Home » Eclipse Projects » Eclipse Platform » Surely the Search code can't be that badly factored?
Surely the Search code can't be that badly factored? [message #22855] |
Tue, 29 April 2003 18:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul E. Keyser![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=rolarenfan%40earthlink.net) Messages: 878 Registered: July 2009 |
R2.0.2, Win2K
So, I found the extensionPoint org.eclipse.search.searchPages, and was
able to define a nice (useless) blank search page; all fine.
Now I wanted to make my search page do something, anything. So I
thought -- hey, I'll have it (note critical ambiguity!) display not the
file-name but the user-friendly 'node' name (our projects' files have
internal-only names; users interact with user-friendly names that are
stored *in* the files). Cool -- after a bit I found
TextSearchResultCollector (plus about four other TextSearchFoo classes),
and in TSRC, lines 134-136, which appears to be exactly what I need to
modify. I'll just copy
org.eclipse.search.internal.ui.text.TextSearchPage intact, and copy and
modify TextSearchResultCollector.
Then it got weird -- since TSRC either uses or is used by many
*package*-access classes, just to modify three lines, I wound up having
to *copy* the code for all of these classes: GotoMarkerAction,
GroupByKeyComputer, ReplaceAction, ReplaceDialog, TextSearchOperation,
and of course TSRC (almost 1000 lines). All but TSRC are of no direct
interest to me: I'd have been happy to accept whatever the existing
classes do. (I guess that the package-access is related to the
package-name "org.eclipse.search.internal.", but in fact many classes in
that package (or its subpackages) are public: e.g., SearchResultView,
TextSearchVisitor, StringMatcher, and TextSearchEngine -- it is
particularly odd to have TSO package but TSE, TSRC, and TSV public,
since TSO creates a TSE which creates a TSV which creates a TSRC, which
then uses a GMA (package), a GBKC (package), and a replaceAction
(package).
And it didn't even work, because SearchResultView appears to *ignore*
the description used by TSRC.
So, before I copy and cauterise another six classes of oddly
*package*-access code in vain, can anyone tell me how to just change the
String that is displayed in the SearchView? And am I just barking up
completely the wrong tree here?
(I shudder to think how messy it will be to write a SearchPage that does
anything but text-searches!)
Thnaks,
Paul K
Re: Surely the Search code can't be that badly factored? [message #23423 is a reply to message #22855] |
Tue, 29 April 2003 20:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bob.objfac.com
"Paul T. Keyser" <rolarenfan@earthlink.net> wrote in message
news:3EAEBF33.DF1F681A@earthlink.net...
I did that. The non-text aspect didn't present much of a problem; as long as
the searching doesn't have to consider more than one resource at a time,
most of the design is going to be about the same. It's just a pity more of
the generic logic isn't captured in some kind of framework.
The API provided is the absolute minimum that will allow you to add a search
page. In fact, it's somewhat less than minimum. Many of the method arguments
are undocumented. I particularly enjoyed the string arguments destined for
MessageFormat for which the javadoc didn't explain how many arguments they
had or what the arguments meant. I had to locate and read a .properties file
to see how the API is used! After "start the search" the page writer is
given no help at all.
So I did what you did, I looked at Text search. However, I didn't try to
copy the internal code out and hack it. That is often like pulling a thread
in a sweater, as you found it. I just used it as a guide to how search works
in general.
Most of Text search seemed pretty sensible and modular to me. The only thing
that impressed me as "badly factored" - probably the same thing that
impressed you - was putting the text compare logic inline in the class that
drives the resource loop. That did seem a bit hacky, but it solved the
problem of where to put the variables that count down the progress. In my
design, I put the compare logic in a separate class and passed it an
interface to use for error and progress reporting. Also, some
simplifications are possible. The same information gets passed to classes at
multiple levels; at least one of those levels can be eliminated. I tried to
abstract the resource filtering mechanism a bit more and I wrote my own file
name wild-card matcher. I _think_ I did it because it wasn't easy to re-use
the one Text uses, but I'm not sure my motives were pure.
Would I have foregone the pleasure of writing all that code and just plugged
my compare logic into some search framework? You bet. I'll vote for that!
Bob
Re: Surely the Search code can't be that badly factored? [message #25966 is a reply to message #23593] |
Thu, 01 May 2003 16:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
What do you mean by "change the text"? Each search page has a tab title, a
fixed Scope section and a variable-height per-page control that is drawn
above Scope. For the title and control, you can specify/draw any text you
want. In fact, you must; there isn't any way to re-use controls from the
existing pages.
Bob
news:3EAEF214.433C8B7E@earthlink.net...
> So, um, you never tried to change the text that the SearchView displays?
That
> would be one task (among many) that I have yet to work out how to do.
> But thanks for the encouragement on creating new Searchers.
> Paul K
Re: Surely the Search code can't be that badly factored? [message #27624 is a reply to message #25966] |
Mon, 05 May 2003 20:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Er, no -- the text displayed in the SearchView, i.e, the View that contains a
list of results (on each of which you can double-click and go to the result).
I wanted to display not the filename (e.g., TextSearchVisitor.java) but
something else (some text derived from the file, e.g.). I wound up figuring
out how to do it -- substitute a new LabelProvider at a certain point in (I
think but can't check right this minute) TextSearchResultsCollector -- but it
was sure not obvious until after I had read and stepped through about 6 or 8
classes, most with package-access (thus requiring that to add trace statements
I had to copy them to my WS and cauterize their imports, often requiring that
I bring in other classes I wasn't directly interested in).
Paul K
> existing pages.
> Bob
> That
> > Thanks,
> > Paul K
Re: Surely the Search code can't be that badly factored? [message #28756 is a reply to message #27624] |
Thu, 08 May 2003 11:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I see. Good point.
(Eclipse is not a framework; it's an application with a plugin API. There's
a difference.)
Bob
news:3EB6CE40.EE4B22E1@earthlink.net...
contains a
result).
figuring
(I
it
8
statements
that
> Paul K
a
you
> > existing pages.
> > Bob
displays?
> > That
> > > Thanks,
> > > Paul K
Current Time: Fri Aug 23 11:13:04 GMT 2024
Powered by FUDForum. Page generated in 0.05191 seconds
