TCPMon integration [message #22460] |
Wed, 12 May 2004 05:19 |
Originally posted by: owhite.civica.com.au
Hi folks,
I'm wondering if there is any interest in integrating tcpmon with eclipse.
I'd like to do some testing at the http level, including XML based
conversations. Httpunit/Junit work quite nicely in eclipse, but it would
be great if I could capture messages and replay them, perhaps with
modification.
Idealy, xml editing and processing facets could be applied to logged
content and messages dragged and dropped into my httpunit scripts. I
imagine SOAP and other WS tools could easily adopt this model.
Thoughts, comments, flames?
Re: TCPMon integration [message #22678 is a reply to message #22635] |
Thu, 13 May 2004 04:23 |
Arthur Ryman wrote:
> IBM has included a TCP/IP monitor in its proposed contributions. See
> http://www.eclipse.org/proposals/eclipse-webtools/Wiki0064.h tml
> We will contribute it as part of the Server Tools. We also have an
> enhanced version for Web Services that is part of the Eclipse Web
> Service Validation Tools project. See http://www.eclipse.org/wsvt/
> The WSVT project has been running for a while. You can get the code and
> contribute if you like.
Cheers Arthur,
I'm not sure I'd know where to start as a contributor, but I'm certainly
happy to share ideas. I'll browse on over to your newsgroup and see where
you're at. :-)
Oliver White
FUDForum. Page generated in 0.04119 seconds
