1DLRCD8LCs
ocxO1Pybjit4jveHJe1Fb4lKGBpOaXiet13zzlNl06LEFNZXdHwVFt0uG1ZZ nlsIYgVfV6PB
N5pEtJbrmQC+JSD2qo0v6riKl+jSKBalzYIe6Kjj+u5jCuLbOl5WYQc8Z61t b7PUmLTx/vOx
2NJqHSCxxFWZVzdJm1aRUW8mJcQO7l/DP9TxI3yfGi8X8+xCiSXScaXdj5/g VQ2vCIQ7h9Tx
Gn5KjbFqfktIjavSNXCv3vQxVYvX246JM6a8It1GB4rVDR1v4mcC/Uob1d+k 26yPuvCv4xeq
fr8USGwpN5ux5uZq+fq1jt+ofA0smK7MNOZfDUe/0/E99atuN6BxTNmKb45E Ocey6DQjr1Tr
sWEoiww1TGWJ2sbWlBXhbryr4x38nteQ3QptZ2uwPvwF72t4r7Mnn/qSeiaZ sMqLJqVwE7eo
5FRmajqeSSQ7nJZbIDEfwdq0f9pUw/fuFhP1qAoC+1iebmzjv4Y+9OMuPsCp IZGjPV8H+O1x
dPEf6A1HbiN0k5+6cC9fg9XVR2n5GO7jp521XXzfBVQ/ccokhlCjr4/1jI81 GP4Ag//BDgW5
90I4UsFD6uURtfx+3cNOYiv/GsbIK44QThF7vMHbYN3bIIYRppceNV773t6l ldp1QsGG+RL5
Fw6sIsrzWcHhcOhoBcfDoc+GjobGKojfwnhPd/ctPClEBedWMdWFC+vRnmI+ wNmkB+fIaoL4
T5HHJCObor9pjuXnyWCGHC4ggqcxillEMYeD3H+YdsdxsYH3iTrvE3XeQx3z nvV5z/q8L7bl
nSe+JO8F4i+SxxJ5m/R3iV4vk4FFDgXytsnbIe8ieUvyzpP3sx/JW/BWzfq8 k/Sidg2EI4po
6JlVzHehgsX1kvZyK/B8A+RAHXKgDnmZhGqQLxOym+8xpqCwCkfg7Mi/ERyp oHQDelgl4Pg7
ePBDrMzWvvwdX76Nr4W+WcEL3PRCBdea9fQilXuVBF7ik9w1xnG1SmZvzU2d TMwnE+RDznfw
XSII1aV8WteoSUV+TKn2B5EQqf24i3VTfyOo/alAFdau8Ie4PhuJrOINHrWe 2/h5Bb+6qZT/
2/Uy7WFmwEa9Da9SwNdxDK8z9Tco/jcbcjVWpzeGt/B2VTbsUz6pFENQQWjh yMht/KH5pL5F
F283xKrVwTT8EX+q8tWqUatY+ejlw45WSwL03MKfmwv5XhVPr/3u4wn8tbrr g/8DUEsDBBQA
AAAIAJpmEjUjsNtljAAAAOwAAAAvAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1s YW5lcy5lZGl0
L2J1aWxkLnByb3BlcnRpZXN1jsEKwjAQRO8L+w+B9qibH6iCB4Ue9OTRi6ah RtJs2CSgf2/q
rVDnNvNgeI3qDMePuPGZ9wiN6vSiz1PbDy0CwsMFcsH4Mtikdoo2NwS1jDMc kl4B5+P1sO0v
pzUWfRnr9Xvy/2EUjlayswnhdZdEhqfovCWWwcpsg5C4iLFEtSUxGoFLjiX/ huquv1BLAwQK
AAAAAACbZhI1AAAAAAAAAAAAAAAAJQAAAHRlc3RpbmcucHJvamVjdC5zd2lt bGFuZXMuZWRp
dC9pY29ucy9QSwMECgAAAAAAm2YSNQAAAAAAAAAAAAAAACoAAAB0ZXN0aW5n LnByb2plY3Qu
c3dpbWxhbmVzLmVkaXQvaWNvbnMvZnVsbC9QSwMECgAAAAAAm2YSNQAAAAAA AAAAAAAAADIA
AAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvaWNvbnMvZnVsbC9j dG9vbDE2L1BL
AwQUAAAACACbZhI10NLe39QAAADfAAAAUAAAAHRlc3RpbmcucHJvamVjdC5z d2ltbGFuZXMu
ZWRpdC9pY29ucy9mdWxsL2N0b29sMTYvQ3JlYXRlU2Nob29sX2NsYXNzZXNf Q2xhc3MuZ2lm
c/d0s7BMFGAQYDjCwPD////79/fb28czMDAcOHDgTNqZhoYGBweH///j58fb /79vD+QCxefM
mXNpWSVQfNd0NSDaOkl5XZf80iapeZViM0uE//19D0R/P58Hoj/PF/++28wA A4o/WRhBtA6I
ANnJwBqjoNCXEmmnxjDz7OEpF7ZO6m/um1TiafzZpOda9iRNMfV+qeRM50CN 2ctPsIv0ac05
ddLNikFH7b63i4VAUMPsFwkfFp1sZ1qY4CZ/o6Xmdq7W6Zfp+Qw5NU2pjU3Z qooM1gBQSwME
FAAAAAgAm2YSNVmfx7DUAAAA3wAAAFMAAAB0ZXN0aW5nLnByb2plY3Quc3dp bWxhbmVzLmVk
aXQvaWNvbnMvZnVsbC9jdG9vbDE2L0NyZWF0ZVNjaG9vbF90ZWFjaGVyc19U ZWFjaGVyLmdp
ZnP3dLOwTBRgEGA4wsDw////+/f329vHMzAwHDhw4P78+w0NDQ4ODv//x8+P t/9/3x7IBYrP
mTPn0rJKoPiu6WpAtHWS8rou+aVNUvMqxWaWCP/7+x6I/n4+D0R/ni/+fbeZ AQYUf7Iwgmgd
EAGyk4E1RkGhLyXSTo1h5tnDUy5sndTf3DepxNP4s0nPtexJmmLq/VLJmc6B GrOXn2AX6dOa
c+qkmxWDjtp9bxcLgaCG2S8SPiw62c60MMFN/kZLze1crdMv0/MZcmqaUhub slUVGawBUEsD
BAoAAAAAAJtmEjUAAAAAAAAAAAAAAAAwAAAAdGVzdGluZy5wcm9qZWN0LnN3 aW1sYW5lcy5l
ZGl0L2ljb25zL2Z1bGwvb2JqMTYvUEsDBBQAAAAIAJtmEjXsUMRfcwAAAIEA AAA5AAAAdGVz
dGluZy5wcm9qZWN0LnN3aW1sYW5lcy5lZGl0L2ljb25zL2Z1bGwvb2JqMTYv Q2xhc3MuZ2lm
c/d0s7BMFGAQYNjMAAYNYNzQcODAgYaGBob/QO5/IPv/fzDrP4h9Ju0MUMrB wUHxJwsjAwMn
gw5II8gMBhY9g5Oeq/davP7yTYX/YaHrdlPWWykJXgsWfrXR+zhN7apZec9K TX7d5Yydbkcm
CgkzMlgDAFBLAwQUAAAACACbZhI1BFEoG3QAAACBAAAAOgAAAHRlc3Rpbmcu cHJvamVjdC5z
d2ltbGFuZXMuZWRpdC9pY29ucy9mdWxsL29iajE2L1NjaG9vbC5naWZz93Sz sEwUYBBg2MwA
Bg1g3NBw4MCBhoYGhv9A7n8g+/9/MOs/iD1nzpxLyyodHBwUf7IwMjBwMuiA NILMYGDRMzjp
uXqvxesv31T4Hxa6bjdlvZWS4LVg4VcbvY/T1K6alfes1OTXXc7Y6XZkopAw I4M1AFBLAwQU
AAAACACbZhI18AWLyXMAAACBAAAAOwAAAHRlc3RpbmcucHJvamVjdC5zd2lt bGFuZXMuZWRp
dC9pY29ucy9mdWxsL29iajE2L1RlYWNoZXIuZ2lmc/d0s7BMFGAQYNjMAAYN YNzQcODAgYaG
Bob/QO5/IPv/fzDrP4h9f/59oJSDg4PiTxZGBgZOBh2QRpAZDCx6Bic9V++1 eP3lmwr/w0LX
7aast1ISvBYs/Gqj93Ga2lWz8p6Vmvy6yxk73Y5MFBJmZLAGAFBLAwQKAAAA AACaZhI1AAAA
AAAAAAAAAAAAKAAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZWRpdC9N RVRBLUlORi9Q
SwMEFAAAAAgAmmYSNYFkSB8SAQAAKAIAADMAAAB0ZXN0aW5nLnByb2plY3Qu c3dpbWxhbmVz
LmVkaXQvTUVUQS1JTkYvTUFOSUZFU1QuTUZ1kc1OwzAQhO+R8g4+0BuxgKOr HgD1gNSiiEjc
XWcbFvwT7E0gfXqcBNKgtsfs7Mx+nmylxT0Eyl7BB3RWsFt+kyYPjS01ZNtf dRLvJulZGhBs
UeumQtt/TErRmZ3TqMYNina0Fa+9ewdFPHyh0dJC4FAiLVmIogaK4SvyzTFl zjMjetQyhFzS
m2B8Gt4rwlaS86fniulcnLRYgj+O1hEgH/ivnkytwYAlSfHoDMKWferiz/zv oRunpMbDYBFs
bCJN1t+185TlUn3I6kwBp0Rp8gKfDXrIxmDBnK84KI11AK6cB+4bS2jgOk0u F7psMeAONVIn
Vh5g4Ogd8zQw+7H4c8sRflzLNvLQFSQ9Rf7hr/wAUEsDBBQAAAAIAJpmEjV1 evQsCQIAANEF
AAAwAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5lZGl0L3BsdWdpbi5w cm9wZXJ0aWVz
rVTLbtswELwHyD8skvgWqG16K+ICQawABlrZsORcBVpcW2xokiCpKEbgfy8f EiK7btGDfSJ3
hjOzq4Wv4b6SaqfZprbfLy+u4f7Twd2Xbqb05vLCn8Zn+HmdQkIlKQLFV+RS of7mqwATCdms
gKomYoNgawSlPWwZGlihbRGFKzMDnAkEIqgnxbdXo9EI0mwCsycoFg9Z/uOh SCcwX8zm6aKY
pjk4wlV4mMQXP8mL0wCBbW+zA0G2eAtEKfTaMmTwR7kOxzXj0TZGjDoeCO04 fmNi7qFocr7R
nfMj/M+8zplc8WbDROYGDGPIW7blRLjPmlJmIW+Ukto6kpavjKLuaG3bJvhG topjIvXGy5TL
afmokVh8rBmnpcU365jvn/ensTsPftn/nfA1Ek6AUnLLlINjFTL3UZ0MLIVL GESfXL3R+Odb
iqbSTFkmxcf7uGuVJ4SF2ikMemupw9J4xXVU7BfOIMfKIoX3u30ytMnZyq3y 5l9GJlJOWg11
b6EJDZ2OwDQoolHYpJ/+vNvrSWct9VGKoo5mXQ9huPFpXtVuqGWI45Yg3Lqu ODGmB8Il1gsk
VY26R7prxJbiRchW9Nhs9cv11Fv1ICWWeMIYnglv8ChJ5Z3QlH3PnTeaw7zR dUjrgphheuPs
3QQGrDxWDlvx/zEDjl/1Q0IIdRzpsKsPcCmMwoqtGVLf229QSwMEFAAAAAgA mmYSNUlcXhEw
AQAA1AIAACkAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvcGx1 Z2luLnhtbKVS
wU7DMAy9V+o/hGjXpiAuHNpNCJg0iQPSxgeU1CtBaRI5zlj/nmSbuh5ASFsO kd6z/Z6duFrs
e812gF5ZU/M7ccsZGGlbZbqav2+WxQNfzPOsWoDUynk4597H3BSKwZuiyDNW SesGVN0nzRMq
pzASs1U7y7OiOJY4HTplUmI86a5gT2CSNHNWGaq5xU6cXAX0WwGtIqEI+je0 O9UCPraNI8Bl
I8miAs9PctX2wAzsCOMJqFjNuAla8zMrdeN94gk8xYGFQ/sFksT6W/W6MeAT c7A6U6u/Ghgm
yj44Z5Gg3QwOksUYYez3uUaj1UuEsZln2zfKTN0mGuwfjTVhkBQQ2iTwZE18 WrpAZ4MA1ymk
6tfmA/SFtbHMAdKwtgElcFYe/rgqx205rlM57lOe/QBQSwMECgAAAAAAmmYS NQAAAAAAAAAA
AAAAACMAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvc3JjL1BL AwQKAAAAAACa
ZhI1AAAAAAAAAAAAAAAAKwAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMu ZWRpdC9zcmMv
dGVzdGluZy9QSwMECgAAAAAAmmYSNQAAAAAAAAAAAAAAADMAAAB0ZXN0aW5n LnByb2plY3Qu
c3dpbWxhbmVzLmVkaXQvc3JjL3Rlc3RpbmcvcHJvamVjdC9QSwMECgAAAAAA mmYSNQAAAAAA
AAAAAAAAAD0AAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVkaXQvc3Jj L3Rlc3Rpbmcv
cHJvamVjdC9Td2ltbGFuZXMvUEsDBAoAAAAAAJtmEjUAAAAAAAAAAAAAAABG AAAAdGVzdGlu
Zy5wcm9qZWN0LnN3aW1sYW5lcy5lZGl0L3NyYy90ZXN0aW5nL3Byb2plY3Qv U3dpbWxhbmVz
L3Byb3ZpZGVyL1BLAwQUAAAACACbZhI1iVttsOwEAAD6EQAAXAAAAHRlc3Rp bmcucHJvamVj
dC5zd2ltbGFuZXMuZWRpdC9zcmMvdGVzdGluZy9wcm9qZWN0L1N3aW1sYW5l cy9wcm92aWRl
ci9DbGFzc0l0ZW1Qcm92aWRlci5qYXZhvVjfb9s2EH5WgPwPnFdgcmrL28se lqVr4LiFgcwN
4rSvBi2dbLYSKZB0XKPN/77jDzmSLdnpBg8ObFG8O959/O6OzODi4vyMXJA/ Y1FsJFss9Rs3
HtRf2Jevxskr8zA4Pyto/IUugGhQmvFFVEjxGWIdTdcszygHZd48sgTk5fmZ +bC8EFKTz/SR
RivNsmgosgw1mOCXDbO3TOnLip6QiwjijBUKIsjTKBZ5LnjEhWbpJrpOaKFB vqOxFnJz+UKt
iflhMfU+HNOyft2DEisZw61APSEPqUHC9BYFDBelFNB5Bi/1tm5gPMIhQn0j csr4WEN+94zw
yywYpVs6h+xfaaJSAVJvphaAF6tOtVzFeiUhMUaGgmvg+ocdeJAA/0W/4v8N qFiywu3ej2jb
gd+8l6p+YrAG2ca09uzZPt25RLNaA5+sD0umCP7pJRCGvpFyOUKddyQV+Ey+ vc0Y/3JglWFG
lXoiYm7fu8T/qd8nc1gw3l8pkP1ExKTff/M8BzzZn3m7AA6SakjK+rCaZywm sVmA2GWqIJ6f
BfAV9zFRpAFbnEV8Mshxo1WAo6Cd+z03f5BkXqaFQn52Lzcq7+vMJ99wwm5F UO5FLLiyHihC
OWE4oBwFUyly3IbUJTpOJTiyxYchNZx+K95BO+DBDuKBhTzwmO+hHdYLTkkS P+zaeAK1whDD
nSlkXfBkmLcTrwTEmjsCFh4ckmzzSln+mUlnL3E8OFnEplmQBej9DFfhB8tt T3EfK0tJyBor
giJXV4SvssxLOliiFtveqM1NlKVJMnUdbV+4IhsYSIPAYUha/GhDHtfArybQ t5h7H0gK1GTE
CVCXQuMauK2PgiXkYNiN8DeHHKEhi2MYS3Qdmmu2lQjCMGxtqN0dEpvduxdC 16XCbs+ZMsTZ
6eq1OSwtWHnCzuzjeGZTa6ZctDMPcKdNet/5WbldqN7pkQM2a5N6U1RW2W0N eFbCsGiG5fz2
ejqdzaaj4cP4w6SUx8IE5XOKYs2DZrSj96PJ6H48nH26vv04mo3/vn4/KjVM mlSfu0fLhY0m
WrD0ZJXA0w03YpwjNI3084knHkFmdOPknECvkQvR1lonxTAHKPvb7wMbS+d4 zCYjM9NXsA1/
1f9zYXRsNFE94OKNaHgR5+IVCcMjp4Wu1zao+LQPXVXzuHpLroyS79/diygD vtDLsGtmfiV/
Wd40ZpcjO/njqMRr0sHPa2e/bRuW2HQzUCQXCXrFK+cwReYbEtMsM+H7k9LP qyJBHIdLliUS
+BPRgrhX2LyNdLz0IJPYy9iubiyZmmVMUfJoz3y1xXpkvWTxEqs9KTAEdAgt l4umTII9IW6G
6O4CkqeTEcIWbF5dK6yeTWs+e4LUIQlrEr7zqTXTGFxtzvDjnStm45tjpIps GnTLphtTBftl
rl7dHD+CPexCDmuyf+qu+dYju55O/KEMK78vi7ZsuvQOSm4/N293LKgDuYtM e//GvTc1IN7e
gIlISzY0XifMDRR5Zi6R5veOSpoDFv0n5Uy7tjK39MOkQ2vWfklRvaQaycuR S46nWHhW3NwX
tPFpe/w/7TnBhzuBtSVT9SD1/L8Awvene6SpcLktOGC00VLlGLazPfeufBng pG8BJHM9wFdt
c+mq3rZ+UVvJ05XwnXbU2KFqfW2bN+bOdJet0JdoPJk+XE+Go23Y+PUPUEsD BBQAAAAIAJtm
EjUf1+ZgQgUAAPkTAABdAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5l ZGl0L3NyYy90
ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL3Byb3ZpZGVyL1NjaG9vbEl0ZW1Q cm92aWRlci5q
YXZhvVdtb9s2EP6sAPkPXFZgcuDI2Jd9WNaigeOiBtIkiL19DWjqbLGhRIGi 4xpF/vuOL5Il
2Uq0dR4SJKJ4d7x7+NyLRufnpyfknPzBZL5VfJXoD249ar6wL99N43fmYXR6 klP2RFdANBSa
Z6soV/IrMB3NNjwVNIPCvHnmMajL0xPzw9NcKk2+0mcarTUX0VgKgRpcZpcH dm94oS9relKt
ImCC5wVEkC4jJtNUZlEmNV9uo6uY5hrUJ8q0VNvLnlq35h9n1Pvwlpb16wEK uVYMbiTqSfWa
GjCpIJrMtFozvVZUfAKK/+FVnZjrCrloOsElonstU8qzqYb0fgdqPwtG6YYu QPwrTVTKQent
zMbcW7UMGWJjZCwzDZn+xw7MFcCP6Nfg8vzoq/oXhw2oLnp0U37GEinFZR/J 8mmPsj107l3u
WZ9GPn/nCS8I/uoECMfISRkMoS52spT4TL5/FDx7ejOGFyIXdsMVg58uLsgC Vjy7WBegLmLJ
yMXFh90eZPH+zscVZKCohrisGeuF4IwwQYuCuHPql3R6EsA3vOm4IAfuDncR IQEpUqEIcBV0
Z8fQ7b9KQy/TQTK/u5c9tffN3CDfccNeRlDeBpNZYT0oCM0IxwXNUHCpZIoX sXQXj1sxrmxF
4kg9p98JeNCNeNCCPLCYBx70fbjDZtEseeKXAxtQUKwxxrC1hcQLXgz5WgEr QLAzx8Hco0Ni
KJjiOSoWloJm09mLHROOFrJpIWQFuryo650n4Z1ltye5j5UvSchrF1uTJ+/f k2wthJd0sEQd
tr1Rm56BASoIHDKkw3oXnkUOzLCiIIncEC1JlQBlGv+MLowTLmIF2YulEqoh RrGRjiFeI9+Q
ezQ316E4okSWrgm5cpC507y1g0XRND80jC02HrvHl2EvhQdI5TOUOijb/6wv dUWeVdEyhc5X
O0cjzm4yITV8fffu5g5rCXaSZs/ijjEo1jYT0TgO27Uf5yNMSCqwXo8/393d PD6Ob65ms8ns
x4zMJ1fjz5MHb6VO3bbBA5z9Ly9CSY2III/3x6fqTvy6eR9D4pfWYQ/9aETG CbAnW3z0Ngci
l/a5zLDYiXsbNpF83LtaVmUOphYGYRLI20ZssQ2RsAAoqVrLlgGmPaHYA9wZ kSsL3nyTE2VE
ZSguhrfKrSvt0Yovj5YRHlP0c5oicQ6mgI8IU1cJunVyZSCo2Bqcw0FUWTtb YpaMUPbX30Yu
mLNBryYjTGvGWeab/p9bC5LS3DhGMMfDX4MDRZxwePb45/TRhfdoOHjWGWKC tBFYP1IZY3hZ
bQwtyGJLGBXCnF5WxXUem6pYtQHDT/sKeWykWeIDqJLYEtxYMvXUmKLk2Y68 jcOGZJNwlhj6
5ggmOoSWy0OXXIEdkLdjdHcFRyzHz5LHzrHyrLA+mjd89uA3IQkbEr4vFxuu MbjGnqGkz8Hp
dejzyjJpUBZxRjH19wppqwj/3kO0LLVONtjDM8xgQ/Y/RBr+Dknb+1s/R4aD IcHCCUOcM0UB
A98WPCt31d3Vnya4bbQOchRrnuWDyTm265dYV/s0eF8b76miKWAPeimcaTcs LiwlhSirdEVb
nVAs7DjQLMBxFxN9nZmPHG18qj5ZjtaNLBV9uLewsQSrj361ySHb3656U6NQ uCt4xehBS80h
84CI6fj2zkM/NZn9CnDHhv5jxdAp7OjsvwUimN7O5le340nkjzHZEg4Gx/es TKDers3BlELl
nWuz+mHX75VvVUS4XuWbi/nArn9Z/1JUksfrNK22ebCTNhpOBYP5Or4Xa/Ql KoGowsY/fwNQ
SwMEFAAAAAgAmmYSNQ5PIZgNAgAAewcAAF4AAAB0ZXN0aW5nLnByb2plY3Qu c3dpbWxhbmVz
LmVkaXQvc3JjL3Rlc3RpbmcvcHJvamVjdC9Td2ltbGFuZXMvcHJvdmlkZXIv U3dpbWxhbmVz
RWRpdFBsdWdpbi5qYXZh1ZXfatswFMavbcg7nEEvuoDlB1gWNkoGYVsZbe5G L2T5xNFqS0aS
243Rd9+x5D+zm3SFUcYgOLYk6/y+7xwdp8vlIoYlrISufxhZHNw6PKfTAT94 ts3P2pt0Eddc
3PICwaF1UhWsNvobCseu72VVcoW2HbmTOZo3i3gRy6rWxoE2BUNRytoiw2rP hK4qrdjm84cv
ZVNI9Yy1jZMlu0KrGyPwkxbc6RAi7ZTsDtIC/dwBQaByhpdgCbFEpxXstfEz AydgLh3UPjwL
0l8lCWRIz0lj0SS5FpAk63EOVf545l2BCg13mPcONVkpBeylIgBRcmvHoBuK GRQDfne0n4XB
A/i5iCMvJqJtPyLWQBrELei9Jx+0sLDiJG50mjeaAUeeOOqQreNuID/GvL28 3r2/vNjAW1B4
f2zJ+Wufk3+lw8g7GuiFbKu6xIpKgZ6oBOqx1Ea+C4PtGy2YVPSeEvhi/h71 y6c9sk2Npr0B
OG+tnRU6fL0J6wDgobU4epjKuELXGGWnBg+Keus34ViNVf9XOo2PeSIk+5MZ c4UFdpbMJnqH
umhDEv9/B45X6eDDc4XvKDoXrqEzK6dbzTSvsnXYeZVm65duIqHxzbQNPS8Q /db3OjnjibTA
p1Y+TfsU7iPeDrgnnkL2tocj2fczAkypxCqsMgwfkk7nBJEW+b+QK+qSjr5J bcranIW80eUX
UEsDBBQAAAAIAJpmEjXaXhB4TwUAAFocAABuAAAAdGVzdGluZy5wcm9qZWN0 LnN3aW1sYW5l
cy5lZGl0L3NyYy90ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL3Byb3ZpZGVy L1N3aW1sYW5l
c0l0ZW1Qcm92aWRlckFkYXB0ZXJGYWN0b3J5LmphdmHNWd1v2zYQf7YB/w8M 1gclmJX3pe1a
pAkQoNuKJdg7LZ1tNpQokHQ6o/X/vuOHaH1QtR1EwYAiicj7vt8dj+zlxcVs Si7I20xUW8lW
a/3efV+2F+zim7v8jfnjcjataPZIV0A0KM3KVVpJ8RUynd5/YwWnJSiz8sRy kFez6WzKikpI
Tb7SJ5puNOPpRynp9jNT+iqyeS04R2FMlE1mIVcpZJxVClIolmkmikKUaSk0 W27TjzmttNV2
FPmf5hfLqFdyAk/boy4H5EwH19PrNS1X0OA7jksglQK64OC9uqWZFnJ7ooD8 edx3z7P67hNT
qNVYfTTLDX4iej6JgrLyTkPxZQ+a4yQYps90AfxZnMhUgdTbe7GR2fFm29Bs XZhyA2IoT1B8
r+Um0xsJuTHhWpTIrk82/0ECxPmDhOHatFUWPnswmU0vfVt4WDNF8J9eA1m6 ffybarO2QYQR
LYi3ydIwNEYiIShSAuSOQG0qa88/DL6BVKmXDIQ6xYqsTACpRvKFkY/Ca2WZ KJ8wQ+Tmj9ua
nJSN2lVGpSAZ5VwZXd8/cFY+kl+WTEIrTaS3sosYQrna23vjom8ctCghag2g vf0oClwoCqEw
W0vr/16QBCTHnzmh2EJWpNhwzSpuQqQ0LTFCTs7bs/mcLGDFyjkGVM5zkZH5 /P1+D8q8v/Mh
RKzux5sFZxnJOFWKhMw2S6qdZQL/ImzyBm1nHzHEoUBkKTLYj34lnV6BC/su QL7PphMLpEmN
pEeACtMk8fCoIyaF0CGzLYjlwGGFLtq8WlB0yFIneTCCk+EQTjoxnNggTjDT GisFkxZvoaTC
jJY6UjAdRxvlEQJZY/Ok7rsb08mOLpK1P99hDX8jbZrkPOZuJ69YjDa3vpBM HLYV5jFbQ/bo
iryuU6Z8FG+FfEAi0l0YNQD7QWNv64M11fkeppS429iclG3mCM0yFPYIBrvi PqKsk3NbdZO2
NynN82T4sE1t1zAexhl/emAdYh44pw6x9c71Yxjax3nNMZkgz+4wag1iRRl6 uCvgpZAWzh6v
w0fqfbYWgu9a7X003DplzRwS1VuKIlaC7agI19BMjYdH+zcauD2OvYVOm1+r Qc2WJOm7Sd5h
rW4490STGIUt5n7QEnOqOEg5fEwkIM7LeDDHx9C1AewrQcjqakUp6668LICc c6+EH6ssAp+e
j130RAjcKdhdH8ROLIzjQ+cBKJ6u8pXA47W14qT7ay8LoNrFV4KQVxcBUcTT LoyiJBZIkdAN
Qike0iiYHIc6MFLjwKLx8FetO9Zo8Ry8N+B9T/+NRsZnF+98bNSuw0x+dx78 FqVKB8QPxU7h
pc4GLvND//8heE+C5cayLxEHkxNuJz6oxuY0HtKhS003Vi/v4wIPWTCTc2fm T/5amNq3t4Y2
KDqTX52SxFH++GEIcFbsCbT7Q/kPNzTqbwILbEF6Y2+ejXcPphVwvNy41UfY 2sbVuPWP3pis
niTcz8pw6/5ZvNAux7cnD/1m9Ax7w5wB/kPYXzGjTXONp67uq015tqU2HawF h2Q7iWdWRDgY
8ai1h7mFS5Ik7sPyIG7uPFXiVZwH1XVI/YaTv5v1mrbpT0NIw5sK/iDcPxmO 2zxQWf02mcSf
LB2Cuqve4fZjQNqUFmcbPpoK8QSv57fT94KudwSe5n3rFat+9Wgr2OEwlDe3 Yw15vLHHBq33
Opo0/4ek9eQaD1JfQIvHjYK2HqOn0Fl7fooe64dVuIKMpsE+SxoU4vTgp22G c1X9ei3rybT3
BJ2SUQPvDTtwxw3h6e+lQcJVLaB/iQn8va0Ie2x4DQIim20RNvr44z9QSwME FAAAAAgAm2YS
NfmDdhYiBQAA+hQAAF4AAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmVk aXQvc3JjL3Rl
c3RpbmcvcHJvamVjdC9Td2ltbGFuZXMvcHJvdmlkZXIvVGVhY2hlckl0ZW1Q cm92aWRlci5q
YXZh3Vjdb9pIEH92pPwPe1ylMykxdy/30Fx6RYS2SCkXhbSvaLHHsK29i3aX UNTyv9/sh4kN
dkKvR3U6gcD2zM7Ox28+1t2zs9MTckb+iMViLdlsrl+6+271gX34bJg8Mxfd 05MFjT/RGRAN
SjM+ixZSfIRYR+MVyzPKQZkn9ywBeXF6Yj4sXwipyUd6T6OlZlnUF1mGK5jg FzXUa6b0RWmd
kLMI4owtFESQp1Es8lzwiAvN0nXUS+hCg3xNYy3k+uLAVSPzx2LqdXhqldXr FpRYyhiuBa4T
8rFlkDC99QKai1wK6DSDQ7WtChgO8BZdfSVyyvhQQ37z4OHDJJhF13QK2T9a iYsWIPV6bB1w
8NKxlstYLyUkRkhfcA1cf7MCdxLge9aX9L8CFUu2cNH7ltX2xgfv0KUfGKxA NiGtOXu2Vzcu
0S4OWHMHNJ77hOv6vL6bM0Xwq+dAGJpBCs0IdYaQVOA1+fIqY/zT08I3REwt xVWJn87PyRRm
jJ8vFcjzRMTk/PzlAw14sk95NQMOkmpIimKynGYsJnFGlSJ+o7LPT08C+Ixh TxSpCQVS0TUZ
5IgLFeBd0JwqHUd/FJOepwFxnrqXSqXn1UQhX5BgwxEU8YgFV1YDRSgnDG8o R8ZUihxDkbq6
gKQE72ytYogkt77R40Gzy4MdnwfW6YH3eo2/w2qFKqDib9vWokAt0chwh4TY CzYGfzsWS0Bv
cwfDhXcPSbaJqCwKDdHJSxwWjmaz6S5kBnq/JKjwL4tvD3NvK0tJyGpLiCKX l4Qvs8xzOrdE
DbK9UJuhyEuTZERz2OcsMTq2vnHHE3wb8+McTRqUbQoP7oA/dZHZBsYoSlKg JmuOEBcpNBqC
gb8XLCHNjqmNTr2xEUqx/gtjiXpDfQ+wHEEYho0Nur2DcRPcWyF0lStsd5wo g6udKaFCw9qD
pSlsTd4PJz73JhyNnXjntpqY93WfFHHCttLqkGaROzS9XpS22W01OHuhWTTD mj/o9d8ObieT
Ue/doGDHwgXFdYpc9Tf1zo7eDEaD22F/8qF3/X4wGb7rvdnKNUlUvm43FpMD 0Grz5UfCtSlB
/594tdX5XwZsVeb3IrZ/3RuP/zuQLfqftyeasfRozc1DDoMxzNE5tRD0bULc g8zo2vE5hk4t
HqKttFaKhnaR97ffu96a1tN2m5zMzLiEE+Zn/YO7vcOksesON6/1h2dxKl6S MPSmtT2Xsd90
pNC1Wu8+z+4GAPL1q3sQZcBneh62DeVX8qcFSEMiOVyTFwfwPCct/Dx3ezT5 e45DYwaK5CJB
zXjp2KHIdE1immXGTj/t/7xcJOiw/pxliQS+IVoQ9wiHT8ON+ztvktjz2KnU SDIlyoii5N4e
cSqbdchqzuI5jiFkgZFFhVBysWnKJNgD0bqP6s4g2Rwt8rY68/JeYfkoVtHZ I6HqkrDC4ec2
tWIajavQDEBeu9o1vCrQE1lct4vRMKYK9mtXpcm+OITR1jbHGew5M+SwIvun zoqyHbKr+sif
MrDy+6Joi2bbT6Ae8A9jpptyq57ddVVz70YwmOyPt2+AiEgLeNQep80bGASe eYli/m+oxFzE
kr9RTrRrK1OLR8xElGblF5jVc6oRzRzB5YCLJWfJzSFYG522J9rjTgne3BGs LLrK54KHd2GE
75M7pK5kuRA8IrRWUunAsBOeW1fTjOOkL/8kc/Xf12vzJqH8CuEXteU8XvHe aUW13anS07Z5
Y14C3GRL1CUajsZ3vVF/sDUbf/4GUEsDBAoAAAAAAJtmEjUAAAAAAAAAAAAA AAAfAAAAdGVz
dGluZy5wcm9qZWN0LnN3aW1sYW5lcy5lZGl0L1BLAwQUAAAACABHZxI11Ryc 0qUAAAAzAQAA
LAAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZGlhZ3JhbS8uY2xhc3Nw YXRonY89C8Iw
FEVnBf9DyG6qm0NrEamgQ5VSZ6nJo43Gl5gP0X9vVYouOri9ezmcy4vT60mR C1gnNSZ0zEaU
AHItJNYJ3ZaL4YSm00E/5qpyzlS+aUPvnQC9vZGjRJFQZzklj/J1Rt9JrrEj ta0ZcCWNA3YQ
nqkqIG/adbYqst18nZezZZ4Vf9iMAMa1BWbhHKQFsVGhluh+qXTwJvjOtpf4 hOPo8/s7UEsD
BBQAAAAIAEhnEjUzQNPNhAAAACoBAAAqAAAAdGVzdGluZy5wcm9qZWN0LnN3 aW1sYW5lcy5k
aWFncmFtLy5vcHRpb25znc0xDsIwDAXQvVLvYKkz6Qm6dWHnAqZ1glHqRHZC r0+EBIgJxPr1
//sDzHSuIbAESLlwEgOfFMqFoJCVlrus6UpLcbbzFlHI3MoYFDfIsYYDS9/1 3QCnqgJJIJCQ
YoT1Bf8Bfq2OD37yGI0+/9+/ycONrWI8ztCghcxa/DM+PsdT0Up3UEsDBBQA AAAIAEdnEjUO
hmKq8gAAALYCAAAqAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFn cmFtLy5wcm9q
ZWN0vVJNS0MxEDwr+B/Ku5vUWw/pK6h4qxSqP2BN1jQlXyR5bX++SZqnPErB g3jbmZ1hhmXZ
6mT07IAhKmeX3QOZdzO03All5bJ7f3u5X3Sr/u6W+eD2yNMzRh6UT1md2Rtm wWCfMKasJ01D
4lEZDRYjEQpkAMNo1RUDd8agTT2j41TY5owV0An6GJQWW4+8oAafshWsqEzr 4IIkyLXyEcle
JMJdyAMcoBow/FTIDghyKNmxYTolGL1I+VWuF0jWYNVnvsfj/8Zu+Q4N/Elo Y8aT57w0BGzq
M7h+7fO+FKi6a55SeaMHqezrhWGcS+L3L0z/7gtQSwMECgAAAAAASGcSNQAA AAAAAAAAAAAA
ACYAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmRpYWdyYW0vYmluL1BL AwQKAAAAAABI
ZxI1AAAAAAAAAAAAAAAALgAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMu ZGlhZ3JhbS9i
aW4vdGVzdGluZy9QSwMECgAAAAAASGcSNQAAAAAAAAAAAAAAADYAAAB0ZXN0 aW5nLnByb2pl
Y3Quc3dpbWxhbmVzLmRpYWdyYW0vYmluL3Rlc3RpbmcvcHJvamVjdC9QSwME CgAAAAAASGcS
NQAAAAAAAAAAAAAAAEAAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVzLmRp YWdyYW0vYmlu
L3Rlc3RpbmcvcHJvamVjdC9Td2ltbGFuZXMvUEsDBAoAAAAAAEhnEjUAAAAA AAAAAAAAAABI
AAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0 aW5nL3Byb2pl
Y3QvU3dpbWxhbmVzL2RpYWdyYW0vUEsDBAoAAAAAAEhnEjUAAAAAAAAAAAAA AABNAAAAdGVz
dGluZy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0aW5nL3By b2plY3QvU3dp
bWxhbmVzL2RpYWdyYW0vZWRpdC9QSwMECgAAAAAASGcSNQAAAAAAAAAAAAAA AFYAAAB0ZXN0
aW5nLnByb2plY3Quc3dpbWxhbmVzLmRpYWdyYW0vYmluL3Rlc3RpbmcvcHJv amVjdC9Td2lt
bGFuZXMvZGlhZ3JhbS9lZGl0L2NvbW1hbmRzL1BLAwQUAAAACABIZxI1nTTj UZgEAAAFCwAA
ggAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZGlhZ3JhbS9iaW4vdGVz dGluZy9wcm9q
ZWN0L1N3aW1sYW5lcy9kaWFncmFtL2VkaXQvY29tbWFuZHMvU3dpbWxhbmVz UmVvcmllbnRD
b25uZWN0aW9uVmlld0NvbW1hbmQuY2xhc3O1Vm1TG1UUfm4ISQjLW2gp9QVR oOSldMVi30Jf
IAnaNkAFDC1adbN7CVs3u5ndTfFP+Af6B/xatZaiM+oHR2f8UY7n3mwIgaHG jiYzu3tfznOe
c85zz+6ff/34M4BZGFGEGEo+93zTrqg113nEdV9d3zWrlmZzTzVMreJqVZUb pq/qTrWq2YbX
Wl/jjmty2885tk2GpmOXTL6ba+yLIsyw4rgVleuWWfO4Wqluq27d9s0qVzk9 HwDqjsubI3Wh
7PmupvsbrmZ7mkTVrACToZcbFb5gaDXfcRmmiofxJUzTwW25SStbPMswPKl5 HncFlpc3PTFL
WGyLITZPxrbp32DoSqZKDOGcY/A4+jAQRT/DwCPtsaZStBU1ZxGIgkEMMYwY 3DNdbiw0Ydd9
za97EmSrB+RRQRQxsi+aNl+pV8vc3RBuGRJFR9eskuaaYhxMRuYDEsvJtpBE mvxWItS2pBSo
KlS3vFPVTDtbbDFd912az6ZKcXThrIIRvMbw8D9EbszUfdNSi6bnZ2Xi/B2T EnC/+P/IiarY
xw/TYrjyqgExdFtamVuiGMdiYxiscH9he5socGPJtDhFlUimjsYsqjypoBuR KM6RFE9Suu2Q
NAQhEUwvkkhHkWKY6EC5CjI4zxAXfMQcF5JPFo9IMps6NLNaFjnPxoncBQUq 3mUYIvNNx/3S
q2k6D+KZPS4GLkkUAoBj4QopvafgbbxDpX5MoTBMFzuKmTLaTxQKhw/uNOWz s6Pb7x0xTSY7
shSSHDacwldcr/t80/R31rhXt3yGr18GcM91Ki73vGWHzqPjZjvzdWIihMgp DW0NLhB0g042
inmG0VYBDzpKwXUdNwbqCXMrdcsa13dMyxg37fHOzkscWdwSR3+B4XTyuEJE c2DIKXgfl6Io
dCJgUYYYPmC4KAmJTtw5n17kcVvBHdxl6CE5rDt1V6fOl0qenL12GQmEZQUr TYQNzaWrmL2n
4COs0azXwk0nO4RNlQTEhoKPmxAN4Dg28SCK+wxXX7m6CrbwCXUPm++u3m1b Ybj+ksD/WTb0
Zqm1S5Uh8y90TYfYtLcduokydnSWRfnJLubzaq0kG0C8kWzRU8h7Zzq4IJRI bYRelfQNEqI/
dVBgcFS8L2kmQtceCG32ym+UEMRvKMGeQ3mCaPgbhLu+R+JbaXxKGjC6DuK0 nAGNRnAmML+D
sHQTS2fOsz2Mtqzicu+b5HRMWo439uF1vCEdxmhtTCLH8BathuiZel+A+1AS J/v0M0wkpvYx
HcKv9DWS+R2xzAvMPE3vYfbpgbME0QAmMYApDOMcRuktIJyOBCQaTgfQj4uY IxdMHMrAlSrH
QLdw1YJsRK1KGKWxIYBhuIwrgfGNgGcknfkBE0ejv0Q2lw8RiRxEH5FFIXHg Kq4FWL9Rhrrp
vvUdEk9wStD5A30/IfsgcX0PN39JP8diIh+kIr8idw3NNLcsiS0z+/iQ4Vp4 hh6KDPtYDWHm
bHgf6yG8QKkV3RjVRbA/g5uUrlvEYZH+OTr7eZSwJDnPNdgccN7Cp1QXJp8+ I/YhspzD5/iC
eC9SyjUahWm9LL3ofwNQSwMECgAAAAAASGcSNQAAAAAAAAAAAAAAAFUAAAB0 ZXN0aW5nLnBy
b2plY3Quc3dpbWxhbmVzLmRpYWdyYW0vYmluL3Rlc3RpbmcvcHJvamVjdC9T d2ltbGFuZXMv
ZGlhZ3JhbS9lZGl0L2hlbHBlcnMvUEsDBBQAAAAIAEhnEjXOzA7n7AAAAKIB AABqAAAAdGVz
bWxhbmVzL2RpYWdyYW0vZWRpdC9oZWxwZXJzL0NsYXNzRWRpdEhlbHBlci5j bGFzc6VPy0oD
QRCsSTa7ukYj4g94Uw8OnpUgBoOHxUsk985uk0zYR5iZ6Hd5EnLwA/wosXcU BW/BGaiequou
et4/Nm8ALnGYoKMw9Oy8qed6ZZsl515Pnk1VUs1OF4bmlirNhfF6weWKrdOj kpy7E+U+CAki
hfGWGT/2LTn+zVKIr01t/FChe3o2VYhGTcEputjto4dYYZCZmh/W1YztI81K VjjKmpzKKVnT
8m8x8gvjFG6y//3tSiGdNGub89i0scd//IslPRFOIOuiPUqurCmYCNOBA73z V+y8yKODVDAO
Yow9wf5Xg9T9MH4QugafUEsDBBQAAAAIAEhnEjXSYvlq7gAAAKUBAABrAAAA dGVzdGluZy5w
cm9qZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0aW5nL3Byb2plY3Qv U3dpbWxhbmVz
L2RpYWdyYW0vZWRpdC9oZWxwZXJzL1NjaG9vbEVkaXRIZWxwZXIuY2xhc3Ol T0FOwzAQnG3T
BEKhFRIP4AYcsDiDQBRR9RBxCerdTVaNKyeubBfexQmJAw/gUQgngJC4IbzS eGd2PFq/vb+8
AjjDOEGPcOXZedUsxdqaFRde5I+q1rJhJ0oll1bWgkvlRcV6zdaJvKiM0bdB mnVKgogw/WvI
93giHf9kEeIL1Sh/SegfHc8J0Y0pOUUf20MMEBNGmWr4blMv2N7LhWbCfmYK qefSqpZ/iZGv
lCNcZ//83Dkhzc3GFjxVbe7Bb8PpSj5IHCIsjPZQqLBowCQw0XFgcPKMrafQ 9JAGjDsxxk7A
4ach3Lvd873ONfoAUEsDBBQAAAAIAEhnEjW2Cb6WdAMAAM8KAAByAAAAdGVz dGluZy5wcm9q
ZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0aW5nL3Byb2plY3QvU3dp bWxhbmVzL2Rp
YWdyYW0vZWRpdC9oZWxwZXJzL1N3aW1sYW5lc0Jhc2VFZGl0SGVscGVyLmNs YXNzrVbtTxNJ
HH6mXShiPRAOT15UfAMK1DkV9c5WFAuEXspLgGvCJzNsx7Jmu9vbnWpI1Jj7 i7gvR/QS47dL
7o8y95vdugWlQWg/dN7n+T3Pb56d6X+fP3wEcBtzCcQYFpX0leWUedVzX0hT 8Y1XVsUWjvR5
yRJlT1S4LFmK70i7Kj2/Mf1U+HKBZpaCiQQMhpzrlbk0bavqS16uPOdezVFW RXJJbbVbldx0
PRnghXB8bttXnjBVA4ihf2E+v/lsbbWQz209y60uL8+tzDP0FV6Il4JT6DLf UB4xzjCcy7mO
r4SjisKuyS6cod0afbTq2pa5O2q6lYpwSgydWcux1CxDfCJVZDBybkl2I44f kujGWYaeguXI
lVplW3qbYtuWOp5rCrsoPEv364OG2rF8hqVCe5JGCs6XpcqTBilKuS9kX08U vi+RnvyjRkR8
nteY9f3r4WAm1RREZ8V1Qoh6hni+vjtzFhdwMYGfGJ62TiKJQQwxJEnkmqCs SKUPeGzi27NM
HRha3dY5zSQwwjBzGhFaw+UkrmCUYvuHYo8fEfvb0KmiNse1JPrxYwI3GLIn oUEsqq5vKVmn
043rGNNGG2cYOEp7Ua9IJTGJKXKoKJEHsoc9cBDf5y55RyiLvM/zvzslV5tz 9ctYRhs8TqfC
MN8OHzGckdXIm/dP5yoNshOBJKLvcvZEcF8nlmB7yVo5T4pojOHNiT+fEGDB lhXpqBa/H4aF
toRnGImkrUs7PO4dq3ESf55S5kGwlrX+1j4ODBdJ8Dw1PXe3noxI7NsTiz0M 1LLQxfbEZxhq
iFyXz6UnHbNh3XenlRlBtSx0qV0MGLo33JpnykVLP50jTd7AW/o6xFXQnUX/ Shg9GB3opDpB
vRi6gjY90VQmaYRTzajumNzHub+CJT1UdgaDPeilMhkuwHn0UW3oK7y++QOF 6KD6yVRf13sM
xPAJw8vUZu9xKY7JqX1cXZn+Fx3pvTSV03v/4PoW28fNh8agMf03JgaNdFDu RXFvETFgiNCH
MYARKi/Rq3OZ5IziJpXjdK/fxg08oN4jjAX8ZkIOdX66NY10wHCG8DghD9Pq n6kVp7099LtD
KgzcpflQx32qY5oDazAJM5AOIlwIZ6MIMYpwj+YN2vngWIx7TTF+CTB+xcNj MbJNMTIBRpay
cRxGrinGbGCCx0Hvyf9QSwMEFAAAAAgASGcSNRIcJmftAAAAqAEAAGwAAAB0 ZXN0aW5nLnBy
ZGlhZ3JhbS9lZGl0L2hlbHBlcnMvVGVhY2hlckVkaXRIZWxwZXIuY2xhc3Ol T7tOAzEQHCeX
OzgCQRT0dECBRQ1CKIiI4kSTKL1zt8ptdI/IduC7qJAo+AA+CrFnEBRUCK80 3pkdj9Zv7y+v
AM6xn6CncO3JeW6Wem3bFeVeTx+5rkxDThdsltbUmgr2uqRqTdbpGZm8JHsr 2l2QEkQKkz+m
fI/HxtFPlkJ8yQ37K4X+8clcIbppC0rRx/YQA8QKo4wbut/UC7Izs6hI4SBr c1PNjeWOf4mR
L9kpjLP//u5CIZ22G5vThLvgw1+Os5V5MDiCrIzuKClZVTARpgMHBqfP2HqS podUMA5ijB3B
4adB7t3wfC+4Rh9QSwMECgAAAAAASGcSNQAAAAAAAAAAAAAAAFMAAAB0ZXN0 aW5nLnByb2pl
Y3Quc3dpbWxhbmVzLmRpYWdyYW0vYmluL3Rlc3RpbmcvcHJvamVjdC9Td2lt bGFuZXMvZGlh
Z3JhbS9lZGl0L3BhcnRzL1BLAwQUAAAACABIZxI1R7SndJ8CAABhBgAAaAAA AHRlc3Rpbmcu
cHJvamVjdC5zd2ltbGFuZXMuZGlhZ3JhbS9iaW4vdGVzdGluZy9wcm9qZWN0 L1N3aW1sYW5l
cy9kaWFncmFtL2VkaXQvcGFydHMvQ2xhc3NFZGl0UGFydCQxLmNsYXNzpVRb TxNBFP6mFBZK
KxXlKihq1XJdKsYQQXyomJi0QApijA9m2I5lyHa3zm4x+Kv0wRA18dXEH2U8 M1tBLK0Kadqe
M+ec7zu3me8/Pn8FkMM9CzGG5VAEofQqdk35e8IJ7c23supyTwR2WfKK4lVb lGVo17gKAzvv
8iBYJX2D1EzOQpxh1lcVWziurAXCrojXxr/mu9KRBFLgB349NCH66IChK9yV QWaeqAtn514i
nGXpyXCF4VH2PECT2wzxvF8WPWDoTaITXQl0IJWEhQsMHVnt0FeQnlirV3eE 2uI7rmDoL/gO
d7e5klpvHMZ1aQwr58gnk6PSBhwleCjyu9It/966xWzhz2Yf13G6yUQudWOQ Ut5QssrVwWPF
KxORoRfDGLUwwjDcCjiJKxhjSFXEiSnOZwt7fJ/bVFXFXt/RVbZPwcJVhoW2 u7LmeyURyHe6
mceRCYwjxdDp6G4wjLZuAe2EEkHdDRnG2qXCMEjVFP39qMNKeHm/WuUeoT9s 7nBJvKnTOE+p
zomiaIKRQMCWirwZRloCMaSJPh+N+BdxoZm4AUXwxvW/8vhnNIbEpl9Xjngi zVqfWMY5PWKG
5FPPE8pYBK1336rnuH5A+10U4a5ftkCX+cHZVz6Ju1igmURL3/xg5LLNJbd9 Y5YwT3e5g145
lk7rC01SnL4Wuum8h6RFxOgDJKamP9LPIZIfSIuhT58ZCy0c1pEmKUmyPr2I foNzCZcbKJI8
NcvQdP/AJwzFUJz5ht4vGH9xiGvFmfdHkKMmhRKFbVIKJQreQgrPMIDnhmIi gmlQaGkC1w3J
BdzATUKJI4NbDdr79K9TjLFjhi6T5EuDNhhZj9BiuI07ZI8ji8m/YrxqiTFl mjpttBnMQjeF
mRiQ1xx0c2zkfgJQSwMEFAAAAAgASGcSNUjp9hQNAwAAxAYAAHIAAAB0ZXN0 aW5nLnByb2pl
Z3JhbS9lZGl0L3BhcnRzL0NsYXNzRWRpdFBhcnQkQ2xhc3NGaWd1cmUuY2xh c3OlVEtPE1EU
/m7flOFNUQEVELUP7PAQQaiwqBJJ6iMWMbIxt+2lDmlnmpmpyH9yoYlAook/ wP9gdKUxRvdu
jOfeVihSXZTNzJxz7/nO953HvP/15h2AKSwH4WFYcYXjGmZRr9jWlsi7enbb KJe4KRy9YPCi
zcu6KBiuXuG26+jpEnecW2TfJ3NcWStGsWqLIHwMY5Zd1EW+ZFQcoRdsvj1d 0B8QJjeLJVG7
x9C3qcKy5Dcs8493NtMYWyxv6nbVdI3yAU7V0DfVXUd/ZPNKhudEaZEhUt55 6IiMleeltGXZ
BcPkJIiBbTAE3KeGMz7JkMq0LpJyBFKGabhLDMvRkwDF1hl8aasg2sDQpaEN 4TC86NHQjl4G
bzS2Lk/6NQQRCtPXgIZT8qQzbwtSlbZMV5guievKGKa4Wy3nhL3GcyUqX6+q wDq3DWnXnT6p
n+H2CUg3tngxiLMMMy30KYxh9IQwwuBPJZPJJWmPabiAcYagI9w18dylVkYz W/wZ14lZUc+6
NjGmmslCXNJwGVGGIbpb49JshOajLc1QLUVcQwIT1AVeKDBMHYWqh6/W69BA 815OFlS11k/Q
T2jYQiW+c5O7fFJ25dhNElH8n4i5aKwlFXJyZjT4ESANdEx7Vm22FzRltBkD VMima+OLbkgt
4axVtfO0smq2jkxEUkpi0FZNU9jqRDhB3GBYaH3KGNob5gyjpMVLvygvPFIQ fXnkSgDd3XJp
yA7QjXZo9Owga5XOPfTuiyd20RnfR3fcu0vWPiKvVPBpevbCR89PBPgBbSyI TnzEGfJIEArF
IIbUXdq4OqxJBCSN4bcYfryPc5lE7/k9jMYT+7jI7sQTE3uIHeIPKqKfieYX wv5KiN8QwXdC
/aHyjNSw6nlC6McVJSNC0pLQCYVhkv7Ktdw6vSUvf/w1pl8eJAko588G4v4D 4rQh9eClej0C
sh7ThxTD0stoUplHIQzUbtUR5NdVlcGHWVxrQqTvxVEirKMJER/mMH+MyBD1 428i/UQk8g8i
s1QhRt7rKmYBiypKUkkRKvsNUEsDBBQAAAAIAEhnEjV7sXt30AcAADoTAABm AAAAdGVzdGlu
Zy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0aW5nL3Byb2pl Y3QvU3dpbWxh
bmVzL2RpYWdyYW0vZWRpdC9wYXJ0cy9DbGFzc0VkaXRQYXJ0LmNsYXNzrVdp extXFX6vrES2
PLFll6R1FseFpJElU5GUpCFO3DpyHKuVE1MlDjFLGUtjeVJppI5GdpRSUqAs oWVf04WtQFsI
0EAqE/y0T/lAWb7AA/+CH8HDe2fGo7FiGzvhgzRzZ+55zznvWe6Zv/3nD28D 2I8bIQQEjlha
xdKNfKJsli5oWSuRmdeLBdXQKomcruZNtZjQcrqVKKumVUkkC2qlcoLrCS5D CAoMlcx8QssW
9HJFS+SLMwmzalh6UfOkq7oN4MhnZtWydqqU05YwBNomU5mzw+nHUyMCIiWw JVkyKpZqWJNq
oaq1AC3/FmjPlgxLMyhiaAI7036lOVOdP5BLpEb1fNXUBgWUsqkXVbNmKxPY fFQ3dGtIIBZN
r2asUbJUSy8ZiUldmx/snxQIJmllGC2IKFCwRaAzrRvaqWpxWjPPqNMFAnen S1m1MKmauly7
D4PWrF4ROJq+fV7pQnCOdgjsW6fBAj1ZU1MtbUSbUasFy0YqFfSsrtGWlmj/ pPRku4K7cU8r
dgp0ZLQiKdaz9q5aCL0Cj67XYhfYMTplacUlME9tLYxd6JPE3ROGwHsVvA97 BLp0GdlCobFP
YH80fUGdUxNUlE+cnpaKB5d7rc0kGgKMTSvuE7j7pKmWZ3Xy72WT60lUYN3c L/NkFcQw9qGv
FXFmalI1SobcEcL7BcZuS4uH4dcwIDV8QCCSVmulquV/JXBAwQP4oMA2J8TN WySF/bcwZpfc
kuJmkcEQDjFFbz9D9+wP4yAOywB/SOCh6J0kuyy2loJWFkhs0AvWpEOJDJhb 7L1NXDQ1hxAe
Ehi9A8ftlQMWxhAOtzFAxxW0I8xGM2M/Z2bcAR9+DdLDvGZNLGtnj9DD/xv8 FjWXG9Uvarnk
rF7ICeyKrlx7dqCmQnhEYHjjyjPcxl61hCSTOq3gBEYlhacUnMaEwA566tjl lxl1KX2wOcf9
J40TYx40TgAqiXMs5bQ6rRUGw0jhMQUZnBForWiW/VTg8OpHwVpoMle3ZCVV jfNr++qMsaBN
rVia0/wU+3J2osAbgYNr+CbxfKZIKS+VP8oaXqecey5k9EtaA0LG4eMKPoHH BcJkf1wtj/Ol
wKF1kV1Uy0VuT6RcucF2qMiGMM2WtXFpBTnIw3pkwiqlmQ7BaKo/FcYU8rLL zApsiqZSkv9I
g7+GG08o+AjOh1BkB1ih/DOWmn3C6R9hFNAXRhlmCE+yd26YeAUVMOwRO5kk 4rhqqHnNFNgb
Xan1LNs0KE9igTkFR3FMWnFRQQ2X2AFZiAK7V0RYal6O7KcUPI1POwZUy0n/ XHRkbfG1Xso+
9oyCNtnHHriNbGR8KrI/teNZfCGEz7MuVtem4Iv4Ej3I30LhnpXb93IOQ/gy m+7669ceKE2V
41vuTKlUmFbNpVS4IlPhCr6i4Kv4GouAlGbKapbdzUnASekOzWozGifM5oIt LDCygRaymgnk
rYMs+KIoB7XvKvg2jnHIaTT/5PKms3OFI99rO2G8gJdCeFHg4f/dq2Wbbjye 1CtVtZAaeUzL
6zS4puBl/EAgREPO1KT3W8mKb2DLWCbhB2Ve/kjBj/ETjinSH2nt8drSXDim G7T5bPRWwTX6
zEqfDylvRvP12A6Wjq3QMV7OAKtzk3KK6OcKTmJMcv2aglfwU6avbuS0i5xR nY69DHDNU9HG
+5WCcw7ebxT8Ar9kLmVKVTPL8rC/FJadwfdLGviZkjIMzbTfyCm93Xcy415i 8tOHvx5swmau
QlwF0IqgrFHeB+XMwWsH3/H7hP8dXA1xT4DXzbH4Ajqv2zJd/A/bT48QaxDd vNvm7MJdeA9g
323lMya9/EJwsZ7nSvB6KLaAnlj3jkXsOr+A3XXcG+veu4h9XPTbi9giBri4 314kYnXs511D
9wHaBwwT7Ti9SBL7OJ+PUPMJ7OC1F6P09ySivMYxxsEyZduoONpdG4NyCHYt S5IXaX/7Ig6e
p3UPpuNvNLl6mjRN+1xtd2HauDpCEqSrbMEu4JgLGFnEkAR8OB2LT72J4WZU nfIXfKgRD1U6
NkI0IccaF/WAvQZaYzcw/A6GGmib7edP+txs9dxkXrryqhvMnvgfkbqKu+Lv IEV2H61jvI4P
B6+1XPMAtxMSuEgzanT1EoFrjOhTjObTPnN7vHj34CwmbRLOeeoO8Sp3BXy4 jqHP+jACHkbA
w+DR62JMMMOkRO8ips7T1o9FojfxyQB8twuYaRDRYWf5c+hktm3ntUFIr0eI 7qHPc7fcv5dw
F9LxRRSYdkYdJa6r4/GBOuZjMf4/9SYu+zLCIef7NO0qI/YCiXmRz17iN+nL tsI+B9RVuInr
JD5DlVu5+7N25IPyyHWNmHONiMZv4nMCf0bfIq7QjufGB6SXrbaTdTwfH7iJ rwfgs2MbsYFX
mS2vcf06drNT3IdrPhuiHrlRfAOysXTRim/iW0QQ8kzwCsDJrC5m1uV37QS7 /Abz9jvNzP6O
GXGDjNZ9zHa5SgS+R1IcwGO2ApZJrKvzld/jah0/bIZ6ixveJtxbPqh2L0js oS7UlMtPJBav
42dXEbweiwcW8GqjIXRzP/An5vy75OIvDP5ffRxEPA4iboLJu9cZQxkH9lZX z2m3OjqlnmuO
ngX8ulnN36nmH1TzTwr9y5fHnZ6aTldNAI7L1/FbWzrAbirIIAd0e1/3fwFQ SwMEFAAAAAgA
SGcSNS/AmZDAAgAAZAYAAHEAAAB0ZXN0aW5nLnByb2plY3Quc3dpbWxhbmVz LmRpYWdyYW0v
YmluL3Rlc3RpbmcvcHJvamVjdC9Td2ltbGFuZXMvZGlhZ3JhbS9lZGl0L3Bh cnRzL0NsYXNz
U2VjdGlvbkVkaXRQYXJ0JDEkMS5jbGFzc61VXU8TURA91xZWyiKlIAqiVKzY Lh+XCn4gxsSQ
qk2qEmpq9G1pr+WS/Wh27+Kb/8mEStTE+OyPMs7dFkHBkGAftjM7PTP3zLkz 7Y+fX74BKOKB
gXMMJSVCJb0mbwX+jqgrXn0vXcf2RMgb0m4GtstFQyresgMV8nXHDsMqwaTv lSi8QdFcMVc0
kGRY9oMmF3VHtkLBhfuOq8D2QjsG883I8+wtR7yWantThJGjcmW35TD0q20Z 5orEpNIDKmsM
qV3byREmFAHDWuUoqSaRCiJPSVfwuu+6xCuSnIC7sk6ndJJ4eSO2VGpQlxKO cIWnGKYrfzco
6n4geOnllqZL+AGNpycSDJnKjr1rc+Lf5L8B/Q+lJ9Ujhr18T7r9j+5OaeY4 +0KNIbnuN8QA
GEZM9KFfe6MmDJzX3kUTA0hp75KJQZgpJDBhYgiTDIm8Th+uSE+8iNwtEbzS w6BV8uu2U7MD
qd+7waQeCYanvZAoHokEyWLgOsPKv/TSAsT9R0o6ByI8btgtJYIUsrih+8gx zORP0a1QMzDL
kD6Ur6oC6mEQeVgGCgyrZ74zE3OYJ+1lWLMd2dBNdoozfPiTV0zpoG457kNL e/RWO5lrhbOP
UOd8W0XhWooufdEExxItQShUZ8NpJPInz1Gq6kdBXTyR+ronTrq5RZ3HYJY9 TwQxQIQG7jCs
92AoaBJLXt3xQ6rzXKhtv2HiPlYZjK60DLMnMT8uH5ao8wT9nibTab0RQDqj 9yG2tA2xpV0g
xDl6hnCB8MPkPaP3PrKT1lwbaWu+jYy10MaYNZFsY9zax+WPcc4V+kzFuaQm G8IUeSb5lImr
uBbHp8nvVH1LNfV3WcvaQ+Yrsm/Iju1jhsz4d9z8jFsJfMLCYe1xzYIRdzaC NMtgivxpNnrk
nGz3nAT9Z+is21gmmyFvBYg91rV3tQ4UvfcLUEsDBBQAAAAIAEhnEjVcbXu5 oAMAAM4IAABv
Y3QvU3dpbWxhbmVzL2RpYWdyYW0vZWRpdC9wYXJ0cy9DbGFzc1NlY3Rpb25F ZGl0UGFydCQx
LmNsYXNzrVVrc1NFGH62TXtIejC1AqEqN42QptBDiiK0gNaQSiQttel0xo/b kyVsPZfMOSeB
v6J/wK84gzDojKNf/Rn+EMdnTyK90LEzTT8k+5539332ea/71z+//g6ggnUL IwLVRMWJDtpO
Jwq3lZs4zafa92SgYqelZTuSvqNaOnE6Mkpip+rJOG7ymA6DGtVr1BYrFjIC k9uyJx1atp1H
WwbJwrjAXBi1HeV6uhMrZ/uxdJXT0+qpimKnXlWeZ0DCaFN6uiUpCIwnT3Rc vE5ijaGZLRLu
jg50ck9guXQMeDObAplq2FJZCJy0YeFEDqPI28hiUmC0ZA7kGzpQq11/S0Ub cstTAlON0JXe
poy0+R4oM8ZRgdrwtIoVOmrpOI2iwOVSY38qFmd2qZpJxOsWLZzdk7S+Oof3 8aGFDwSWhuZl
4xzO8462Mp+ximqe8lWQCFwqzTR2F4byH1MOI+XUBoQNj4s2LuEjgewbAIG7 +yzbtIy6QaJ9
5bih74eB09UOj/a0S6ad1Myp981T1KKNT3C5T8swpYv3Q1/qQGDhAFpJJINY pn45Gzuy9PbY
Mpol5vIYUlms5HAFZVNRswIvjqFqWR5DhOyQPB1QapsTuAbHwpzAzaNF08Z1 VARssqw9c71u
rHtsmNLuul7vBoHpoz2VPWBg4QbHx5FdNlSaiUy68QTm8ZmNm/ic/cVyMZ2f dnnd7Ny2sQB2
Xo47KyqOZZubp0oHtFoOd/GFBU6h8zt79SBRUdTtJKpFJ1XHxMHGl2aO5Ds0 Mxzc7xkkl7Bj
Pel100nylrekpv7rqwuHZIvzsDNopGFqos/HzJra0VF2wky8EU3nLjb+Pzom 1s2wG7lqWZsJ
On1Qtc8ZDNZOPQhUlB5QnLL5WuB6YcxkrKjkSdiysYZvma3BDNhQz5Jdb9D8 vjlw+Lu1yIpl
ZfA3BjE5aR4GvrEj/GWRo3aC0i1+G02uPPsL7PIrvPNzeuZdo0t3aC3GMEXJ pmy07+FUqj+N
MwOUv4k9xnV99k8UfkCj/AL2S0yv9NcLq/31499w5bvytauzrzDzGldH8Afm FzLTmdf4VOBH
WOIn5MzXLYHnRv8Sd8Rz3lDAA9RZrX1W8+QBcYLHs8iLHArC5kA/yc622WKn sSTO4AHXuijg
oTiLNXEuZX8P44bhgL2RlvAV0fNcq7hP9AJuo4ZlRuwGPfuat2bwkH7V8Q2l UcomMg2scJ2i
JFKcKU7G/rrK/wyH+aN/AVBLAwQUAAAACABIZxI1jmyjjIcCAADEBQAAbwAA AHRlc3Rpbmcu
cy9kaWFncmFtL2VkaXQvcGFydHMvQ2xhc3NTZWN0aW9uRWRpdFBhcnQkMi5j bGFzc61UXU8T
QRQ9A4W1ZYFSBMUvUIv2A5i28mQVJaRGkgokJTz4YobtWIbsztbZLYSf4r9A EyXxwR/gjzLe
XRCqoKjYTXfv3nvn3HvO3J0vXz99BlDGvIUehqVQBqHSLd42/rZ0Qt7YVZ4r tAx4U4mWER6X
TRXytjBhwJdcEQQNSlO+rpF7jbzZioUEw1PftLh0XNUOJG95r7np6FB5kkuy O4oH0uwoh2AJ
iWy+Fj+eKx0uNkU7lIahP9xSQbZETdUv3FWV4B4prcIFht3cf8Crd/OLOEnH N5LXVjcjwGp9
W+wITpAt3ggNlarmNxgSS35TJsEwYKMP/Sn0YtCGhSGG+dw/IQ7XlZYrHW9T mnWx6UqGTN13
hLshjIrej5yJSEqG2sWJZysk5UBWaF/veX4noO2ZPKfzH/LLUYenqDCkWvJk 56dzXSlxF9V8
l+cI18I1hsrv5izca0se97Jcc6UndbhOnhRu4JaFmwzpnzFtTGKKRkW+6QiX BBvLnS6bf5nE
HWQt3GVYPF9PiuyopjTBSayrl8DGNO4R/Zjlq3KpVKFZqP89qWo0TDkbV3CV wRLflRw5JSTV
avgd48hnKpqMibM2eS5axGAvay1NnCBJjOGadlw/ILovZLjlNy2U/kiBcybK RgUPGJI0AIeH
AMPjXP6XEji+5/n6rCNk+XB5FSX6wnrpUGPpdPSZkdVDfwuXyJ8ka4WiCXra heIHpAozswew
38VZw3RPxdkMfewh0mRNxVg2RpABYmsUl+McG2MYpyiLVD/CXqVIFBvNTBQ/ 4vpbWO9xe79Q
PMD9/eMSQxEkW0CSPcEgW4zLjB8uOy4zijwKMZFivG4Gs3FzjK7ol8Ec3RPg KH8DUEsDBBQA
AAAIAEhnEjXECBCuyQMAALYHAABvAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1s YW5lcy5kaWFn
cmFtL2Jpbi90ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL2RpYWdyYW0vZWRp dC9wYXJ0cy9D
bGFzc1NlY3Rpb25FZGl0UGFydCQzLmNsYXNzrVVbc9tEFP5OHKJEVhPjpjSh LS2tW2wnrZqG
W+M2EBz3htKGOBgoF8/G3jjqyJKR5BRmOsxAw61chhme/Av6zAw1lwemfeVH MZyVDW6aBB7S
B0m7Z79zzne+Pbv686/f/wAwhbKGPkI+lEFouzWz4Xs3ZCU0izftuiNcGZhV W9R8UTdl1Q7N
hvDDwMw7IgiKDLM9t8DmRbampjX0ExI3xLow2bNmXltRkTQMEJI961LTdcWK IwkD4ZodpE5z
cmvX2XOE4XXhpMI1uSQ/bHI4wrjl+TVTVhy7EUizJlfN7hKDB87Zrh3OEsrp x5B8x0SZEqE/
71XlEAgjBjQMqtGTBoag64hhr4E4RgmxtIKOWLYrrzbrK9Jf7miUtLyKcErC t9W8a+xXwhEK
u2eemmYtYn7T1XEAhzQcJMztOqiBZ3CYMGgHc2xfl1F111WGZw0cVUu6HSiw qkZHCic0HCfs
30FEA88hzdrUZFj4KJRuVVbnRShYxXTGivqqGdqOuSAauUFkCamq7TMhRbIs uw5VdiirHbeF
U66sCT+OSZzScJKwZ1MIAya4I2OcjHAibT3azbnMVpOGM4S9PXOe4wsm4Ot8 vJ438AJeJAyp
rCXhNDty5JUcLxs4ixlWSlQqMoiOwsXH0Y75TEnDOUL2UUX9jqKBOR9JpBy6 Iis6swZewauE
uFKal5ZZPcJo+uGSi6HP3HIK/pqBvIIbDLfEinQUXkcBFzVc2HQRdJwMXMJl PnmcUDjcvvu2
U5fbJIfXDVhY6BBR/a+KIxxnIg8XVPXFzTNVrsury9D/2Fz0bDeMmF0zsIg3 uEEa0l/1/Hqv
2mhP/z9IpqTCFFUYPpvxbuOofWXa1jY7zacoLntqEia3XAk7a8/OetFr+hV5 wVbHe3y7TT2l
srLYl11X+hFAsoYjBbfieAGruyDDNa9q4H18QBjbUvi/xA6m/+Oywmm+nGL8 PIG+RELdVkAi
qe4q/lX08ROHwat7eHSe5zH+jmQn7mE4O3kPiewvSP4UAffxW48cuDT6BE/x SDkyHPsxFtnH
MdoJRQOMVNiN7M8YbuPpFm51Rkda8HmUaONYMvMbJvrwAFMtHNtsu48pS+En 2pj+FS/dxaxa
f4BcCyc7cc53PnNtzLcwrlbvI/ePz5U2rt6F3oEs9fhfQZK5fcoN8BnG6DYO 0Oc4RBs4yvM0
fYFJ+hImfY0p+gpneT5Dd3CJvsESfYtV+g4ufY9b9ANu049R/UciuTa69c9g GMt4kxVweVTC
W5Hwb0fZ38H1SD+KFAPzeJff/dyR7/0NUEsDBBQAAAAIAEhnEjX+0/mLQAIA AFIFAABvAAAA
dGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFncmFtL2Jpbi90ZXN0aW5n L3Byb2plY3Qv
U3dpbWxhbmVzL2RpYWdyYW0vZWRpdC9wYXJ0cy9DbGFzc1NlY3Rpb25FZGl0 UGFydCQ0LmNs
YXNzrVRdTxNBFD1TWtaW1SIIih/4VbEtH1MJD5oak4YUJa5oUsL7dHdchmx3 m5kpaPxVJoKJ
D/4Af5Tx7tKggDEBfJjN3Tv3nHvmzN398fPbdwBPsOQgx7BqpbEqDnlfJzvS t7yzp3qRiKXh
gRKhFj0uA2V5X2hr+GokjOlQmUriNqXfUbay4iDP8DbRIZd+pPpG8lC+z2CH qFbXWC18+1KL
/rbyRXQEbfm+NEZ1I3lqj2HUbitTaZBG78Iim0T3XMXKvmD4VP0PfN45jtus bTHkV5NAFsEw
5qKA0RJGcNmFgysMT6vnZi17KpYbg15X6k1BdjJMeAkVbQmt0vdhMp9aytC+ uAGVFbLUCaXd
ED0iXj4u3exZLoZ3qyJlP/LfN93elXEquoRp3HBwnaF1YTUuZnCToUh61lQ4 0KRotlo7JinQ
Ym854OuH+820+20XdzBLVhHME10ZbcoP9pWM+lIzNKr/gte8HbErOIkMecdq Et8s4h4eOLjP
sHgmK1w8RIXGU0sziGx6caeoGRidiJ/RYoZSJxloX66p9O5n/mbcUtqLwV2P Y6mzAknzUW7H
fpQYav1G2u0kcLGARYYp8umPJkcf6twJq9PBPV3XRIOmfoT+PWx8PB19inK0 HFyifJGiZ/Se
7o/V5/dRqi98hfs5KyrTs5QVMxTopzVOkUsxleIqJrL8JK4NaV4TSVo7OV// QjS0DjB1gFv7
uHuCLpfHRK6Q0U0fQoZ0afQIc5nexxmmilqGYllbUFWdnnnCzf8CUEsDBBQA AAAIAEhnEjWP
pEkCqhYAADE6AABtAAAAdGVzdGluZy5wcm9qZWN0LnN3aW1sYW5lcy5kaWFn cmFtL2Jpbi90
ZXN0aW5nL3Byb2plY3QvU3dpbWxhbmVzL2RpYWdyYW0vZWRpdC9wYXJ0cy9D bGFzc1NlY3Rp
b25FZGl0UGFydC5jbGFzc7RaCXxU1dU/ZxKYZOayBUIIYYkIGCbRYYuKUTGE BEaTkBIEg1V4
zLwkT2cJM5OEuGtp61a7umBbF7RiFRWtTIixCi5Q11qttdal1rpbu2jV0kW/ c+59M/NmyQLy
/fhN3nLvPed/9nPv48kvHngIAObZ5tnBhlAd1SNRI9jm7giHztK9UXdztxHw a0E94vYZWltY
C7h1nxF1d2jhaMRd49cikWaaZoSCtfS6id7aIRfhpFC4za17/UZHRHe3BVrd 4c5g1AjoCSKd
hqRjkgkF+CagB6NJKiMRFh8QFc8qfVO0ulsL63EiCPmrPc2nVtev8yxFQA/C qJpQMBLVgtHV
mr9TzwEYcwuCPaAFtTY9jDCnPoWj3uqOhkL+iHupESYhmWyDmlqFMJK4RnhR Vf1AML2hQCAU
ZJQ0scvwkhLVIrenSV6JzGj1ptavs/gRhLH1Z2ldmrszavjd9UYkSnOcPr1V 6/RHWUCEAjWB
jNLmbo6GyViM5ngjaERPRHCVDQgnGIpqbCn3akPvrpqzGiG3JuTTHZADRQLG wySEGamrdVqt
e0Nh3V27YgO7g1w1pt4I6o2dgQ16eJW2wa8zpJBX86/WwgY/my9zo+0GyVNT /5VdiuTL7SLM
CEcMUziEYm9Y16L6UqU5SSnkN7yGTpByyuasZqlnCJgOpXkwk7SeNLGc12OH 2Qi1w3VAk7S7
Xtug+9NJOWAWlLGCSx1ABhJQDhUI4wz2RL8/OQ9hXpnFtqbGM1wyuUBao6BN j0q27B3LdX8H
++TcVDv6wlr3fJ/bU2e0dYb1qjmZHmSHuQgLBhRXrSdpWyWFiHtNWOuQXB3g hvkCFsBCCiSC
onx0QllWHkcjTMqCyyRUCfPJkRUHhCmDSUBiR7KIPW9QsTMRsRu44QQBJ8Ji gh+Jwy8syz63
Ek5gv1ZhGNe7xxsKxgGcOITerYOR7qibnKij3fBS8gpQWqliNLUC6mCZUiaT 5qAcxsJKqLUo
xYpp8eBKGYKyUlG9gAZoVCpSoA4vG87KSqgnhRlyRelQCxDy4vgRjh04jw3i jZIpwqkCVkMp
xVhnMKy3URLVw6uNSKfmj/DoaQJaYC0VB+JWZ3rb9MENJ6l+XcCRcFQ+3Z0p YBwU8Lv1AjTm
NCYLH68AH4+NDuuthLLdHEKoPCjRKEmRSzRQxvbXtBt+X1gnpRbEAy1ZL/LB gLPtcBa5cXKk
JuT3q6QaEeCHsQiO2oamVS3r6j3NqxAmEmVJdElPs07lMGp4lxtB8vJTs0XC wPCz1uVlysya
35LPRSSFDUvWZC2ECIeleX1mLWIdkzRR2EgCkK5C/i49jt4kw1O6BHTDJnKu uPbS05NJzg7n
IMwaVn2hQNDjOKcPgZJktWYKB1wIF9vhIiqMQ9dFVmDy9VL1lrUYCjf5O9uM oIBL4BvUIHCu
kI2Nl3x5GUl3CGhL/X5TQAdsZNDfFnApXKZcxRPVAzJml+oRb9jooDXU82Up XqkmPKtV8+pu
tlRnmG7SKBC/K+A7driSauTwVwm4Cr5L5Z6Na0QiJHMGsKPKDhjG9wX8gJOw U3URcgqFjM9C
teJAaFqcgCsMa/ZaAdfBFspCCddHOKFs4Ngaupm0w48RFg60nj1TOqbMB6Z3 Vvu0DkpaDrge
ihjUDQJuhJus8biiQyYNcteDwpZChFS7FW61wy2DtPbDJCXgZ3AbxbRhtvKy qfM44Xa4ww4/
R1h00GoUcCdsp6TNGqB0F1VJD+G41AohVRkn6pF65La3ypOl8XHA3bDDDveQ XtPHBNzLcoz0
68G2aLvMi6lucr+AnRBTbhIvVtPSTJFWrXjZLgHHQVUePEAlgsQIaOGepWGt rTTekSI8KOCX
8BBtiYiwtQedO2QYpzWhdtiN0DTcJj/eKSfGWdBm3W/p+E2ID8MjAh41i6ss oHW67tugec8m
NXX4rJgLMiGrpMiTmEEe/AoB2D2eFPAU2zcudty8DiPCj2rrQr60lnX0awF7 ubGdYCFF7mb4
NJkC5mdNLLxT0cNU92p01d2Hwok1pKwXhpX5h9gRzZzngOfhRd5U/A6hruwQ 7LF4LyHbANqM
+3UeagqHKDwiKrdnk5QbYQqEYJQKIVGk5oOEVo/V8jFBoYpV/wcBL8ErCPrw IukrcsynXPOa
gNfhj9SBNq5opPa4+isnMG7+/iRgFIx2Qg/8WcBbiX1PT4duh3cOiXHnO+Bt eI+N+z5C96Ew
7hA9SvbdzofwkR3+8hVydbN6y03KX79aATEpVTGov3Ph/AfChoNxowM9nnGo N6pLdbbTxSyZ
CEsGJMwKHlCU5UkaTJ/7lvjxU3m6hgY5gGJP/JeglCbs8G/aeA6jJVekOIdl kHPAfvivgP/B
FyoJ8KRk+pIuhXB0WQa6zNbeWv7kuioHAtrsiAi1B+TIicE47TrNS2B6BOZg LsKkDJh8CCXz
sn+QvePwTg6zVDylvQxu5JL7cSTFKtppNzgcDWUoaNis5DYU8wU60EmuE7G4 TkUm54E8hxP9
uA493BoKB5KjTHm0gE/hMweOxQI7jkM4YpgkBY7nMp0baQ/R1mh21q10mx4K 6NFwj7spRAHA
ouBEnGTHopSmSOUjgcU4WW3YTNcbX5bNr6bgNDtOpa3ikPwETsdS1RI0r1kl Xw1xrqJgsnFn
kHh4+OAnHnGhqK/Qu6gYSYsZ8pxkGMog1ZXVsHH3Yxkzm83GcAkUrNWxfLBr aLTn18IUAGxs
rCH3z7DgSn1jJ8UXwpRMXzDHTA+aK3AezlddPq+kkFwaCmhGkLvczF13NKwF I5osKO5VyXvl
0om1VXZceEiq3wIHLsCjOaKOQVh3yKtfqjqcuAgJ+XGU3Q5ObIHH4wnUkFKC qd3k9XdGjC5q
IMusTfTKzmDQLEUZbaoDF2O1HU+ipj455qGGJhzupBLhI5q67D0ELpGtcIfa k1AXTJh4t28P
x+1ePKCclCyi7XrCQVDn07jB+VXxAbmXveVkgacwa2F24eZpLWKDwEYecMbb 85A8cMEmgV+T
nmt5XxPyh8I82CxwlXXw1KBPD/uNoM6DqwWu4cEJ5iA3I2frq9rDoc62dp7Q IuBqWMh3pws4
H5bx3RkCPHAy360TuB41hELeK4VYTT1+fUV3kE/l+NBmziAdSOr3g3z0om5H H22HhlzQaN40
kU0oGwpsRdpP5OuexuZV1Y011HfOH5prGpEqJwEwBJ6FZ6ujg4Q4ZLmBD8ZU YqTWFAMCgxhS
OdRct3zAbztq2TB0IylRuGxMO6LJOjkB2YkdGBEYhWfIV4yIxeJu7BLYjZvI Hcyz98Qg58S1
nFBHRBT8iqHhJThWMcvzBJ7PLMcYkTQ/cuOFAi9ithNMtikT7HhJWk1JyfXM ZakW1ZjHZoHf
5B2A0zRRoxaQ4n5b4KW8rx9lvl+uG23tUR65XOAVjGqkEVkS8vv41XcEXsWv 8oyIJ0o7Ra8D
L8bvcQL8PkJRlgNYj0fl8R8K/BFerU7lmUtG7c2KW5apvFbzKb1CZV+iDiYS gTx4MZRTZG79
Mf7Ujj9BmJylBpqnFQJvwC3qy0UdOWMbWSDoM5mM8KrrIF8OFC8ypObzxc9+ +RRcp6CP2PGW
QTrjAbp0T5yMateduBV/JvA23EYpmoMp9YA5skQni8ipvozvT1k+n2Ye1iP+ XMAYGGvHO8na
6bZe0mn4KSLy8C5ypjhveYrtwDvwHt4jLua7ewXeh78gt9I6OvSgj5uALCdR JrUqXrFTYIxd
Ny8aUoNO3IUP2LEPYXQqSIH9+CBCDknPn8Y82c7O8SGEqYPKzg67W+AefITa T7JW3Ep1hl82
NZuyOPqQbbxk4DcpcRI1Wg3VecXJD7X1ZTfdhY8JfJzjNTdinMMfxHGfwJu5 EqFBRgnrgVDy
00LCvViipwQ+zd8OJ6g5qUIxoWcFPsGEuCZVe/lswqBWIN6acMRmbjUy50k/ eV7gC/hbCkUt
Od6EMHM46+34u0PSnC104Iv4e85NLyOc+//SnCX3ZdUbIlHuebPsMmX+e0Xg q1zvzbNaPuRU
hX4i+Ve8omp+i8Fy8I8CX4PSPPwTJe2UNcXKggMse0vgm2zGonYt6PPrVk+r 7ZLfgdyZsW8e
MAR5ck+Kd0q3ew8/sOP7aaV08HUCP+RPWXxqUKdrUcqf3Ch8JPCv+De1c0/U wHWWbD1z4Jah
OkqhtqEzqlfxhuwfAj/GTyiNUKsoP1UWZjsNXsvYPxX4GWPh0teod8tTeDv+ i4I7tbHk0wX8
N/7Xjv9BOH6ogKaE7J83N+g2v0dJ/Cvlp1Xa+MMl+L/Ms8gDJVPFcL4UNrCh ucdUSqosq89A
Ptgne1V6yA9tOQKvwy1kCdsIYRuZaYlEU8NT8oQtn6dMTpmS0oDwNKewCZ5W lGHTeC/htY0W
tjE8pzBjjupDvLZxwlbAM8alzFCNh9c2QdgKeXR8yqjqQZxwu61I2CbZinkL GqlubeW4DbaZ
3j4xi1942DG22kqEbYqNduUlWjj9c6xJhkvlwqFKZTa/46B/lv/so5i0HSbw bXyH2gRdYarI
oDhIAFLX1KoiiJK8l3SQxfjk3AEutU3m57mTBvS74fUS3EapD4rxLzl5KpXP nMtfbQ9BMpWn
CGg7UqDA2ZQnmuXnSKpGxKs424qjWGqC5QlSppMT9AgcBlTt6TeC/hWDHfLo Ph8AbOCgnxOE
vB8Fo+WVehd5HQcFdC2jueNhAv0tpKcT6b2NriNd5b0w8V45r5j+OuTbINEP wWS6m6hmQQlM
AZB3U2Ea0cjl/6Bl0qqnJ6RrgasXDnMVHN4Ps1p64YgYzEnSnUgUATppZhfh 7iaEXYRrk+Qh
1GqTRy7/Xw6TcjNdmX9R+R5wbwFn+W5wx2DeDrpWxuCYHQnyo0ktABcQ6QtJ 7Ist0IsS0Ivg
WFgkoR8HVSYDnebwyhLFYDQzqIjB8dskr0q6PSkpQwEtBbiMmFxO91cSk6sk o1JFIsGoxGTE
d9U000brlkDNoDItNWVani7Tj4jd1STTtUPIRDvtwWU6JSnTinSZbiQmN9H9 VmJy65AyNcHX
aDXCSikLs/TSbAZW4orBKld5DNa4+O/pO+EMerOOfhuSLCeTEwHcQYzvJOfd TmzvIrnupvf3
WGRMZa1LGVuhzWTIDsJgcu+D9qTGRsp3Oy1OlWtSQQiQU6u1R5sGsGH6ygct /G0J/jYKhQLJ
vwM2mjQaTBqFJFq4vnwv2Mu3gYMeOndDT5KsiqZHyfcfs5AuNEmPoPg8F86T pM+HZSbp9WZk
TtoFFxDBzTH4Vn35PrDvgsvrSaffS1JXinyKdP80cXqK4v8ZcpRnKcqfs3Cb ZHJzUl74IbkT
c7saFprcrqAnnnUM1hOza/bCdL70w/UtzLsXfkKXn8bg5j7YlgMsqIMw3HU9 5LnuhzPqy5Ng
ZstE9BI9/Z7uXiZmfyDWr1CaeBlmwWswF16HSnjDAuwYE5iN3ldLDSPcB4tN YAESi11wuosQ
/IKY9roK+mLQ31CxBx7eAo6K3fBwDPakZ5h3ifl7pNf3KTQ+oEz1F4s3T0+Y dLrJcCzp6zF4
XHrz3oROfGY+m82q2AcjC/btGEgpT+RAuj0+plj6hOzxKQXwZ/T+c+L+qcUl Zyfy3NNkL8Wx
0nRnJxF+di+MyN2esz1BVvnmFxYSzoRXPwe/MUkskIUBIL8fnm+hRPzbNOfG ERYC+QkCL5G5
FIHTTKmnKalHYLrQffCyzSKt1DfOBjseAfk4B0ahCybRNcllWoLLjZRdMgL3 1XSE87IG7nWw
xVx7KXFkO84n33tjH8wxw60P3kSo74e3W9hVNlM9e7fBtQs+oET3t53wBk9O cppG1gE8llAv
ggl4HBRjFUyj6wxcCkdincVb5psIJtC6j6W3zCDFfwL/BM7nn5JtFaozTQOV EqPP90GRqx/2
E5Jd8B/6fdmLI2LIwfJ5mp9gA2FoJK2tgHHYRJprhBJcadFAadxP+KMSZFTt nfB5WtXGFjLa
2gGqtlNSzeUvF5BMg8wnzxXDUTEck05tPeHTLHjyEngExruIdSaeEkWjsGD/ bTCO73fD/vIY
lsTwsLQAxTYQ2E67VAOK6DoZz86e83EmziImNm6XTGZnmMymMoM9sH9LghXx OWIb2OlpTlpl
w43gwDBpNwpTsMvCamqC1VQsxwqpmyMx3ndcQFC5Lk4rbyCi7n5c0OKq6MXK PjzWBmu2QV7j
kTE88V4GSEluEi5OEfE8gn0Bvb2avOsaon+d5OtSFBN8p2EN+RxTmIK1dMcU crEOl5H35fL/
TzWxnG7aqdjVi8sJjYd+lKtxBf1W0u/UpMjKuW8gMjdCHt4EfFQyFreSo99C cG61GLM4YcxT
Eoy6zCJ+lMy4RPk0Trrm/doYfl0l4PpylYDL0xOwcus7iOudxG07TMe7YDbe TWG1w6L4o0zO
083Uy4pflcBwnmnjhSTsmffhhj5sR+hDvw12YweXn6mMR/Y14/mOWpvyPqQd QAw705HEiHIv
8GFaIe6Cw7EPFmC/BclCE0khIe3BcySSNQkkmw8KybmM5IIkkhkUNoB7iPIj hGQPIXmUkDwG
Lnwc5tJ1Ae4bAlFjAtF9JBUnpqaBEC3qx4tbCMQ3EOjvt+Tfy5DSpz13G+Tm 0NOV8mkEP13U
i99tcFXE8AdJtC4KfcBniOuzhPYZQvtrcuHnCPFvqEF4Huro/mR8AVbgi5ZE 2ZRAXWWiPpkS
0TV4LVHN5f23ib/G1KhTFvQ+vN4G6TnnFYrWVy0KcSaixYk34k1SITcnFPKk WQ/Wc6Hag1u3
UO/J7Rj77DW7cSvxuNUGO/H2nBO2UbXoxztaxuP2Xrx7Sgx3xPB+l+t+vH1K H/ayBn8Zw4c3
23AKv+vDRxFu/vI5zim9uDeJcj7vsPBNQvlnGINvUXC9TfH9FpTiOzAL3yV3 fw9q6bqcnk/H
D2EdfmRR1HpTmjG0Y1J93ww4Gn9FLsKKeiIh18VmT7aIseyFuTm0HSmxwC9R 8GP45GbEEgvg
1xXgZ9Ij4RNK5f/XltWERBlF0fOOI2NmNWpMUaBjf+o3o2M5+VNJP4qLNBdF m5a1aleuWrZr
WZsGCtoFQ7QpqBmFNm1sVyhJEBhRSUEuSox+FtF573vz+TW1mcu7c9/hvnvf u/dcvjVl9Bs6
JAvmB4bMr1iYh71jG9Dl3LFhfqFch+5MKMxhAXpk5p8hJU8W1eAq5tVjM291 NSOLEJM02MqG
/xQc2g+BHjjvK1u96svrGjLALbHN9VG1WoqCNOrpSrMceRO0mreBRVES1w8f epNGgtuQ4vYY
YHME+C4CtL3V/tckwPcWUPGtxWoTVjs2MhPDaoqwlpV1h2VeuhouLqgr+NHg lHutKwZ6bl9u
aTCbNWtGd+77VDBjfqqV/C6TJTy1ZkxUzRptgS/hvtMm49qzJdx02sZQext9 brmpuuxwy1R1
2eKWrXGIyRJOh4TfzmzFbJXRMl1nS0TYZ/yr6vbvaarHZGe5wxqkgzItUZye s7Zsd/bZCjPr
ESuK9oPih+xEml3IsBu9DDDALAYlR5jDGHswyV6cYR7n2Ifz3I8Lkhd5AJfZ j2nJKyzgKg/i
GgdwnYO4IVnkEO7wEO7yMO7xCB5IznAET3gUczyG5zwusnoCSxzFB47hE8ex wpP4ygmXuYKb
FVaj6rLKXdyt3CXxmXvcPJDBZu6V93Wap9rYKf+VUZ2g7G9Lzt/df4ZIxjmc HyJTDQx06nDn
PlQ53M4Kcw//3m0uud1uAFVc7G9e8bCNJIEF52sLlkNp+r1cDPV/AFBLAwQU AAAACABIZxI1
Cofns1MCAAB1BAAAZwAAAHRlc3RpbmcucHJvamVjdC5zd2ltbGFuZXMuZGlh Z3JhbS9iaW4v
dGVzdGluZy9wcm9qZWN0L1N3aW1sYW5lcy9kaWFncmFtL2VkaXQvcGFydHMv U2Nob29sRWRp
dFBhcnQuY2xhc3OlUmtPE0EUPQOlL5ciBVFUQJBHu1VGPreSmBaTJlVIqk38 ZIZlWobso9md
QvhZxsQmkvgD/FHGO9ulBRMTovthZ+fsveec+/j56/sPAHt4lcEUQ1XLSCu/ x/thcCYdzdsX
ynOFLyN+okQvFB6XJ0rzvgh1xNvOaRC4BwQc0T2DFEMtCHtcOq7qR5L3vC4P B75WnhynD1TM
MCJojMBrBobsu8PGQetzs8FQbJ2Jc8FJvMfbOiRTVYZcp9n++GYUwJoMs/XA j7TwdUe4AzlN
lRwSSY30faX3GaZL5Q5Dqh6cyCzmKH9cTw4M8xZmkGaYaylfvh94xzL8II5d acQDR7gdESpz
T8B0LWG1S62/lekHWmgV+Lyj5EW13MljGg8tLOIB2dCnKmJ43fqPJlMPUudE zbBzRw8My04o
hZYN2RUDV8dMgascJSPjbtXCU1hZPGMotKVHvVRO/P8ygw2GO5tNKBO/TS29 a7ax4mUe69g0
3bDy1P5tCzso0RiUmaHrTuIY9ko3xn94bJSrtwuWXT5JoE5nYdN868IPfEWz y+AFQ/PfzI9J
bjqvYJMh3w4GoSPfKrMPC7dHs2sMU4G0dbSHU8iZ5aKvZWSQJTQXo6blWdyD RcgsITad5kkX
C19x/0scU6R3nk7Q1wxFLcQoKJL2KMnbJ8RgabsyxNKfeSuUtxrnLY2i8Ih8 xDp4jCfEkTJT
T7gk3YyLNXuIFbu4doX1T0M8/4Ytu1i+QoUuL+kyEdmgEoBNStui4rZRoHOe hrmIEpHvkHQ5
FrdGtIk4w27MwH8DUEsDBBQAAAAIAEhnEjX2IYBsbgQAANgJAACIAAAAdGVz dGluZy5wcm9q
YWdyYW0vZWRpdC9wYXJ0cy9Td2ltbGFuZXNFZGl0UGFydEZhY3RvcnkkTGFi ZWxDZWxsRWRp
dG9yTG9jYXRvci5jbGFzc7VWbVcbRRR+JiQspNOiRWhtS+kLlCRA12KtL9Qq pKRGA8VCQWqt
TpIhGdzsprsbAtVfoP3kN+vRetQfoOfUxaPnePzsD/FneLyzidBSAnzQD5Pd uXtfnvvcO3fy
59+//g7gAj41EGG47UvPV3bJrLrOiiz45lxdVSxhS88sKlFyRcWUReWbVeH6 3tbHKZLNkigj
Cr7jrg/kRF5aaWlZ+oPj5pyCoIeBKMMzK2JVmGRVMq/ndQgD7QxDjlsyZcFS VU+aJbls+o5j
eeZTLhhilvbNcCz3uEnRFfWxohnGHWdov6xs5V9h6Eu0VksuMETTTlHG0YaD HJ04xNCWSC50
gmByGOhg6MopW87UKnnpzou8JRkOayjWgnCV3jeFUb+sPIY7uf+TP0qsoyT9 XIOAE4nkbhR0
uNLSZgQu+SQJK8uiIM1VJevSfZxiIiSOYzhh4DjDwH4sOPpwkiFOoNKO7bsO wTq7DZZX9826
KpIKWTaUxg2cIvyttOblmh+nEpzh6EFvHAM4Z2CQ4WirbDmGkGA4SNbadtKp 2UVPp70jQSXp
VKTvrps3qD7UhpYcjyOFEQPDDIP7MuAY1QGNMO/quoZocryACwzdvitszyLe 552JvOdYNV2B
0R3bcNPxfNNG91JYhX68yHERLzViZIg2htM7EEsNVS2rgmdqFUrjZbxq4BWi bodoGVWqufKm
ryzlK+lxvAZqk0NN/9MEhBwxXEvsEWUPFE1HBOZ1vGHgyrZWaqXP8SYmiD6C M7EqXVGS6bJw
F1XRL4eHMmsgvUd5rqqKtD3l2Jq/KY4MrjEcKDiVKtVgTt2jOgwkstld8M86 KqRxElk9Dt7W
3byXti7XJHIc05ihwSPXqsIuMgw/Fakl3LD9ZjnexQ2qtyf9BtbZ3Xtmy3z/ Xd6PeY6boLnX
STz/e07O7dZYTx6S9zQtSzSud6Fly0JTk8L7HLfxgabmbk1YFK8nkdt+B4wn b3WS6occH0Ew
sDVaWS0pcBRDybreLXOU9C5W132hJYpjRUvay1KVyr5OkcZBBTal6G2laFA1 qB6UeLxA00uG
04sy399c1OOd5grDyZaTTc8dredSMkTPPitCnS1WCUd8zqm5BZlR+irpa3Ur nNesMfCsbUs3
bQnPk56BewxT/8mlw9C787WDUzSM22jFaEX0tUh/GPS+E3pMH6BdhuQResZT G+Cp4Z/R9RPt
IniWfg+RLvAZovicLO7jMO16G9roxnNA+Ka9Upn1xG/6NMM9EEs9QtePm+7a Q+EXoRveUGi6
YTiCo03jv0gvRs/ycIDn/0D/dCrA6QBnAyRn9OtogPMjAcZ+waUAly9FR3/D 5NJIJBLg6gbe
6onGym0B3glwfZG+pJZIdW4DiwFuPcCRkdFHuEMrT0vSKgf4eCvdMUIFfEnp PCBcX+E4vsYZ
fINBeg7hIRL4libjQ0zgO8zhe2roH8JcLjbwblJShoMqZdNBR+IuXPLeTUfX g090DpF1DYIo
jWA1jFzHWkijpmwdnyD+D1BLAwQUAAAACABIZxI1EKLgLecEAAAACwAAhwAA AHRlc3Rpbmcu
cy9kaWFncmFtL2VkaXQvcGFydHMvU3dpbWxhbmVzRWRpdFBhcnRGYWN0b3J5 JFRleHRDZWxs
RWRpdG9yTG9jYXRvci5jbGFzc7VW3VcbVRD/3fCxkG5BS2lV2tJaaJMAXUs/ FaylKanUQGlJ
QcCqS3JJLm5207sbAvW71q8n3+zRB1991XPq4tFzPD77R3mcu5sS+eZw9GFz d+7OzJ35zW/u
5K+/f/sDwFl8rSHCMOtx1xN23ihJZ4FnPWOiIoqWaXPXyAkzL82iwXPCM0qm 9Nzax2HaG6et
lJn1HLncleFLXpJbltp3ZNrJmrRoqGd4ZsFcNA0yyhu35tQJGhoZTjsyb/Cs JUouN/J83vAc
x3KNDS4YmivSLKXNOW4xXEivMSvOG7Jse6LIjZw0K/05oyyMeZEvS4p+6qnZ AEPjoLCFd4Xh
cmxPHuKTDPVJJ8ejqMN+Hc1oYaiLxSebQQnq0NDE0JoWNh8rF+e4zJhzFmc4 oJKwJk0plFzd
rPcKwmW4l/4fgaeU9Tz3pmrIXYrF94hdk+SW8kqhx9eitzBvZrmxKHiFy3+X juCK4gUc0dDB
0LUbCx1HcYwhSjEnHduTDkV8cl3EbsUzKiJHKmQZKg1oOM5wZCstBU2UCvSi jnYciqILpzR0
M5zbAxA6TiPGsJ8cK7fXnLKdcxUia4Oseshzp8g9uWzcocIS8y0+EEUCvRp6 GLp3ZaCjTx2o
BZCUllX0ho6XcJahzZOm7VpUkowzNOc6VlkVpy+2bSSZqo0iYVCgLpzTcR4X KCnhqpxUriWe
C4g9o75f0nEZL4cxKAWGg5RurZ0nPEn8pcwG8KqGwTWtHn7TcQWvUftZ3M57 hcDziIahHTC4
TrWwXeHYzYRZUsd1DDM0UFWVCzYSRSdu6HgdIwz7sk6xROlPiAcEQVdsZGQj aaiVSgWRdY1x
R9gehXsVb6gWTiuO7aStkEpgTMctjBMSLvfCo8a3R3s1hYHd86MTd3RMIBMC niKKM5zYpAlW
I1QqZDeJNzVMEc03OSgV8PiuJyzhCe7qmMYMQ0vV/yjFQI4YbmyDQ3DKDlFU HVEwb+FtDffW
tf1W+jreUfRoo3CGFrk08zxZMOWUKrSqkqljDlmiD18qmTYRs2dDfbfGXeFJ TTSPPI0QOuBp
x57aDtG17SoUSxZoVm2DTs0iZApdFEXYKub7ZdOi89pj6fUDcCA+o5hd0nFf MZstKYnA8AJp
WUmLOipKaixwkS94KpllHQ/wPiXj1pLRCBCChKZTNEuXKQ8uU8pxd9e0mkVB Wx/b8qJVba/0
JIVNQOySy9To5iLFEZ1wyjLLU0LNvaNbjbAzCh8aWCO2zWXSMl2Xuxq+ZBj+ TyYklWDTGYnj
Re: problems implementing swimlanes [message #24017 is a reply to message #23223] |
Sat, 19 August 2006 06:45 |
Hi Michael,
The problem I am facing is the xml that is getting generated.If I use
the containment feature for Class-Teacher I am getting an xml of the form :
<classes section="Section A" >
</classes>
what I actually require is
ie classes and teachers should be at the same level in the generated xml
and the diagrammatic representation should be such that teachers are
represented withing the "classes" swimlane.
Sayed Aamir Shoeb
Michael Golubev wrote:
> I am trying to implement this for UML2 activity diagram partitioning but
> without great success.
> The only thing I may suggest to you for now is to patch layout edit policy
> for Classes to force them to always fit the whole available screen place
> (say, horizontally). Obviously it is not directly supported by generation,
> so you need to start from gmfgraph model with ClassRectangleFigure.
> This way you will emulate the partitioning of the whole diagram, and
> generated code will handle the simple containment Class-Teacher.
> Michael
> "sayed" <sayed.shoed@tavant.com> wrote in message
> news:ec4ai1$jbf$1@utils.eclipse.org...
>> Regards
>> Sayed Aamir
Re: problems implementing swimlanes [message #24051 is a reply to message #23223] |
Sat, 19 August 2006 06:50 |
Hi Michael,
</classes>
Sayed Aamir
> Michael
>> Regards
>> Sayed Aamir
FUDForum. Page generated in 0.03359 seconds
