Home » Eclipse Projects » Eclipse Platform » Eclipse 2.1.3 + Linux GTK + Java Api Doc
Eclipse 2.1.3 + Linux GTK + Java Api Doc [message #235137] Tue, 27 April 2004 06:47 Go to next message
Originally posted by: eichbaum25.web.de
How can i use the java api docs with the "F1" key
with Linux like "Eclipse/Windows"?
When I press the "F1" key (Linux) nothing happens.
Platform SuSE 9.0
KDE 3.2.1
Eclipse 2.1.3 (Api Doc Location indicated)
Greetz
Boris
Sorry for my bad english
Re: Eclipse 2.1.3 + Linux GTK + Java Api Doc [message #235196 is a reply to message #235137] Tue, 27 April 2004 08:47 Go to previous messageGo to next message
Hi Boris,
To show javadoc use F2 on all platforms.
To show help, which is F1 on win32, use Shift+F1 on linux-gtk.
Grant
"Boris Juszczak" <eichbaum25@web.de> wrote in message
news:c6ldd7$n7j$1@eclipse.org...
> Platform SuSE 9.0
> KDE 3.2.1
> Greetz
> Boris
Re: Eclipse 2.1.3 + Linux GTK + Java Api Doc [message #235341 is a reply to message #235196] Tue, 27 April 2004 11:41 Go to previous messageGo to next message
Hi Grant,
when I mark a passage or set the cursor in a Word (like JFrame) and press
Shift+F1 nothing happens.
If I'm pressing F2 then there is only a small helpwindow (show tooltip
description - say's the key mapping).
When I use Windows, then it opens an explorer window with the docs of the
whole class.
Boris
Grant Gayed wrote:
> Hi Boris,
> Grant
>> Platform SuSE 9.0
>> KDE 3.2.1
>> Greetz
>> Boris
Re: Eclipse 2.1.3 + Linux GTK + Java Api Doc [message #236430 is a reply to message #235341] Thu, 29 April 2004 08:47 Go to previous messageGo to next message
ok, I didn't realize that Shift+F1 does not work in 2.1.3 on gtk. This is a
bug that is fixed in the 3.0 stream. I'm surprised that F1 opens an
explorer window for you on windows though, because I don't see this, I just
get a hover window with some faked clickable links.
Grant
news:c6lujm$eru$1@eclipse.org...
> Hi Grant,
> whole class.
> Boris
> Grant Gayed wrote:
> > Hi Boris,
> > Grant
> >> Hi,
> >> Platform SuSE 9.0
> >> KDE 3.2.1
> >> Greetz
> >> Boris
Re: Eclipse 2.1.3 + Linux GTK + Java Api Doc [message #237040 is a reply to message #236430] Thu, 29 April 2004 16:31 Go to previous message
Hi Grant,
thank you for this hint regarding the 3.0 - i will try it.
greetings
Boris
> a
> just get a hover window with some faked clickable links.
> Grant
Previous Topic:Local CVS Repository, Win98
Next Topic:EditorPart page close button
Current Time: Thu Mar 13 17:11:55 EDT 2025
Powered by FUDForum. Page generated in 0.03348 seconds
