Home » Language IDEs » Java Development Tools (JDT) » IFile for project-less source file?
IFile for project-less source file? [message #233527] Mon, 31 July 2006 14:06 Go to next message
Hi all,
I've written a little plugin that runs OrganizeImportsOperation on a
file opened in the IDE. I'm currently trying to turn this into a
standalone Java app that organizes the imports of a file specified as a
program argument.
My question is this: how can I get an IFile for a .java file that does
not have an associated Eclipse project? Do I really have to create a
project and copy the file into it? I seem to recall seeing somewhere in
the JavaEditor that a dummy project was created so that the Java Editor
could open up .java files independent of projects. Could I do a similar
thing here? (I can't remember now where I saw the pseudo-project magic
being done.)
In either case, can someone give me a nudge in the right direction? I
tried doing something like that described here:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg50 548.html
but got a "Workspace is closed" exception.
David
Re: ICompilationUnit for project-less source file? [message #233544 is a reply to message #233527] Mon, 31 July 2006 15:30 Go to previous messageGo to next message
Okay, I found createFakeCompiltationUnit in
CompilationUnitDocumentProvider. Using it as a guide, I created the code
below. I'm still getting this "Workspace is closed" exception, but this
time at the call to newWorkingCopy.
Anyone have a suggestion?
David
------------ %< Complete code below %< --------------
package edu.wm.cs.PlanCleanupStandalone;
import java.io.BufferedReader;
import java.io.FileReader;
import java.io.Reader;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.Path;
import org.eclipse.jdt.core.IBuffer;
import org.eclipse.jdt.core.IClasspathEntry;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.ISourceRange;
import org.eclipse.jdt.core.WorkingCopyOwner;
import org.eclipse.jdt.core.dom.CompilationUnit;
import
org.eclipse.jdt.internal.corext.codemanipulation.OrganizeImp ortsOperation;
import
org.eclipse.jdt.internal.corext.codemanipulation.OrganizeImp ortsOperation.IChooseImportQuery;
import org.eclipse.jdt.internal.corext.util.TypeInfo;
import org.eclipse.jdt.internal.ui.javaeditor.DocumentAdapter;
import org.eclipse.jdt.launching.JavaRuntime;
public class PlanCleanupStandalone {
if (args.length == 0) {
System.err.println("provide a java file as an argument");
System.exit(1);
removeUnusedImports(args[0]);
System.out.println("Done!");
private static void removeUnusedImports(String filepath) {
// IFile file = null; // How to get this without a project?
// ICompilationUnit cu = JavaCore.createCompilationUnitFrom(file);
ICompilationUnit cu = createFakeCompilationUnit(filepath);
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setSource(getSource(filepath).toCharArray());
CompilationUnit astRoot = (CompilationUnit)parser.createAST(null);
CompilationUnit astRoot = null;
IChooseImportQuery query= new IChooseImportQuery() {
public TypeInfo[] chooseImports(TypeInfo[][] openChoices,
ISourceRange[] ranges) {
throw new RuntimeException();
try {
OrganizeImportsOperation oi = new OrganizeImportsOperation(cu,
astRoot,
/*ignore lower case*/ false, false, true, query);
oi.run(null);
} catch (CoreException core) { core.printStackTrace();}
// Inspired by CompilationUnitDocumentProvider.createFakecompiltationUnit
private static ICompilationUnit createFakeCompilationUnit(final
String filepath) {
try {
WorkingCopyOwner woc= new WorkingCopyOwner() {
public IBuffer createBuffer(ICompilationUnit workingCopy) {
return new DocumentAdapter(workingCopy, new Path(filepath));
IClasspathEntry[] cpEntries = new IClasspathEntry[] {
JavaRuntime.getDefaultJREContainerEntry() };
final ICompilationUnit cu= woc.newWorkingCopy(filepath,
cpEntries, null, null);
cu.getBuffer().setContents(getSource(filepath));
// if (!isModifiable(element))
// JavaModelUtil.reconcile(cu);
return cu;
} catch (CoreException ex) {
return null;
public static String getSource(String filepath) {
int READER_CHUNK_SIZE= 2048;
int BUFFER_SIZE= 8 * READER_CHUNK_SIZE;
StringBuffer buffer= new StringBuffer(BUFFER_SIZE);
try {
Reader in= new BufferedReader(new FileReader(filepath));
char[] readBuffer= new char[READER_CHUNK_SIZE];
int n;
n= in.read(readBuffer);
while (n > 0) {
buffer.append(readBuffer, 0, n);
} catch (Exception e) {
System.err.println("Problems reading from file " + filepath);
System.exit(1);
return buffer.toString();
Re: ICompilationUnit for project-less source file? [message #233654 is a reply to message #233544] Wed, 02 August 2006 08:18 Go to previous message
David Coppit wrote:
>> does not have an associated Eclipse project?
> code below. I'm still getting this "Workspace is closed" exception,
> but this time at the call to newWorkingCopy.
You could file a feature request against JDT Core to support calling
this method without having a workspace.
Dani
> David
> import
> import
> public static void main(String[] args) {
> System.exit(1);
> try {
> astRoot,
> oi.run(null);
> // Inspired by
> String filepath) {
> try {
> return cu;
> return null;
> try {
> int n;
> while (n > 0) {
> System.exit(1);
Previous Topic:Strange Error: Files Appearing Blank
Next Topic:Build path specifies unavailable execution environment: ... How to eliminate?
Current Time: Sat Nov 01 12:30:19 EDT 2025
Powered by FUDForum. Page generated in 0.03904 seconds
