Home » Newcomers » Newcomers » Running C/C++ program
Running C/C++ program [message #231827] Sun, 09 September 2007 05:56 Go to next message
Originally posted by: arellano.fiu.edu
I am running a simple C program for testing purposes
The progam is suposed to:
Print "Enter Values"
Receice two numbers from keyboard
Print "worked"
The problem that I have is that "Enter Values" will not print till both
numbers are entered.
What can be wrong,
Wilmer
Re: Running C/C++ program [message #231835 is a reply to message #231827] Sun, 09 September 2007 07:14 Go to previous messageGo to next message
Wilmer,
Maybe you have to flush the stream before the output is displayed.
> Print "worked"
> both numbers are entered.
> What can be wrong,
> Wilmer
Re: Running C/C++ program [message #231850 is a reply to message #231835] Sun, 09 September 2007 11:07 Go to previous messageGo to next message
Thanks Ed,
I new to C and eclipse, can you tel me how to flush the stream?
I am running under windows XP with CYGWIN and my code is:
#include <stdio.h>
#include <math.h>
int main(void)
int k;
float r;
printf("Enter Values \n");
scanf("%i %e",&k,&r);
printf("worked %i and %3.3e \n",k,r);
return(0);
Wilmer
Re: Running C/C++ program [message #231878 is a reply to message #231850] Sun, 09 September 2007 14:24 Go to previous messageGo to next message
Wilmer,
It's been so many years since I've done C/C++ programming. I just did a
google for "c programing flush stream" and it turns up answers...
> Thanks Ed,
> #include <stdio.h>
> #include <math.h>
> int main(void)
> int k;
> float r;
> return(0);
> Wilmer
Re: Running C/C++ program [message #231911 is a reply to message #231850] Sun, 09 September 2007 21:55 Go to previous message
> Thanks Ed,
> #include <stdio.h>
> #include <math.h>
> int main(void)
> int k;
> float r;
> return(0);
> Wilmer
well i think you're facing this problem while *DEBUGGING* the program .
If so then go to Run->Open Debug Dialog->Debugger
select "gdb/mi" as your default debugger and "standard" as your command
set and not "standard(windows)" as your command set .
This should solve the problem
Previous Topic:Eclipse invoking Emacs
Next Topic:Eclipse TPTP Error
Current Time: Wed Apr 16 10:01:22 EDT 2025
Powered by FUDForum. Page generated in 0.04765 seconds
