| [JET2] Using MessageDialog in custom Tag [message #22536] | Tue, 19 June 2007 05:46  |  |
| Eclipse User  |  |  |  |  | Originally posted by: vincent.lg.voila.fr
 Hi everyone,
 I wrote some custom tags for my application and I wanted to display a
 MessageDialog to ask users for something, but
 MessageDialog.openInformation() throws a nullPointerException.
 Here is a sample code :
 public class AutoDeployTag extends AbstractEmptyTag {
 public AutoDeployTag() {
 // TODO Auto-generated constructor stub
 public void doAction(TagInfo td, JET2Context context, JET2Writer
 out)
 throws JET2TagException {
 MessageDialog.openInformation(null, "Test", "Test");
 The dialog fails because it can't find any active shell to be displayed
 on. I tried to pass
 Activator.getDefault().getWorkbench().getDisplay().getActive Shell()
 instead of null, but it doesn't work.
 Does anyone have an idea ?
 Many Thanks.
| Re: [JET2] Using MessageDialog in custom Tag [message #22709 is a reply to message #22580] | Tue, 19 June 2007 09:48   |  |
 Thanks a lot for the quick answer Paul,
 Indeed, I've found that one couldn't create a MessageDialog outside the UI
 thread, as you mentioned it in your answer. And I think I will give up
 because you're right saying JET should be able to run without the UI.
 I've one more question : I would like to be able to make a copy of some
 files at the end of the transformation. In the workspace tags, it is only
 proposed to create/copy files and folders in the current workspace, but
 I'd like to copy them outside the workspace, say in my 'homedir' for
 example. As it was impossible with standard tags, I've created a new tag
 to copy the generated files (those in workspace) in my 'homedir', but it
 is also impossible because JET uses a transaction system and actually
 writes files on the disk when the transformation has ended, and the copy
 doesn't work since files does not yet exist.
 Can you give me some information about how I can do that ? Maybe there's a
 way to chain 2 transformations, one that writes files in the workspace,
 and the other that deploy those files elsewhere.
 Many thanks,
 Vincent.
| Re: [JET2] Using MessageDialog in custom Tag [message #23015 is a reply to message #22709] | Wed, 20 June 2007 08:36  |  |
| Eclipse User  |  |  |  |  | Vincent:
 Your tag can participate in JET's transactin by adding an 'action' via the
 WorkspaceContextExtender:
 WorkspaceContextExtender.getInstance(context).addAction(  ...an
 implementation of IWorkspaceAction or a subclass of
 AbstractWorkspaceAction...)
 Although this is targetted at writting to the Eclipse workspace, I think you
 could make them work for your purposes. If you subclass
 AbstractWorkspaceAction, you must implement three methods:
 * performAction, which would actually write your file (and which would have
 access to all previously written files)
 * requiresValidateEdit, which can return false, as files outside the
 workspace are not affected by the team system.
 * getResource(), which can return null (or throw an
 UnsupportedOperationException) - it will not be called if
 requiresValidateEdit returns false.
 Actions added via addAction are executed in the order in which they are
 added. WorkspaceContextExtender also has a method addFinalAction, which
 causes the action to be executed after all actions added by addAction.
 Paul
 "vincent" <vincent.lg@voila.fr> wrote in message
 news:b52f08b4fe4c4a642c7ffb134a729203$1@www.eclipse.org...
 > Many thanks, Vincent.
FUDForum. Page generated in 0.04053 seconds
