Home » Eclipse Projects » Remote Application Platform (RAP) » RAP sample archive corrupted
RAP sample archive corrupted [message #1911] Wed, 13 December 2006 18:28 Go to next message
Mario Scalas is currently offline Mario ScalasFriend
Member
Hi all, I wanted to check the RAP sample project but the archive linked on
the wiki page (http://w4teclipse.com/rap/rapsample.zip) seems to be
corrupted (it is zero-bytes!). I tried to contact Innopract but got no
feedback and the file is still corrupted: any solutions?
Mario
Mario Scalas
Affiliate Researcher
Collaborative Development Group
University of Bari - C.S. Dept.
Via E. Orabona, 4
70125 Bari - ITALY
web: http://cdg.di.uniba.it/scalas/
"Relax. You don't have to be a great designer --you just have to be
creatively lazy."
-- Kent Beck
Re: RAP sample archive corrupted [message #1926 is a reply to message #1911] Thu, 14 December 2006 13:42 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Mario,
thank You for the hint. The file itself is intact but the server refuses
to deliver it. We are working on it and I will post a note when the
problem is solved.
In the meantime I could send the file to You by email. Please drop me a
note if You wish so.
I tried to tack Your contact attempt - without success. Could You tell
me how You tried to contact us?
Cheers
Rüdiger
> Regards
> Mario
Re: RAP sample archive corrupted [message #1940 is a reply to message #1911] Thu, 14 December 2006 14:45 Go to previous messageGo to next message
Hi all,
The RAP example archive is available again. Sorry for the inconvenience.
Rüdiger Herrmann
> Regards
> Mario
Re: RAP sample archive corrupted [message #1953 is a reply to message #1926] Fri, 15 December 2006 17:24 Go to previous messageGo to next message
Member
Rüdiger Herrmann wrote:
<snip>
I've filled the form at http://www.w4toolkit.com/index.php?main=kontakt
(ehm ..., sorry if there was a better way but I didn't find any else)
Cheers
Mario
Mario Scalas
creatively lazy."
-- Kent Beck
Re: RAP sample archive corrupted [message #1967 is a reply to message #1940] Fri, 15 December 2006 17:26 Go to previous messageGo to next message
Member
> Hi all,
I can confirm that the archive is ok :)
Mario
Mario Scalas
creatively lazy."
-- Kent Beck
Re: RAP sample archive corrupted [message #1980 is a reply to message #1953] Mon, 18 December 2006 10:34 Go to previous messageGo to next message
Hi Mario,
thank You for the hint. I will make sure that future form
submissions are delivered to the person in charge.
For communication regarding RAP I recommend to use this
newsgroup or the RAP mailing list (for development-related
communication).
Cheers
Rüdiger
Mario Scalas wrote:
> <snip>
> Cheers
> Mario
Re: RAP sample archive corrupted [message #1994 is a reply to message #1967] Mon, 18 December 2006 10:53 Go to previous messageGo to next message
though the RAP example archive is available again, it does
not show the most current development any more.
I would recommend to check out from CVS directly (described
here: http://www.eclipse.org/rap/cvs.php).
This also includes a demo project that shows a web application
using the SWT-like widget API (called RWT) running on the server
side Equinox OSGi framework.
Rüdiger
Mario Scalas wrote:
>> Hi all,
> Thanks
> Mario
Re: RAP sample archive corrupted [message #2008 is a reply to message #1994] Tue, 19 December 2006 17:20 Go to previous message
Member
Thanks, I'll watch this out :)
Mario
Mario Scalas
creatively lazy."
-- Kent Beck
Previous Topic:Relation to Portals
Next Topic:Incomplete checkin?
Current Time: Sat Nov 09 03:30:44 GMT 2024
Powered by FUDForum. Page generated in 0.03221 seconds
