Home » Language IDEs » C / C++ IDE (CDT) » CDT6.0 container_loc
CDT6.0 container_loc [message #235648] Fri, 10 July 2009 15:16 Go to next message
Hey all,
have I seen this correct, that the variable 'container_loc' of the build
command is not usable any more?
I have seen this solution
<http://dev.eclipse.org/mhonarc/lists/cdt-dev/msg14567.html> with
${container_loc} is ${selected_resource_loc}/..
but this does not work for me. Perhaps because it is on Linux and a path
like
/home/thundernail/workspace/projectA/path/to/source/source.c pp/.. is not
valid.
Is there any solution to set the workdirectory of the make command to the
directory of the active file?
thanks
Thundernail
Re: CDT6.0 container_loc [message #235657 is a reply to message #235648] Fri, 10 July 2009 16:42 Go to previous messageGo to next message
The problem with these variables is that the build plugin is independent
of UI plugins and so it cannot expand UI variables. The best you can do is
to use build variables like ${ProjDirPath}.
> like
> valid.
If you use "Build Project" command it is always executed in project build
directory. As an alternative you could try Make Target view. If you create
its target in a subfolder the working directory will be that subfolder.
This holds true for not managed build only.
> thanks
> Thundernail
Andrew
Re: CDT6.0 container_loc [message #235667 is a reply to message #235657] Sat, 11 July 2009 06:19 Go to previous message
Thanks for the reply,
The build plugin has the ${selected_resource_loc} variable, so it should
be possible to give the path of the directory.
I don't linke the idea to set up the Make Targets for around 100
directorys ;-)
My solution at the moment is a Makefile at the protject root, that
forwards to the Makefile in the directory of the ressource.
My build command:
make RESOURCE_LOC=${selected_resource_loc}
The Makefile in the project root directory:
CONTAINER_LOC:=$(shell dirname "${RESOURCE_LOC}")
all:
@$(MAKE) -C ${CONTAINER_LOC}/ all;
Previous Topic:CDT 6.0: Scanner Discovery
Next Topic:MinGW Windows, Slow Builds
Current Time: Sun Nov 02 01:20:45 EDT 2025
Powered by FUDForum. Page generated in 0.03817 seconds
