Home » Eclipse Projects » DTP » Can DTP be used to save EMF instances?
- Can DTP be used to save EMF instances? [message #1930] Wed, 12 October 2005 17:26 Go to next message
Will I be able to use DTP to persist arbitrary EMF instances to a
database? I.e., can it be used to persist any EObject?
Ed Merks
- Re: Can DTP be used to save EMF instances? [message #1973 is a reply to message #1930] Thu, 13 October 2005 10:24 Go to previous message
Originally posted by: jograham.sybase.com
Ed Merks wrote:
> Ed Merks
Hi Ed,
I guess the answer is "sort of." Using the connectivity components, you
can persist whatever you'd like to a database. Unfortunately, we currently
don't have components that would help more than that. There are a couple
of ORM initiatives in the Technology PMC: We've suggested to these groups
that a common ORM framework (independent of specifics such as EJB 3) makes
sense for inclusion in DTP, but we have not received any proposals in this
area to date. If we had such a generic ORM framework, then perhaps tooling
that automatically handles arbitrary EObjects could be built with it (and
that would be a great component for DTP as well).
Maybe as DTP gets the core frameworks and tools in place we'll be able to
find support for such capabilities.
HTH,
John Graham
Eclipse Data Tools Platform Project PMC
- Re: Can DTP be used to save EMF instances? [message #566847 is a reply to message #1930] Thu, 13 October 2005 10:24 Go to previous message
Ed Merks wrote:
> Ed Merks
Hi Ed,
HTH,
John Graham
Previous Topic:Suggestions for EclipseCon06 DTP tutorial session
Next Topic:Documents for first iteration available
Current Time: Mon Apr 28 11:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
