Home » Language IDEs » C / C++ IDE (CDT) » CDT CEditor typing preferences
CDT CEditor typing preferences [message #230311] Thu, 12 February 2009 15:57 Go to next message
In an archive post (msg 14564) Raghavendra described a problem when
CEditor is embedded in a multipage editor. Specifically, when embedded,
if you type '{' followed by CR, the embedded editor does not generate the
closing '}'.
The thread does not have a solution to the problem. The final entry
suggests debugging BracketInserter.verifyKey(), but this method generates
the closing char for '[', '(', '\'', and '\"', but not '{'.
I'm hoping someone knows the solution or at least can point me to where
the closing '}' is generated.
Re: CDT CEditor typing preferences [message #230340 is a reply to message #230311] Fri, 13 February 2009 13:15 Go to previous messageGo to next message
> the closing '}'.
> generates the closing char for '[', '(', '\'', and '\"', but not '{'.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=206301
Anton Leherbauer
Wind River CDT Team, Austria
Re: CDT CEditor typing preferences [message #230349 is a reply to message #230340] Fri, 13 February 2009 14:48 Go to previous messageGo to next message
Thank you, Anton
As the curly brackets problem also occurs with the Java and JavaScript
editors, can you tell me what you changed to fix the problem in cdt 4.0.2?
Re: CDT CEditor typing preferences [message #230356 is a reply to message #230349] Sat, 14 February 2009 05:48 Go to previous message
> Thank you, Anton
Look at CAutoIndentStrategy.computeSmartMode()
Previous Topic:Build All--where is the control
Next Topic:Discovery options
Current Time: Wed Oct 15 19:07:38 EDT 2025
Powered by FUDForum. Page generated in 0.10350 seconds
