Home » Modeling » OCL » accessing dynamic eobject api + function libraries
accessing dynamic eobject api + function libraries [message #22906] Thu, 10 May 2007 17:27 Go to next message
Kagan Turgut is currently offline Kagan TurgutFriend
i would like to be able to check whether an attribute is actually set or
not within an expression, and unset it if necessary within an ocl
expression.
how can i call the eobject dynamic methods such as eIsSet(x),
isUnsettable(x) unset(x) etc within an OCL expression?
thanks in advance,
kagan
Re: accessing dynamic eobject api + function libraries [message #22950 is a reply to message #22906] Thu, 10 May 2007 18:58 Go to previous messageGo to next message
Hi, Kagan,
In any case, you should never be able to call eUnset() because OCL is a
side-effect-free language. Its semantics do not allow the modification of
the model that it is constraining/querying.
Regarding eIsSet() and isUnsettable(): OCL provides no means to access the
metamodel of the model that it is constraining. That is, you can check
whether
self.oclIsKindOf(Xyz)
but you cannot do
self.oclType
to get the Xyz metaclass in order then to do
self.oclType.getEStructuralFeature("x")
I don't know whether this is an accidental or intentional omission from the
spec. I suspect that it is accidental because the UML 2.1 specification
actually uses such non-existent constructs as "self.oclType" in defining
its constraints.
Christian
> expression.
> thanks in advance,
> kagan
Re: accessing dynamic eobject api + function libraries [message #23670 is a reply to message #22906] Wed, 16 May 2007 23:24 Go to previous messageGo to next message
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
You may try implementing a property (added to your .ecore before
generation),
returning the instance of the ecore:EClass metaclass,
then you can reason over it with OCL.
You
Re: accessing dynamic eobject api + function libraries [message #23880 is a reply to message #23670] Thu, 17 May 2007 13:10 Go to previous messageGo to next message
Hi, Antonio,
You can take this one step further by not actually implementing the
modelClass property in your Ecore model (which might be seen as breaking
the model's semantic cohesion, especially as it crosses meta-levels), but
rather defining it in a custom Ecore environment as an OCL-defined
"additional attribute", for use by OCL constraints only.
See the newly-added Programmer's Guide topic in the M7 build, that discusses
how to extend the environment for this kind of situation, with a working
example. The example defines an additional operation, but the mechanism is
the same:
OCL Developer Guide
Programmer's Guide
Advanced Topics
Customizing the Environment
The example adds a regexMatch() operation to the String primitive type. It
is actually implemented in the
org.eclipse.ocl.ecore.tests.EcoreEnvironmentTest class, verbatim from the
guide.
Christian
> generation),
> Youll need to add the ecore metamodel Ecore.ecore
> as a resource to your own .ecore metamodel.
> For any side effects, you may just invoke any method of your own
> implementation.
> Thats breaking the rules, right.
> Thats why we put them there, first!
> <eClassifiers xsi:type="ecore:EClass" name="ConModelClass"
> abstract="true">
> <eStructuralFeatures xsi:type="ecore:EReference" name="modelClass"
> lowerBound="1" eType="ecore:EClass
> ../../../plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EC lass "
> changeable="false" volatile="true" transient="true" derived="true"/>
> </eClassifiers>
> From the OCL console:
> Evaluating:
> self.modelClass
> Results:
> EClass Proceso
> Evaluating:
> self.modelClass.eAllAttributes
> Results:
> EAttribute codigoYNombre
> EAttribute codigo
> EAttribute nombre
> EAttribute codigoCompleto
<snip>
Re: accessing dynamic eobject api + function libraries [message #23921 is a reply to message #23880] Thu, 17 May 2007 14:20 Go to previous messageGo to next message
Wow!
What an amazing piece of technology you guys are putting together!
I believe most would agree that the actual power of the approach,
as you guys are implementing it withing the Eclipse ecosystem,
exceeds whatever where the most forward-looking expectatives
of the original OCL spec.
We
Re: accessing dynamic eobject api + function libraries [message #23959 is a reply to message #23921] Thu, 17 May 2007 14:44 Go to previous messageGo to next message
Hi, Antonio,
<blushing>Thanks for the vote of confidence!</blushing>
We're all very pleased that what we are providing is proving so valuable to
you.
Have you cast your vote for EMF?
http://www2.sys-con.com/java/readerschoice2004/frameliveupda te.cfm?BType=11
cW
> Wow!
> Were now in Inception work,
> and the focus is such, that Ive had no reason to allocate time to use your
> last versions -
> no need for the profits of detailed OCL specification.
> But I am really, really looking forward to it
> (about the 2nd or 3rd time I declare so).
> Cheers!
> ACV
<snip>
oclType, Re: accessing dynamic eobject api + function libraries [message #43504 is a reply to message #22950] Sun, 18 November 2007 11:28 Go to previous messageGo to next message
Philipp Kutter is currently offline Philipp KutterFriend
Hi, Christian.
Is oclType now accessible in the newest version of the ocl.ecore,
or do I need to add it by hand to the environment?
I came to the problem trying to access eContainer, an Issue I will
describe in a separate post.
Best, Philipp
Christian W. Damus wrote 10.05.2007:
> Hi, Kagan,
> whether
> but you cannot do
> self.oclType
> its constraints.
> Cheers,
> Christian
>> expression.
>> thanks in advance,
>> kagan
Re: oclType, Re: accessing dynamic eobject api + function libraries [message #43598 is a reply to message #43504] Mon, 19 November 2007 13:13 Go to previous message
Hi, Philipp,
Nope, oclType isn't available yet, and probably won't be until the OMG
defines it.
Of course, one could consider, in the mean-time, sneaking it in via a new
ProblemOption (error by default) for those clients that don't mind
depending on non-standard constructs. The problem with that, though, is
that probably the OMG would end up defining something different, which
makes for an incompatible transition for these clients, anyway.
Christian
Philipp W. Kutter wrote:
> Hi, Christian.
> Best, Philipp
-----8<-----
Previous Topic:Query evaluate DynamicEObjectImpl problem.
Next Topic:Defining EOpposites on subclasses
Current Time: Thu Dec 26 15:52:02 GMT 2024
Powered by FUDForum. Page generated in 0.03709 seconds
