Add/Remove links in the properties part of an element [message #229813] |
Thu, 25 January 2007 14:36 |
Conor Missing name Messages: 159 Registered: July 2009 |
I'd like to be able to use the add/remove link in the properties part of
an element in some code. I was wondering how I might call this?
To elaberate, when an element is hightlighted and the properties are being
shown, it is possible to got to the properties part that shows links to
other element, click on the '...' part to get a window up that shows all
the elements and you can then add/remove links.
Example:
element A can be linked to elements of type B, in the properties of A
there is an entry of B, which is all links of that element of type A to B.
It is then possible to get up a window that allows you to add/remove links
to nodes of type B from a list provided. It's this window I'd like to be
able to call up.
Thank you in advance,
Gaff
FUDForum. Page generated in 0.03354 seconds
